Set MC Firmware size in read commands in
env to 2MB.
Update DDR Memory read address for MC firmware to
0x80a00000 and MC DPC address to 0x80e00000.
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
env to 2MB.
env to 2MB.
env to 2MB.
- Marvell SheevaPlug: Convert Ethernet and SATA to Driver Model (Tony)
- Zyxel NSA310S NAS: Convert to Driver Model (Tony)
- Turris_omnia: Add `u-boot-env` NOR partition (Marek)
- Turris_omnia: Fixup MTD partitions in Linux' DTB (Marek)
- Espressobin: Enable 'mtd' command and define SPI NOR partitions (Pali)
https://source.denx.de/u-boot/custodians/u-boot-ti
- Enabled distro boot for all TI platforms.
- Cleanup for AM335x Guardian Board
- PRUSS rproc on AM65 platform.
- Add PMIC support for J7200
- Misc fixes for Nokia RX-51
# Conflicts:
# arch/arm/mach-omap2/am33xx/Kconfig
U-Boot now supports parsing SPI NOR partitions from Device Tree. So enable
'mtd' command support for Espressobin board and define partition layout in
U-Boot Espressobin DTS file. Access to SPI NOR via 'sf' command is old
method and 'mtd' command is now preferred variant.
From include file remove '#define CONFIG_MTD_PARTITIONS' as this option is
now defined and enabled in defconfig file. This change is required to fix
compile error:
CC arch/arm/lib/asm-offsets.s
In file included from include/config.h:4,
from include/common.h:16,
from lib/asm-offsets.c:14:
include/configs/mvebu_armada-37xx.h:63: warning: "CONFIG_MTD_PARTITIONS" redefined
#define CONFIG_MTD_PARTITIONS /* required for UBI partition support */
In file included from ././include/linux/kconfig.h:4,
from <command-line>:
include/generated/autoconf.h:44: note: this is the location of the previous definition
#define CONFIG_MTD_PARTITIONS 1
After enabling support for mtd command, output from 'mtd list' on
Espressobin board is:
=> mtd list
List of MTD devices:
* w25q32dw
- device: spi-flash@0
- parent: spi@10600
- driver: jedec_spi_nor
- path: /soc/internal-regs/spi@10600/spi-flash@0
- type: NOR flash
- block size: 0x1000 bytes
- min I/O: 0x1 bytes
- 0x000000000000-0x000000400000 : "w25q32dw"
- 0x000000000000-0x0000003f0000 : "firmware"
- 0x0000003f0000-0x000000400000 : "u-boot-env"
Signed-off-by: Pali Rohár <pali@kernel.org>
Reviewed-by: Konstantin Porotchkin <kostap@marvell.com>
Enable DM SATA, removed IDE driver, and add SATA MV driver.
Signed-off-by: Tony Dinh <mibodhi@gmail.com>
As the logic here is only used when we have a USB host controller, test
on CONFIG_USB_HOST rather than CONFIG_USB in general. This lets us move
towards using CONFIG_USB only as a menu symbol to say that we have some
form of USB, and then USB_HOST or USB_GADGET depending on the role that
USB plays within the build.
Reuse the common logic to allow for BOOT_TARGET_DEVICES to list USB as a
possibility if we're building for a platform that will have USB but not
if we don't, so that we don't hit the link-time check for trying to have
USB boot on a non-USB system.
Acked-by: Tom Warren <twarren@nvidia.com>
These USB defines do not change the build as there is no USB support
enabled currently.
Cc: Ian Ray <ian.ray@ge.com>
Cc: Sebastian Reichel <sebastian.reichel@collabora.com>
Reviewed-by: Sebastian Reichel <sebastian.reichel@collabora.com>
This board has not been converted to CONFIG_DM_MMC by the deadline.
Remove it. As this is also the last in family remove the related
support as well.
Cc: Angelo Durgehello <angelo.dureghello@timesys.com>
Cc: TsiChung Liew <Tsi-Chung.Liew@nxp.com>
support as well.
Remove it.
Remove it.
The capsule signature is now part of our DTB. This is problematic when a
user is allowed to change/fixup that DTB from U-Boots command line since he
can overwrite the signature as well.
So Instead of adding the key on the DTB, embed it in the u-boot binary it
self as part of it's .rodata. This assumes that the U-Boot binary we load
is authenticated by a previous boot stage loader.
Reviewed-by: Masami Hiramatsu <masami.hiramatsu@linaro.org>
Tested-by: Masami Hiramatsu <masami.hiramatsu@linaro.org>
Tested-by: Sughosh Ganu <sughosh.ganu@linaro.org>
Signed-off-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
- A large rework of the logic around supporting various image
types/formats and sharing between the host and target.
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
i.MX
- mx7ulp : fix WDOG
- imx8 : Phytec
- USB3 support for i.MX8
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/8277
This macro is no longer needed for code flow or #ifdefs. Remove it.
Signed-off-by: Alexandru Gagniuc <mr.nuke.me@gmail.com>
It is no longer necessary to implement rsa_() functions as no-ops
depending on config options. It is merely sufficient to provide the
prototypes, as the rsa code is no longer linked when unused.
It is no longer necessary to implement ecdsa_() functions as no-ops
prototypes, as the ecdsa code is no longer linked when unused.
The purpose of this change is to enable crypto algorithms to be placed
in linker lists, rather than be declared as a static array. The goal
is to remove the crypto_algos array in a subsequent patch.
Create a new linker list named "cryptos", and search it when
image_get_crypto_algo() is invoked.
NOTE that adding support for manual relocation of crypto_algos within
linker lists is beyond the scope of this patch.
This is not needed with Kconfig, since we can use IS_ENABLED() easily
enough. Drop it.
Reviewed-by: Alexandru Gagniuc <mr.nuke.me@gmail.com>
We already have a host Kconfig for these SHA options. Use
CONFIG_IS_ENABLED(SHAxxx) directly in the code shared with the host build,
so we can drop the unnecessary indirections.
We already have a host Kconfig for SHA1. Use CONFIG_IS_ENABLED(SHA1)
directly in the code shared with the host build, so we can drop the
unnecessary indirection.
Drop the _SUPPORT suffix so we can use CONFIG_IS_ENABLED() with this
option.
option.
Drop the ENABLE and SUPPORT parts of this, which are redundant.
These option are named inconsistently with other SPL options, thus making
them incompatible with the CONFIG_IS_ENABLED() macro. Rename them.
The ENABLE part of this name is redundant, since all boolean Kconfig
options serve to enable something. The SUPPORT part is also redundant
since Kconfigs can be assumed to enable support for something. Together
they just serve to make these options overly long and inconsistent
with other options.
Rename FIT_ENABLE_SHAxxx_SUPPORT to FIT_SHAxxx
Add the variable used by PXE command for fdtoverlays support
since the commit 69076dff2284 ("cmd: pxe: add support for FDT overlays").
Reused the unused "splashimage" address as CONFIG_SPLASH_SOURCE and
CONFIG_VIDEO_LOGO are not activated and U-Boot display the "BACKGROUND"
image found in extlinux.conf to manage splashscreen on stm32mp1 boards.
Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
Reviewed-by: Patrice Chotard <patrice.chotard@foss.st.com>
- x86: various improvements made in getting Chromium OS verified boot
running on top of coreboot, booting into U-Boot.
By default bootmenu is loaded only from eMMC. After this change U-Boot
first tries to load bootmenu from uSD card and if it fails then fallback to
eMMC. People want to boot alternative OS from removable uSD without need to
modify eMMC content. So this backward compatible change allows it.
Part of this change is also optimization of trymmc* macros so they can be
used in preboot macro for loading bootmenu.
Link: https://lore.kernel.org/r/20210618132704.32066-2-pali@kernel.org
Enable U-Boot bootz command and update env scripts to try loading also
zImage file and to try booting via bootz command.
Update also lowlevel_init.S code for checking validity of zImage magic to
correctly relocate kernel in zImage format.
This change allows U-Boot to directly boot Linux kernel without need for
converting kernel image into U-Boot uImage format.
Link: https://lore.kernel.org/r/20210618132704.32066-1-pali@kernel.org
TI J7200 EVM has lp876441 pmic that is similar to tps65941. Add support
for same with existing driver with new compatible.
Signed-off-by: Gowtham Tammana <g-tammana@ti.com>
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
Link: https://lore.kernel.org/r/20210714205300.17424-2-g-tammana@ti.com
Swap out the TI-centric "envboot" logic for the generic distro_bootcmd
logic for the bootcmd we run before trying to do something more complex
involving additional firmware, etc.
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Link: https://lore.kernel.org/r/20210713141139.15183-1-trini@konsulko.com
The usbtty functionality is not currently used on these two platforms,
disable it.
Link: https://lore.kernel.org/r/20210708014348.4010-1-trini@konsulko.com
Cc: Lokesh Vutla <lokeshvutla@ti.com> (maintainer:J721E BOARD)
Link: https://lore.kernel.org/r/20210701142743.26190-1-trini@konsulko.com
Remove the environment support for various legacy boot methods. With
this, we will now default to booting any distribution that follows the
generic distro boot framework and no longer attempt to boot various
legacy (to this SoC) scripts/etc. Note that if we do not find anything
here we will continue to try and Android methods and will start by
trying fastboot.
Link: https://lore.kernel.org/r/20210701132612.7559-3-trini@konsulko.com
<configs/ti_omap5_common.h>
This include file is only used by ti_omap5_common.h. Further, the move
is towards using the generic distro boot framework and not this set of
macros. Start by moving all of the contents in directly to where they
are used.
Link: https://lore.kernel.org/r/20210701132612.7559-2-trini@konsulko.com
Link: https://lore.kernel.org/r/20210701132612.7559-1-trini@konsulko.com
The Programmable Real-Time Unit - Industrial Communication
Subsystem (PRU-ICSS) is present of various TI SoCs such as
AM335x or AM437x or the AM654x family. Each SoC can have
one or more PRUSS instances that may or may not be identical.
The PRUSS consists of dual 32-bit RISC cores called the
Programmable Real-Time Units (PRUs), some shared, data and
instruction memories, some internal peripheral modules, and
an interrupt controller. The programmable nature of the PRUs
provide flexibility to implement custom peripheral interfaces,
fast real-time responses, or specialized data handling.
Add support for pruss driver. Currently am654x family
is supported.
Signed-off-by: Keerthy <j-keerthy@ti.com>
Signed-off-by: Roger Quadros <rogerq@ti.com>
Link: https://lore.kernel.org/r/20210622063431.3151-2-lokeshvutla@ti.com
Link: https://lore.kernel.org/r/20210610230147.22475-1-trini@konsulko.com
- Enable lcd controller
- Display splash screen
Signed-off-by: Gireesh Hiremath <Gireesh.Hiremath@in.bosch.com>
Link: https://lore.kernel.org/r/20210611161350.2141-16-Gireesh.Hiremath@in.bosch.com
Enable backlight, set brightness value and dimming frequency
Link: https://lore.kernel.org/r/20210611161350.2141-13-Gireesh.Hiremath@in.bosch.com
read boot mode gpio and set the swi status
Link: https://lore.kernel.org/r/20210611161350.2141-12-Gireesh.Hiremath@in.bosch.com
autoload: if set to "no" then rarpb, bootp or dhcp commands will
just perform a configuration lookup from the BOOTP / DHCP server,
but not try to load any image using TFTP
Link: https://lore.kernel.org/r/20210611161350.2141-8-Gireesh.Hiremath@in.bosch.com
Set tftp_load_addr to 0x82000000 in MEM_LAYOUT_ENV_SETTINGS
Signed-off-by: Moses Christopher <BollavarapuMoses.Christopher@in.bosch.com>
Link: https://lore.kernel.org/r/20210611161350.2141-5-Gireesh.Hiremath@in.bosch.com
