The bootcmd_mfg env variable is legacy from IMX downstream u-boot branch
and is not needed on mainline.
Upstream-Status: Submitted [https://lore.kernel.org/u-boot/20231004191358.24488-1-francesco@dolcini.it/]
Signed-off-by: Joao Paulo Goncalves <joao.goncalves@toradex.com>
Signed-off-by: Francesco Dolcini <francesco.dolcini@toradex.com>
Add USB support.
Upstream-Status: Pending
As of now, no iMX8 USB support present in mainline.
Signed-off-by: Andrejs Cainikovs <andrejs.cainikovs@toradex.com>
Move i.MX auxiliary core memory base and size configuration
to defconfig where it should belong.
Upstream-Status: Submitted [https://lore.kernel.org/all/20230303132642.15574-14-andrejs.cainikovs@toradex.com/]
Update the distro config env memory layout for the Colibri iMX8X:
- kernel_comp_addr_r=0xb0000000 temporary area for uncompressing (ie FIT
images or Image.gz booted using booti)
- kernel_comp_size=0x08000000
- loadaddr=0x95c00000 avoiding any reserved areas located before that
- fdt_addr_r = loadaddr + 128MB - allows for 128MB kernel
- scriptaddr = fdt_addr_r + 512KB - allows for 512KB fdt
- ramdisk_addr_r = scriptaddr + 512KB - allows for 512KB script
Idea of memory layout taken from commit a9f1e35bedc4
("apalis-imx8: update env memory layout").
Note that for our regular BSP Layers and Reference Images for Yocto
Project an updated distro boot script is required (see
meta-toradex-bsp-common/recipes-bsp/u-boot/u-boot-distro-boot).
Upstream-Status: Submitted [https://lore.kernel.org/all/20230303132642.15574-13-andrejs.cainikovs@toradex.com/]
Make sure M4 binary loading works equally well
on ext4 as well as fat file systems.
Upstream-Status: Submitted [https://lore.kernel.org/all/20230303132642.15574-12-andrejs.cainikovs@toradex.com/]
Drop obsolete environment variables boot_file, bootcmd_mfg,
fdt_addr, finduuid, image, mfgtool_args, mmcargs, mmcdev, mmcpart,
panel, sec_boot, vidargs.
Upstream-Status: Submitted [https://lore.kernel.org/all/20230303132642.15574-10-andrejs.cainikovs@toradex.com/]
The following expression is used to construct the device tree name:
fdtfile=${soc}-colibri-${fdt_board}.dtb
- soc is set dynamically (either imx8qxp or imx8dx)
- fdt_board can be modified by the user (eval-v3, aster, iris/iris-v2)
Upstream-Status: Submitted [https://lore.kernel.org/all/20230303132642.15574-9-andrejs.cainikovs@toradex.com/]
Update update_uboot confirmation message.
Upstream-Status: Submitted [https://lore.kernel.org/all/20230303132642.15574-7-andrejs.cainikovs@toradex.com/]
Remove obsolete SDHC related config defines. Nowadays, all SDHC related
hardware configuration comes from the device tree.
Upstream-Status: Submitted [https://lore.kernel.org/all/20230303132642.15574-6-andrejs.cainikovs@toradex.com/]
Remove obsolete net USB start.
While at it also add a comment about enabling distro-boot.
Upstream-Status: Submitted [https://lore.kernel.org/all/20230303132642.15574-5-andrejs.cainikovs@toradex.com/]
This commit does remove the options argument from the console
kernel-argument as it prevents the serial driver from outputting
anything.
Do this by switchting to use the variable "setup" as it is done on other
Toradex modules.
Upstream-Status: Submitted [https://lore.kernel.org/all/20230303132642.15574-3-andrejs.cainikovs@toradex.com/]
Add USB support.
Upstream-Status: Inappropriate [other]
No iMX8 USB support present in mainline.
Delete unused boot_file environment variable.
Upstream-Status: Submitted [https://lore.kernel.org/u-boot/20230113171751.331268-15-francesco@dolcini.it/]
Add M4 boot environment functions for reference.
Upstream-Status: Submitted [https://lore.kernel.org/u-boot/20230113171751.331268-22-francesco@dolcini.it/]
Update the distro config env memory layout for the Apalis iMX8 aka
QuadMax:
- kernel_comp_addr_r=0xf0000000 temporary area for uncompressing (ie FIT
- loadaddr=0x95400000 avoiding any reserved areas located before that
Basic idea of memory layout taken from commit fd5c7173ade4
("imx8m{m,n}_venice: update env memory layout"). However, moved past
any reserved areas to avoid any kind of conflicts.
Upstream-Status: Submitted [https://lore.kernel.org/all/20221212000930.45505-17-marcel@ziswiler.com/]
Upstream-Status: Backport [https://lore.kernel.org/all/20221212000930.45505-16-marcel@ziswiler.com/]
Drop obsolete environment variables fdt_addr, finduuid, mmcargs, mmcdev,
mmcpart and panel.
Upstream-Status: Submitted [https://lore.kernel.org/all/20221212000930.45505-15-marcel@ziswiler.com/]
Introduce setup setting setupargs and move earlycon there.
Upstream-Status: Submitted [https://lore.kernel.org/all/20221212000930.45505-14-marcel@ziswiler.com/]
Upstream-Status: Submitted [https://lore.kernel.org/all/20221212000930.45505-13-marcel@ziswiler.com/]
Upstream-Status: Submitted [https://lore.kernel.org/all/20221212000930.45505-12-marcel@ziswiler.com/]
Update SPDX license identifier string.
While at it also update copyright period.
Upstream-Status: Submitted [https://lore.kernel.org/all/20221212000930.45505-11-marcel@ziswiler.com/]
The distroboot script system scans boot_scripts variable and
try to find and use to boot each script name mentioned there.
Setting global variable "script" breaks this general mechanism
of searching and running a distro boot script.
Remove global variables "script" to fix working the general
distro boot script mechanism.
Upstream-Status: Submitted [https://lore.kernel.org/all/20221212000930.45505-9-marcel@ziswiler.com/]
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Implement PCB version and SoC variant handling which automatically loads
the correct device tree for the Linux kernel.
Upstream-Status: Submitted [https://lore.kernel.org/all/20221212000930.45505-3-marcel@ziswiler.com/]
Drop legacy nfsboot script in favor of distroboot DHCP boot.
Upstream-Status: Backport [1410cba567803b66b1ac7a354f5cda0c5f0e84ec]
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Use the same name of DHCP Distroboot script as in regular eMMC case.
Upstream-Status: Backport [1377a776c3f9c8580462f42a5d078976e5eec3ee]
update-to-5.15.52_2.1.0__toradex_imx_lf_v2022.04
Drop obsolete networking/PHY related configuration defines.
Upstream-Status: Submitted [https://lore.kernel.org/all/20220921113419.1088398-1-marcel@ziswiler.com/]
Update the distro config env memory layout for the Verdin iMX8M Mini and
Verdin iMX8M Plus:
- loadaddr=0x48200000 allows for 128MB area for uncompressing (ie FIT
images, kernel_comp_addr_r, kernel_comp_size)
Memory layout taken from commit fd5c7173ade4
Upstream-Status: Submitted [https://lore.kernel.org/all/20220819051827.185560-2-marcel@ziswiler.com/]
Align default ip address with other Toradex boards.
Upstream-Status: Inappropriate [configuration]
(cherry picked from commit 8aa931d8f78e8cf5b2c84421314ef47971384778)
* origin/imx_v2022.04: (9 commits)
LFU-384 board: freescale: imx8m[q,m,n,p]_evk: add per system GUID
capsule: board: Add information needed for capsule updates
doc: uefi: Update the capsule update related documentation
mkeficapsule: Remove raw and FIT GUID types
FMP: Remove GUIDs for FIT and raw images
Add Per system GUID for SR-IR-2.0
Reviewed-by: Ye Li <ye.li@nxp.co>
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Add a structure which defines the information that is needed for
executing capsule updates on a platform. Some information in the
structure like the dfu string is used for making the update process
more robust while some information like the per platform image GUIDs
is used for fixing issues. Initialise this structure in the board
file, and use the information for the capsule updates.
Signed-off-by: Sughosh Ganu <sughosh.ganu@linaro.org>
The capsule update code has been modified for getting the image GUID
values from the platform code. With this, each image now has a unique
GUID value. With this change, there is no longer a need for defining
GUIDs for FIT and raw images. Remove these GUID values.
MLK-26005 configs: imx93: modify mem=
Ethosu occupies 0x10000000 DRAM from 0xc0000000 so that increase mem= by
256MB to include it.
Signed-off-by: Alice Guo <alice.guo@nxp.com>
Reviewed-by: Ye Li <ye.li@nxp.com>
LFU-381 imx93_evk: Fix conflict SPL early malloc address
Because the early malloc pool size is set to 0x18000, so using this
start address may cause conflict with ATF, then corrupt the heap data.
So we delete the definition to use the default early malloc pool from
CONFIG_SPL_STACK to avoid any conflict
Signed-off-by: Ye Li <ye.li@nxp.com>
Reviewed-by: Jacky Bai <ping.bai@nxp.com>
systemd prints its messages on the last console= statement that it finds
in the kernel arguments. The current ordering sends the systemd messages
to tty1, by default this is the display.
Ensure that systemd sends its messages to the default UART, reorder the
console= statements accordingly.
Upstream-Status: Backport [a3f2dcf8f44445703a1919a5fa83b4328b244f92]
Reviewed-by: Stefano Babic <sbabic@denx.de>
LFU-376 imx93_evk: Change ethprime to eQOS port for default
LFU-378 imx8ulp: Hang the u-boot when M33 is not loaded
LFU-377-2 imx: spl_imx_romapi: Get and print boot stage
LFU-377-1 imx: container: Skip container set check for ROM API
To align with iMX8MP, use eQOS port as default ethernet port, so
set ethprime to eth1
Reviewed-by: Peng Fan <peng.fan@nxp.com>
MA-20481-2 Enable round mipi-panel usmp-rm67162 for imx8ulp watch board
MA-20481-1 Add board files and defconfig for imx8ulp watch board
New imx8ulp_watch files are based on imx8ulp_evk and modified for watch board.
Change-Id: I0ad6130cd7df60cb453abb9adcf36242f3cc0fd5
Signed-off-by: Zhang Bo <bo.zhang@nxp.com>
* remotes/origin/ls_v2022.04:
LF-6627: ls1043ardb: nand driver fixups for revision v7.0 boards
board: ls1043ardb: fdt fixups for revision v7.0 boards
The LS1043ARDB rev v7.0 board replaces the AQR105 PHY on MAC9 with an
AQR113C PHY. The address of the PHY on the MDIO bus changes from 0x1 to
0x8. Enable CONFIG_OF_BOARD_FIXUP and update both u-boot and Linux device
trees to reflect this change.
Signed-off-by: Camelia Groza <camelia.groza@nxp.com>
LFU-372-3 imx8ulp: Enable SCMI thermal for temperature
LFU-372-2 DTS: imx8ulp: Add SCMI sensor node
LFU-372-1 thermal: Add SCMI Sensor based thermal driver
Add SCMI Sensor protocol based thermal driver to get temperature
from SCMI platform server.
Reviewed-by: Alice Guo <alice.guo@nxp.com>
* origin/imx_v2022.04: (11 commits)
LFU-332-10: configs: imx8mm: ab2 target board config options
LFU-332-9: include: configs: imx8mm ab2: board configs
LFU-332-8: dts: arm: imx8mm ab2: target board support
LFU-332-7: arm: mach imx8m: imx8mm ab2 target board configs
LFU-332-6: board: freescale: imx8mm ab2: target board support
Common config options for imx8m mini audio board 2
Signed-off-by: Adrian Alonso <adrian.alonso@nxp.com>
Common config options for imx8m nano audio board 2
