path: root/include
2007-09-07[MIPS] Update asm string headerShinya Kuribayashi
This patches contains several bugfixes and cleanups in the latest upstream: - Don't include linux/config.h - Remove buggy inline version of memscan. - Merge with Linux 2.6.11-rc3. - Fix undefined reference to strcpy in binfmt_misc caused by gcc 3.4. - Goodbye mips64. 31704 lines of code bite the dust. - Replace extern inline with static inline. - Fix return value of strncpy. - Remove a bunch more "$1" clobbers. Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
2007-09-07Merge with /home/wd/git/u-boot/custodian/u-boot-mpc85xxWolfgang Denk
2007-09-07Merge with /home/wd/git/u-boot/custodian/u-boot-mpc5xxxWolfgang Denk
2007-09-06Migrate 5xxx boards from CONFIG_OF_FLAT_TREE to CONFIG_OF_LIBFDTGrant Likely
Affects boards: icecube (lite5200), jupiter, motionpro, tqm5200 Tested on: lite5200b Note: the fixup functions have not been moved to a common place. This patch is targeted for immediate merging as in solves a build issue, but the final name/location of the fixups is still subject to debate. I propose to merge this now, and move the fixups in the next merge window to be usable by all targets. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-09-06libfdt: add convenience function fdt_find_and_setprop()Grant Likely
Given the path to a node, fdt_find_and_setprop() allows a property value to be set directly. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-09-05Changed API name to coloured_led.hPeter Pearse
Removed code using deprecated ifdef CONFIG_BOOTBINFUNC Tidied other cpu/arm920t/start.S code
2007-09-04Fix ULI RTC support on MPC8544 DSKumar Gala
The RTC on the M1575 ULI chipset requires a dummy read before we are able to talk to the RTC. We accomplish this by adding a second memory region to the PHB the ULI is on and read from it. The second region is added to maintain compatiabilty with Linux's view of the PCI memory map. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-09-04Add coloured led interface for ARM boards.Peter Pearse
Use it in cpu/arm920t/start.S to indicate U-Boot code has been entered.
2007-09-04Move include/led.h to board/at91rm9200dkPeter Pearse
2007-09-04Rename CONFIG_CMD_MUX to CONFIG_CMD_AT91_SPIMUXPeter Pearse
2007-09-02Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-08-31ppc4xx: (Re-)Enable CONFIG_PCI_PNP on AMCC 440EPx SequoiaGary Jennejohn
The 440EPx has a problem when the PCI_CACHE_LINE_SIZE register is set to non-zero, because it doesn't support MRM (memory-read- multiple) correctly. We now added the possibility to configure this register in the board config file, so that the default value of 8 can be overridden. Here the details of this patch: o drivers_pci_auto.c: introduce CFG_PCI_CACHE_LINE_SIZE to allow board-specific settings. As an example the sequoia board requires 0. Idea from Stefan Roese <sr@denx.de>. o board/amcc/sequoia/init.S: add a TLB mapping at 0xE8000000 for the PCI IO-space. Obtained from Stefan Roese <sr@denx.de>. o include/configs/sequoia.h: turn CONFIG_PCI_PNP back on and set CFG_PCI_CACHE_LINE_SIZE to 0. Signed-off-by: Gary Jennejohn <garyj@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-30Reduce BOOTDELAY variable to 1 second by default for STK1002Hans-Christian Egtvedt
Signed-off-by: Hans-Christian Egtvedt <hcegtvedt@atmel.com> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-08-30Remove double quotation marks around MAC address for STK1002Hans-Christian Egtvedt
2007-08-29ppc4xx: Change lwmon5 default environment to support Linux RTCStefan Roese
The Linux PCF8563 RTC driver doesn't do autoprobing, so we need to supply the RTC I2C address as bootline parameter. This patch adds support for this rtc probing parameter to the bootargs: "rtc-pcf8563.probe=0,0x51" Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-29Merge with git+ssh://gemini/home/wd/git/u-boot/masterWolfgang Denk
2007-08-29sbc8641: remove unused OF_FLAT_TREE_MAX_SIZEKim Phillips
this had slipped through the cracks, since the sbc board was added after I wrote the original patch to remove all these symbols, and before it was merged. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-29Add mii_init() prototypeWolfgang Denk
to get rid of a *lot* of compiler warnings. Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-08-29Disable network support on cmi_mpc5xx boardWolfgang Denk
..because it caused compiler errors and there seems to be no board maintainer to take care of this. Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-08-298548cds fixesEd Swarthout
Restore CONFIG_EXTRA_ENV_SETTINGS definition which contains the correct consoledev needed for linux boot. Standardize on fdt{file,addr} var to hold dtb file name. Set PCI inbound memory region from CFG_MEMORY_{BUS,PHYS}. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
2007-08-29Enable L2 cache for MPC8568MDS boardHaiying Wang
The L2 cache size is 512KB for 8568, print out the correct informaiton. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2007-08-29support board vendor-common makefilesKim Phillips
if a board/$(VENDOR)/common/Makefile exists, build it. also add the first such case, board/freescale/common/Makefile, to handle building board-shared EEPROM, PIXIS, and MDS-PIB code, as dictated by board configuration. thusly get rid of alternate build dir errors such as: FATAL: can't create /work/wd/tmp/u-boot-ppc/board/freescale/mpc8360emds/../common/pq-mds-pib.o: No such file or directory by putting the common/ mkdir command in its proper place (the common Makefile). Common bits from existing individual board Makefiles have been removed. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-29Fix compiler warning in include/s3c2410.hMartin Krause
This patch fixes the "type qualifiers ignored on fuction return tpye" warning for include/s3c2410.h Signed-off-by: Martin Krause <martin.krause@tqs.de>
2007-08-29fdt: remove unused OF_FLAT_TREE_MAX_SIZE referencesKim Phillips
and make some minor corrections to the FDT part of the README. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-29Merge with /home/wd/git/u-boot/custodian/u-boot-ppc4xxWolfgang Denk
2007-08-28[UC101] Fix: if no CF in the board, U-Boot resets sometimes.Heiko Schocher
2007-08-28IDE: - make ide_inb () and ide_outb () "weak", so boards canHeiko Schocher
define there own I/O functions. (Needed for the pcs440ep board). - The default I/O Functions are again 8 Bit accesses. - Added CONFIG_CMD_IDE for the pcs440ep Board. Signed-off-by: Heiko Schocher <hs@denx.de>
2007-08-27AVR32: Change prototype of memsetSemih Hazar
Signed-off-by: Semih Hazar <semih.hazar@indefia.com> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-08-24ppc4xx: Add RTC POST test to lwmon5 board configurationStefan Roese
Since this RTC POST test is taking quite a while to complete it's only initiated upon special keypress same as the complete memory POST. Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-24ppc4xx: Change GPIO signal for watchdog triggering on lwmon5Stefan Roese
2007-08-23ppc4xx: Add support for 2nd I2C EEPROM on lwmon5 boardStefan Roese
This patch adds support for the 2nd EEPROM (AT24C128) on the lwmon5 board. Now the "eeprom" command can be used to read/write from/to this device. Additionally a new command was added "eepromwp" to en-/disable the write-protect of this 2nd EEPROM. The 1st EEPROM is not affected by this write-protect command. Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-22ppc4xx: Remove unused option CFG_INIT_RAM_OCMStefan Roese
2007-08-21Merge with /home/stefan/git/u-boot/u-boot-ppc4xxStefan Roese
2007-08-21ppc4xx: Add matrix kbd support to lwmon5 board (440EPx based)Stefan Roese
This patch adds support for the matrix keyboard on the lwmon5 board. Since the implementation in the dsPCI is kind of compatible with the "old" lwmon board, most of the code is copied from the lwmon board directory. Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-18Merge with /home/wd/git/u-boot/custodian/u-boot-coldfireWolfgang Denk
2007-08-18Merge with /home/wd/git/u-boot/custodian/u-boot-mpc85xxWolfgang Denk
2007-08-18Merge with /home/wd/git/u-boot/custodian/u-boot-mpc83xxWolfgang Denk
2007-08-18Merge with git+ssh://gemini_vpn/home/wd/git/u-boot/masterWolfgang Denk
2007-08-18lib_ppc: make board_add_ram_info weakKim Phillips
platforms wishing to display RAM diagnostics in addition to size, can do so, on one line, in their own board_add_ram_info() implementation. this consequently eliminates CONFIG_ADD_RAM_INFO. Thanks to Stefan for the hint. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-18ColdFire: Fix some remaining problems with CFG_CMD_Stefan Roese
2007-08-18Coding style cleanupStefan Roese
2007-08-17ColdFire: Add M5235EVB Platform for MCF523xTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-08-16mpc83xx: implement board_add_ram_infoKim Phillips
add board_add_ram_info, to make memory diagnostic output more consistent. u-boot banner output now looks like: DRAM: 256 MB (DDR1, 64-bit, ECC on) and for boards with SDRAM on the local bus, a line such as this is added: SDRAM: 64 MB (local bus) also replaced some magic numbers with their equivalent define names. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-16mpc83xx: Split PIB init code from pci.c and add Qoc3 ATM card supportTony Li
The patch split the PIB init code from pci.c to a single file board/freescale/common/pq-mds-pib.c And add Qoc3 ATM card support for MPC8360EMDS and MPC832XEMDS board. Signed-off-by Tony Li <tony.li@freescale.com>
2007-08-16ColdFire: Add M54455EVB for MCF5445xTsiChungLiew
2007-08-16ColdFire: Add M5253EVBE platform for MCF52x2TsiChungLiew
2007-08-16ColdFire: Add M5249EVB platform for MCF52x2TsiChungLiew
2007-08-16ColdFire: Update Freescale MCF52x2 platformsTsiChungLiew
2007-08-16ColdFire: Update EB+MCF-EV123 platformTsiChungLiew
2007-08-16ColdFire: update TASREG platform for MCF52x2TsiChungLiew
