While converting CONFIG_SYS_[DI]CACHE_OFF to Kconfig, there are instances
where these configuration items are conditional on SPL. This commit adds SPL
variants of these configuration items, uses CONFIG_IS_ENABLED(), and updates
the configurations as required.
Acked-by: Alexey Brodkin <abrodkin@synopsys.com>
Signed-off-by: Trevor Woerner <trevor@toganlabs.com>
[trini: Make the default depend on the setting for full U-Boot, update
more zynq hardware]
CONFIG_SYS_[DI]CACHE_OFF had been partially converted to Kconfig
parameters; only for the ARC architecture. This patch turns these two
parameters into Kconfig items everywhere else they are found.
All of the include/configs/* and defconfig changes in this patch are
for arm machines only. The Kconfig changes for arc, nds32, riscv,
and xtensa have been included since these symbols are found in code
under arch/{arc,nds32,riscv,xtensa}, however, no currently-defined
include/configs/* or defconfigs for these architectures exist which
include these symbols.
These results have been confirmed with tools/moveconfig.py.
Acked-by: Alexey Brodkin <abrodkin@snopsys.com>
[trini: Re-migrate for a few more boards]
Eventually these configuration items will be converted to Kconfig,
therefore there's little point in leaving commented-out versions of
them in include/configs.
This config is the only config that uses:
#define CONFIG_SYS_DCACHE_OFF 1
in its #define.
Remove the superfluous "1" so this cache #define is like all the others.
- arndale fixes
- SoCFPGA DT and reset cleanup, AE MCVEVK board support.
The CONFIG_POWER and CONFIG_POWER_I2C were introduced in
include/configs/exynos5-common.h in commit 19bd3aaa5991 ("exynos5: fix
build break by adding CONFIG_POWER") and then it propagated up to
include/configs/arndale.h. However before that commit, there was no
build break at all on Arndale and SMDK5250 boards. It seems the commit
fixed nothing and just added unused defines.
In fact, the Arndale board is not configuring its PMIC (S5M8767) which
uses I2C bus.
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
Re-add support for Aries Embedded MCV SoM, which is CycloneV based
and the associated MCVEVK and MCVEVP baseboard. The board can boot
from eMMC. Ethernet and USB is supported.
The Aries Embedded boards have been removed with commit 03b54997d568
("board/aries: Remove"). I will now take care of them.
The device-tree files are from mainline Linux commit e93c9c99a629
("Linux v5.1)".
Signed-off-by: Wolfgang Grandegger <wg@aries-embedded.de>
CC: Marek Vasut <marex@denx.de>
CC: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
Move the U-Boot environment to 0x80000 to match the downstream
vendor fork and allow easy migration from one to the other.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Chris Brandt <chris.brandt@renesas.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Pull request for UEFI sub-system for v2019.07-rc3
The development target for the UEFI sub-system is EBBR compliance. We have
already implemented some further protocols to enable running the UEFI Shell
and the UEFI SCT test suite.
As some boards are severely memory constrained make some of these extras
customizable.
Provide bug fixes. The most prominent ones let us pass the UEFI SCT memory
allocation tests.
- A10 FPGA programming support, Gen5 livetree conversion
Correct the description of utf8_utf16_strnlen() and utf8_utf16_strlen() to
reflect that they return u16 count and not byte count.
For these functions and utf16_utf8_strnlen() describe the handling of
invalid code sequences.
Increasing Malloc pool size up to 0x15000 is required to support FAT in SPL
. The result of calculation is come from default max cluster(0x10000) +
others(0x2000) + additional memory for headroom(0x3000).
Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
Add FPGA driver to support program FPGA with FPGA bitstream loading from
filesystem. The driver are designed based on generic firmware loader
framework. The driver can handle FPGA program operation from loading FPGA
bitstream in flash to memory and then to program FPGA.
Last change to this board was done in 2016, has no prospects of
ever being converted to DM, drop it.
Cc: Vladimir Zapolskiy <vz@mleia.com>
Cc: Yoshihiro Shimoda <shimoda.yoshihiro.uh@renesas.com>
Cc: Mark Jonas <mark.jonas@de.bosch.com>
There is no check for CONFIG_CRC32 so the #define in image.h does
nothing. Remove it.
Reported-by: Robert P. J. Day <rpjday@crashcourse.ca>
Signed-off-by: Chris Packham <judge.packham@gmail.com>
Reviewed-by: Stefano Babic <sbabic@denx.de>
Due to some mistakes in the source code, it was not possible to really
turn FIT support off. This commit fixes the problem by means of the
following changes:
- Enclose "bootm_host_load_image" and "bootm_host_load_images" between
checks for CONFIG_FIT_SIGNATURE, in common/bootm.c.
- Enclose the declaration of "bootm_host_load_images" between checks for
CONFIG_FIT_SIGNATURE, in common/bootm.h.
- Condition the compilation and linking of fit_common.o fit_image.o
image-host.o common/image-fit.o to CONFIG_FIT=y, in tools/Makefile.
Signed-off-by: Carlos Santos <casantos@datacom.ind.br>
[fabio: adapt for 2016.07]
Signed-off-by: Fabio Estevam <festevam@gmail.com>
[Ricardo: fix conditional compilation and linking of the files mentioned above
for 2016.07]
Signed-off-by: Ricardo Martincoski <ricardo.martincoski@gmail.com>
[Jörg: adapt for 2019.01]
Signed-off-by: Jörg Krause <joerg.krause@embedded.rocks>
[Retrieved from:
https://git.buildroot.net/buildroot/tree/package/uboot-tools/0003-Make-FIT-support-really-optional.patch]
Signed-off-by: Fabrice Fontaine <fontaine.fabrice@gmail.com>
Improvements and new features:
- split more rockchip pinctrl_core feature into per SoC
- enable TPL for evb-rk3399 board
- enable TPL/SPL for evb-px5 board
- enable TPL and OP-TEE support for evb-rk3229
- update fix in arm common assembly start code for rockchip header file
- update default SPL_FIT_GENERATOR for rockchip
- rk3399 boards update to use '-u-boot.dtsi'
- add new rk3399 boards: Nanopi M4, Nanopc T4
- enable sound for chromebook_minnie
- DM updates for multiple MVEBU boards (Stefan)
- Add CRS305-1G-4S board (Luka)
- Enable MMC in SPL on clearfog (Baruch)
- Correct SYS_TEXT_BASE for qemu.
- Support booti.
- Increase SYSBOOTM_LEN for Fedora/RISCV kernel.
- Support SMP booting from flash.
When AE350 boots from flash, use CONFIG_OF_SEPARATE instead of
CONFIG_OF_BOARD.
Also remove unused code about prior_stage_fdt_address.
And modify CONFIG_SYS_FDT_BASE as flash address.
Signed-off-by: Rick Chen <rick@andestech.com>
Cc: Greentime Hu <greentime@andestech.com>
Reviewed-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de>
- Set fdt_addr variable, which is needed for extlinux to find FDT.
Otherwise booting kernel using extlinux results in missing FDT.
- Also run fdt addr with FDT address so that fdt commands would
work out of the box in U-Boot prompt.
This is successfully used by Fedora/RISCV with 5.1-rc3+ kernel using
OpenSBI -> U-Boot (S-mode) [extlinux] -> Kernel setup.
Signed-off-by: David Abdurachmanov <david.abdurachmanov@gmail.com>
Reviewed-by: Anup Patel <anup.patel@wdc.com>
After updating Fedora/RISCV kernel to 5.1-rc3+ the size increased above
the current threshold. Looking into HiKey, Dragonboards, etc. seems that
SZ_64M is a popular option.
This sucessfully boots Fedora/RISCV with 5.1-rc3+ kernel on QEMU 4.0 (master)
with OpenSBI -> U-Boot (S-mode) [extlinux] -> Kernel setup.
CRS305-1G-4S has a switch chip with an integrated CPU (98DX3236) and
like some of the other similar boards requires bin_hdr.
bin_hdr (DDR3 init stage) is currently retrieved from the stock
bootloader and compiled into the kwb image.
Adds support for U-Boot, enable UART, SPI, Winbond SPI flash chip
support and writing env to SPI flash.
Signed-off-by: Luka Kovacic <me@lukakovacic.xyz>
Reviewed-by: Chris Packham <judge.packham@gmail.com>
- Various PHY fixes / enhancements.
- TI K2G fixes
- H6 Beelink GS1 board (Clément)
- Olimex A64-Teres-I board (Jonas)
- sunxi build fix for CONFIG_CMD_PXE|DHCP (Ondrej)
- Change include order (Jagan)
- EPHY clock changes (Jagan)
- EMAC enablement on Cubietruck Plus, BPI-M3 (Chen-Yu Tsai)
Getting a RESET by index with device is not straight forward
for some use-cases like handling clock operations for child
node in parent driver. So we need to process the child node
in parent probe via ofnode and process RESET operation for child
without udevice but with ofnode.
So add reset_get_by_index_nodev() and move the common code
in reset_get_by_index_tail() to use for reset_get_by_index()
Cc: Stephen Warren <swarren@nvidia.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Getting a CLK by index with device is not straight forward
in parent probe via ofnode and process CLK operation for child
So add clk_get_by_index_nodev() and move the common code
in clk_get_by_index_tail() to use for clk_get_by_index()
- Allow x86 boards to use TPL, SPL and U-Boot proper
- Update sysreset x86 driver to utilize ACPI registers to do power off
- Add a new chromebook_samus_tpl board for TPL support
- Several minor changes in binman tool
Pull request for UEFI sub-system for v2019.07-rc2 (2)
Fix a bunch of errors in the UEFI sub-system:
* implement missing UnloadImage(),
* implement missing RegisterProtocolNotify(),
* unload images in Exit(),
* parameter checks.
Provide a unit test for UnloadImage().
Remove a redundant function for unit tests.
Clean up the UEFI sub-system initialization
Rockchip platform suppose to use TPL(run in SRAM) as dram init and
SPL(run in DDR SDRAM) as pre-loader, so that the SPL would not be
limited by SRAM size.
This patch add rk3399-board-tpl.c and its common configs.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Use larger space for load bl31 in SPL
Tested-by: Andy Yan <andy.yan@rock-chips.com>
Prefer to use default setting like other SoCs.
Move original spl to tpl, and add spl to load next stage firmware,
adapt all the address and option for them.
Add a version of samus which supports booting from TPL to SPL and then
to U-Boot. This allows TPL to select from an A or B SPL to support
verified boot with field upgrade.
Add the required CPU code so that TPL builds correctly. Also update the
SPL code to deal with being booted from TPL.
With the move to Kconfig this option should be set in Kconfig, not in the
config header file. Move it.
Add a new ioctl() request to read information about the power-management
system. This can be used to power off the device.
This reverts commit aec4298ccb337106fd0115b91d846a022fdf301d.
Unfortunately this has a dramatic impact on the pre-relocation memory
used on x86 platforms (increasing it by 2KB) since it increases the
overhead for each PCI device from 220 bytes to 412 bytes.
The offending line is in UCLASS_DRIVER(pci):
.per_device_auto_alloc_size = sizeof(struct pci_controller),
This means that all PCI devices have the controller struct associated
with them. The solution is to move the regions[] member out of the array,
makes its size dynamic, or split UCLASS_PCI into controllers and
non-controllers, as the comment suggests.
For now, revert the commit to get things running again.
Two new helper functions (phy_read_mmd() and phy_write_mmd()) are added
to allow access to the MMD PHY registers.
The MMD PHY registers can be accessed by several means:
1. Using two new MMD access function hooks in the PHY driver. These
functions can be implemented when the PHY driver does not support the
standard IEEE Compatible clause 45 access mechanism described in clause
22 or if the PHY uses its own non-standard access mechanism.
2. Direct access for C45 PHYs and C22 PHYs when accessing the reachable
DEVADs.
3. The standard clause 45 access extensions to the MMD registers through
the indirection registers (clause 22) in all the other cases.
Signed-off-by: Carlo Caione <ccaione@baylibre.com>
Consistently use efi_uintn_t as type of memory keys.
Reviewed-by: Alexander Graf <graf@amazon.com>
If the parent image handle does not refer to a loaded image return
EFI_INVALID_PARAMETER.
(UEFI SCT II 2017: 3.4.1 LoadImage() - 5.1.4.1.1)
Mark our root node as a loaded image to avoid an error when using it as
parent image.
The RegisterProtocolNotify() boot service registers an event to be
notified upon the installation of a protocol interface with the
specified GUID.
Add the missing implementation.
Function memcmp() is available in efi_freestanding.c. So we do not remove a
further implementation.
Replace all usages of efi_st_memcmp() by memcmp().
Implement unloading of images in the Exit() boot services:
* unload images that are not yet started,
* unload started applications,
* unload drivers returning an error.
