path: root/include
2017-02-08dm: core: Replace of_offset with accessorSimon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-02-07x86: qemu: Add build options for SPLBin Meng
If SPL is used we want to use the generic SPL framework and boot from SPI via a board-specific means. Add these options to the board config file. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-02-07x86: link: Add build options for SPLSimon Glass
If SPL is used we want to use the generic SPL framework and boot from SPI via a board-specific means. Add these options to the board config file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-02-06x86: Use unsigned long for address in table generationSimon Glass
We should use unsigned long rather than u32 for addresses. Update this so that the table-generation code builds correctly on 64-bit machines. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-02-03Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: configs/ls1046aqds_defconfig configs/ls1046aqds_nand_defconfig configs/ls1046aqds_qspi_defconfig configs/ls1046aqds_sdcard_ifc_defconfig configs/ls1046aqds_sdcard_qspi_defconfig configs/ls1046ardb_emmc_defconfig configs/ls1046ardb_qspi_defconfig configs/ls1046ardb_sdcard_defconfig
2017-02-03arch: powerpc: Move CONFIG_FSL_ELBC to KconfigPrabhakar Kushwaha
Enable ELBC from Kconfig. Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-02-03arch: powerpc: Move CONFIG_FSL_IFC to KconfigPrabhakar Kushwaha
Enable IFC from Kconfig. Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-02-03board: freescale: ls1012a: Enable secure DDR on LS1012A platformsPrabhakar Kushwaha
PPA binary needs to be relocated on secure DDR, hence marking out a portion of DDR as secure if CONFIG_SYS_MEM_RESERVE_SECURE flag is set Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Signed-off-by: Abhimanyu Saini <abhimanyu.saini@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-02-01Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2017-02-01Merge git://www.denx.de/git/u-boot-marvellTom Rini
2017-02-01lib: tpm: Add command to flush resourcesMario Six
This patch adds a function to the TPM library, which allows U-Boot to flush resources, e.g. keys, from the TPM. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Stefan Roese <sr@denx.de>
2017-01-31mmc: zynq: rename CONFIG_ZYNQ_SDHCI to CONFIG_MMC_SDHCI_ZYNQMasahiro Yamada
Make the naming scheme consistent; all SDHCI-base drivers prefixed with CONFIG_MMC_SDHCI_. While we are here, add "depends on ARCH_ZYNQ || ARCH_ZYNQMP". Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-30BOARD: MCCMON6: Provide support for iMX6q based mccmon6 boardLukasz Majewski
This patch provides u-boot support for Liebherr (LWN) mccmon6 board. Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-29ARM: uniphier: make update commands more flexible for ATFMasahiro Yamada
Currently, SPL (u-boot-spl.bin) and U-Boot (u-boot.bin) are stored in non-volatile devices, and some environments are defined to update the images easily. When ARM Trusted Firmware is fully used, SPL is not used. U-Boot proper is contained as BL33 into FIP (Firmware Image Package), which is standard container used by ATF. Allow to use it. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-01-29ARM: uniphier: change CONFIG_SPL_PAD_TO to 128KBMasahiro Yamada
The Boot ROM supports authentication feature to prevent malformed software from being run on products. The signature is added at the tail of the second stage loader (= SPL in U-boot terminology). The size of the second stage loader was 64KB, and it was consistent across SoCs. The situation changed when LD20 SoC appeared; it loads 80KB second stage loader, and it is the only exception. Currently, CONFIG_SPL_PAD_TO is set to 64KB and U-Boot proper is loaded from the 64KB offset of non-volatile devices. This means the signature of LD20 SoC (located at 80KB offset) corrupts the U-Boot proper image. Let's move the U-Boot proper image to 128KB offset. It uses 48KB for nothing but padding, and we could actually locate the U-Boot proper at 80KB offset. However, the power of 2 generally seems a better choice for the offset address. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-01-29ARM: uniphier: change the offset to environment storage areaMasahiro Yamada
When ARM Trusted Firmware is used, bl1.bin + fip.bin exceeds 512KB, so the boot image and the current environment area will overlap. Move the environment storage to 1MB offset. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-01-29ARM: uniphier: set initrd_high environment to skip initrd relocationMasahiro Yamada
The boot_ramdisk_high() checks the environment "initrd_high" and, if it is set to (ulong)-1, skip the initrd relocation. This is useful for faster booting when we know the initrd is already located within the reach of the kernel. Change "norboot" to copy images in order to make it work without depending on the automatic relocation. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-01-29ARM: uniphier: use Image.gz instead Image for booting ARM64 LinuxMasahiro Yamada
The ARM64 Linux raw image now amounts to 15MB and it is getting bigger and bigger. Using Image.gz saves about 8MB. The cost of unzip is smaller than what we get by saving the kernel loading from non-volatile devices. The ARM32 Linux still uses zImage, a self-decompressor image, so it should not be affected. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-01-29ARM: uniphier: collect SPL CONFIG symbols to the bottom of headerMasahiro Yamada
For clarification, move CONFIG symbols that affect SPL building into a single place. Drop #ifdef CONFIG_SPL ... #endif since it is harmless to define CONFIG_SPL_... during U-Boot proper building. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-01-29ARM: uniphier: detect RAM size by decoding HW register instead of DTMasahiro Yamada
U-Boot needs to set up available memory area(s) in dram_init() and dram_init_banksize(). It is platform-dependent how to detect the memory banks. Currently, UniPhier adopts the memory banks _alleged_ by DT. This is based on the assumption that users bind a correct DT in their build process. Come to think of it, the DRAM controller has already been set up before U-Boot is entered (because U-Boot runs on DRAM). So, the DRAM controller setup register seems a more reliable source of any information about DRAM stuff. The DRAM banks are initialized by preliminary firmware (SPL, ARM Trusted Firmware BL2, or whatever), so this means the source of the reliability is shifted from Device Tree to such early-stage firmware. However, if the DRAM controller is wrongly configured, the system will crash. If your system is running, the DRAM setup register is very likely to provide the correct DRAM mapping. Decode the SG_MEMCONF register to get the available DRAM banks. The dram_init() and dram_init_banksize() need similar decoding. It would be nice if dram_init_banksize() could reuse the outcome of dram_init(), but global variables are unavailable at this stage because the .bss section is available only after the relocation. As a result, SG_MEMCONF must be checked twice, but a new helper uniphier_memconf_decode() will help to avoid code duplication. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-01-28ARM: stm32: enable support for smsc phy on stm32f746-disco boardMichael Kurz
This patch enables support for the smsc phy on the stm32f746-disco board. Signed-off-by: Michael Kurz <michi.kurz@gmail.com> Acked-by: Vikas MANOCHA <vikas.manocha@st.com> Series-changes 3: - Add Acked-by tag to 'enable support for smsc phy on...'
2017-01-28net: stm32: add designware mac glue code for stm32Michael Kurz
This patch adds glue code required for enabling the designware mac on stm32f7 devices. Signed-off-by: Michael Kurz <michi.kurz@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-01-28ARM: DTS: stm32: add stm32f746 device tree pin control filesMichael Kurz
This patch adds pin control definitions for use in device tree files The definitions are based on the stm32f746 files from current linux kernel "include/dt-bindings/pinctrl/stm32f746-pinfunc.h". Signed-off-by: Michael Kurz <michi.kurz@gmail.com> Acked-by: Vikas MANOCHA <vikas.manocha@st.com>
2017-01-28board/chiliboard: Add support for chiliBoardMarcin Niestroj
chiliBoard is a development board which uses chiliSOM as its base. Hardware specification: * chiliSOM (TI AM335x, DRAM, NAND) * Ethernet PHY (id 0) * USB host (usb1) * MicroSD slot (mmc0) Signed-off-by: Marcin Niestroj <m.niestroj@grinn-global.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-28aspeed: Support for ast2500 Eval Boardmaxims@google.com
ast2500 Eval Board device tree and board specific configuration. Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-28aspeed: Board init functions and common configs for ast2500 based boardsmaxims@google.com
Add configuration file with parameters that are very likely to be shared by all ast2500-based boards. Add ast2500-board.c file with the init code that is very likely to be shared by all ast2500-based boards. Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-28aspeed: Add basic ast2500-specific drivers and configurationmaxims@google.com
Clock Driver This driver is ast2500-specific and is not compatible with earlier versions of this chip. The differences are not that big, but they are in somewhat random places, so making it compatible with ast2400 is not worth the effort at the moment. SDRAM MC driver The driver is very ast2500-specific and is completely incompatible with previous versions of the chip. The memory controller is very poorly documented by Aspeed in the datasheet, with any mention of the whole range of registers missing. The initialization procedure has been basically taken from Aspeed SDK, where it is implemented in assembly. Here it is rewritten in C, with very limited understanding of what exactly it is doing. Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-28arm: Note vendor-required status of certain MACH_TYPE valuesTom Rini
In the cases of some boards, a MACH_TYPE number is used which is either not registered upstream or worse (for functionality) is re-using the number of a different (or reference) platform instead. Make sure we have a comment in these cases. Cc: Albert ARIBAUD <albert.aribaud@3adev.fr> Cc: Walter Schweizer <swwa@users.sourceforge.net> Cc: Stefan Roese <sr@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de>
2017-01-28am335x_shc: Drop MACH_TYPE usageTom Rini
This board is using MACH_TYPE values that were clearly picked during development and not registered. Remove rather than support. Cc: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-28arm: Clean up MACH_TYPE_xxx usage after re-sync of mach-typesTom Rini
With the latest mach-types values we have many instances where we no longer need to define a value and a few cases where the name (but not value) have changed slightly. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-28Revert "arm: Remove unregister MACH_TYPE_xxx uses"Tom Rini
This reverts commit 70b26cd057f42c7126088b49d4285955c8a00eae. This is not a strict revert as it is easier to fix board/atmark-techno/armadillo-800eva/armadillo-800eva.c to now the correct name (same value) than to revert that change too. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-28disk: convert CONFIG_AMIGA_PARTITION to KconfigPatrick Delaunay
2017-01-28disk: convert CONFIG_MAC_PARTITION to KconfigPatrick Delaunay
2017-01-28disk: convert CONFIG_PARTITIONS to KconfigPatrick Delaunay
2017-01-27armv8: ls1046aqds: added usb feature supportTang Yuantian
The LS1046AQDS processor has three integrated USB 3.0 controllers (USB1, USB2, and USB3) that allow direct connection to the USB ports with appropriate protection circuitry and power supplies. USB1 and USB2 ports are powered by a NX5P2190UK device, which supplies 5v power at up to 1.2 A. The power enable and power-fault-detect pins are connected to the LS1046A processor via CPLD for individual port management. Signed-off-by: Tang Yuantian <yuantian.tang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-27imx: mx6sxsabreauto: enable more dm driversPeng Fan
Enable MMC/I2C/GPIO/PMIC/REGULATOR/PCA953X DM drivers for mx6sxsabreauto board. Drop non-DM code. Note: The i.MX DM drivers has such dependency. MXC GPIO -> MXC I2C -> PFUZE/REGULATOR MXC GPIO -> PCA953X MXC GPIO -> FSL_USDHC So the drivers needs to be enabled all to avoid compiling error. The uboot dm tree log: => dm tree Class Probed Name ---------------------------------------- root [ + ] root_driver thermal [ ] |-- imx_thermal simple_bus [ + ] |-- soc simple_bus [ + ] | |-- aips-bus@02000000 simple_bus [ ] | | |-- spba-bus@02000000 gpio [ + ] | | |-- gpio@0209c000 gpio [ + ] | | |-- gpio@020a0000 gpio [ + ] | | |-- gpio@020a4000 gpio [ + ] | | |-- gpio@020a8000 gpio [ + ] | | |-- gpio@020ac000 gpio [ + ] | | |-- gpio@020b0000 gpio [ + ] | | |-- gpio@020b4000 simple_bus [ ] | | |-- anatop@020c8000 simple_bus [ ] | | |-- snvs@020cc000 pinctrl [ + ] | | `-- iomuxc@020e0000 pinconfig [ + ] | | `-- imx6x-sabreauto pinconfig [ + ] | | |-- i2c2grp-1 pinconfig [ + ] | | |-- i2c3grp-2 pinconfig [ ] | | |-- uart1grp pinconfig [ + ] | | |-- usdhc3grp pinconfig [ ] | | |-- usdhc3grp-100mhz pinconfig [ ] | | |-- usdhc3grp-200mhz pinconfig [ + ] | | |-- usdhc4grp pinconfig [ + ] | | `-- vccsd3grp simple_bus [ + ] | |-- aips-bus@02100000 mmc [ + ] | | |-- usdhc@02198000 mmc [ + ] | | |-- usdhc@0219c000 i2c [ + ] | | |-- i2c@021a4000 i2c_generic [ + ] | | | |-- generic_8 i2c_generic [ + ] | | | `-- generic_4e i2c [ + ] | | `-- i2c@021a8000 gpio [ + ] | | |-- gpio@30 gpio [ + ] | | `-- gpio@32 simple_bus [ ] | `-- aips-bus@02200000 simple_bus [ ] | `-- spba-bus@02200000 simple_bus [ + ] `-- regulators regulator [ + ] `-- regulator@0 Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2017-01-27imx: mx6sx: add dts for mx6sxsabreauto boardPeng Fan
Add dts for mx6sxsabreauto board. dts related files imported fro Linux (commit e5517c2a5a4). Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2017-01-27udoo_neo: Remove ramdiskaddr environment variableBreno Lima
Remove unused ramdiskaddr environment variable. Suggested-by: Andreas Färber <afaerber@suse.de> Signed-off-by: Breno Lima <breno.lima@nxp.com>
2017-01-27udoo_neo: Remove trailing semicolon and spaceBreno Lima
Remove the trailing semicolon and space. It's not necessary to have it on the last condition. Suggested-by: Andreas Färber <afaerber@suse.de> Signed-off-by: Breno Lima <breno.lima@nxp.com>
2017-01-27udoo_neo: Add fdt_addr_r environment variableBreno Lima
According to doc/README.distro: "fdt_addr_r: Mandatory. The location in RAM where the DTB will be loaded or copied to when processing the fdtdir/devicetreedir or fdt/devicetree options in extlinux.conf." So add the fdt_addr_r environment variable. Suggested-by: Andreas Färber <afaerber@suse.de> Signed-off-by: Breno Lima <breno.lima@nxp.com>
2017-01-27imx: nitrogen6x: fix USB host initializationGary Bisson
USB Host scanning has been broken since v2016.05. This is due to all the USB changes that happened between v2016.03 and v2016.05, especially: 2ef117fe4f usb: Remove 200 ms delay in usb_hub_port_connect_change() a22a264ec3 usb: Change power-on / scanning timeout handling So we need to increase the init delay to 2s using the usb_pgood_delay environment variable. Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com>
2017-01-27mx6qsabreauto: Pass the correct parallel NOR widthFabio Estevam
On mx6qsabreauto the parallel NOR width is 16 bits, so pass configure CONFIG_SYS_FLASH_CFI_WIDTH correctly so that the CFI driver does not use 8 bits by default. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-01-26Merge git://www.denx.de/git/u-boot-marvellTom Rini
2017-01-25Drop CONFIG_CMD_DOCSimon Glass
This is not used in U-Boot, and the only usage calls a non-existent function. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-25Drop the static inline print_cpuinfo()Simon Glass
This is only called from one place and the function cannot be inlined. Convert it to a normal function. Signed-off-by: Simon Glass <sjg@chromium.org>
