CONFIG_FPGA_SOCFPGA
Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
Reviewed-by: Ley Foon Tan <ley.foon.tan@intel.com>
Reviewed-by: Dinh Nguyen <dinguyen@kernel.org>
CONFIG_FPGA
CONFIG_FPGA_ALTERA
CONFIG_ENV_IS_IN_ONENAND
CONFIG_ENV_IS_IN_FAT
CONFIG_ENV_IS_IN_REMOTE
CONFIG_ENV_IS_IN_SPI_FLASH
CONFIG_ENV_IS_IN_DATAFLASH
CONFIG_ENV_IS_IN_EEPROM
CONFIG_ENV_IS_IN_NVRAM
CONFIG_ENV_IS_IN_FLASH
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
The above CONFIG options are in Kconfig, and now have correct depends and
inter-dependencies. Migrate these to configs/ from include/configs/. In the
case of CMD_UBIFS also change it to be a default y if CMD_UBI.
With PowerPC 4xx support removed, we have removed xilinx-ppc support as
well, remove this file now.
Fixes 98f705c9cefd ("powerpc: remove 4xx support")
Pasting longer lines into the U-Boot console prompt sometimes leads to
characters missing. One problem here is the small 16-byte FIFO of the
legacy NS16550 UART, e.g. on x86 platforms.
This patch now introduces a Kconfig option to enable RX interrupt
buffer support for NS16550 style UARTs. With this option enabled, I was
able paste really long lines into the U-Boot console, without any
characters missing.
Cc: Bin Meng <bmeng.cn@gmail.com>
[trini: Guard ns16550_serial_remove with
CONFIG_IS_ENABLED(SERIAL_PRESENT) to match struct assignment]
commit 2eb48ff7a210d ("powerpc, 8260: remove support for mpc8260")
removed support for 8260 CPU.
This patch remove some remainders.
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
reginfo command is calling mpc8xx_reginfo(), mpc85xx_reginfo()
or mpc86xx_reginfo() based on CONFIG_ symbol.
As those 3 functions can't me defined at the same time, let's
rename them print_reginfo() to avoid the #ifdefs
The name is kept generic as it is not at all dependent on
powerpc arch and any other arch could want to also print
such information.
In addition, as the Makefile compiles cmd/reginfo.c only when
CONFIG_CMD_REGINFO is set, there is no need to enclose the U_BOOT_CMD
definition inside a #ifdef CONFIG_CMD_REGINFO
Lets all remove the #ifdefs around the U_BOOT_CMD as this
file is only compiled when CONFIG_CMD_REGINFO is defined
Finally, this is a PowerPC-only command, disable it on a number of
non-PowerPC platforms.
The Odroid C2 has two GiB of memory with two reserved regions.
reg = <0x0 0x0 0x0 0x1000000>;
reg = <0x0 0x10000000 0x0 0x200000>;
Patch
bfcef28ae4cf (arm: add initial support for Amlogic Meson and
ODROID-C2) provided function dram_init_banksize to reserve the
first 16 MiB of RAM for firmware in function dram_init_banksize
in arch/arm/mach-meson/board.c and defined
CONFIG_NR_DRAM_BANKS = 1.
With this patch dram_init_banksize is changed to additionally
reserve the 2MiB region for the ARM Trusted Firmware (BL31).
CONFIG_NR_DRAM_BANKS is set to 2.
Cc: Andreas Färber <afaerber@suse.de>
All current environments that implement redundancy use almost
identical implementations. This patch implements the env_nand
implementation as a function in env_common, and updates the
env_export function to export an env_nand-style 'flags' field by
default.
Signed-off-by: Fiach Antaw <fiach.antaw@uqconnect.edu.au>
Change get_enable return type to int so errors can be returned.
Signed-off-by: Keerthy <j-keerthy@ti.com>
Move CONFIG_CMD_SATA option to Kconfig to fix the following build
error:
In file included from include/configs/mx6cuboxi.h:137:0,
from include/config.h:7,
from include/common.h:21,
from common/env_common.c:11:
include/config_distro_bootcmd.h:161:2: error: expected '}' before 'BOOT_TARGET_DEVICES_references_SATA_without_CONFIG_SATA'
Reported-by: Stefano Babic <sbabic@denx.de>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
If no vmlinuz is found on mmc, try to boot from pxe.
Signed-off-by: Patrick Bruenn <p.bruenn@beckhoff.com>
Replace fdtaddr and rdaddr variable names with u-boot standard names
fdt_addr_r and ramdisk_addr_r.
This will make the use of pxe boot more easy.
Add support for Falcon mode and explain in the README the steps to
boot the kernel directly without loading the full U-Boot.
Signed-off-by: Diego Dorta <diego.dorta@nxp.com>
Acked-by: Fabio Estevam <fabio.estevam@nxp.com>
warp can run different kernel versions, such as NXP 4.1 or
mainline.
Currently the rootfs location is passed via mmcblk number and the
problem with this approach is that the mmcblk number for the eMMC
changes depending on the kernel version.
In order to avoid such issue, use UUID method to specify the rootfs
location.
Succesfully tested booting a NXP 4.1 and also a mainline 4.12 kernel.
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
location.
Also add CONFIG_BOOTCOMMAND to run finduuid function and distro_bootcmd.
This change was made based on U-Boot commit:
- ca4f338e2efece5196eb2178e5f7d07be828da6e
Signed-off-by: Fabio Berton <fabio.berton@ossystems.com.br>
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
location.
location.
mx6sabre boards can run different kernel versions, such as NXP 4.1 or
mainline.
location.
Succesfully tested booting a NXP 4.1 and also a mainline kernel on a
mx6qsabresd and mx6dlsabreauto.
WEIM cannot be used when I2C3 is enabled due to pin conflict, so keep
WEIM disabled by default.
I2C3 controls GPIO I2C expander (USB host and OTG have VBUS controlled by
the GPIO I2C expander), magnetometer, accelerometer.
Not disabling WEIM in U-Boot causes I2C3 to behave badly when booting
a NXP 4.1 kernel, which leads to probe failure on several devices,
including the lack of USB:
imx_usb 2184000.usb: Can't register ci_hdrc platform device, err=-517
By keeping WEIM disabled in U-Boot these kernel issues are gone.
Reported-by: Takashi Matsuzawa <tmatsuzawa@xevo.com>
Change is consistent with other SOCs and it is in preparation
for adding SOMs. SOC's related files are moved from cpu/ to
mach-imx/<SOC>.
This change is also coherent with the structure in kernel.
CC: Fabio Estevam <fabio.estevam@nxp.com>
CC: Akshay Bhat <akshaybhat@timesys.com>
CC: Ken Lin <Ken.Lin@advantech.com.tw>
CC: Marek Vasut <marek.vasut@gmail.com>
CC: Heiko Schocher <hs@denx.de>
CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com>
CC: Christian Gmeiner <christian.gmeiner@gmail.com>
CC: Stefan Roese <sr@denx.de>
CC: Patrick Bruenn <p.bruenn@beckhoff.com>
CC: Troy Kisky <troy.kisky@boundarydevices.com>
CC: Nikita Kiryanov <nikita@compulab.co.il>
CC: Otavio Salvador <otavio@ossystems.com.br>
CC: "Eric Bénard" <eric@eukrea.com>
CC: Jagan Teki <jagan@amarulasolutions.com>
CC: Ye Li <ye.li@nxp.com>
CC: Peng Fan <peng.fan@nxp.com>
CC: Adrian Alonso <adrian.alonso@nxp.com>
CC: Alison Wang <b18965@freescale.com>
CC: Tim Harvey <tharvey@gateworks.com>
CC: Martin Donnelly <martin.donnelly@ge.com>
CC: Marcin Niestroj <m.niestroj@grinn-global.com>
CC: Lukasz Majewski <lukma@denx.de>
CC: Adam Ford <aford173@gmail.com>
CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr>
CC: Boris Brezillon <boris.brezillon@free-electrons.com>
CC: Soeren Moch <smoch@web.de>
CC: Richard Hu <richard.hu@technexion.com>
CC: Wig Cheng <wig.cheng@technexion.com>
CC: Vanessa Maegima <vanessa.maegima@nxp.com>
CC: Max Krummenacher <max.krummenacher@toradex.com>
CC: Stefan Agner <stefan.agner@toradex.com>
CC: Markus Niebel <Markus.Niebel@tq-group.com>
CC: Breno Lima <breno.lima@nxp.com>
CC: Francesco Montefoschi <francesco.montefoschi@udoo.org>
CC: Jaehoon Chung <jh80.chung@samsung.com>
CC: Scott Wood <oss@buserror.net>
CC: Joe Hershberger <joe.hershberger@ni.com>
CC: Anatolij Gustschin <agust@denx.de>
CC: Simon Glass <sjg@chromium.org>
CC: "Andrew F. Davis" <afd@ti.com>
CC: "Łukasz Majewski" <l.majewski@samsung.com>
CC: Patrice Chotard <patrice.chotard@st.com>
CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
CC: Hans de Goede <hdegoede@redhat.com>
CC: Masahiro Yamada <yamada.masahiro@socionext.com>
CC: Stephen Warren <swarren@nvidia.com>
CC: Andre Przywara <andre.przywara@arm.com>
CC: "Álvaro Fernández Rojas" <noltari@gmail.com>
CC: York Sun <york.sun@nxp.com>
CC: Xiaoliang Yang <xiaoliang.yang@nxp.com>
CC: Chen-Yu Tsai <wens@csie.org>
CC: George McCollister <george.mccollister@gmail.com>
CC: Sven Ebenfeld <sven.ebenfeld@gmail.com>
CC: Filip Brozovic <fbrozovic@gmail.com>
CC: Petr Kulhavy <brain@jikos.cz>
CC: Eric Nelson <eric@nelint.com>
CC: Bai Ping <ping.bai@nxp.com>
CC: Anson Huang <Anson.Huang@nxp.com>
CC: Sanchayan Maity <maitysanchayan@gmail.com>
CC: Lokesh Vutla <lokeshvutla@ti.com>
CC: Patrick Delaunay <patrick.delaunay@st.com>
CC: Gary Bisson <gary.bisson@boundarydevices.com>
CC: Alexander Graf <agraf@suse.de>
CC: u-boot@lists.denx.de
Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
CONFIG_SYS_FSL_ESDHC_FORCE_VSELECT is not the correct method
to set I/O to 1.8. To boards that does not support vqmmc-supply,
use vs18_enable in fsl_esdhc_cfg. If regulator is supported,
use fixed 1.8V regulator for vqmmc-supply.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Cc: York Sun <york.sun@nxp.com>
When using eMMC with 1.8V I/O, the VSELECT bit need to be set in
the USDHC controller when init.
This patch adds a parameter "vs18_enable" in fsl_esdhc_cfg
structure and priv data, so each controller can have different
settings.
We could not use CONFIG_SYS_FSL_ESDHC_FORCE_VSELECT, it has problem
that it will apply to all USDHC controllers and it only set the 1.8V
at init phase. So if user does not select to the eMMC device,
the voltage on the I/O pins are not correct.
The type should be int, not u8. cfg->wp_enable will finally be
assigned to priv->wp_enable whose type is int.
Add u-boot-dtb.img for SPL_FS_LOAD_PAYLOAD_NAME when
OF_CONTROL used.
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
As mx6sabreauto supports SPL now, all variants can boot using the same
defconfig.
This patch:
- Removes non-SPL targets.
- Renames target to mx6sabreauto_defconfig.
- Renames folder and board files to mx6sabreauto.
- Updates MAINTAINERS, Makefile and Kconfig accordingly.
- Removes .cfg files.
- Adds a README with instructions to build and flash SPL and u-boot.img.
Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com>
Reviewed-by: Stefano Babic <sbabic@denx.de>
Add support for mx6q, mx6dl and mx6qp sabreauto boards in SPL.
Retrieved the mx6q DCD table from:
board/freescale/mx6qsabreauto/imximage.cfg
Retrieved the mx6dl DCD table from:
board/freescale/mx6qsabreauto/mx6dl.cfg
Retrieved the mx6qp DCD table from:
board/freescale/mx6qsabreauto/mx6qp.cfg
Flashed SPL and u-boot.img to an SD card and could successfully boot it
on mx6q, mx6qp and mx6dl sabreauto boards.
The Cubox-i and Hummingboard series of devices have an option of
SATA on board, and depending on how the fuses are blown even the
option to boot SPL from SATA. So enable support for it so it can
be used to boot the OS from if people desire.
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Remove the "Q" from the file guard symbol, so that it matches
the file name.
The Turris Omnia is a open-source router created by CZ.NIC.
The code is based on the Marvell/db-88f6820-gp by Stefan Roese
with modifications from Tomas Hlavacek in the CZ.NIC turris-omnia-uboot
repository, which can be found at
https://gitlab.labs.nic.cz/turris/turris-omnia-uboot
By default, the Turris Omnia uses btrfs as the main and only filesystem,
and also loads kernel and device tree from this filesystem. Since U-Boot
does not yet support btrfs, you should not flash your Turris Omnia board
with this unless you know what you are doing.
Signed-off-by: Tomas Hlavacek <tomas.hlavacek@nic.cz>
Signed-off-by: Marek Behun <marek.behun@nic.cz>
create mode 100644 board/CZ.NIC/turris_omnia/Makefile
create mode 100644 board/CZ.NIC/turris_omnia/kwbimage.cfg
create mode 100644 board/CZ.NIC/turris_omnia/turris_omnia.c
create mode 100644 configs/turris_omnia_defconfig
create mode 100644 include/configs/turris_omnia.h
This module can be found on the Turris Omnia board connected
via the I2C interface.
Among some cryptographic functions, the chip has a 512 bit
One Time Programmable memory, 88 byte configuration memory
and 512 byte general purpose memory.
The Turris Omnia stores serial number and device MAC address in
the OTP memory.
This commit adds basic support for reading the EEPROM and also
exposes the chips Random Number Generator.
The driver is based on code by
Josh Datko, Cryptotronix, jbd@cryptotronix.com
and also
Tomas Hlavacek, CZ.NIC, tomas.hlavacek@nic.cz
create mode 100644 drivers/misc/atsha204a-i2c.c
create mode 100644 include/atsha204a-i2c.h
When CONFIG_CMD_FASTBOOT or CONFIG_USB_FUNCTION_FASTBOOT are defined
in am335x_evm.h, a dependency on g_dnl.c is created. This in turn
creates a dependency on having USB gadget enabled.
As a result we can't create configs with USB gadget disabled.
Since these CONFIG_ variables are now part of kconfig, move them to
the board defconfigs, and out of am335x_evm.h. This both preserves
current defaults, and allows creating configs with USB gadget off.
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
Make make nand_info array static, since all direct users of nand_info array
have been converted to use get_nand_dev_by_index() API.
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
nand_info is used all over the file so abstract it with
get_nand_dev_by_index() which will help for DM conversion.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
This function returns the pointer to the value of a node property.
The current name ofnode_read_prop() is confusing. Follow the naming
of_get_property() from Linux.
The return type (const u32 *) is wrong. DT property values can be
strings as well as integers. This is why of_get_property/fdt_getprop
returns an opaque pointer.
The of_n_addr_cells() and of_n_size_cells() functions are useful for
getting the size of addresses in a node, but in a few places U-Boot needs
to obtain the actual property value for a node without walking up the
stack. Add functions for this and just the existing code to use it.
Add a comment to the existing ofnode functions which do not do the right
thing with a flat tree.
This fixes a problem reading PCI addresses.
Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
Tested-on: Beaver, Jetson-TK1
