Create a Kconfig entry for DISPLAY_CPUINFO and make it be the default
in certain architectures. Migrate all config files.
Boards where ECs that use a I2C port != 0 specify this in the
devicetree file via the google,remote-bus property.
Previously this was ignored and hardcoded to port 0.
Signed-off-by: Moritz Fischer <moritz.fischer@ettus.com>
Cc: u-boot@lists.denx.de
The SPL size for dra7x platform increased beyond 64K,
increasing the size to 256K to cater for future enhancement.
Signed-off-by: Ravi Babu <ravibabu@ti.com>
removing CONFIG_SPL_ENV_SUPPORT defined in header files
due to moved to kconfig option for CONFIG_SPL_ENV_SUPPORT
This reverts commit 82f5279b0cd99a9163d34cfe926d0316d9dc0d37.
The build failure of k2*evm boards was fixed in a different way by
the previous commit. It is nasty to patch generic drivers around
with #ifdef CONFIG_CLK just for the KeyStone's matter.
The KeyStone platform has its own clk_get_rate() but its prototype
is different from that of the common-clk (clk-uclass) framework.
Prefix the KeyStone specific implementation with ks_ in order to
avoid name-space conflict.
Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
Due to clock source restrictions on i.MX6, certain pixel clock rates can
not be supported. Hence default the resolution/frame rate during boot to a
supported value by passing video bootargs 1024x768@60 for
HDMI (Display Port1) and LVDS (Display Port2) on B850v3.
Signed-off-by: Ken Lin <ken.lin@advantech.com.tw>
Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com>
Now that fastboot options are available in Kconfig, we can migrate them
from DRA7 header to corresponding DRA7 defconfigs.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Add device model enabled PMIC driver for Ricoh RN5T567 PMIC used
on Colibri iMX7.
Remove legancy I2C config and code in favor of upcomming DM/DT
enable I2C support.
Tweaks (no functional changes) to include/search.h, including:
* use standard multiple inclusion check
* fix spelling mistakes
* have comments match actual names in function prototypes
* remove obsolete reference to "do_apply"
* replace "hashing table" with "hash table"
Fix various misspellings of:
* deprecated
* partition
* preceding,preceded
* preparation
* its versus it's
* export
* existing
* scenario
* redundant
* remaining
* value
* architecture
Reviewed-by: Jagan Teki <jteki@openedev.com>
Drop a few that are not used in U-Boot.
Reviewed-by: York Sun <york.sun@nxp.com>
There is no need for this to be in the BSS region. By moving it we can delay
use of BSS in SPL. This is useful for machines where the BSS region is not
in writeable space. On 64-bit x86, SPL runs from SPI flash and it is easier
to eliminate BSS use than link SPL to run with BSS at a particular
cache-as-RAM (CAR) address.
Upda the SPL FIT code to use the spl_image parameter.
Update the fat loader to avoid using the spl_image global variable.
Update the ext loader to avoid using the spl_image global variable.
Rather than having a global variable, pass the spl_image as a parameter.
This avoids BSS use, and makes it clearer what the function is actually
doing.
Add a linker list declaration for this method and remove the explicit
switch() code. Update existing users.
switch() code. We need two variants - one for BOOT_DEVICE_CPGMAC and one for
BOOT_DEVICE_USBETH.
At present there are two SPI functions only used by freescale which are
defined in the spi_flash.h header. One function name matches an existing
generic SPL function.
Move these into a private header to avoid confusion.
Arcturus looks like it does not actually support SPI, so drop the SPI code
from that board.
switch() code. Also set up the sunxi function.
switch() code.
switch() code.
switch() code.
switch() code.
switch() code.
switch() code.
switch() code.
switch() code.
Add a linker list macro which can be used to declare an SPL image loader.
Update spl_load_image() to search available loaders for the correct one.
At present some spl_xxx_load_image() functions take a parameter and some
don't. Of those that do, most take an integer but one takes a string.
Convert this parameter into a struct so that we can pass all functions the
same thing. This will allow us to use a common function signature.
Move this option to Kconfig and tidy up existing uses. Also add a function
comment to the header file.
Add some comments to describe this function.
Instead of using the global spl_image variable, pass the required struct in
as an argument.
as an argument.
Rather than act on the global variable, pass the required struct in as a
parameter.
At present this is only used on ARM and sandbox, but it is just as
applicable to other architectures. Move the function prototype into the
generic SPL header.
Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
PCM052 SoMs may be equipped with various sizes of DDR.
Keep default of 256MB; new PCM052-based targets will
specify their actual DDR size.
Linux command line is auto-adjusted to DDR size.
This format can be flashed directly at address 0 of
the NAND FLASH, as it contains all necessary headers.
Merge 'spare' into 'bootloader' partition
Use same partition for ramdisk and rootfs boot scenarios.
Remove 'ramdisk' partition, use 'rootfs' for ramdisk
(ramdisk and nand boot scenarios are mutually exclusive).
Expand last partition to end of actual NAND size.
Adjust UBIFS rootfs boot kernel arguments.
Add i.MX6ULL EVK board support:
Add device tree file, which is copied from NXP Linux.
Enabled DM_MMC, DM_GPIO, DM_I2C, DM_SPI, PINCTRL, DM_REGULATOR.
The uart iomux settings are still keeped in board file.
Boot Log:
U-Boot 2016.09-rc1-00366-gbb419ef-dirty (Aug 11 2016 - 13:08:58 +0800)
CPU: Freescale i.MX6ULL rev1.0 at 396MHz
CPU: Commercial temperature grade (0C to 95C) at 15C
Reset cause: POR
Model: Freescale i.MX6 ULL 14x14 EVK Board
Board: MX6ULL 14x14 EVK
DRAM: 512 MiB
MMC: initialized IMX pinctrl driver
FSL_SDHC: 0, FSL_SDHC: 1
In: serial
Out: serial
Err: serial
Net: CPU Net Initialization Failed
No ethernet found.
Hit any key to stop autoboot: 0
=> mmc dev 1
switch to partitions #0, OK
mmc1 is current device
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Add i.mx6ul clock header, copied from kernel commit (29b4817d401).
i.MX6ULL reuse the file in Linux Kernel, so let's keep the same.
There is no stable mmcblk device numbering over different linux versions.
Enable CMD_PART to be able to query the UUID of the root filesystem partition.
So we can pass root=PARTUUID=XXX instead of root=/dev/mmcblkXpY in bootargs.
Leave the default environment as is for now to stay compatible with original
TBS settings.
Signed-off-by: Soeren Moch <smoch@web.de>
Currently the driver asserts WDOG_B by clearing WCR_WDA bit when
enabling the watchdog. Do not clear WCR_WDA.
Signed-off-by: Ross Parker <rossjparker@gmail.com>
The linux kernel imx_v6_v7_defconfig sets the user/kernel memory split
to 3G/1G now (was 2G/2G before). We have to adapt the BOOTMAPSZ so that
the decompressor finds zImage and dtb in lowmem.
The videoargs script is kernel version dependent and since wandboard
uses distro config, there is no need to handle videoargs locally.
In case such video related settings are needed, then the proper
location would be the distro extlinux.conf or boot.scr files.
So remove 'videoargs' script.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
