path: root/include
2019-06-20Merge https://gitlab.denx.de/u-boot/custodians/u-boot-mpc85xxTom Rini
- PCIe driver change to support DM model - T2080QDS migrated to use PCIe DM model
2019-06-20powerpc: T208xQDS: Disable legacy PCIe driver when DM_PCI is enabledHou Zhiqiang
Disable legacy PCIe driver and unused PCIe macros when DM_PCI enabled. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-20powerpc: mpc85xx: Move CONFIG_FSL_PCIE_RESET to KconfigHou Zhiqiang
Use the Kconfig option to select the PCIe reset errata. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-19Merge https://gitlab.denx.de/u-boot/custodians/u-boot-fsl-qoriqTom Rini
- LS1046AFRWY support - USB errata fix and secure boot defconfig support for LS1028A - Enabled SDHC and SATA for LX2160 - LS1046A serdes fixes - other minor fixes
2019-06-19armv8: ls1046afrwy: Add support for LS1046AFRWY platformVabhav Sharma
LS1046AFRWY board supports LS1046A family SoCs. This patch add base support for this board. Board support's 4GB ddr memory, i2c, micro-click module,microSD card, serial console,qspi nor flash,ifc nand flash,qsgmii network interface, usb 3.0 and serdes interface to support two x1gen3 pcie interface. Signed-off-by: Camelia Groza <camelia.groza@nxp.com> Signed-off-by: Madalin Bucur <madalin.bucur@nxp.com> Signed-off-by: Pankit Garg <pankit.garg@nxp.com> Signed-off-by: Pramod Kumar <pramod.kumar_1@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Signed-off-by: Vabhav Sharma <vabhav.sharma@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-19armv8: ls2088ardb: Fix MC firmware loading during SD bootWasim Khan
During SD boot, MC firmware and DPC are copied from SD card to DDR. Size reserved between MC and DPC firmware on DDR is 1MB. If the size of MC firmware(load address 0x80000000) is more than 1 MB then part of MC firmware will be overwritten by DPC firmware (load address 0x80100000). Fix: Update the MC/DPL/DPC firmware's DDR address as per their respective addresses in SD card. Signed-off-by: Wasim Khan <wasim.khan@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-19armv8: ls2088aqds: Fix MC firmware loading during SD bootWasim Khan
2019-06-19armv8: ls2088aqds: Add bootcmd for TFA bootWasim Khan
Add bootcmd for IFC NOR boot and SD boot. Signed-off-by: Wasim Khan <wasim.khan@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-19configs: Unset CONFIG_SPI_FLASH_BAR, move CONFIG_FSL_QSPI to defconfigAshish Kumar
Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-19ls1046ardb: Add CONFIG_ENV_ADDR to init env in qspi bootPankit Garg
Signed-off-by: Pankit Garg <pankit.garg@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-19armv8: ls1028a: Add secure boot defconfigYuantian Tang
Add secure boot defconfig for ls1028aqds and ls1028ardb boards. Signed-off-by: Yuantian Tang <andy.tang@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-19board: lx2160a: use default scan_dev_for_bootMian Yousaf Kaukab
Default environment variable is more complete. Also scans for efi binaries for example. Signed-off-by: Mian Yousaf Kaukab <ykaukab@suse.de> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-17Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
- Drop zipitz2 board (Tom) - Add DEPRECATED option (Tom) - Mark legacy or non-dm drivers as DEPRECATED (Jagan)
2019-06-17Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
- Assorted gadget fixes
2019-06-15Merge tag 'efi-2019-07-rc5-2' of git://git.denx.de/u-boot-efiTom Rini
Pull request for UEFI sub-system for v2019.07-rc5 (2) This pull request provides bug fixes for the UEFI sub-system. The most relevant one concerns the allocation of memory at address 0. It is needed for booting Linux on several boards via bootefi, e.g. the Asus TinkerBoard. An undefined reference bug in disk/part.c related to a division is resolved.
2019-06-15Merge branch 'master' of git://git.denx.de/u-boot-shTom Rini
- More board removal
2019-06-14cmd: define CMD_DATA_SIZE when CONFIG_CMD_SETEXPR is selectedBartosz Golaszewski
The setexpr shell command calls cmd_get_data_size() which is only built when CMD_DATA_SIZE is defined. We need to define CMD_DATA_SIZE if CONFIG_CMD_SETEXPR is selected or the build will fail if no other command selecting this option is enabled. Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
2019-06-14configs: Migrate CONFIG_SYS_LDSCRIPT to KconfigTom Rini
In order to migrate this symbol to Kconfig introduce a new symbol to guard it, CONFIG_SYS_CUSTOM_LDSCRIPT. When that is set we can then provide the exact final location o the script. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-06-14configs: Remove unneeded CONFIG_SYS_LDSCRIPT instancesTom Rini
A number of boards set CONFIG_SYS_LDSCRIPT and then end up using one of the default searched LDSCRIPT paths. Remove these customizations. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-06-14configs: Migrate the various SPL_BOOT_xxx choices for PowerPCTom Rini
The non-CONFIG_SPL_FRAMEWORK SPL used on some PowerPC platforms have a choice between CONFIG_SPL_NAND_BOOT, CONFIG_SPL_MMC_BOOT and CONFIG_SPL_SPI_BOOT. Migrate this to Kconfig Signed-off-by: Tom Rini <trini@konsulko.com>
2019-06-14net: Convert CONFIG_TFTP_BLOCKSIZE to KconfigMarek Vasut
Convert CONFIG_TFTP_BLOCKSIZE to Kconfig, update defconfigs, headers and whitelist. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Joe Hershberger <joe.hershberger@ni.com>
2019-06-14net: Convert CONFIG_IP_DEFRAG to KconfigMarek Vasut
Convert CONFIG_IP_DEFRAG to Kconfig, update defconfigs, headers and whitelist. This patch is a follow-up on a patch by Christian Gmeiner with the added config/header/whitelist updates. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Reported-by: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Joe Hershberger <joe.hershberger@ni.com>
2019-06-14efi_loader: add RuntimeServicesSupported variableAKASHI Takahiro
This variable is defined in UEFI specification 2.8, section 8.1. Its value should be updated whenever we add any usable runtime services function. Currently we only support SetVirtualAddress() for all systems and ResetSystem() for some. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-06-14sh: r0p7734: Remove the boardMarek Vasut
Last change to this board was done in 2016, has no prospects of ever being converted to DM, drop it. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Chris Brandt <chris.brandt@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Vladimir Zapolskiy <vz@mleia.com> Cc: Yoshihiro Shimoda <shimoda.yoshihiro.uh@renesas.com>
2019-06-14sh: ap325rxa: Remove the boardMarek Vasut
2019-06-14sh: ap_sh4a_4a: Remove the boardMarek Vasut
2019-06-14sh: ms7750se: Remove the boardMarek Vasut
2019-06-14sh: ms7722: Remove the boardMarek Vasut
2019-06-14sh: espt_giga: Remove the boardMarek Vasut
2019-06-14fastboot: Use const qualifier for char *part_nameSam Protsenko
In fastboot_*_get_part_info() functions we can use stronger typing by expecting const strings. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-06-13configs: Disable now unbuildable SPI options for boardsTom Rini
Now that various SPI related options depend on CONFIG_DEPRECATED, in order for platforms to build out of the box they need to disable various other options. Cc: Albert ARIBAUD <albert.aribaud@3adev.fr> Cc: Marek Vasut <marex@denx.de> Cc: Vladimir Zapolskiy <vz@mleia.com> Cc: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marek.vasut@gmail.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2019-06-13arm: Remove zipitz2 boardTom Rini
Per discussion on the list, drop this board again. Cc: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Vasily Khoruzhick <anarsoul@gmail.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2019-06-12Merge tag 'u-boot-amlogic-20190612' of git://git.denx.de/u-boot-amlogicTom Rini
- pinctrl: meson-gx: fix GPIO_TEST_N and GPIOCLK_ groups - pinctrl: meson-gxbb: add hdmi related pins to fix HDMI on GXBB - pinctrl: meson: add support for getting pinmux status - pinctrl: meson-g12a: add support for drive-strength-microamp property
2019-06-12Merge tag 'efi-2019-07-rc5' of git://git.denx.de/u-boot-efiTom Rini
Pull request for UEFI sub-system for v2019.07-rc5 This pull request provides fixes for event services.
2019-06-12dm: pinctrl: Add driver-strength-microamp propertyGuillaume La Roque
Add drive-strength-microamp property support to allow drive strength in uA Signed-off-by: Guillaume La Roque <glaroque@baylibre.com> Tested-by: Neil Armstrong <narmstrong@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-06-11Merge tag 'u-boot-stm32-20190606' of https://github.com/pchotard/u-bootTom Rini
- Add Ethernet support for STM32MP1 - Add saveenv support for STM32MP1 - Add STM32MP1 Avenger96 board support - Add SPI driver suport for STM32MP1 - Add watchdog support for STM32MP1 - Update power supply check via USB TYPE-C for STM32MP1 discovery board
2019-06-11Merge tag 'u-boot-imx-20190612' of git://git.denx.de/u-boot-imxTom Rini
u-boot-imx-20190612 -------------------- - Board fixes: - imx6logic - wandboard - mx6sabre boots again - imx8qm_mek - pico-* boards - Toradex apalis / colibri - engicam imx6 (environment) - KP MX53 - opos6ul - Switch to DM: - vining2000 - dh MX6 - Toradex colibri i.MX7 - Novena - Security : fix CSF size for HAB - Other: - imx: fix building for i.mx8 without spl - pcie and switch to DM mx6sabreauto: Enable SPL SDP support
2019-06-11ARM: imx: vining2000: Enable DM SerialMarek Vasut
Enable DM Serial support on iMX6SX VINING|2000. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Silvio Fricke <silvio.fricke@softing.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-11imx8qxp_mek: Remove unneeded config options settingsFabio Estevam
Remove such unneeded custom config options because the provided default values are good enough. Signed-off-by: Fabio Estevam <festevam@gmail.com> Acked-by: Peng Fan <peng.fan@nxp.com>
2019-06-11imx8qm_mek: Remove unneeded config options settingsFabio Estevam
2019-06-11imx: Extend PCL063 support for phyCORE-i.MX6ULL SOMParthiban Nallathambi
Extend PHYTEC phyBOARD-i.MX6UL for phyCORE-i.MX6UL SoM (PCL063) with eMMC on SoM. CPU: Freescale i.MX6ULL rev1.0 792 MHz (running at 396 MHz) CPU: Industrial temperature grade (-40C to 105C) at 38C Reset cause: POR Model: Phytec phyBOARD-i.MX6ULL-Segin SBC Board: PHYTEC phyCORE-i.MX6ULL DRAM: 256 MiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 In: serial@02020000 Out: serial@02020000 Err: serial@02020000 Net: FEC0 Working: - Eth0 - i2C - MMC/SD - eMMC - UART (1 & 5) - USB (host & otg) Signed-off-by: Parthiban Nallathambi <parthitce@gmail.com>
2019-06-11apalis-tk1: use UUID for rootfsIgor Opaniuk
1. Replace usage of "/dev/mmcblk*p*" with a proper UUID of rootfs partition. This fixes the issue, when MMC controllers are probed in a different order in U-boot and Linux kernel. 2. Fix legacy USB command (both sdboot and usbboot can be used now). Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-06-11apalis_imx6: use UUID for rootfsIgor Opaniuk
2019-06-11colibri_vf: use UUID for rootfsIgor Opaniuk
Replace usage of "/dev/mmcblk*p*" with a proper UUID of rootfs partition. This fixes the issue, when MMC controllers are probed in a different order in U-boot and Linux kernel. Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-06-11colibri-imx6ull: use UUID for rootfsIgor Opaniuk
2019-06-11colibri_imx7: use UUID for rootfsIgor Opaniuk
2019-06-11board: toradex: add apalis imx8qm 4gb wb it v1.0b module supportMarcel Ziswiler
This commit adds initial support for the Toradex Apalis iMX8QM 4GB WB IT V1.0B module. Unlike the V1.0A early access samples exclusively booting from SD card, they are now strapped to boot from eFuses which are factory fused to properly boot from their on-module eMMC. U-Boot supports either booting from the on-module eMMC or may be used for recovery purpose using the universal update utility (uuu) aka mfgtools 3.0. Functionality wise the following is known to be working: - eMMC, 8-bit and 4-bit MMC/SD card slots - Gigabit Ethernet - GPIOs - I2C Unfortunately, there is no USB functionality for the i.MX 8QM as of yet. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-06-11ARM: imx: novena: Convert to DM VIDEOMarek Vasut
Enable DM Video support on iMX6Q Novena and fix minor details to restore previous behavior of the system. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Vagrant Cascadian <vagrant@debian.org>
2019-06-11ARM: imx: novena: Convert block devices to DMMarek Vasut
Enable DM block, DM MMC and DM SATA support on iMX6Q Novena convert board code to match the DM support. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Vagrant Cascadian <vagrant@debian.org>
2019-06-11pico-imx7d: Add boot option for verified bootJun Nie
Add boot option to boot from fitimage to support verified boot. The boot script plain text file should be packed into fit blob as image with name of bootscr. Signed-off-by: Jun Nie <jun.nie@linaro.org>
