include/configs/km_arm.h
For ARM systems, before ELF relocation was introduced,
CONFIG_SKIP_RELOCATE_UBOOT coul be used to prevent *COPYING* the
U-Boot image from whereever it was loaded to it's link address
(CONFIG_SYS_TEXT_BASE). The name was badly chosen, as no relocation
was performed at all, it was just a memcpy().
With ELF relocation, this does not work like that any more, and
related boards need to be fixed anyway. So don't keep this relict any
longer.
Tested-by: Heiko Schocher <hs@denx.de>
Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
When this define was introduced, the idea was to provide a soft
migration path for ARM boards to get adapted to the new relocation
support. However, other recent changes led to a different
implementation (ELF relocation), where this no longer works. By now
CONFIG_SYS_ARM_WITHOUT_RELOC does not only not help any more, but it
actually hurts because it obfuscates the actual code by sprinkling it
with lots of dead and non-working debris.
So let's make a clean cut and drop CONFIG_SYS_ARM_WITHOUT_RELOC.
By now, the majority of architectures have working relocation
support, so the few remaining architectures have become exceptions.
To make this more obvious, we make working relocation now the default
case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC.
After moving the definition of CONFIG_SYS_TEXT_BASE to the respective
board config files, all Marvell kirkwood board have just a single and
common entry in their config.mk files:
KWD_CONFIG = $(SRCTREE)/board/$(BOARDDIR)/kwbimage.cfg
Replace the only reference to KWD_CONFIG in the top level Makefile by
an equivalent setting, and remove all kirkwood config.mk files.
Signed-off-by: Wolfgang Denk <wd at denx.de>
Cc: Prafulla Wadaskar <prafulla at marvell.com>
Cc: Siddarth Gore <gores at marvell.com>
Cc: Simon Kagstrom <simon.kagstrom at netinsight.net>
Cc: Heiko Schocher <hs at denx.de>
Cc: Eric Cooper <ecc at cmu.edu>
Acked-by: Wolfgang Denk <wd at denx.de>
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
Current default options increase u-boot size to overlap the location of the environment in NAND, move environment higher up
Signed-off-by: Gray Remlin <g_remlin@rocketmail.com>
This patch is to fix build breakage and support new relocation
scheme for mx51evk.
- Correct IRAM base address and add size definition
The IRAM starts from 0x1FFE0000 on final revsion i.mx51 than
0x1FFE8000 which is for older revision.
- Include imx-regs.h in mx51evk.h
Definitions like CSD0_BASE_ADDR and IRAM_BASE_ADDR can be
referred to.
- Define CONFIG_SYS_INIT_RAM_ADDR and CONFIG_SYS_INIT_RAM_SIZE
They are used to define init RAM layout.
- Remove comment for CONFIG_SYS_GBL_DATA_SIZE which has been
buried by Wolfgang's commit below
25ddd1fb: Replace CONFIG_SYS_GBL_DATA_SIZE by auto-generated value
Signed-off-by: Shawn Guo <shawn.gsc@gmail.com>
This patch is to consolidate default mx51evk env for two primary
boot modes, mmcboot and netboot.
It also cleans some unused env like netdev, uboot and redundant
env like loadaddr since CONFIG_LOADADDR already defines it.
The mx51evk u-boot has an issue that system will get reset
every 2 hours.
MC13892 has an inside charge timer which expires in 120 minutes.
If ICHRG and CHGAUTOB are not set properly, this timer expiration
will get system power recycled.
Since mx51evk has no Li-Ion battery on board, the patch sets
ICHRG in externally powered mode and sets CHGAUTOB bit to avoid
automatic charging, so that system will not get reset by this
timer expiration.
The patch also corrects the bit field definition of register 48
(Charger 0) per latest MC13892 Reference Manual.
Move CONFIG_SYS_TEXT_BASE to the board's config file, and remove the
now unnecessary config.mk file.
Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com>
Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
A recurrent issue is that certain C level constructs like sizeof() or
offsetof() cannot be used in assembler files, which is inconvenient
when such constructs are used in the definition of macro names etc.
To avoid duplication of such definitions (and thus another cause of
problems), we adapt the Linux way to automatically generate the
respective definitions from the respective C header files.
In Linux, this is implemented in include/linux/kbuild.h, Kbuild, and
arch/*/kernel/asm-offsets.c; we adapt the code from the Linux v2.6.36
kernel tree.
We also copy the concept of the include/generated/ directory which can
be used to hold other automatically generated files as well.
We start with an architecture-independent lib/asm-offsets.c which
generates include/generated/generic-asm-offsets.h (included by
include/asm-offsets.h, which is what will be referred to in the actual
source code). Later this may be extended by architecture-specific
arch/*/lib/asm-offsets.c files that will generate a
include/generated/asm-offsets.h.
CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be
some end address; to make the meaning more clear we rename it into
No other code changes are performed in this patch, only minor editing
of white space (due to the changed length) and the comments was done,
where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations
looks seriously broken. Last known maintainers on Cc:
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Martin Winistoerfer <martinwinistoerfer@gmx.ch>
Board support for the Guntermann & Drunck CATCenter Io.
Board support for the Guntermann & Drunck IoCon.
Signed-off-by: Dirk Eibach <eibach@gdsys.de>
SICRH has been misconfigured, i.e. TSEC2 clock + D[0:3] are GPIOs.
Fix this to be RGMII signals again.
Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
This patch adds CONFIG_SYS_FLASH_BANKS_SIZES define to make use of new
cfi_flash driver ability to detect flash chips that are bigger than a
corresponding address window (we have such situation on some revs of
a4m072).
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
Initial support for Extreme Engineering Solutions XPedite5500 -
a P2020-based PMC/XMC single board computer.
Signed-off-by: John Schmoller <jschmoller@xes-inc.com>
Add memory and I2C posts to the XPedite517x/520x/537x board families.
The PIC's TFRR register doesn't affect hardware and is generally unused,
so use as storage for the POST word.
Acked-by: Heiko Schocher <hs@denx.de>
Acked-by: Wolfgang Denk <wd@denx.de>
Some U-Boot images for X-ES boards support multiple products in the same
family. For example, the XPedite5370, XPedite5371, and XPedite5372 are
similar enough that one U-Boot image can work on all 3 cards. To make it
clear that a U-Boot image can work on boards of the same family, rename
the boards with the least significant digit of 'x'.
While we're at it, change the board config file and make targets to be
lowercase.
Also change the default uImage and fdt filenames to "board.uImage" and
"board.dtb" to be more generic.
Add board_flash_wp_on() to check a pca9557 gpio pin to see
if non-volatile memory write protection is enabled.
Previously, write protected NOR flashes would fail initialization which
resulted in a bootup error such as:
DTT: 53 C local / 64 C remote (adt7461@4c)
DTT: 54 C local (ds1621@48)
FLASH: Executed from FLASH1
POST memory PASSED
FLASH: ## Unknown FLASH on Bank 1 - Size = 0x00000000 = 0 MB
## Unknown FLASH on Bank 2 - Size = 0x00000000 = 0 MB
*** failed ***
### ERROR ### Please RESET the board ###
With this patch, NOR flash initialization is skipped:
POST memory PASSED
FLASH: Uninitialized - Write Protect On
L2: 1024 KB enabled
NAND: 1024 MiB
Note that flash related commands such as flinfo and saveenv will error
out when flash write protection is enabled.
Create a common checkboard() function to support all X-ES's Freescale
boards.
Also, add a get_board_derivative() function which reads hardware
strapping resistors to determine what model a board is. This allows one
U-Boot image to support multiple boards.
Add a new 'pci enum' command which re-enumerates the PCI buses. This
command is enabled via the CONFIG_CMD_PCI_ENUM define and can be useful
in boards with FPGAs connected via PCI/PCIe, boards that support PCI
hot-plugging, or during PCI debug.
Also enable the 'pci enum' command for X-ES's Freescale-based boards.
Common Freescale code for PCI initialization now exists, so migrate X-ES
boards to use it.
The recent change the env code added an additional 32 bytes into gd_t
and that causes to grow pass the previous CONFIG_SYS_GBL_DATA_SIZE size.
This board is broken and it's not possible to repair it.
This board is broken and impossible to repair without deep knowledge or
availability of the hardware.
