Create an entry for "config USB_EHCI_MX7" in Kconfig and
switch over to it for all boards.
The MXC UART IP can be run in DTE or DCE mode. This depends on the
board wiring and the pinmux used and hence is board specific. This
extends platform data with a new field to choose wheather DTE
mode shall be used.
The cm-fx6 module has an on-board spi flash chip. Enable mtd support
and the mtdparts command. Also define a default partitioning, add
it to the default environment, and enable support to overwrite the
partitioning defined in a device tree by it. Finally, probe for the
chip on preboot to register the flash chip and, thus, establish the
connection between the mtd environment settings and the actual device.
These changes move the effective default partitioning from the device
tree shipped with the vendor kernels to U-Boot which becomes the single
point of definition for the partitioning for all device tree based
kernels (in particular, for the upstream Linux kernel which does not
have a default partitioning defined in its device tree).
Signed-off-by: Christopher Spinrath <christopher.spinrath@rwth-aachen.de>
Reviewed-by: Stefano Babic <sbabic@denx.de>
Define an inline stub for fdt_fixup_mtdparts in the case that
CONFIG_FDT_FIXUP_PARTITIONS is not defined. This avoids the need
to guard every call to this function by a proper #ifdef in board
files.
Reviewed-by: Igor Grinberg <grinberg@compulab.co.il>
Currently, entire script segments have to be changed in the default
environment to change the kernel image location or to append kernel
cmdline parameters. In the later case this has to be changed for
every possible boot device.
Introduce new variables for kernel image locations and boot device
independent kernel parameters to make it easier to change these
settings.
Reviewed-by: Nikita Kiryanov <nikita@compulab.co.il>
Add PMIC support. Tested by command "pmic PFUZE3000 dump".
Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Recently I started to notice that u-boot.img built for Wandboard
by some toolchains becomes so large that it basically overlaps with
U-Boot environment area on SD-card.
According to
http://wiki.wandboard.org/index.php/Boot-process#sdcard_boot_data_layout
Wandboard's SD-card layout is as follows:
------------------------------>8---------------------------
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
Acked-by: Fabio Estevam <fabio.estevam@nxp.com>
1. 0x00000000 Reserved For MBR
2. 0x00000200 512 Secondary Image Table (optional)
3. 0x00000400 1024 uBoot Image (Starting From IVT)
4. 0x00060000 393216 start of uboot env (size:8k)
5. 0x00062000 end of uboot env
6. 0x00100000 1048576 Linux kernel start
7. 0x0076AC00 7777280 start of partition 1
So for U-Boot we have 383kB (392192 bytes).
But in up to date U-Boot for Wandboard we build separately
a) SPL
b) u-boot.img
which gives us a bit more detailed SD-card layout:
3. 0x00000400 1024 SPL
4. 0x00011400 70656 u-boot.img
5. 0x00060000 393216 start of uboot env (size:8k)
6. 0x00062000 end of uboot env
>From that layout we may calculate amount of space reserved for
u-boot.img. It's just 315kb (322560 bytes).
Now if I build U-Boot with Sourcery CodeBench ARM 2014.05 produced
u-boot.img is already more than we expected
(323840 bytes instead of "< 322560"):
ls -la u-boot.img
-rw-rw-r-- 1 user user 323840 Jul 5 07:38 u-boot.img
Funny enough if I rebuild U-Boot with ARM toolchain available in
my Fedora 23 distro u-boot.img becomes a little bit smaller:
ls -la u-boot.img
-rw-rw-r-- 1 user user 322216 Jul 5 07:39 u-boot.img
What's worse this problem might not affect people most of the time
because what happens people would just copy u-boot.img on SD-card and
live in happiness with it... well until somebody attempts to save
environment in U-Boot with "saveenv" command which will simply
overwrite the very end of u-boot.img.
That will lead to unusable SD-card until user dd u-boot.img on
SD-card again.
I may foresee this issue in the future to become more visible once we
add more features in U-Boot for Wandboard or just existing code base
becomes bulkier and people will consistently get larger u-boot.img
files produced.
IMHO there's an obvious solution for all that - just move U-Boot's env
to the very end of the gap between U-Boot and the first real partition
on the SD-card. This patch will follow
8fb9eea5653796 ("mx6sabre_common: Fix U-Boot corruption after 'saveenv'").
So env is still not in the very end of the gap (obviously 256kb is way
too much for U-Boot's env) but at least we have now the same
partitioning for i.MX6 boards.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Cc: Peter Robinson <pbrobinson@gmail.com>
Cc: Peter Korsgaard <peter@korsgaard.com>
Define a default board_run_command() function. This function contains
the commands needed to boot the board when CLI is disabled (CONFIG_CMDLINE=n).
Signed-off-by: Andrej Rosano <andrej@inversepath.com>
Switch to using zImage instead of uImage.
Add USB host support.
Tested by connecting a USB pen drive:
=> usb start
starting USB...
USB0: Port not available.
USB1: USB EHCI 1.00
scanning bus 1 for devices... 2 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
Add script for retrieving the kernel via TFTP and mounting the
rootfs via NFS.
Signed-off-by: Diego Dorta <diego.dorta@nxp.com>
DFU is a convenient way to program U-boot binary into the eMMC.
Add support for it.
Pico-imx6ul has a KSZ8081 Ethernet PHY.
Add support for it.
Instead of passing the total RAM size via PHYS_SDRAM_SIZE option,
we should better use imx_ddr_size() function, which automatically
determines the RAM size.
Signed-off-by: Gilles Chanteperdrix <gilles.chanteperdrix@xenomai.org>
Add Phytec-i.MX6 SOM with NAND
Support:
- 1GB RAM
- Ethernet
- SPI-NOR Flash
- NAND (1024 MB)
- external SD
- UART
Custom Board based on MX6 Dual, 1GB RAM and eMMC.
There are two variants of the board with and without
PCIe (ZC5202 and ZC5601).
Commit 9262367 moves USB errata workaround into a C file. This
causes compiling error for kmcoge4 and kmlion1. To enable the
errata workaround, define CONFIG_USB_EHCI_FSL in common header.
Signed-off-by: York Sun <york.sun@nxp.com>
Cc: Ed Swarthout <Ed.Swarthout@nxp.com>
Cc: Sriram Dash <sriram.dash@nxp.com>
Fixes: 92623672f9d3 ("fsl: usb: make errata function common for PPC and ARM")
We want people using errnos for errors instead of -1, so make it easy
by always including the definition of all the errnos.
We have driver-model drivers for some of these now, so drop them.
Signed-off-by: Tom Warren <twarren@nvidia.com>
The pmic framework uses errno_str() and this requires board that use it to
enable CONFIG_ERRNO_STR to avoid a build error. Update the header to provide
a NULL error message when CONFIG_ERRNO_STR is not defined, and fix the build
error.
This will show as "(null)" when U-Boot prints it.
Bring in a copyright for this file from cmd/pmic.c since this file was
submitted by the same author at around the same time. Also fix the missing
header guard.
DRA72-Evm revC uses dra72-evm-revc.dtb. Update the same in env vatiables.
As the help message of CONFIG_BOOTDELAY says, CONFIG_BOOTDELAY=-2
means the autoboot with no delay, with no abort check even if
CONFIG_ZERO_BOOTDELAY_CHECK is defined.
To sum up, the autoboot behaves as follows:
[1] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=y
autoboot with no delay, but you can abort it by key input
[2] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n
autoboot with no delay, with no check for abort
[3] CONFIG_BOOTDELAY=-1
disable autoboot
[4] CONFIG_BOOTDELAY=-2
As you notice, [2] and [4] come to the same result, which means we
do not need CONFIG_ZERO_BOOTDELAY_CHECK. We can control all the
cases only by CONFIG_BOOTDELAY, like this:
[2] CONFIG_BOOTDELAY=-1
disable autoboot
[3] CONFIG_BOOTDELAY=-2
This commit converts the logic as follow:
--> CONFIG_BOOTDELAY=-2
Acked-by: Vladimir Zapolskiy <vz@mleia.com>
Acked-by: Christian Riesch <christian.riesch@omicronenergy.com>
Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
This recently added board missed the tree-wide migration of
CONFIG_BOOTDELAY.
Acked-by: Pavel Machek <pavel@denx.de>
Introudce wp_enable. To check WPSPL, wp_enable needs to be set
to 1 in board code.
Take i.MX6UL for example, for some boards, they do not use WP singal,
so they does not configure USDHC1_WP_SELECT_INPUT, and its default
value is 0(GPIO1_IO02). However GPIO1_IO02 is muxed for i2c usage and
SION bit set. So USDHC controller can always get wp signal and WPSPL
shows write protect and blocks driver continuing. This is not what
we want to see, so add wp_enable, and if set to 0, just omit the
WPSPL checking and this does not effect normal working of usdhc
controller.
If wp-gpios is provided in dts, wp_enable is set to 1, otherwise 0.
Signed-off-by: Peng Fan <van.freenix@gmail.com>
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
Cc: York Sun <york.sun@nxp.com>
Tested-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
When booting in eMMC fast boot, MMC host does not exit from
boot mode after bootrom loading image. So the first command
'CMD0' sent in uboot will pull down the CMD line to low and
cause errors.
This patch cleans the MMC boot register in "mmc_init" to put the
MMC host back to normal mode.
Also clear DLL_CTRL delay line settings at USDHC initialization
to eliminate the pre-settings from boot rom.
Now I2C is initialized early enough to access FPGA so it supports to
show board info as early as other boot methods.
Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com>
Get the clocks from FPGA through I2C, if IFC is disabled.
In order to process the CHUNK_TYPE_DONT_CARE properly, there is
a requirement to be able to 'reserve' a specified number of blocks
in the storage media. Because of the special handling of "bad blocks"
in NAND devices, this is implemented in a storage abstraction function.
Signed-off-by: Steve Rae <srae@broadcom.com>
Reviewed-by: Maxime Ripard <maxime.ripard@free-electrons.com>
- update fastboot_okay() and fastboot_fail()
This file originally came from upstream code.
While retaining the storage abstraction feature, this is the second
set of the changes required to resync with the
cmd_flash_mmc_sparse_img()
in the file
aboot.c
from
https://us.codeaurora.org/cgit/quic/la/kernel/lk/plain/app/aboot/aboot.c?h=LE.BR.1.2.1
While retaining the storage abstraction feature, this is the first
in the file
aboot.c
from
This "session-id" alogrithm is not required, and currently corrupts
the stored image whenever more the one "session" is required.
add DM and DTS support for the at91 based siemens
boards.
Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
[rebased on current ToT]
Signed-off-by: Andreas Bießmann <andreas@biessmann.org>
[rebase on current ToT, don't delete gurnard DTB creation]
The SPL code already knows which boot device it calls the spl_boot_mode()
on, so pass that information into the function. This allows the code of
spl_boot_mode() avoid invoking spl_boot_device() again, but it also lets
board_boot_order() correctly alter the behavior of the boot process.
The later one is important, since in certain cases, it is desired that
spl_boot_device() return value be overriden using board_boot_order().
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
[add newly introduced zynq variant]
Signed-aff-by: Andreas Bießmann <andreas@biessmann.org>
The distro script is supposed to use the internal fdt as fallback if we
find no viable other option. However, we're missing a space key to actually
make that work.
Add the space, so we can successfully load an EFI blob even when there is
no device tree provided on the target device.
Rename B&R kwb board to brxre1
Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
Rename B&R tseries board to brppt1
The Kona PHY supports an 8-bit wide UTMI interface,
therefore, choose this Kconfig setting.
I still see some defines of this config in board headers. Move them
to defconfigs (+ renaming to CONFIG_HUSH_PARSER) to complete this
migration.
If CONFIG_ENV_VARS_UBOOT_CONFIG is enabled (it is by distro), this
code causes build error for boards without CONFIG_SYS_{CPU,_BOARD}.
