path: root/include
2020-08-25arm: octeontx2: Add support for OcteonTX2 SoC platformsSuneel Garapati
This patch adds support for all OcteonTX2 96xx/95xx boards from Marvell. For 96xx boards, use octeontx_96xx_defconfig and for 95xx boards, use octeontx_95xx_defconfig. Signed-off-by: Suneel Garapati <sgarapati@marvell.com>
2020-08-25arm: octeontx: Add support for OcteonTX SoC platformsSuneel Garapati
This patch adds support for all OcteonTX 81xx/83xx boards from Marvell. For 81xx boards, use octeontx_81xx_defconfig and for 83xx boards, use octeontx_83xx_defconfig. Signed-off-by: Suneel Garapati <sgarapati@marvell.com>
2020-08-25pci: pci-uclass: Add VF BAR map support for Enhanced AllocationSuneel Garapati
Makes dm_pci_map_bar API available to map BAR for Virtual function PCI devices which support Enhanced Allocation. Signed-off-by: Suneel Garapati <sgarapati@marvell.com> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com>
2020-08-25pci: pci-uclass: Add support for Single-Root I/O VirtualizationSuneel Garapati
SR-IOV - Single Root I/O Virtualization PF - Physical Function VF - Virtual Function If SR-IOV capability is present, use it to initialize Virtual Function PCI device instances. pci_sriov_init function will read SR-IOV registers to create VF devices under the PF PCI device and also bind driver if available. This function needs to be invoked from Physical function device driver which expects VF device support, creating minimal impact on existing framework. Signed-off-by: Suneel Garapati <sgarapati@marvell.com> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com>
2020-08-25pci: pci-uclass: Dynamically allocate the PCI regionsStefan Roese
Instead of using a fixed length pre-allocated array of regions, this patch moves to dynamically allocating the regions based on the number of available regions plus the necessary regions for DRAM banks. Since MAX_PCI_REGIONS is not needed any more, its removed completely with this patch. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Thierry Reding <treding@nvidia.com> Cc: Marek Vasut <marek.vasut+renesas@gmail.com>
2020-08-25dm: core: Add API to read PCI bus-range propertyStefan Roese
Add dev_read_pci_bus_range() to read bus-range property values Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-08-25fdtdec: Add API to read pci bus-range propertySuneel Garapati
Add fdtdec_get_pci_bus_range to read bus-range property values. Signed-off-by: Suneel Garapati <sgarapati@marvell.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-08-24Merge tag 'u-boot-clk-24Aug2020' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-clk - Add CCF clocks definitions for iMX6Q enet (ETH) - Several fixes for CCF framework - the most notable is the one, which adds get_rate helper to clk-mux.c - Improvements for clk command - better visibility and alignment.
2020-08-24dm: test: clk: add the test for the ccf gated clockDario Binacchi
Unlike the other clock types, in the case of the gated clock, a new driver has been developed which does not use the registering routine provided by the common clock framework. The addition of the ecspi0 clock to sandbox therefore allows testing the ccf gate clock. Signed-off-by: Dario Binacchi <dariobin@libero.it> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-08-23Merge tag 'dm-pull-22aug20' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-dm replace devfdt_get_addr_ptr() with dev_read_addr_ptr() binman fixes for portage various minor fixes 'bind' command improvements
2020-08-23stdio: Tidy up the coding styleSimon Glass
Bring the coding style in this file up to the current level. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-08-23stdio: Drop #ifdefs in the header fileSimon Glass
These prevent the use of IS_ENABLED() and are unnecessary. Drop them and fix a few code-style nits nearby. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-08-23Convert CONFIG_SYS_DEVICE_NULLDEV to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_DEVICE_NULLDEV Signed-off-by: Simon Glass <sjg@chromium.org>
2020-08-23Convert CONFIG_SPLASH_SCREEN et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SPLASH_SCREEN CONFIG_SPLASH_SCREEN_ALIGN CONFIG_SPLASHIMAGE_GUARD CONFIG_SPLASH_SOURCE Signed-off-by: Simon Glass <sjg@chromium.org>
2020-08-23Convert CONFIG_NETCONSOLE to KconfigTom Rini
This converts the following to Kconfig: CONFIG_NETCONSOLE Signed-off-by: Tom Rini <trini@konsulko.com>
2020-08-22dm: core: Fix devfdt_get_addr_ptr return valueOvidiu Panait
According to the description of devfdt_get_addr_ptr, this function should return NULL on failure, but currently it returns (void *)FDT_ADDR_T_NONE. Fix this by making devfdt_get_addr_ptr return NULL on failure, as described in the function comments. Also, update the drivers currently checking (void *)FDT_ADDR_T_NONE to check for NULL. Signed-off-by: Ovidiu Panait <ovidiu.panait@windriver.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-08-22dm: fix ofnode_read_addr/size_cells()Heinrich Schuchardt
In the case of the live tree ofnode_read_addr_cells() and ofnode_read_size_cells() return the #address-cells and #size-cells defined in the parent node. With the patch the same is done for a non-live tree. The only consumer of these functions is currently the CFI flash driver. This patch fixes the incorrect parsing of the device tree leading to 'saveenv' failing on qemu_arm64_defconfig. For testing qemu-system-aarch64 has to be called with -drive if=pflash,format=raw,index=1,file=envstore.img to provide the flash memory. envstore.img must be 64 MiB large. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Stefan Roese <sr@denx.de>
2020-08-20Merge tag 'xilinx-for-v2020.10-rc3' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze Xilinx changes for v2020.10-rc3 - Fix fdtfile variable setup - Fix bootm_*/fdt_high/initrd_high variables handling - Fix Kconfig dependencies for Xilinx drivers - Fix booting u-boot from lowest memory - Fix firmware payload argument count for Versal - Fix dfu configurations - Fix mio_bank property handling - Fix and align code around ID detection - Start to use ENV_VARS_UBOOT_RUNTIME_CONFIG - Simplify logic around reading MAC from eeprom - Decrease malloc length for zynqmp mini qspi - Enable preboot for ZynqMP and Versal i2c: - Fix i2c eeprom partitions handling mmc: - Fix logic around HS mode enabling and use proper functions
2020-08-20clk: versal: Move pm_query_id out of clock driverMichal Simek
There is no reason to have firmware specific structure in clock driver. Move it to generic location and also initialize enum values which is based on https://lore.kernel.org/linux-arm-kernel/20200318125003.GA2727094@kroah.com/ recommended way to go to make sure that values guaranteed by compiler. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-08-20xilinx: common: Get rid of fdt_high variableMichal Simek
There is no need to setup this variable if bootm_low and bootm_size variable are properly setup. If fdt_high variable is missing U-Boot is asking LMB to return free memory which is not used. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-08-20xilinx: zynqmp: synchronize firmware call return payloadIbai Erkiaga
Removes duplicated definition of PAYLOAD_ARG_CNT and define it in the firmware driver. Additionally fixes payload buffer declarations without macro usage Signed-off-by: Ibai Erkiaga <ibai.erkiaga-elorza@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-08-20xilinx: zynqmp: Enable DFU tftp supportMichal Simek
Enable DFU tftp support for firmware update. Fill dfu_ram_tftp variable to have command present for showing how to use it. boot FIT image has been created from below fragment. Key part is that type of image has to be firmware. Also based on experiment load property is completely ignored and base addresses are taken from dfu_alt_info variable. $ cat update_uboot.its /dts-v1/; / { description = "Automatic U-Boot update"; #address-cells = <1>; images { Image { description = "Kernel"; data = /incbin/("/tftpboot/Image"); compression = "none"; arch = "arm64"; type = "firmware"; os = "linux"; load = <0x80000>; entry = <0x80000>; hash-1 { algo = "sha1"; }; }; system.dtb { description = "DTB"; data = /incbin/("/tftpboot/system.dtb"); compression = "none"; arch = "arm64"; type = "firmware"; load = <0>; hash-1 { algo = "sha1"; }; }; }; }; $ mkimage -f update_uboot.its /tftpboot/boot When U-Boot starts get IP address and server IP. dhcp setenv serverip 192.168.0.105 And then run prepared command. run dfu_ram_tftp Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-08-20xilinx: Align dfu ram with booti commandMichal Simek
Image should be loaded to 0x80000 address and not to $kernel_addr_r. Also kernel_addr, fdt_addr and fdt_size in zynqmp case are not defined that's why define it to be aligned with Versal. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-08-20arm64: zynqmp: Reduce malloc memory for mini QSPI configurationAshok Reddy Soma
Mini U-boot runs on lower foot print of 256KB OCM. Hence 8K memory for malloc may not be required. Reduce it by 1.5K. Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-08-20lib: fdt: Introduce fdtdec_setup_mem_size_base_lowest()Michal Simek
New function should be called from board dram_init() because it initialized gd->ram_base/ram_size. It finds the lowest available memory. On systems with multiple memory nodes finding out the first memory node by fdtdec_setup_mem_size_base() is not enough because this memory can be above actual U-Boot VA mapping. Currently only mapping till 39bit is supported (Full 44bit mapping was removed by commit 7985cdf74b28 ("arm64: Remove non-full-va map code")). If DT starts with the first memory node above 39bit address then system can be unpredictable. The function is available only when multiple memory bank support is enabled. Calling fdtdec_setup_memory_banksize() from dram_init() is not possible because fdtdec_setup_memory_banksize() is saving dram information to bd structure which is placed on stack but not initialized at this time. Also stack is placed at location setup in dram_init(). Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-08-19arm: dts: mt7622: add SATA reset constantsFrank Wunderlich
add reset constants used for SATA to header file Signed-off-by: Frank Wunderlich <frank-w@public-files.de>
2020-08-18ARM: uniphier: rename include guard of include/configs/uniphier.hMasahiro Yamada
Make the include guard match to the file name. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2020-08-15Merge tag 'efi-2020-10-rc3-2' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-efi Pull request for UEFI sub-system for efi-2020-10-rc3 (2) This series includes bug fixes for: * UEFI secure boot - images with multiple signatures * UEFI secure boot - support for intermediate certificates * corrections for UEFI unit tests * missing loadaddr on MAIX board
2020-08-14board: xen: De-initialize before jumping to LinuxOleksandr Andrushchenko
Free resources used by Xen board before jumping to Linux kernel. Signed-off-by: Oleksandr Andrushchenko <oleksandr_andrushchenko@epam.com> Signed-off-by: Anastasiia Lukianenko <anastasiia_lukianenko@epam.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-08-14xen: pvblock: Add initial support for para-virtualized block driverAnastasiia Lukianenko
Add initial infrastructure for Xen para-virtualized block device. This includes compile-time configuration and the skeleton for the future driver implementation. Add new class UCLASS_PVBLOCK which is going to be a parent for virtual block devices. Add new interface type IF_TYPE_PVBLOCK. Implement basic driver setup by reading XenStore configuration. Signed-off-by: Andrii Anisov <andrii_anisov@epam.com> Signed-off-by: Anastasiia Lukianenko <anastasiia_lukianenko@epam.com> Signed-off-by: Oleksandr Andrushchenko <oleksandr_andrushchenko@epam.com>
2020-08-14xen: Port Xen grant table driver from mini-osOleksandr Andrushchenko
Make required updates to run on u-boot. Signed-off-by: Oleksandr Andrushchenko <oleksandr_andrushchenko@epam.com> Signed-off-by: Anastasiia Lukianenko <anastasiia_lukianenko@epam.com>
2020-08-14xen: Port Xen bus driver from mini-osOleksandr Andrushchenko
Make required updates to run on u-boot and strip test code. Signed-off-by: Anastasiia Lukianenko <anastasiia_lukianenko@epam.com> Signed-off-by: Oleksandr Andrushchenko <oleksandr_andrushchenko@epam.com>
2020-08-14lib: sscanf: add sscanf implementationAndrii Anisov
Port sscanf implementation from mini-os and introduce new Kconfig option to enable it: CONFIG_SSCANF. Disable by default. Signed-off-by: Andrii Anisov <andrii_anisov@epam.com> Signed-off-by: Anastasiia Lukianenko <anastasiia_lukianenko@epam.com> Signed-off-by: Oleksandr Andrushchenko <oleksandr_andrushchenko@epam.com>
2020-08-14linux/compat.h: Add wait_event_timeout macroOleksandr Andrushchenko
Add wait_event_timeout - sleep until a condition gets true or a timeout elapses. This is a stripped version of the same from Linux kernel with the following u-boot specific modifications: - no wait queues supported - use u-boot timer to detect timeouts - check for Ctrl-C pressed during wait Signed-off-by: Oleksandr Andrushchenko <oleksandr_andrushchenko@epam.com> Signed-off-by: Anastasiia Lukianenko <anastasiia_lukianenko@epam.com> [trini: Drop atomic_read from gadget/ether.c as this has existed for a while and now causes problems] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-08-14xen: Port Xen event channel driver from mini-osOleksandr Andrushchenko
Make required updates to run on u-boot. Strip functionality not needed by U-boot. Signed-off-by: Oleksandr Andrushchenko <oleksandr_andrushchenko@epam.com> Signed-off-by: Anastasiia Lukianenko <anastasiia_lukianenko@epam.com>
2020-08-14xen: Port Xen hypervisor related code from mini-osOleksandr Andrushchenko
Port hypervisor related code from Mini-OS. This is referencing the code of Mini-OS from [1] by Huang Shijie and Volodymyr Babchuk which is for ARM64. Update essential arch code to support required bit operations, memory barriers etc. Copyright for the bits ported belong to at least the following authors, please see related files for details: Copyright (c) 2002-2003, K A Fraser Copyright (c) 2005, Grzegorz Milos, gm281@cam.ac.uk,Intel Research Cambridge Copyright (c) 2014, Karim Allah Ahmed <karim.allah.ahmed@gmail.com> [1] - https://github.com/zyzii/mini-os.git Signed-off-by: Oleksandr Andrushchenko <oleksandr_andrushchenko@epam.com> Signed-off-by: Anastasiia Lukianenko <anastasiia_lukianenko@epam.com> [trini: Drop wmb() from musb-net/linux-compat.h now] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-08-14board: Introduce xenguest_arm64 boardAndrii Anisov
Introduce a minimal Xen guest board running as a virtual machine under Xen Project's hypervisor [1], [2]. Part of the code is ported from Xen mini-os and also uses work initially done by different authors from NXP: please see relevant files for their copyrights. [1] https://xenbits.xen.org [2] https://wiki.xenproject.org/ Signed-off-by: Andrii Anisov <andrii_anisov@epam.com> Signed-off-by: Oleksandr Andrushchenko <oleksandr_andrushchenko@epam.com> Signed-off-by: Anastasiia Lukianenko <anastasiia_lukianenko@epam.com>
2020-08-14riscv: load addresses for Sipeed MAIXHeinrich Schuchardt
Define default load addresses and the device tree name for the Sipeed MAIX. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-08-14xen: Add essential and required interface headersOleksandr Andrushchenko
Add essential and required Xen interface headers only taken from the stable Linux kernel stable/linux-5.7.y at commit 66dfe4522160 Linux 5.7.5. These are better suited for U-boot than the original headers from Xen as they are the stripped versions of the same. At the same time use public protocols from Xen RELEASE-4.13.1, at commit 6278553325a9 update Xen version to 4.13.1 as those have more comments in them. Signed-off-by: Oleksandr Andrushchenko <oleksandr_andrushchenko@epam.com> Signed-off-by: Anastasiia Lukianenko <anastasiia_lukianenko@epam.com> Acked-by: Peng Fan <peng.fan@nxp.com>
2020-08-14configs: evb-ast2500: Move BOOTCOMMAND from header to defconfigChia-Wei, Wang
Move the BOOTCOMMAND definition from the board inclusion header to the default configuration file. Signed-off-by: Chia-Wei, Wang <chiawei_wang@aspeedtech.com>
2020-08-14include/configs: aspeed: Remove hardcoded variablesChia-Wei, Wang
The hardcoded platform variables such as DRAM base address are not common to Aspeed SoCs AST24xx/AST25xx/AST26xx. This patch replaces those hardcoded with macros defined in a newly added header, where the basic SoC HW information are assigned accordingly. Signed-off-by: Chia-Wei, Wang <chiawei_wang@aspeedtech.com>
2020-08-14drivers: pci: add api to get dma regionsRayagonda Kokatanur
Add api to get dma regions. Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com>
2020-08-14efi_loader: signature: correct a behavior against multiple signaturesAKASHI Takahiro
Under the current implementation, all the signatures, if any, in a signed image must be verified before loading it. Meanwhile, UEFI specification v2.8b section 32.5.3.3 says, Multiple signatures are allowed to exist in the binary’s certificate table (as per PE/COFF Section “Attribute Certificate Table”). Only one hash or signature is required to be present in db in order to pass validation, so long as neither the SHA-256 hash of the binary nor any present signature is reflected in dbx. This patch makes the semantics of signature verification compliant with the specification mentioned above. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reported-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-08-13efi_loader: signature: rework for intermediate certificates supportAKASHI Takahiro
In this commit, efi_signature_verify(with_sigdb) will be re-implemented using pcks7_verify_one() in order to support certificates chain, where the signer's certificate will be signed by an intermediate CA (certificate authority) and the latter's certificate will also be signed by another CA and so on. What we need to do here is to search for certificates in a signature, build up a chain of certificates and verify one by one. pkcs7_verify_one() handles most of these steps except the last one. pkcs7_verify_one() returns, if succeeded, the last certificate to verify, which can be either a self-signed one or one that should be signed by one of certificates in "db". Re-worked efi_signature_verify() will take care of this step. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
2020-08-11Merge tag 'ti-v2020.10-rc3' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-ti - Added support for J7200 evm - DM_ETH and DM_USB migrations for omap3 - USB DFU and mass storage support for AM65x evm - RTI watchdog support for K3 devices - Fix an issue with L3 cache on K3 devices
2020-08-11board: ti: j7200: Introduce support for j7200 build targetsLokesh Vutla
j7200-evm has minor differences with j721e-evm based on the IPs available in the SoC. Introduce separate build targets for j7200-evm to incorporate the differences. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Suman Anna <s-anna@ti.com>
2020-08-11configs: am65x_evm_a53: Enable USB Mass storage and DFU boot modesFaiz Abbas
Enable configs to facilitate booting from USB Mass Storage devices as well as USB peripheral boot Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
2020-08-11configs: am65x_evm: Add support for DFU related configsFaiz Abbas
Add offset and environment related configs used for booting from DFU. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
2020-08-11spl: usb: Create an API spl_usb_load()Faiz Abbas
Create a new API spl_usb_load() that takes the filename as a parameter instead of taking the default U-boot PAYLOAD_NAME Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
2020-08-11Merge tag 'efi-2020-10-rc3' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-efi Pull request for UEFI sub-system for efi-2020-10-rc3 Bugs in the UEFI sub-system are fixed: * use the optional data of the BootXXXX variables as load options * simplify function public_key_verify_signature() * amend a copyright notice
