path: root/include
2009-04-04at91: move dataflash spi driver to drivers/spiJean-Christophe PLAGNIOL-VILLARD
2009-04-04at91: move usb driver to drivers/usbJean-Christophe PLAGNIOL-VILLARD
2009-04-04at91rm9200: move serial shutdown code to serial driversJean-Christophe PLAGNIOL-VILLARD
introduce serial_exit for this purpose. Use it only when the rm9200 serial driver is active Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-04at91rm9200: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
add CONFIG_AT91RM9200_USART to activate the driver Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-04Add support for the AT91RM9200EK Board.Ulf Samuelsson
The AT91RM9200-EK Evaluation Board supports the AT91RM9200 ARM9-based 32-bit RISC microcontroller and enables real-time code development and evaluation. Here is the chip page on Atmel website: http://www.atmel.com/dyn/products/tools_card.asp?tool_id=3507 with - NOR (cfi driver) - DataFlash - USB OHCI - Net - I2C (hard) Signed-off-by: Ulf Samuelsson <ulf@atmel.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-04at91: rename DATAFLASH_MMC_SELECT to CONFIG_DATAFLASH_MMC_SELECTJean-Christophe PLAGNIOL-VILLARD
2009-04-04at91sam9: add watchdog supportJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-04MPC8260ADS: Define CONFIG_HAS_ETH0.Scott Wood
This is required so that the MAC address will be updated in the device tree. Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-04-04PQ2FADS: Enable PCI.Scott Wood
PCI on PQ2FADS is very similar to PCI on MPC8272ADS. Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-04-04rename include/zlib.h to include/u-boot/zlib.hJean-Christophe PLAGNIOL-VILLARD
Some systems have zlib.h installed in /usr/include/. This isn't the desired file for u-boot code - we want the one in include/zlib.h. This rename will avoid the conflict. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-04-04include/ns16550.h: Unify structure declaration for registersDetlev Zundel
Instead of special casing the different access patterns, use common code with light macros sprinkled in to accomodate for the different layouts of the register structure. Note that this also changes the types of the registers for the "positively packed (>1)" cases. As the registers truly are unsigned chars, this is surely the Right Thing, but it is a semantic change. Note that for this case depending on the endianness on the bus, we may see a change of behaviour. Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-04-04Add support for building native win32 toolsPeter Tyser
Add support for compiling the host tools in the tools directory using the MinGW toolchain. This produces executables which can be used on standard Windows computers without requiring cygwin. One must specify the MinGW compiler and strip utilities as if they were the host toolchain in order to build win32 executables, eg: make HOSTCC=i586-mingw32msvc-gcc HOSTSTRIP=i586-mingw32msvc-strip tools Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-04elf.h: Use stdint.h to provide standard typedefs for WIN32Peter Tyser
The original code provided an incomplete set of typedefs for WIN32 compiles and replicated the standard typedefs that are already provided by stdint.h Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-03mflash: Initial mflash supportunsik Kim
Mflash is fusion memory device mainly targeted consumer eletronic and mobile phone. Internally, it have nand flash and other hardware logics and supports some different operation (ATA, IO, XIP) modes. IO mode is custom mode for the host that doesn't have IDE interface. (Many mobile targeted SoC doesn't have IDE bus) This driver support mflash IO mode. Followings are brief descriptions about IO mode. 1. IO mode based on ATA protocol and uses some custom command. (read confirm, write confirm) 2. IO mode uses SRAM bus interface. Signed-off-by: unsik Kim <donari75@gmail.com>
2009-04-03Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
2009-04-03Merge branch 'master' of git://git.denx.de/u-boot-fdtWolfgang Denk
2009-04-03Rename common ns16550 constants with UART_ prefix to prevent conflictsDetlev Zundel
Fix problems introduced in commit 7b5611cdd12ca0cc33f994f0d4a4454788fc3124 [inka4x0: Add hardware diagnosis functions for inka4x0] which redefined MSR_RI which is already used on PowerPC systems. Also eliminate redundant definitions in ps2mult.h. More cleanup will be needed for other redundant occurrences though. Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-04-03Add "source" command; prepare removal of "autoscr" commandWolfgang Denk
According to the doc/feature-removal-schedule.txt, the "autoscr" command will be replaced by the "source" command in approximately 6 months from now. This patch prepares this change and starts a 6 month transition period as follows: - The new "source" command has been added, which implements exactly the same functionlaity as the old "autoscr" command before - The old "autoscr" command name is kept as an alias for compatibility - Command sequences, script files atc. have been adapted to use the new "source" command - Related environment variables ("autoscript", "autoscript_uname") have *not* been adapted yet; these will be renamed resp. removed in a separate patch when the support for the "autoscr" command get's finally dropped. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-04-02Blackfin: force all boards to HZ of 1000Mike Frysinger
Since the Blackfin timer code requires HZ to be 1000, barf on any board that tries to use a different value. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-04-02Blackfin: bf518f-ezbrd: new board portMike Frysinger
2009-04-02Blackfin: bf526-ezbrd: new board portMike Frysinger
2009-04-02Blackfin: bf538f-ezkit: new board portMike Frysinger
2009-04-02Blackfin: bf527-ezkit: new board portMike Frysinger
2009-04-02Blackfin: bf548-ezkit: new board portMike Frysinger
2009-04-01libfdt: Fix C++ compile-time cast error on gnu 4.2.1Laurent Gregoire
Allow the inclusion of libfdt.h in C++ source. Signed-off-by: Laurent Gregoire <laurent.gregoire@tomtom.com> Acked-by: David Gibson <david@gibson.dropbear.id.au>
2009-04-02Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-04-01mpc83xx: Set guarded bit on BAT that covers the end of the address spaceScott Wood
The mpc8313erdb board currently sets DBAT6 to cover all of the final 256MiB of address space; however, not all of this space is covered by a device. In particular, flash sits at 0xfe000000-0xfe7fffff, and nothing is mapped at the far end of the address space. In zlib, there is a loop that references p[-1] if p is non-NULL. Under some circumstances, this leads to the CPU speculatively loading from 0xfffffff8 if p is NULL. This leads to a machine check. Signed-off-by: Scott Wood <scottwood@freescale.com> continuation to the remaining mpc83xx boards that suffer from the same problem. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-04-01Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2009-04-01rtc: remove broken rtc_read and rtc_write declarationsKim Phillips
commit 04e11cf3 "rtc: add support for 4543 RTC (manufactured by e.g. EPSON)" introduces the following build error on boards configuring e.g, the ds1374 rtc: Configuring for MPC837XEMDS board... ds1374.c:103: error: static declaration of 'rtc_read' follows non-static declaration /home/r1aaha/git/u-boot/include/rtc.h:64: error: previous declaration of 'rtc_read' was here ds1374.c:104: error: conflicting types for 'rtc_write' /home/r1aaha/git/u-boot/include/rtc.h:65: error: previous declaration of 'rtc_write' was here this reverts the erroneous chunk. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Detlev Zundel <dzu@denx.de> CC: Detlev Zundel <dzu@denx.de> CC: Andreas Pfefferle <ap@denx.de>
2009-04-0186xx: Cleanup MP supportKumar Gala
* Use CONFIG_MP instead of CONFIG_NUM_CPUS to match 85xx * Introduce determine_mp_bootpg() helper. We'll need this to address a bug introduced in v2009.03 with 86xx MP booting. We have to make sure to reserve the region of memory used for the MP bootpg() so other u-boot code doesn't use it. * Added dummy versions of cpu_reset(), cpu_status() & cpu_release() to allow cmd_mp.c to build and work. In the future we should look at implementing all these functions. This could be common w/85xx if we use spin tables on 86xx. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-03-30MPC85xx: Add MPC8569MDS board supportHaiying Wang
This patch adds MPC8569MDS board support. The UART, QE UEC1 and UEC2, BRD EEPROM on I2C2 bus, PCI express and DDR3 SPD are supported in this patch. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Hillel Avni <Hillel.Avni@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-03-30MPC85xx: Add MPC8569 CPU supportHaiying Wang
There is a workaround for MPC8569 CPU Errata, which needs to set Bit 13 of LBCR in 4K bootpage. We setup a temp TLB for eLBC controller in bootpage, then invalidate it after LBCR bit 13 is set. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-03-30fsl-ddr: add the DDR3 SPD infrastructureDave Liu
- support mirrored DIMMs, not support register DIMMs - test passed on P2020DS board with MT9JSF12872AY-1G1D1 - test passed on MPC8569MDS board with MT8JSF12864HY-1G1D1 Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Travis Wheatley <travis.wheatley@freescale.com>
2009-03-3083xx: Use common LSDMR defines from asm/fsl_lbc.hKumar Gala
Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-03-3085xx: Use common LSDMR defines from asm/fsl_lbc.hKumar Gala
2009-03-30Add LSDMR (SDRAM Mode Register) definition on localbusKumar Gala
The masks for various bit defines of LSDMR are common and thus we can define them in one place rather than replicating them in each config.h Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-03-30OMAP: rename timer divisorLadislav Michl
Divisor field is called PTV not PVT. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-30s3c2410: move nand driver to drivers/mtd/nandJean-Christophe PLAGNIOL-VILLARD
2009-03-30s3c24x0: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
2009-03-30davinci: move nand driver to drivers/mtd/nandJean-Christophe PLAGNIOL-VILLARD
2009-03-30imx: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
2009-03-30inka4x0: Add hardware diagnosis and RTC in configuration.Detlev Zundel
This patch adds the board specific communication routines needed by the external 4543 RTC. Signed-off-by: Detlev Zundel <dzu@denx.de> Signed-off-by: Andreas Pfefferle <ap@denx.de>
2009-03-30inka4x0: Add hardware diagnosis functions for inka4x0Detlev Zundel
This patch adds advanced diagnosis functions for the inka4x0 board. Signed-off-by: Andreas Pfefferle <ap@denx.de> Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-03-30rtc: add support for 4543 RTC (manufactured by e.g. EPSON)Detlev Zundel
2009-03-30drivers/twserial: Add protocol driver for "three wire serial" interface.Detlev Zundel
This pretty unintelligent interface is used on some RTC chips. Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-03-29arm720t/clps7111: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
add CONFIG_CLPS7111_SERIAL to activate the driver Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-29lpc2292: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
add CONFIG_LPC2292_SERIAL to activate the driver Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-29ks8695: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
add CONFIG_KS8695_SERIAL to activate the driver Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-29s3c64xx: move usb driver to drivers/usbJean-Christophe PLAGNIOL-VILLARD
add CONFIG_USB_S3C64XX to activate the driver Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-29netarm: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
add CONFIG_NETARM_SERIAL to activate the driver Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
