FIT images require MD5 support to verify image checksums. So far this
was expressed by defining a CPP symbol in image.h. Since MD5 is now a
first class Kconfig citizen, express that in Kconfig instead.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Xilinx changes for v2017.05
- Move to DM clk driver
- Add clk support for zynq_sdhci
ISEE's U-Boot and Linux are using 1bit ECC scheme, while we
switched to 8bit ECC to fullfill flash specification requirements.
However when trying to run U-Boot on board with 1bit ECC'd data
on flash, UBI code takes several minutes to pass scan as reading
of every block ends with ecc error (which is also printed on
console).
So, until proper solution is developed, disable environment
alltogether.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
This is a 96Board compliant board based on STiH410 SoC:
- 1GB DDR
- On-Board USB combo WiFi/Bluetooth RTL8723BU
with PCB soldered antenna
- Ethernet 1000-BaseT
- SATA
- HDMI
- 2 x USB2.0 type A
- 1 x USB2.0 type micro-AB
- SD card slot
- High speed connector (SD/I2C/USB interfaces)
- Low speed connector (UART/I2C/GPIO/SPI/PCM interfaces)
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
This device tree has been extracted from v4.9 kernel
Raw uboot image is used in place of FIT image in secure boot.
The maximum allocated size of raw u-boot bin is 1MB in memory map.
Hence , CONFIG_SYS_MONITOR_LEN has been modified to 1 MB.
The bootscript (BS_ADDR) and its header (BS_HDR_ADDR) offset on
MMC have also been modified to accommodate the increase in uboot size.
Signed-off-by: Vinitha Pillai-B57223 <vinitha.pillai@nxp.com>
Reviewed-by: Sumit Garg <sumit.garg@nxp.com>
Reviewed-by: Ruchika Gupta <ruchika.gupta@nxp.com>
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
Remove the DDR interactive debugging to reduce the size of spl image.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
Use Kconfig option instead of config macro in header file.
Signed-off-by: York Sun <york.sun@nxp.com>
Clean up existing usage.
This moves all of the current ARM errata from various header files and in to
Kconfig. This allows for a minor amount of cleanup as we had some instances
where both a general common header file was enabling errata as well as the
board config. We now just select these once at the higher level in Kconfig
In some cases this is absolutely required, so select this for some secure
features. This also requires migration of RSA_FREESCALE_EXP
Cc: Ruchika Gupta <ruchika.gupta@nxp.com>
Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Cc: Naveen Burmi <NaveenBurmi@freescale.com>
Cc: Po Liu <po.liu@freescale.com>
Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Cc: Priyanka Jain <Priyanka.Jain@freescale.com>
Cc: Sumit Garg <sumit.garg@nxp.com>
Cc: Shaohui Xie <Shaohui.Xie@freescale.com>
Cc: Chunhe Lan <Chunhe.Lan@freescale.com>
Cc: Feng Li <feng.li_2@nxp.com>
Cc: Alison Wang <alison.wang@freescale.com>
Cc: Mingkai Hu <Mingkai.Hu@freescale.com>
Cc: York Sun <york.sun@nxp.com>
Cc: Saksham Jain <saksham.jain@nxp.freescale.com>
Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
For the memory footprint reason, the Boot ROM can not load the ARM
Trusted Firmware BL1 directly when Trusted Board Boot is enabled.
The second stage loader is Socionext's own firmware, so rename it
for clarification.
Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
need to add before div in mmc update scripts. Otherwise we could
write one block more ba acident
there was a double bracketed var ref. fix this.
Playing with USB-to-Ethernet dongles it turns out,
that these will not work with special settings
depending on the use case different CMA sizes are
needed for linux. Add env var to enable passing CMA size
via kernel command line
The fdt_addr and ramdisk_addr_r are currently both defined to
0x83000000 and that's not going to work well for anyone. Move
the ramdisk_addr_r to 0x84000000.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Standard boot processes including distro boot generally expect the
default console to be defined.
Tested-by: Breno Lima <breno.lima@nxp.com>
This is no longer used anywhere.
Added SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION and
SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION to Kconfig.
Due to SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION being moved to
Kconfig the board defconfigs for db-88f6820-gp_defconfig
kc1_defconfig and sniper_defconfig need to be updated.
Signed-off-by: Dalon Westergreen <dwesterg@gmail.com>
the socfpga bootrom supports mmc booting from either a raw image
starting at 0x0, or from a partition of type 0xa2. This patch
adds support for locating the boot image in the first type 0xa2
partition found.
Assigned a partition number of -1 will cause a search for a
partition of type CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION_TYPE
and use it to find the u-boot image
Move the zynq to clock framework and remove unused functions as well as
the CONFIG_ZYNQ_PS_CLK_FREQ configuration.
Signed-off-by: Stefan Herbrechtsmeier <stefan.herbrechtsmeier@weidmueller.com>
Xilinx fixes for v2017.03
- defconfig alignment
- Topic.nl board updates
- Minor microblaze comment fix
We repeated partial moves for CONFIG_SYS_NO_FLASH, but this is
not completed. Finish this work by the tool.
During this move, let's rename it to CONFIG_MTD_NOR_FLASH.
Actually, we have more instances of "#ifndef CONFIG_SYS_NO_FLASH"
than those of "#ifdef CONFIG_SYS_NO_FLASH". Flipping the logic will
make the code more readable. Besides, negative meaning symbols do
not fit in obj-$(CONFIG_...) style Makefiles.
This commit was created as follows:
[1] Edit "default n" to "default y" in the config entry in
common/Kconfig.
[2] Run "tools/moveconfig.py -y -r HEAD SYS_NO_FLASH"
[3] Rename the instances in defconfigs by the following:
find . -path './configs/*_defconfig' | xargs sed -i \
-e '/CONFIG_SYS_NO_FLASH=y/d' \
-e 's/# CONFIG_SYS_NO_FLASH is not set/CONFIG_MTD_NOR_FLASH=y/'
[4] Change the conditionals by the following:
find . -name '*.[ch]' | xargs sed -i \
-e 's/ifndef CONFIG_SYS_NO_FLASH/ifdef CONFIG_MTD_NOR_FLASH/' \
-e 's/ifdef CONFIG_SYS_NO_FLASH/ifndef CONFIG_MTD_NOR_FLASH/' \
-e 's/!defined(CONFIG_SYS_NO_FLASH)/defined(CONFIG_MTD_NOR_FLASH)/' \
-e 's/defined(CONFIG_SYS_NO_FLASH)/!defined(CONFIG_MTD_NOR_FLASH)/'
[5] Modify the following manually
- Rename the rest of instances
- Remove the description from README
- Create the new Kconfig entry in drivers/mtd/Kconfig
- Remove the old Kconfig entry from common/Kconfig
- Remove the garbage comments from include/configs/*.h
The kernel partition in QSPI is 0x440000 large, not 0x400000. Fix this
in the environment, otherwise the kernel will fail to boot if it occupies
more space.
Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl>
Miniarm is the internal project code. Now it is officially named Tinker board.
So rename it.
Signed-off-by: Eddie Cai <eddie.cai@rock-chips.com>
Keep it same with other boards otherwise i have to write special script for it..
Signed-off-by: Jacob Chen <jacob2.chen@rock-chips.com>
To reduce redundant code.
Signed-off-by: John Haechten <john.haechten@microsemi.com>
Albeit it's a typo, neither CONGIG_CMD_STORAGE nor CONFIG_CMD_STORAGE
are used anywhere, so remove the define from the board configs.
Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
CONFIG_CMD_ZIP is not defined by any board. I am moving
CONFIG_CMD_UNZIP to defconfig files except UniPhier SoC family.
I am the maintainer of UniPhier platform, so I know "select CMD_UNZIP"
is better for this platform.
Acked-by: Michal Simek <michal.simek@xilinx.com>
Acked-by: Ryan Harkin <ryan.harkin@linaro.org>
Tested-by: Ryan Harkin <ryan.harkin@linaro.org>
CONFIG_SPL_STACK_SIZE is not a config option, so rename it.
Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com>
Now that we have a Kconfig for the API, convert the two boards that
are using this to Kconfig and remove CONFIG_API from the whitelist.
Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com>
The previous commit ("add a new command to show .config contents")
improves the basic infrastructure of "embed a compressed file into
the U-Boot image, and print it by a command". The same pattern for
the "license" command.
This commit reworks the command to improve the following:
[1] Improve log style
Kbuild style log
GZIP cmd/license_data.gz
CHK cmd/license_data_gz.h
UPD cmd/license_data_gz.h
CHK cmd/license_data_size.h
UPD cmd/license_data_size.h
instead of the bare Make log:
cat ./Licenses/gpl-2.0.txt | gzip -9 -c | \
tools/bin2header license_gzip > ./include/license.h
[2] Collect related code into the "cmd" directory
Prior to this commit, the license.h was created by tools/Makefile,
placed under the "include" directory, included from cmd/license.c,
and deleted by the top-level Makefile. It is not a good idea to
scatter related code.
[3] Drop the fixed-malloc size LICENSE_MAX
Just allocate the minimum required size of buffer because we know
the size of the original gpl-2.0.txt.
[4] Fix more issues
Terminate the buffer with zero to prevent puts() from over-running.
Add "static" to do_license.
At present devices use a simple integer offset to record the device tree
node associated with the device. In preparation for supporting a live
device tree, which uses a node pointer instead, refactor existing code to
access this field through an inline function.
This patch enables crc8 to be used from within the tools directory using
u-boot/crc.h.
Signed-off-by: Olliver Schinagl <o.schinagl@ultimaker.com>
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
Signed-off-by: Olliver Schinagl <oliver@schinagl.nl>
There are various places where the ethernet device name is defined to
several different sizes. Lets add a define and start using it.
In u-boot printf has been extended with the %pM formatter to allow
printing of MAC addresses. However buffers that want to store a MAC
address cannot safely get the size. Add a define for this case so the
string of a MAC address can be reliably obtained.
Commit 674bb249825a ("net: cosmetic: Replace magic numbers in arp.c with
constants") introduced a nice define to replace the magic value 6 for
the ethernet hardware address. Replace more hardcoded instances of 6
which really reference the ARP_HLEN (iow the MAC/Hardware/Ethernet
address).
If SPL is used we want to use the generic SPL framework and boot
from SPI via a board-specific means. Add these options to the
board config file.
If SPL is used we want to use the generic SPL framework and boot from SPI
via a board-specific means. Add these options to the board config file.
We should use unsigned long rather than u32 for addresses. Update this so
that the table-generation code builds correctly on 64-bit machines.
configs/ls1046aqds_defconfig
configs/ls1046aqds_nand_defconfig
configs/ls1046aqds_qspi_defconfig
configs/ls1046aqds_sdcard_ifc_defconfig
configs/ls1046aqds_sdcard_qspi_defconfig
configs/ls1046ardb_emmc_defconfig
configs/ls1046ardb_qspi_defconfig
configs/ls1046ardb_sdcard_defconfig
