Becuase the board select menu in arch/arm/Kconfig is too big,
move the KirkWood board select menu to kirkwood/Kconfig.
Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and
CONFIG_SYS_SOC="kirkwood").
Acked-by: Prafulla Wadasdkar <prafulla@marvell.com>
Cc: Luka Perkov <luka@openwrt.org>
move the Rmobile board select menu to rmobile/Kconfig.
Consolidate also common settings (CONFIG_SYS_CPU="armv7" and
CONFIG_SYS_SOC="rmobile").
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
move the Tegra board select menu to tegra/Kconfig.
Insert the Tegra SoC select menu between the arch select and the
board select.
Architecture select
|-- Tegra Platform (Tegra)
|- Tegra SoC select (Tegra20 / 30 / 114 / 124)
|- Board select
CONFIG_SYS_SOC="tegra*") and always "select" CONFIG_SPL as follows:
config TEGRA
bool
select SPL
Cc: Tom Warren <twarren@nvidia.com>
move the Zynq board select menu to zynq/Kconfig.
CONFIG_SYS_SOC="zynq").
Refactor board/xilinx/zynq/MAINTAINERS too.
Tested-by: Michal Simek <michal.simek@xilinx.com>
Newer FLASH types used on these boards don't allow writing of subpages.
So disable subpage write in the NAND driver. Additionally we need to
tell the UBI layer in the kernel that he also should only write 2048
bytes. This is done with an additional command line parameter for the
kernel commandline.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Prafulla Wadaskar <prafulla@marvell.com>
Add support for booting Images and for unzipping Image.gz files.
- Drop DEBUG
- Drop defines we can use the default of.
- Provide a larger malloc pool.
- Correct default locations for kernel / initrd / device tree
The default format for arm64 Linux kernels is the "Image" format,
described in Documentation/arm64/booting.txt. This, along with an
optional gzip compression on top is all that is generated by default.
The Image format has a magic number within the header for verification,
a text_offset where the Image must be run from, an image_size that
includes the BSS and reserved fields.
This does not support automatic detection of a gzip compressed image.
The bcm_ep board configuration is used by a number of boards
including Cygnus and NSP.
Add builds for the bcm958300k and the bcm958622hr boards.
Signed-off-by: Scott Branden <sbranden@broadcom.com>
Signed-off-by: Steve Rae <srae@broadcom.com>
The Broadcom StarFighter2 Ethernet driver is used in multiple Broadcom
SoC(s) and:
- supports multiple MAC blocks,
- provides support for the Broadcom GMAC.
This driver requires MII and PHYLIB.
Signed-off-by: Jiandong Zheng <jdzheng@broadcom.com>
To enable hypervisors utilizing the ARMv7 virtualization extension
on the Arndale board, add the simple SMP pen address writer function
and add the required configuration variables to switch all cores to
HYP mode before launching the OS.
This allows booting KVM and Xen directly from u-boot.
Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org>
Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Enable initialization fo designware ethernet controller. With this
patch, ethernet works in my configuration, provided I set ethernet
address in the environment.
Signed-off-by: Pavel Machek <pavel@denx.de>
To fix the build error when build for Altera dev kit, not
virtual target. At same time, set the build for Altera dev
kit as default instead virtual target. With that, U-Boot
is booting well and SPL still lack of few drivers.
Signed-off-by: Chin Liang See <clsee@altera.com>
Cc: Pavel Machek <pavel@denx.de>
Cc: Tom Rini <trini@ti.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Commit e3a5bbce broke the FIT image tests by not loading a ramdisk even if
a load address is provided in the FIT. The rationale was that a load address
of 0 should be considered to mean 'do not load'.
Add a new load operation which supports this feature, so that the ramdisk
will be loaded if a non-zero load address is provided.
The commit (SHA1: 8fc171318e352) reintroduced correct values for vendor and
product IDs required for UMS gadget to work properly either at Windows or
Linux.
This data was missing for GONI target, so this commit corrects this mistake.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Robert Baldyga <r.baldyga@samsung.com>
Acked-by: Minkyu Kang <mk7.kang@samsung.com>
snyc with linux v3.15:
commit 1860e379875dfe7271c649058aeddffe5afd9d0d
Author: Linus Torvalds <torvalds@linux-foundation.org>
Date: Sun Jun 8 11:19:54 2014 -0700
Linux 3.15
Cc: Scott Wood <scottwood@freescale.com>
while playing with the new mtd/ubi/ubifs sync, found some
small updates for it:
- add del_mtd_partition() to include/linux/mtd/mtd
- mtd: add a debug_printf
- remove some not used functions
resync ubi subsystem with linux:
commit 455c6fdbd219161bd09b1165f11699d6d73de11c
Date: Sun Mar 30 20:40:15 2014 -0700
Linux 3.14
A nice side effect of this, is we introduce UBI Fastmap support
to U-Boot.
Cc: Sergey Lapin <slapin@ossfans.org>
Cc: Joerg Krause <jkrause@posteo.de>
- move linux specific defines from usb and video code
into linux/compat.h
- move common linux specific defines from include/ubi_uboot.h
to linux/compat.h
- add for new mtd/ubi/ubifs sync new needed linux specific
defines to linux/compat.h
[trini: Add spin_lock_irqsave/spin_unlock_irqrestore dummies from
usb/lin_gadet_compat.h]
add missing ERR_CAST to linux/err.h as it is needed for ubi/ubifs support
from linux 3.14:
Linux 3.14
Needed for the MTD/UBI/UBIFS resync
Just copied the files from Linux, and added in the c-file
the "#define __UBOOT__" for adding U-Boot special code. In
this case we use this just for adding including U-Boot
headers.
resync with linux:
Linux 3.14
Just copied the files from Linux, changed the license file header,
and add in the c-file:
+#define __UBOOT__
#include <linux/rbtree_augmented.h>
+#ifndef __UBOOT__
#include <linux/export.h>
+#else
+#include <ubi_uboot.h>
+#endif
so, it compiles for U-Boot.
Include general configs/ti_am335x_common.h and drop redundant #defines.
Signed-off-by: Matwey V. Kornilov <matwey.kornilov@gmail.com>
DRA7 evm REV G and later boards uses a vtt regulator for DDR3 termination
and this is controlled by gpio7_11. Configuring gpio7_11.
The pad A22(offset 0x3b4) is used by gpio7_11 on REV G and later boards,
and left unused on previous boards, so it is safe enough to enable gpio
on all DRA7 boards.
Use generic board setup functions by defining
CONFIG_SYS_GENERIC_BOARD.
Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il>
Cc: Raphael Assenat <raph@8d.com>
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
This patch adds support for parallel NOR device (S29GL512S10) present on J6-EVM.
The Flash device is connected to GPMC controller on chip-select[0] and accessed
as memory-mapped device. It has data-witdh=x16, capacity-64MBytes(512Mbits) and
is CFI compatible.
As multiple devices are share GPMC pins on this board, so following board
settings are required to detect NOR device:
SW5.1 (NAND_BOOTn) = OFF (logic-1)
SW5.2 (NOR_BOOTn) = ON (logic-0) /* Active-low */
SW5.3 (eMMC_BOOTn) = OFF (logic-1)
SW5.4 (QSPI_BOOTn) = OFF (logic-1)
And also set appropriate SYSBOOT configurations:
SW3.1 (SYSBOOT[ 8])= ON (logic-1) /* selects SYS_CLK1 speed */
SW3.2 (SYSBOOT[ 9])= OFF (logic-0) /* selects SYS_CLK1 speed */
SW3.3 (SYSBOOT[10])= ON (logic-1) /* wait-pin monitoring = enabled */
SW3.4 (SYSBOOT[11])= OFF (logic-0) /* device type: Non Muxed */
SW3.5 (SYSBOOT[12])= OFF (logic-0) /* device type: Non Muxed */
SW3.6 (SYSBOOT[13])= ON (logic-1) /* device bus-width: 1(x16) */
SW3.7 (SYSBOOT[14])= OFF (logic-0) /* reserved */
SW3.8 (SYSBOOT[15])= ON (logic-1) /* reserved */
Also, following changes are required to enable NOR Flash support in
dra7xx_evm board profile:
This patch adds support for x16 NAND device (MT29F2G16AAD) connected to GPMC
chip-select[0] on DRA7xx EVM.
As GPMC pins are shared by multiple devices, so in addition to this patch
following board settings are required for NAND device detection [1]:
SW5.9 (GPMC_WPN) = OFF (logic-1)
SW5.1 (NAND_BOOTn) = ON (logic-0) /* Active-low */
SW5.2 (NOR_BOOTn) = OFF (logic-1)
SW2.1 (SYSBOOT[0]) = ON (logic-1) /* selects NAND Boot */
SW2.2 (SYSBOOT[1]) = OFF (logic-0) /* selects NAND Boot */
SW2.3 (SYSBOOT[2]) = OFF (logic-0) /* selects NAND Boot */
SW2.4 (SYSBOOT[3]) = OFF (logic-0) /* selects NAND Boot */
SW2.5 (SYSBOOT[4]) = ON (logic-1) /* selects NAND Boot */
SW2.6 (SYSBOOT[5]) = ON (logic-1) /* selects NAND Boot */
SW2.7 (SYSBOOT[6]) = OFF (logic-0) /* reserved */
SW2.8 (SYSBOOT[7]) = OFF (logic-0) /* reserved */
SW3.4 (SYSBOOT[11])= OFF (logic-0) /* device type: Addr/Data Muxed */
SW3.5 (SYSBOOT[12])= ON (logic-1) /* device type: Addr/Data Muxed */
Following changes are required in board.cfg to enable NAND on J6-EVM:
This patch adds support for NAND device connected to GPMC chip-select on
following AM43xx EVM boards.
am437x-gp-evm: On this board, NAND Flash signals are muxed with eMMC, thus at a
time either eMMC or NAND can be enabled. Selection between eMMC and NAND is
controlled by:
(a) Statically using Jumper on connecter (J89) present on board.
(a) If Jumper on J89 is NOT used, then selection can be dynamically controlled
by driving SPI2_CS0[MUX_MODE=GPIO] pin via software:
SPI2_CS0 == 0: NAND (default)
SPI2_CS0 == 1: eMMC
am43x-epos-evm: On this board, NAND Flash control lines are muxed with QSPI,
Thus only one of the two can be used at a time. Selection is controlled by:
(a) Dynamically driving following GPIO pin from software
GPMC_A0(GPIO) == 0 NAND is selected (default)
NAND device (MT29F4G08AB) on these boards has:
- data-width=8bits
- blocksize=256KB
- pagesize=4KB
- oobsize=224 bytes
For above NAND device, ROM code expects the boot-loader to be flashed in BCH16
ECC scheme for NAND boot, So by default BCH16 ECC is enabled for AM43xx EVMs.
Signed-off-by: Pekon Gupta <pekon@ti.com>
This patch
- consolidate CONFIG_SYS_NAND_xx and CONFIG_SPL_NAND_xx from various
configuration files into single file.
- update MTD Partition table to match AM335x_EVM DT in linux-kernel
- segregate CONFIGs based on different boot modes (like SPL and U-Boot)
When we're using EMMC_BOOT that means we have environment on eMMC so
we can make use of CONFIG_SPL_ENV_SUPPORT within Falcon Mode.
In the case of SPL on these boards we only need environment for
SPL_USBETH, so it's safe to normally use ENV_IS_NOWHERE and SPL+NAND
does not support environment today.
Cc: Hannes Petermaier <oe5hpm@oevsv.at>
There are times where we may need more than a few kilobytes of stack
space. We also will not be using CONFIG_SPL_STACK location prior to DDR
being initialized (CONFIG_SYS_INIT_SP_ADDR is still used there) so pick
a good location within DDR for this to be. Tested on
OMAP4/AM335x/OMAP5/DRA7xx.
On am335x_evm we only support USBETH for a networking SPL option so move
the rest of the defines under that area as that's the only time we need
(and want) environment support here.
The Altera EPCS is SPI flash. We have been using SPI flash driver
to access EPCS for years. The old EPCS driver could be removed.
This patch implements the generic board init as described in
doc/README.generic-board.
Signed-off-by: Scott McNutt <smcnutt@psyent.com>
Commit b3dd64f5d537 "bootm: use genimg_get_kernel_addr()" introduced
a bug for booting FIT image. It's because calling fit_parse_config()
twice will give us wrong value in img_addr.
Add a new function genimg_get_kernel_addr_fit() whichl will always
return fit_uname_config and fit_uname_kernel for CONFIG_FIT.
genimg_get_kernel_addr() will ignore those to parameters.
Reported-by: York Sun <yorksun@freescale.com>
Signed-off-by: Bryan Wu <pengw@nvidia.com>
Add a BSD-3 relicensed version of the Android sparse format image
header from:
https://android.googlesource.com/platform/system/core/+/28fa5bc347390480fe190294c6c385b6a9f0d68b/libsparse/sparse_format.h
Unchanged except for the license header.
Signed-off-by: Colin Cross <ccross@android.com>
Add i210 support to the e1000 driver.
Acked-by: Tim Harvey <tharvey@gateworks.com>
This board has been orphaned for a while and old enough.
These boards have been orphaned for a while and old enough.
