Quick manual fixup to merge the USB boot related defines and TPM related
defines.
include/configs/exynos5250-dt.h
Support to check whether the SD3.0 or not.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Tested-by: Rommel Custodio <sessyargc@gmail.com>
eMMC vesrion is supported up to v4.5.
But bootloader isn't saw the exact eMMC version.
After applied this patch,
if use the mmcinfo command, then can see the exactly mmc version.
Acked-by: Rommel Custodio <sessyargc@gmail.com>
The ARM errata 742230 - "ARM errata: DMB operation may be faulty" is
claimed for Cortex-A9 (r1p0..r2p2). Though i.MX6 uses a newer revision
than r2p2, we are seeing a reboot failure on i.MX6 SMP build that can be
fixed by applying the workaround for this errata. So for safety, let's
define CONFIG_ARM_ERRATA_742230 to enable the workaround on i.MX6.
Exynos5250 supports secondary USB device boot mode. If the iROM fails
to download u-boot from the primary boot device (such as SD or eMMC),
it will try to retrieve from the secondary boot device (such as USB).
Signed-off-by: Naveen Krishna Ch <ch.naveen@samsung.com>
Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com>
this is usefull when writing an UBI image which contains
and UBIFS volume (check README.nand and UBI FAQ for more details)
Signed-off-by: Eric Bénard <eric@eukrea.com>
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
Since the ICH SPI controller uses PCI, we must ensure that PCI is available
before it is inited.
This fixes the current "ICH SPI: Cannot find device" message on boot.
Beaver is a Tegra30 board that is nearly 100% compatible w/Cardhu.
Add a Beaver build so it can begin to be differentiated, if need be.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Boot script support brings TEC in line with other Tegra boards. To
enable booting a Linux kernel with initial ramdisk, also include support
for the new FIT image type.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Boot script support brings Plutux in line with other Tegra boards. In
order to enable booting a Linux kernel with initial ramdisk, also add
support for the new FIT image type.
Boot script support brings Medcom-Wide in line with other Tegra boards.
In order to enable booting a Linux kernel with initial ramdisk, also add
Some 3rd-party flash tools use the -v (verify) option of crc32 command.
This target wants to check full SPL size, BSS included.
Remove CONFIG_SPL_MAX_SIZE definition and instead define
CONFIG_SPL_MAX_FOOTPRINT.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Remove SPL-related ASSERT() in arch/arm/cpu/u-boot.lds
as this file is never used for SPL builds.
Rewrite the ASSERT() in arch/arm/cpu/u-boot-spl.lds
to separately test image (text,data,rodata...) size,
BSS size, and full footprint each against its own max,
and make Tegra boards check full footprint.
Also, output section mmutable is not used in SPL builds.
Remove it.
Finally, update README regarding the (now homogeneous)
semantics of CONFIG_SPL_[BSS_]MAX_SIZE and add the new
CONFIG_SPL_MAX_FOOTPRINT macro.
Reported-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Rework the waiting for transfer completion loop condition
to continue waiting until both Transfer Complete and DMA End
interrupts occur. Checking of DLA bit in Present State register
looks not needed in addition to interrupts status checking,
so it can be removed from the condition. Also, DMA Error
condition is added to the list of data errors, checked in the loop.
Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com>
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
TPM command library implements a subset of TPM commands defined in TCG
Main Specification 1.2 that are useful for implementing secure boot.
More TPM commands could be added out of necessity.
You may exercise these commands through the 'tpm' command. However, the
raw TPM commands are too primitive for writing secure boot in command
interpreter scripts; so the 'tpm' command also provides helper functions
to make scripting easier.
For example, to define a counter in TPM non-volatile storage and
initialize it to zero:
$ tpm init
$ tpm startup TPM_ST_CLEAR
$ tpm nv_define d 0x1001 0x1
$ tpm nv_write d 0x1001 0
And then increment the counter by one:
$ tpm nv_read d 0x1001 i
$ setexpr.l i $i + 1
$ tpm nv_write d 0x1001 $i
Signed-off-by: Che-Liang Chiou <clchiou@chromium.org>
This is used on some Exynos 5250 variants.
Add a driver for the I2C TPM from Infineon.
Signed-off-by: Rong Chang <rongchang@chromium.org>
Signed-off-by: Tom Wai-Hong Tam <waihong@chromium.org>
This enables the device tree library on the Integrator platforms
so we can pass a device tree when booting.
As this board has NAND and supports YAFFS2, add CONFIG_MD_NAND_YAFFS
Cc: David Müller <d.mueller@elsoft.ch>
Acked-by: David Müller <d.mueller@elsoft.ch>
drivers/video/exynos_fb.c
ext3 should not be used on SD cards, so use ext4 instead.
Cc: Sricharan R <r.sricharan@ti.com>
This reverts commit 239cb9d904cfa8ab50d840a47b3306189d695c75.
This board is from a u-boot point of view a mixture between kmnusa and
a standard km_kirkwood board. We have our u-boot environment in the spi
NOR flash, but we have a direct connection between the kirkwood and the
piggy. A FPGA is connected via the PCIe interface. So we only have to
select the specific features in the board setup.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Prafulla Wadaskar <prafulla@marvell.com>
Acked-By: Prafulla Wadaskar <prafulla@marvell.com>
Switch from 1-bit ecc to 4-bit ecc.
commit 9660e442 cosmetic: s/BOARD_LATE_INIT/CONFIG_BOARD_LATE_INIT
removes BOARD_LATE_INIT and uses CONFIG_BOARD_LATE_INIT instead.
Therefore we have to use this define.
Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
The conversion of mx31pdk to SPL NAND fixed the boot issue, but we start seeing
resets in loop, which prevents us from reaching the U-boot prompt.
Until the proper fix can be identified, disable watchdog, so that mx31pdk
can be functional again.
Following the removal of the smdk6400 board, the s3c64xx SoC becomes unused, so
remove associated code. It will still be possible to restore it later from the
Git history if necessary.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
The migration of boards from Makefile to boards.cfg was due for v2012.03, but
smdk6400 did not follow, and it does not build, so move it to scrapyard. It will
still be possible to restore it from the Git history before fixing it.
Commit e05e5de7fae5bec79617e113916dac6631251156 made the 2 1st parameters of
ARM's relocate_code() useless since it moved the code handling them to crt0.S.
So, drop these parameters.
This also fixes support for mx31pdk and tx25, which had been broken by commit
e05e5de7fae5bec79617e113916dac6631251156.
Acked-by: Scott Wood <scottwood@freescale.com>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
Change CONFIG_SPL_PAD_TO from a link address to an image offset since this is
more handy and closer to the purpose of this config.
Automatically define CONFIG_SPL_PAD_TO to CONFIG_SPL_MAX_SIZE (or 0 without
CONFIG_SPL_MAX_SIZE).
Test that CONFIG_SPL_PAD_TO >= CONFIG_SPL_MAX_SIZE if CONFIG_SPL_PAD_TO is
non-zero.
Commit e05e5de7fae5bec79617e113916dac6631251156 made ARM's relocate_code()
return to its caller, but it did not update its declaration accordingly.
Fixing this function declaration fixes dropped C code following calls to
relocate_code().
Add support for the Samsung K9LAG08U0M NAND Flash (2-GiB MLC NAND Flash, 2-kiB
pages, 256-kiB blocks, 30-ns R/W cycles, 1 CS) on mx53ard.
eNFC_CLK_ROOT is set up with a cycle time of 37.5 ns (400 MHz / 3 / 5) for this
board, which satisfies the 30-ns NF R/W cycle requirement.
Add some abstraction to NFC definitions so that some parts of the current code
can also be used for future i.MX5 code.
Clean up a few things by the way.
Allow the user to specify two UBI volumes to use for the environment
UBI is a better place for the environment on NAND devices because it
handles wear-leveling and bad blocks.
Gluebi is needed in Linux to access the env as an MTD partition.
Part, Read, and Write functionality that will be used by env_ubi.
The function get_timer() should return time in ms and CONFIG_SYS_HZ
should be set to 1000 by default. Fix both of these items.
Signed-off-by: Jon Hunter <jon-hunter@ti.com>
The current u-boot binary needs more than 128KB of flash space and so
move the u-boot environment from an offset of 128KB to 256KB in flash
to ensure the enviroment does not overlap with u-boot.
