RC Release 09.02.00.010
Sync with kernel please
Signed-off-by: Nishanth Menon <nm@ti.com>
This adds initial support for the Toradex Aquila AM69 module.
Upstream-Status: Pending
Signed-off-by: Emanuele Ghidoli <emanuele.ghidoli@toradex.com>
Create separate helper for just reserving framebuffer region without
creating or enabling simple-framebuffer node.
This is useful for scenarios where user want to preserve the bootloader
splash screen till OS boots up and display server gets started without
displaying anything else in between and thus not requiring
simple-framebuffer.
Signed-off-by: Devarsh Thakkar <devarsht@ti.com>
Add new partition to support avb on vendor_dlkm partition.
Add for both Beagle Play and AM62X SK EVM.
Signed-off-by: Guillaume La Roque <glaroque@baylibre.com>
[mkorpershoek: added beagle play bits]
Signed-off-by: Mattijs Korpershoek <mkorpershoek@baylibre.com>
Add new partition to support factory reset protection with android 14.
It's needed to be able to do factory reset.
To fix vts_fs_test and be compliance with google requirements we need to
move on f2fs partition type.
fastboot format metadata fail with actual size so update it to 64MB.
Add APIs to set a firmware_name to a rproc and boot the rproc with the
same firmware.
Clients can call rproc_set_firmware() API to set firmware_name for a rproc
whereas rproc_boot() will load the firmware set by rproc_set_firmware() to
a buffer by calling request_firmware_into_buf(). rproc_boot() will then
load the firmware file to the remote processor and start the remote
processor.
Also include "fs-loader.h" and make remoteproc driver select FS_LOADER in
Kconfig so that we can call request_firmware_into_buf() from remoteproc
driver.
Signed-off-by: MD Danish Anwar <danishanwar@ti.com>
Update the USB0, USB1 nodes and enable them.
Signed-off-by: Ravi Gunasekaran <r-gunasekaran@ti.com>
commit 0d72b0f2f83b788273c40ed4a64d1adf74877726 upstream.
Since upstream U-Boot uses ti_common.env instead of ti_armv7_common.env,
the implementation here differs in this aspect from the upstream commit.
The main_cpsw0_qsgmii_phyinit command is defined only for certain TI
SoCs which have the do_main_cpsw0_qsgmii_phyinit variable set.
Add a check to ensure that the main_cpsw0_qsgmii_phyinit command is run
only for such SoCs.
Signed-off-by: Manorit Chawdhry <m-chawdhry@ti.com>
Signed-off-by: Siddharth Vadapalli <s-vadapalli@ti.com>
Reviewed-by: Mattijs Korpershoek <mkorpershoek@baylibre.com>
Useful when trying to check if an opp efuse is burned in or not.
k3_avs driver checks opp_ids when probing and overwrites the voltage
values in vd_data for the respective board. This can be called to check
that data and returns 0 if valid.
Reviewed-by: Udit Kumar <u-kumar1@ti.com>
Signed-off-by: Reid Tonking <reidt@ti.com>
J7200 has support for opp_low, so adding the option here
Introduce the initial configs needed to support the J722S SoC family.
Signed-off-by: Vaishnav Achath <vaishnav.a@ti.com>
Signed-off-by: Jayesh Choudhary <j-choudhary@ti.com>
Introduce support for J722S SoC.
simple-framebuffer.
same firmware.
processor.
driver.
only for such SoCs.
These headers follow the pattern:
| #if CONFIG_IS_ENABLED(FANCY_FEATURE)
| void foo(void);
| #else
| static inline void foo(void) { return -ENOSYS; }
| #endif
In the #else path ENOSYS is used, however linux/errno.h is not included.
If errno.h has not been included already the compiler errors out even
if the inline function is not referenced.
Make those headers self contained.
Upstream-Status: Submitted [https://lore.kernel.org/all/20240118181106.4133924-1-max.oss.09@gmail.com/T/#u]
RC Release 09.01.00.008
RC Release 09.01.00.006
Actually we just do a resize to fix issue when apply overlay on device
tree without any free space but if overlay take more place as default
extra size added fdt apply will fail.
So to fix this issue add extra size corresponding to page size.
Acked-by: Vishal Mahaveer <vishalm@ti.com>
Tested-by: Mattijs Korpershoek <mkorpershoek@baylibre.com>
Copy this over from k3_dfu.env.
Signed-off-by: Roger Quadros <rogerq@kernel.org>
Provide NAND device and NAND driver configuration for AM64x EVM.
The following shall be the eMMC layout for AM64x platform:
boot0 partition
0x0+----------------------------------+
| tiboot3.bin (1 MB) |
0x800+----------------------------------+
| tispl.bin (2 MB) |
0x1800+-----------------------------------+
| u-boot.img (4 MB) |
0x3800+-----------------------------------+
| environment (128 KB) |
0x3900+-----------------------------------+
Move u-boot environment from 0x3400 to ox3800 since at 0x3400
it overlaps with u-boot.img.
Signed-off-by: Judith Mendez <jm@ti.com>
am62b_p1_skevm eeprom has been introduced with
commit 09b2c79a8df8 ("board: ti: am62x: Add support to detect AM62B-P1 board")
Since this support, board_name is updated and we can no longer boot android
since we don't set the proper dtb_index.
Add am62b_p1_skevm and load the same dtb as for am62x_skevm.
Add Android bootflow support for AM62PX SoC.
The dtb directory structure had been standardized by the TI arago
distribution. The TI legacy platform still using the default mmc
environment from the header file. Add the directory dtb/ to the DTB
search path.
Signed-off-by: Sinthu Raja <sinthu.raja@ti.com>
For legacy platforms the packaging of fitimage doesn't prefix the "conf-"
in the DTB config section. So, drop the conf- prefix from the fdtfile name
Fixes: 1eaf714ce2 "include: configs: Override get_fit_config to get FIT config for AM57x"
Introduce the initial configs needed to support the am62px SoC family
[bb@ti.com: rebased on TI's 2023.10 uboot]
Signed-off-by: Bryan Brattlof <bb@ti.com>
Include the clock and lpsc tree files needed for the wkup spl to
initialize the proper PLLs and power domains to boot the SoC.
[bb@ti.com: rebased to TI's 2023.04 uboot]
As AM57x uses overlays for display and camera interfaces, add support to
load DT overlay files to MMC boot.
TI AM57x boards use a custom (though family common to TI boards) mechanism
for booting Linux. Add support to enable custom MMC boot as a default
option along with the distroboot approach.
Also, add supporting mmc boot environment variables which shall be used for
custom MMC boot
commit 7ebbce535c774806b3db0bedd2ba3cfb95c07658 upstream.
After the refactor with conf- nodes in fitImage, overlaystring wasn't
didn't handle the new conf- nodes in FIT Booting. Fix get_overlaystring
to handle conf- nodes.
Fixes: 837833a724b7 ("environment: ti: Add get_fit_config command to get FIT config string")
Reported-by: Aniket Limaye <a-limaye@ti.com>
Reviewed-by: Andrew Davis <afd@ti.com>
The get_fit_config is introduced [1] in ti_armv7_common.h to mangle the
fdtfile name when used to select a config node from the OE made FIT image.
The ti_armv7_common.h is common for both K3 and AM57xx platforms. AM57xx
platforms' fdtfile name does not have '/' so the setexpr command fails and
boot hangs.
Override the get_fit_config in AM57x specific config header to get the FIT
config name.
[1]:472b8e71be84667201d0fb28649c3c6649ac49f8
DTBOs are stored in vendor specific directories in Linux.
Add the vendor prefix to the path to load the overlay correctly.
Beagle Play has a different dts and is also identified as
board_name = am62x_beagleplay.
It also has a different boot flow than the AM62x SK EVM.
AM62x SK EVM:
1. Boot rom reads UDA (User Data Area), looking for tiboot3
2. Boot rom finds tiboot3 and loads it
Beagle Play:
1. Boot rom looks for tiboot3 in mmc0boot0
Because of this difference, we need to have another environment file for the
Beagle Play, to describe the partitioning table.
Add support for it to enable Android boot flow.
The U-Boot environment is stored at offset 0x680000 (6.5MB)
While this is fine for AM62x SK EVM (because its mmc0boot0 partition is 31.5MB),
this does won't work on the Beagle Play, which only has 4MB.
Booting Beagle Play shows:
Loading Environment from MMC... MMC: block number 0x3500 exceeds max(0x2000)
*** Warning - !read failed, using default environment
Move the U-boot environment at lba 0x800 on mmc0boot0.
This reserves 1MB so that tiboot3 to be on mmc0boot0 as well, which is the
case for BeaglePlay.
Also add a raw_partition label so that we can erase it with:
fastboot erase bootenv
The boot0 partition now looks as:
blk
boot0 partition (31.5 MB)
| empty (1 MB) |
| padding (384 KB) |
0xc00+----------------------------------+
| Remaining space (30.0 MB) |
0xfc00+----------------------------------+
pick
Note:
CONFIG_ENV_OFFSET is in bytes and fastboot_raw_* is in lba number.
CONFIG_ENV_OFFSET=0x100000 -> lba 0x800
env size + padding = 512KB -> length of 0x400 lbas
The U-Boot environment is saved in mmc0boot0, not in a GPT user partition.
Remove this un-needed partition here since it's misleading.
Some time when you try to format metadata partition it's not working
because partition-type was not defined and found in mmc.
So to fix it add variable to define metadata partition format to ext4.
To fully support android 13 and fix vts_generic_boot_image_test we need
to have an init_boot partition [1].
[1]: https://source.android.com/docs/core/architecture/partitions/generic-boot
- Add vendor_boot and init_boot partitions in partition table.
- Rework Android bootflow to include vendor_boot image loading.
Signed-off-by: Safae Ouajih <souajih@baylibre.com>
