path: root/include
2017-01-04move UL() macro from armv8/mmu.h into common.hAndre Przywara
The UL() macro is pretty useful in sharing constants between assembly and C files while still being able to specify a type for C. Move the macro from an armv8 specific header into a common header file to be able to use it by arm code (for instance) as well. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Alexander Graf <agraf@suse.de> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-01-04armv8: prevent using THUMBAndre Przywara
The predominantely 32-bit ARM targets try to compile the SPL in Thumb mode to reduce code size. The 64-bit AArch64 instruction set does not know an alternative, concise encoding, so the Thumb build option should only be set for 32-bit targets. Likewise -marm machine options are only valid for ARMv7 targets. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-01-02Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2017-01-02configs: engicam: Add fitboot env supportJagan Teki
Add FIT image booting from MMC device, during MMC bootcmd u-boot env script look for bootscript, else fit image or else finally look for legacy image uImage. Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-01-02configs: engicam: Cleanup on mmcboot envJagan Teki
- Add tab space - remove exctra 'mmc dev ${mmcdev}' Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-01-02configs: engicam: Enable CONFIG_IMAGE_FORMAT_LEGACYJagan Teki
Enabling FIT along with Signature will make bootm to not-understanding u-boot legacy image formats like uImage, etc. So this patch enabling legacy image format for backward compatibility. Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-01-02defconfigs: imx6: engicam: Enable FITJagan Teki
Enable Flattened Image Tree support for all Engicam boards. Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-01-02imx6: engicam: Add nandboot env supportJagan Teki
Add config options for booting Linux from NAND in UBI format. Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-01-02defconfigs: engicam: Enable UBI commandsJagan Teki
Create ubifs.img: $ mkfs.ubifs -q -r /rootfs -m 4096 -e 253952 -c 7936 -o ubifs.img Write ubifs.img: --------------- icorem6qdl> nand erase.part rootfs icorem6qdl> ubi part rootfs icorem6qdl> ubi create rootfs icorem6qdl> ext4load mmc 0:2 ${loadaddr} ubifs.img 166592512 bytes read in 8091 ms (19.6 MiB/s) icorem6qdl> ubi write ${loadaddr} rootfs ${filesize} 166592512 bytes written to volume rootfs icorem6qdl> ubifsmount ubi0:rootfs Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-01-02configs: engicam: Rename nand with gpmi-name in mtdpartsJagan Teki
gpmi-nand is the proper name used in nand driver from Linux for all imx related nand boards, so rename mtdparts name as gpmi-nand instead of nand, this will eventually reflects all nand info to Linux from u-boot like mtdparts. Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-01-02imx6: engicam: Use bootm instead of bootzJagan Teki
Boot Linux with uImage instead of zImage, so update bootz with bootm. Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-01-02configs: engicam: Increase nand kernel partition sizeJagan Teki
Increase the nand kernel partition size, for supporting large uImage files, maximum 8MiB. Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-01-02arm: am57xx: cl-som-am57x: update default envUri Mashiach
Modify U-Boot default env settings. Boot sequence: 1. SD card boot script 2. SD card boot no script 3. SATA boot script 4. SATA boot no script 5. eMMC boot script 6. eMMC boot no script Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-02arm: am57xx: cl-som-am57x: add ETH supportDmitry Lifshitz
Add MAC support. Use PHY, connected to RGMII1 as a default Eth adapter, by appropriate setting of 'cpsw_data.active_slave'. 'cpsw_phy' env variable can override this setting. Set the MAC addresses in the U-Boot environment. The addresses are retrieved from the on-board EEPROM or from the SOC's MAC fuses. Set the following PHYs RGMII clock delays: - Enable RX delay - Disable TX delay Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> [uri.mashiach@compulab.co.il: add RGMII clock delays] Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-02arm: am57xx: cl-som-am57x: fetch board rev from EEPROMDmitry Lifshitz
Add PCB revision message. Implement board revision get_board_rev API. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Commit description update. Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-02arm: am57xx: cl-som-am57x: add initial board supportDmitry Lifshitz
Features supported : * Serial console * SPI Flash * MMC/SD Card * eMMC storage * SATA * PCA9555 - GPIO expander over I2C5 bus * USB Use spl alternate boot device feature to define fallback to the main boot device as it is defined by hardware. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> [uri.mashiach@compulab.co.il: Adjust to v2016.11] Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2017-01-02OMAP3: omap3_logic: Remove display parameterAdam Ford
The display is done in the device tree now, and there is no need to pass 'display' kernel parameter any longer. Signed-off-by: Adam Ford <aford173@gmail.com>
2017-01-02ARM: OMAP3_LOGIC: Remove ONENAND config optionsAdam Ford
These boards do not and never have had ONENAND support, so let's remove it. Signed-off-by: Adam Ford <aford173@gmail.com>
2017-01-02ARM: imx7s-warp: enable USB gadget ethernetKevin Hilman
Enable USB gadget ethernet by default to have networking capabilities. Tested using DHCP and TFTP to transfer kernel, DT, ramdisk. Cc: Fabio Estevam <festevam@gmail.com> Signed-off-by: Kevin Hilman <khilman@baylibre.com>
2017-01-02udoo_neo: Use 'fdtfile' variable nameFabio Estevam
'fdtfile' is the preferred name for the variable that contains the device tree blob according to the README file. It also makes it consistent with other i.MX boards that use config_distro, so change it accordingly. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-01-02tools: mkimage: add firmware-ivt image type for HAB verificationSven Ebenfeld
When we want to use Secure Boot with HAB from SPL over U-Boot.img, we need to append the IVT to the image and leave space for the CSF. Images generated as firmware_ivt can directly be signed using the Freescale code signing tool. For creation of a CSF, mkimage outputs the correct HAB Blocks for the image. The changes to the usual firmware image class are quite small, that is why I implemented that directly into the default_image. Cc: sbabic@denx.de v2-Changes: None Signed-off-by: Sven Ebenfeld <sven.ebenfeld@gmail.com> Reviewed-by: George McCollister <george.mccollister@gmail.com> Tested-by: George McCollister <george.mccollister@gmail.com>
2017-01-02arm: imx: add HAB authentication of image to SPL bootSven Ebenfeld
When using HAB as secure boot mechanism on Wandboard, the chain of trust breaks immediately after the SPL. As this is not checking the authenticity of the loaded image before jumping to it. The HAB status output will not be implemented in SPL as it adds a lot of strings that are only required in debug cases. With those it exceeds the maximum size of the available OCRAM (69 KiB). The SPL MISC driver support must be enabled, so that the driver can use OTP fuse to check if HAB is enabled. Cc: sbabic@denx.de v2-Changes: None Signed-off-by: Sven Ebenfeld <sven.ebenfeld@gmail.com> Reviewed-by: George McCollister <george.mccollister@gmail.com> Tested-by: George McCollister <george.mccollister@gmail.com>
2016-12-29mmc: move MMC_SDHCI_IO_ACCESSORS to KconfigMasahiro Yamada
This is a user-unconfigurable option that is selected by the drivers that need to overwrite SDHCI IO memory accessors. (BCM2835 SDHCI seems the only driver that needs to do so.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-29mmc: move some SDHCI related options to KconfigMasahiro Yamada
While I moved the options, I also renamed them so that they are all prefixed with MMC_SDHCI_. This commit was created in the following steps. [1] Rename with the following command find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_MMC_SDMA/CONFIG_MMC_SDHCI_SDMA/g s/CONFIG_BCM2835_SDHCI/CONFIG_MMC_SDHCI_BCM2835/g s/CONFIG_KONA_SDHCI/CONFIG_MMC_SDHCI_KONA/g s/CONFIG_MV_SDHCI/CONFIG_MMC_SDHCI_MV/g s/CONFIG_S5P_SDHCI/CONFIG_MMC_SDHCI_S5P/g s/CONFIG_SPEAR_SDHCI/CONFIG_MMC_SDHCI_SPEAR/g ' [2] create the Kconfig entries in drivers/mmc/Kconfig [3] Move the options by the following command tools/moveconfig.py -y MMC_SDHCI_SDMA MMC_SDHCI_BCM2835 \ MMC_SDHCI_KONA MMC_SDHCI_MV MMC_SDHCI_S5P MMC_SDHCI_SPEAR [4] Sort drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-29mmc: move CONFIG_SDHCI to Kconfig, renaming to CONFIG_MMC_SDHCIMasahiro Yamada
Move CONFIG_SDHCI to Kconfig and rename it to CONFIG_MMC_SDHCI. My motivation for the rename is, ultimately, to make all the MMC options prefixed with MMC_ and SDHCI options with MMC_SDHCI_, like Linux. This commit was created as follows: [1] Rename the config option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_SDHCI/CONFIG_MMC_SDHCI/g' [2] create the entry for MMC_SDHCI in drivers/mmc/Kconfig [3] run "tools/moveconfig.py -y MMC_SDHCI" [4] add "depends on MMC_SDHCI" to existing SDHCI driver entries Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-27Update Maintainer and Author's email addressAjay Bhargav
I am not longer using my old email address "ajay.bhargav@einfochips.com". For U-Boot development email address is now updated to contact@8051projects.net Signed-off-by: Ajay Bhargav <contact@8051projects.net>
2016-12-23Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
2016-12-21spi: Zap armada100_spi.c and envJagan Teki
armada100_spi.c and related env is zapping becuase of "no DM conversion". Cc: Ajay Bhargav <ajay.bhargav@einfochips.com> Signed-off-by: Jagan Teki <jagan@openedev.com>
2016-12-21spi: Zap mpc52xx_spi.c, config and related codeJagan Teki
armada100_spi.c, related config options and related codes are zapping becuase of "no DM conversion". Cc: Werner Pfister <Pfister_Werner@intercontrol.de> Signed-off-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-12-20fdt: add memory bank decoding functions for board setupNathan Rossi
Add two functions for use by board implementations to decode the memory banks of the /memory node so as to populate the global data with ram_size and board info for memory banks. The fdtdec_setup_memory_size() function decodes the first memory bank and sets up the gd->ram_size with the size of the memory bank. This function should be called from the boards dram_init(). The fdtdec_setup_memory_banksize() function decode the memory banks (up to the CONFIG_NR_DRAM_BANKS) and populates the base address and size into the gd->bd->bi_dram array of banks. This function should be called from the boards dram_init_banksize(). Signed-off-by: Nathan Rossi <nathan@nathanrossi.com> Cc: Simon Glass <sjg@chromium.org> Cc: Michal Simek <monstr@monstr.eu> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-12-20block: Move ceva driver to DMMichal Simek
This patch also includes ARM64 zynqmp changes: - Remove platform non DM initialization - Remove hardcoded sata base address Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-20dm: Add support for scsi/sata based devicesMichal Simek
All sata based drivers are bind and corresponding block device is created. Based on this find_scsi_device() is able to get back block device based on scsi_curr_dev pointer. intr_scsi() is commented now but it can be replaced by calling find_scsi_device() and scsi_scan(). scsi_dev_desc[] is commented out but common/scsi.c heavily depends on it. That's why CONFIG_SYS_SCSI_MAX_DEVICE is hardcoded to 1 and symbol is reassigned to a block description allocated by uclass. There is only one block description by device now but it doesn't need to be correct when more devices are present. scsi_bind() ensures corresponding block device creation. uclass post_probe (scsi_post_probe()) is doing low level init. SCSI/SATA DM based drivers requires to have 64bit base address as the first entry in platform data structure to setup mmio_base. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-20common: miiphyutil: Add helper function for mdio bus nameMichal Simek
The most of ethernet drivers are using this mdio registration sequence. strcpy(priv->bus->name, "emac"); mdio_register(priv->bus); Where driver can be used only with one MDIO bus because only unique name should be used. Other drivers are using unique device name for MDIO registration to support multiple instances. snprintf(priv->bus->name, sizeof(bus->name), "%s", name); With DM dev->seq is used more even in logs (like random MAC address generation: printf("\nWarning: %s (eth%d) using random MAC address - %pM\n", dev->name, dev->seq, pdata->enetaddr); ) where eth%d prefix is used. Simplify driver code to register mdio device with dev->seq number to simplify mdio registration and reduce code duplication across all drivers. With DM_SEQ_ALIAS enabled dev->seq reflects alias setting. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-19serial: 16550: Add Ingenic JZ4780 supportMarek Vasut
Add compatibility string for the Ingenic JZ4780 SoC, the necessary UART enable bit into FCR and register shift. Neither are encoded in the DTS coming from Linux, so we need to support it this way. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: Paul Burton <paul.burton@imgtec.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-19serial: 16550: Add getfcr accessorMarek Vasut
Add function which allows fetching the default FCR register setting from platform data for DM , while retaining old behavior for non-DM by returning UART_FCRVAL. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-18Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
Migrate CONFIG_ARCH_USE_MEMSET/MEMCPY with this merge. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-16Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2016-12-16imx6: icorem6_rqs: Add FEC supportJagan Teki
Add FEC support for Engicam i.CoreM6 RQS modules. Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-12-16imx6: geam6ul: Add FEC supportJagan Teki
Add FEC support for Engicam GEAM6UL module. Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-12-16arm: imx6q: Add Engicam i.CoreM6 Quad/Dual RQS Starter Kit initial supportJagan Teki
Boot from MMC: ------------- U-Boot SPL 2016.11-rc2-g217bd8e-dirty (Nov 08 2016 - 22:59:44) Trying to boot from MMC1 U-Boot 2016.11-rc2-g217bd8e-dirty (Nov 08 2016 - 22:59:44 +0530) CPU: Freescale i.MX6D rev1.2 at 792 MHz Reset cause: POR Model: Engicam i.CoreM6 Quad/Dual RQS Starter Kit DRAM: 512 MiB MMC: FSL_SDHC: 0 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: CPU Net Initialization Failed No ethernet found. Hit any key to stop autoboot: 0 icorem6qdl-rqs> Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-12-16imx6: geam6ul: Add default mtd nand partition tableJagan Teki
geam6ul> mtdparts device nand0 <nand>, # parts = 6 0: spl 0x00200000 0x00000000 0 1: uboot 0x00200000 0x00200000 0 2: env 0x00100000 0x00400000 0 3: kernel 0x00400000 0x00500000 0 4: dtb 0x00100000 0x00900000 0 5: rootfs 0x1f600000 0x00a00000 0 Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-12-16imx6: geam6ul: Enable MTD device supportJagan Teki
Enable MTD device, partition and command support. Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-12-16imx6: geam6ul: Add NAND supportJagan Teki
Add NAND support for Engicam GEAM6UL board. Boot Log: -------- U-Boot SPL 2016.11-g537fa5f (Nov 28 2016 - 11:42:28) Trying to boot from NAND NAND : 256 MiB U-Boot 2016.11-g537fa5f (Nov 28 2016 - 11:20:06 +0100) CPU: Freescale i.MX6UL rev1.1 69 MHz (running at 396 MHz) CPU: Automotive temperature grade (-40C to 125C) at 42C Reset cause: WDOG Model: Engicam GEAM6UL DRAM: 128 MiB NAND: 256 MiB MMC: FSL_SDHC: 0 * Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: No ethernet found. Hit any key to stop autoboot: 0 Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-12-16arm: imx6ul: Add Engicam GEAM6UL Starter Kit initial supportJagan Teki
Boot Log: -------- U-Boot SPL 2016.11-rc2-00144-g922adaa-dirty (Oct 28 2016 - 18:55:30) Trying to boot from MMC1 U-Boot 2016.11-rc2-00144-g922adaa-dirty (Oct 28 2016 - 18:55:30 +0530) CPU: Freescale i.MX6UL rev1.1 528 MHz (running at 396 MHz) CPU: Industrial temperature grade (-40C to 105C) at 43C Reset cause: POR Model: Engicam GEAM6UL DRAM: 128 MiB MMC: FSL_SDHC: 0 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: CPU Net Initialization Failed No ethernet found. Hit any key to stop autoboot: 0 geam6ul> Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-12-16arm: dts: Add devicetree for i.MX6ULJagan Teki
Add i.MX6UL dtsi support from Linux. Here is the last commit: "ARM: dts: add gpio-ranges property to iMX GPIO controllers" (sha1: bb728d662bed0fe91b152550e640cb3f6caa972c) Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-12-16imx6: icorem6: Add custom splashscreen supportJagan Teki
Add custom splashscreen, engicam.bmp support for Engicam i.CoreM6 qdl board. Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-12-16imx6: icorem6: Add framebuffer supportJagan Teki
Add IPUv3 framebuffer support for Engicam i.CoreM6 qdl board. Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-12-16Kconfig: Move USE_ARCH_MEMCPY/MEMSET to KconfigFabio Estevam
Move USE_ARCH_MEMCPY/MEMSET options to Kconfig. Make it "default y" for the ARMv7 architecture and make it depend on !ARM64 && !SPL. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-12-16arm: imx: add i.MX53 Beckhoff CX9020 Embedded PCPatrick Bruenn
Add CX9020 board based on mx53loco. Add simplified imx53 base device tree from kernel v4.8-rc8, to reuse serial_mxc with DTE and prepare for device tree migration of other functions and imx53 devices. The CX9020 differs from i.MX53 Quick Start Board by: - use uart2 instead of uart1 - DVI-D connector instead of VGA - no audio - CCAT FPGA connected to emi - enable rtc Signed-off-by: Patrick Bruenn <p.bruenn@beckhoff.com>
