The default value of CONFIG_SYS_BOOTM_LEN, 0x800000, causes error
when uncompressing Image.gz out of FIT image.
Uncompressing Kernel Image ... Error: inflate() returned -5
Image too large: increase CONFIG_SYS_BOOTM_LEN
and loading Image out of FIT image.
Loading Kernel Image ... Image too large: increase CONFIG_SYS_BOOTM_LEN
Must RESET board to recover
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Use dfu_alt_info_emmc variable from include/environment/ti/dfu.h file.
It was probably overlooked when extracting DFU variables to mentioned
file.
This patch fixes DFU on BeagleBone Black, so that we can use commands
like ones below to upgrade various images on eMMC:
=> setenv dfu_alt_info $dfu_alt_info_emmc
=> dfu 0 mmc 1
$ dfu-util -D MLO -a MLO.raw
$ dfu-util -D u-boot.img -a u-boot.img.raw
Without this patch, the user is forced to assign the value to
dfu_alt_info_emmc manually, which contradicts with instructions [1].
[1] http://processors.wiki.ti.com/index.php/Linux_Core_U-Boot_User%27s_Guide
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
git://www.denx.de/git/u-boot-microblaze
Xilinx changes for v2018.01-rc2-v2
fpga:
- Enable loading bitstream via fit image for !xilinx platforms
zynq:
- Fix SPL SD boot mode
zynqmp:
- Not not reset in panic
- Do not use simple allocator because of fat changes
- Various dt chagnes
- modeboot variable setup
- Fix fpga loading on automotive devices
- Fix coverity issues
test:
- Fix env test for !hush case - Stephen's patch
Increase setup, assertion and hold time related to chip-select signal.
Additional delay is needed for the signal to propogate through FPGA.
This adjustment slightly increase the read and write cycle but has no
impact on burst read or write.
Signed-off-by: York Sun <york.sun@nxp.com>
Again the image size increases and the length needs to be adjusted.
This commit adds ENV_SIZE and ENV_OFFSET configuration items for
ARCH_ROCKCHIP, but keeps these non-visible (i.e. not prompt is given).
With these new items present, the configuration from the header files
is moved to Kconfig.
Keeping these non-visible is necessary to have the possibility to
select new default values if CONFIG_IS_IN_* is changed (interactively
or with oldconfig). Otherwise it will always be set to a previous
value if used with a prompt. As an example if we do a defconfig with
CONFIG_IS_IN_MMC and change it to CONFIG_IS_IN_SPI_FLASH via
menuconfig, ENV_SIZE and ENV_OFFSET will not be changed to the correct
values as defconfig will already have set them to the default values
of CONFIG_IS_IN_MMC in .config.
Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
User do not need to access the reserved part in system, remove them
from partition table.
Rename atf to trust as generic name for armv7 do not use ATF.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Provide a function to remove a handle from the object list
after removing all protocols.
To avoid forward declarations other functions have to move up
in the coding.
efi_setup_loaded_image() should return an error code indicating if
an error has occurred.
An error occurs if a protocol cannot be installed.
Add LS1012ARDB RevC/RevC1/RevC2/RevD/RevE information and
detect it when u-boot starts up.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
This patch is to clean up definitions for I2C IO expanders.
The value 0x10 of __SW_BOOT_EMU is wrong. It should be 0x2.
Fixed it in this patch.
This patch is enabling support for SPL QSPI boot.
First of all it is necessary to generate atf-spi.ub which is different
format than atf-uboot.ub (this can be made as legacy image too)
ADDR=`arm-xilinx-linux-gnueabi-readelf -a bl31.elf | grep "Entry point
address" | cut -d ':' -f 2 | sed -e 's/^[ \t]*//'`
aarch64-linux-gnu-objcopy -O binary bl31.elf bl31.bin
./tools/mkimage -f auto -A arm64 -T firmware -C none -O u-boot -a $ADDR
-e $ADDR -n "atf1" -E -b arch/arm/dts/zynqmp-zcu102.dtb -d bl31.bin
atf-uboot.ub
./tools/mkimage -A arm64 -T firmware -C none -O u-boot -a $ADDR -e $ADDR
-n "atf-for-qspi" -E -d bl31.bin atf-spi.ub
This patch is using this QSPI layout with offsets:
0 boot.bin
512k atf-ub
640k u-boot.bin
1280k u-boot.img
Which corresponding by writing these images(read from MMC)
mmcinfo
sf probe
load mmc 0 10000000 boot.bin
sf erase 0 +$filesize
sf write 10000000 0 $filesize
load mmc 0 10000000 atf-spi.ub
sf erase 0x80000 +$filesize
sf write 10000000 0x80000 $filesize
load mmc 0 10000000 u-boot.bin
sf erase 0xa0000 +$filesize
sf write 10000000 0xa0000 $filesize
load mmc 0 10000000 u-boot.img
sf erase 0x140000 +$filesize
sf write 10000000 0x140000 $filesize
For testing u-boot running in EL3 you can break atf-spi.ub like this:
sf probe
sf erase 0x80000 +4
Then u-boot.img is executed.
This was caused by: "fs/fat: Reduce stack usage"
(sha1:2460098cffacd18729262e3ed36656e6943783ed) which converted
fat code to use malloc. But simple malloc is not freeing space
that's why full malloc implementation is needed.
Malloc space is added to RAM.
Do not perform reset when panic happens because in the next reset
panic happens again and logs are overflood by the same errors.
This can be enabled by default and reset can be performed via watchdog.
This patch is fixing two issues:
1. Insufficient stack size for fat fs buffers
2. Insufficient space in malloc area
Tested on zc702 and zc706.
This drops the limit that fpga is only loaded from FIT images for Xilinx.
This is done by moving the 'partial' check from 'common/image.c' to
'drivers/fpga/xilinx.c' (the only driver supporting partial images yet)
and supplies a weak default implementation in 'drivers/fpga/fpga.c'.
Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com>
Tested-by: Michal Simek <michal.simek@xilinx.com> (On zcu102)
Include common config_distro_defaults.h and config_distro_bootcmd.h
for u-boot enviroments to support automatical distro boot which
scan boot.scr from external storage devices(e.g. SD and USB)
and execute autoboot script.
Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@nxp.com>
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
The BRDCFG5[SPISDHC] register field of Qixis device is used
to control SPI and SDHC signal routing.
10 = Force SDHC Mode
- SPI_CS[0] is routed to CPLD for SDHC_VS use.
- SPI_CS[1] is unused.
- SPI_CS[2:3] are routed to the TDMRiser slot.
11 = Force eMMC Mode
- SPI_CS[0:3] are routed to the eMMC card.
0X = Auto Mode
- If SDHC_CS_B=0 (SDHC card installed): Use SDHC mode
described above.
- Else SDHC_CS_B=1 (no SDHC card installed): Use eMMC
mode described above.
In default the hardware uses auto mode, but sometimes we need
to use force SDHC mode to support SD card hotplug, or SD sleep
waking up in kernel. This patch is to support force SDHC mode
by hwconfig.
Texas Instrument's TPS65910 PMIC contains 3 buck DC-DC converts, one
boost DC-DC converter and 8 LDOs. This patch implements driver model
support for the TPS65910 PMIC and its regulators making the get/set
API for regulator value/enable available.
This patch depends on the patch "am33xx: Add a function to query MPU
voltage in uV" to build correctly. For boards relying on the DT
include file tps65910.dtsi the v3 patch "power: extend prefix match
to regulator-name property" and an appropriate regulator naming is
also required.
Signed-off-by: Felix Brack <fb@ltec.ch>
This patch extends pmic_bind_children prefix matching. In addition to
the node name the property regulator-name is used while trying to match
prefixes. This allows assigning different drivers to regulator nodes
named regulator@1 and regulator@10 for example.
I have discarded the idea of using other properties then regulator-name
as I do not see any benefit in using property compatible or even
regulator-compatible. Of course I am open to change this if there are
good reasons to do so.
Allow SPL to access binman symbols and use this to get the address of
U-Boot. This falls back to CONFIG_SYS_TEXT_BASE if the binman symbol
is not available.
Binman construct images consisting of multiple binary files. These files
sometimes need to know (at run timme) where their peers are located. For
example, SPL may want to know where U-Boot is located in the image, so
that it can jump to U-Boot correctly on boot.
In general the positions where the binaries end up after binman has
finished packing them cannot be known at compile time. One reason for
this is that binman does not know the size of the binaries until
everything is compiled, linked and converted to binaries with objcopy.
To make this work, we add a feature to binman which checks each binary
for symbol names starting with '_binman'. These are then decoded to figure
out which entry and property they refer to. Then binman writes the value
of this symbol into the appropriate binary. With this, the symbol will
have the correct value at run time.
Macros are used to make this easier to use. As an example, this declares
a symbol that will access the 'u-boot-spl' entry to find the 'pos' value
(i.e. the position of SPL in the image):
binman_sym_declare(unsigned long, u_boot_spl, pos);
This converts to a symbol called '_binman_u_boot_spl_prop_pos' in any
binary that includes it. Binman then updates the value in that binary,
ensuring that it can be accessed at runtime with:
ulong u_boot_pos = binman_sym(ulong, u_boot_spl, pos);
This assigns the variable u_boot_pos to the position of SPL in the image.
For external data, FIT has a optional property "data-position" which
can set the external data to a fixed offset to FIT beginning.
Add the support for this property in SPL FIT.
Signed-off-by: Ye Li <ye.li@nxp.com>
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Tomas Melin <tomas.melin@vaisala.com>
Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
Cc: "Andrew F. Davis" <afd@ti.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: "tomas.melin@vaisala.com" <tomas.melin@vaisala.com>
Cc: Kever Yang <kever.yang@rock-chips.com>
Cc: Andre Przywara <andre.przywara@arm.com>
Cc: York Sun <york.sun@nxp.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: "Cooper Jr., Franklin" <fcooper@ti.com>
Cc: George McCollister <george.mccollister@gmail.com>
Cc: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
Cc: Jean-Jacques Hiblot <jjhiblot@ti.com>
Cc: Rick Altherr <raltherr@google.com>
The Micron Flash is locked by default. This will automaticlly
unlock so manually unlocking is unnecessary in U-Boot.
This symbol enables some library code used by various SATA drivers,
so make this a non-user-visible symbol select'ed by the respective
drivers, and let moveconfig handle the rest.
And use 'imply' liberally.
Use 'imply' here liberally to avoid the combinatorial explosion of
defconfig changes in the PowerPC boards.
Synopsys HSDK clock controller generates and supplies clocks to various
controllers and peripherals within the SoC.
Each clock has assigned identifier and client device tree nodes can use
this identifier to specify the clock which they consume. All available
clocks are defined as preprocessor macros in the
dt-bindings/clock/snps,hsdk-cgu.h header and can be used in device
tree sources.
Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Neither denali.c nor denali_spl.c references this option.
This option is no longer used.
Add bits to support yet another board, the R8A77995 D3 Draak.
The DT file is from Linux 4.15-rc1 , commit
b35334447513c14a4dd55a67c269a743d4a4824b .
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Add bits to support yet another board, the R8A77970 V3M Eagle.
Add bits to support yet another SoC, the R8A77995 D3 .
Add bits to support yet another SoC, the R8A77970 V3M .
