Update the secure boot headers offsets of Kernel and other
firmware images for SD and XSPI boot sources used by
esbc_validate command.
Signed-off-by: Priyanka Singh <priyanka.singh@nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Add emmc in supported boot_targets and
Add bootcmd environment variable for emmc boot.
Signed-off-by: Meenakshi Aggarwal <meenakshi.aggarwal@nxp.com>
Setting fdt_high and initrd_high to 0xffffffffffffffff leads to
various difficulty to resolve bugs.
Remove them and use bootm_size instead to safely contain a kernel,
device tree and initrd for relocation.
Signed-off-by: Yuantian Tang <andy.tang@nxp.com>
This patch sets CONFIG_SYS_BOOTMAPSZ to the amount of memory available
to safely contain a kernel, device tree and initrd for relocation. The
way to set fdt_high as 0xffffffff to disable device tree relocation is
removed.
Signed-off-by: Alison Wang <alison.wang@nxp.com>
Currently this causes failures of the platform when running the EFI
loader tests, so disable it for now.
This reverts commit af827140e5965e5bb2bcad1c53ca8419b428ff6d.
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip
- Fixed for rv1108 and elgin-rv1108 board
- Fix the keyboard from USB instead of CrOS EC
These boards aren't ChromeOS devices so won't have a cros-ec-keyb
input as it's the keyboard available via the ChromeOS Embedded
Controller. Update them to use a USB keyboard which would actually
be available. Also enable the usb keyboard option for those devices
that don't have it enabled already.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Reviewed-by: Michael Trimarchi <michael@amarulasolutions.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
EFI was disabled in f95b8a4b5f64f because of the missing DTB file,
and indeed, the DTB file is required to load recent versions of GRUB
(2.04) correctly.
Signed-off-by: Kristian Amlie <kristian.amlie@northern.tech>
'vendor' is both an input and an output parameter. So it cannot be
constant.
Fixes: 0bda81bfdc5c ("efi_loader: use const efi_guid_t * for variable services")
See UEFI specification, section 8.5.3.
In addition, the structure, efi_capsule_header, should be "packed"
as it is a serialized binary format in a capsule file.
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
This is a preparatory patch.
Those functions will be used in an implementation of UEFI firmware
management protocol as part of my capsule update patch.
Some of those values will be used in an implementation of UEFI firmware
These flags are expected to be set in OsIndicationsSupported variable
if corresponding features are supported. See UEFI specification,
section 8.5.4.
In particular, capsule-related flags will be used in my capsule
update patch.
Fix misspelled EFI_OS_INDICATIONS_BOOT_TO_FW_UI.
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Currently watchdog tries to use dev_read_u32_default to get timeout
configuration in case OF_CONTROL is enabled. However, if SPL is
built with OF_PLATDATA this has no sense as there is no device tree.
This patch fixes this issue by only use dev_read_u32_default if OF_CONTROL
is enabled but OF_PLATDATA is not.
Signed-off-by: Walter Lozano <walter.lozano@collabora.com>
- DM support for CAxxxx SoCs
- eMMC board for presidio-asic
- Add defer probe for mmc sdhci
- TI SoCs mmc misc update
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
Fixes for 2020.04
- DM : mx6sabresd
- mx6ul_14x14_evk: fix video
- mx8qxp; fix console for booting
- sync DTS with kernel (imx6sx)
- drop obsolete woodburn (mx35)
Travis: https://travis-ci.org/sbabic/u-boot-imx/builds/660550811
https://gitlab.denx.de/u-boot/custodians/u-boot-atmel
First set of u-boot-atmel fixes for 2020.04 cycle:
- Includes two small configuration fixes that will solve the SPL booting
on sama5d3_xplained board.
This fixes the following warning:
===================== WARNING ======================
This board does not use CONFIG_DM_ETH (Driver Model
for Ethernet drivers). Please update the board to use
CONFIG_DM_ETH before the v2020.07 release. Failure to
update by the deadline may result in board removal.
See doc/driver-model/migration.rst for more info.
Signed-off-by: Pedro Jardim <jardim.c.pedro@gmail.com>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
Set CONFIG_SYS_BOOTMAPSZ to the amount of memory available which is needed
to relocate the kernel, device tree and initrd.
Remove 'fdt_high' and 'initrd_high' environment variables from default
environment which prevents relocation of FDT and initrd.
Signed-off-by: Oliver Graute <oliver.graute@kococonnector.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Peng Fan <peng.fan@nxp.com>
Cc: Ye Li <ye.li@nxp.com>
Cc: uboot-imx <uboot-imx@nxp.com>
Convert imx6sabresd ethernet to driver model to fix the following warning:
Signed-off-by: Alifer Moraes <alifer.wsdm@gmail.com>
Uboot size is incorrect.
Uboot SPL use CONFIG_SYS_MONITOR_LEN to read uboot from NAND : 0x80000
With sama5d3_xplained_nandflash_defconfig : u-boot.bin size is ~800Ko 0xC0000
So I increased size to 1MB : 0x100000
Signed-off-by: Fabien Lehoussel <fabien.lehoussel@medianesysteme.com>
The helper is used to reset PHYs on connect and it determines the clause
to use (C22/C45) based on interface type. This fixes 'PHY reset timed out'
warnings in console for USXGMII/XFI PHYs.
Signed-off-by: Alex Marginean <alexandru.marginean@nxp.com>
Add NC-SI to the usual phy handling. This makes two notable changes:
- Somewhat similar to a fixed phy, phy_connect() will create an NC-SI
phy if CONFIG_PHY_NCSI is defined.
- An early return is added to phy_read() and phy_write() to handle a
case like the NC-SI phy which does not define a bus.
Signed-off-by: Samuel Mendoza-Jonas <sam@mendozajonas.com>
Reviewed-by: Joel Stanley <joel@jms.id.au>
This introduces support for the NC-SI protocol, modelled as a phy driver
for other ethernet drivers to consume.
NC-SI (Network Controller Sideband Interface) is a protocol to manage a
sideband connection to a proper network interface, for example a BMC
(Baseboard Management Controller) sharing the NIC of the host system.
Probing and configuration occurs by communicating with the "remote" NIC
via NC-SI control frames (Ethernet header 0x88f8).
This implementation is roughly based on the upstream Linux
implementation[0], with a reduced feature set and an emphasis on getting
a link up as fast as possible rather than probing the full possible
topology of the bus.
The current phy model relies on the network being "up", sending NC-SI
command frames via net_send_packet() and receiving them from the
net_loop() loop (added in a following patch).
The ncsi-pkt.h header[1] is copied from the Linux kernel for consistent
field definitions.
[0]: https://github.com/torvalds/linux/tree/master/net/ncsi
[1]: https://github.com/torvalds/linux/blob/master/net/ncsi/ncsi-pkt.h
Added missing USDHC Base address defines
fdt_high value of 0xffffffff disables fdt relocation on boot. We don't
need that for Cubox-i/Hummingboard. Rely on generic code to find the
optimal fdt location at boot time.
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
Sync the imx6sx dts files with kernel 5.4.16.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Currently the expansion of the console variable leads to
the following kernel command line:
console=ttyLP0,${baudrate} earlycon root=/dev/mmcblk1p2 rootwait rw
, which causes the console to not show characters after the LPUART driver
is probed as the 'baudrate' variable is not properly translated.
Fix it by splitting the console variable in two parts: one for the
ttyLP0 part and the other one for the baudrate, which matches the way
it is done on other i.MX targets.
Tested by successfully booting a mainline kernel on a i.MX8QXP MEK
board.
Board is not longer used, remove it.
With CONFIG_SUPPORT_EMMC_BOOT moved to Kconfig, move it to defconfig
files.
Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
MMC_LEGACY & SD_LEGACY are not differentiated timings in the spec and
don't have any meaningful differences. Therefore, get rid of all
references to SD_LEGACY and use MMC_LEGACY to mean both of them.
Add the sdhci_deferred_probe() function to register as the
deferred_probe() callback to the mmc core. It will in turn call the
deferred_probe() callback of the platform drivers as declared in the
sdhci_ops.
Add a deferred_probe() API for platforms that want to do some
configurations just before starting to enumerate the device.
Add a saved_clock member to struct mmc to store the previous clock speed
in the clock needs to be stopped for some time.
This header uses bd_t without including its definition.
Change it to (struct bd_info), and add the forward declaration
to specify it as a structure.
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
- Limit bootloader size to 1 MiB on R-Car Gen3
- ABB SECU board
- Assorted minor fixes
Add initial support for the ABB SECU board, which is an ArriaV-based
SoCFPGA system with ethernet and booting from Denali NAND.
Signed-off-by: Holger Brunck <holger.brunck@ch.abb.com>
Cc: Ley Foon Tan <ley.foon.tan@intel.com>
Cc: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
In various cases a power domain must stay enabled after device
removal when booting OS (i.e. serial debug console or display).
Add a flag to selectively skip switching off a power domain.
Fixes: 52edfed65de9 ("dm: core: device: switch off power domain after device removal")
Acked-by: Neil Armstrong <narmstrong@baylibre.com>
Tested-by: Guillaume La Roque <glaroque@baylibre.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze
Xilinx fixes for v2020.04-rc4
- Fix link good bit handling in dp83867
- Rename generic Zynq defconfig
- Fix zybo z7 low leve setup
- Fix error path in zynq_gem driver and fix 64bit usage
- Fix invalid clock name quieries for Versal
- Fix zynq/zynqmp SPL low level configuration via DT selection
The Denali SPL shim won't build without these options set,
set them accordingly to fix the build error and let the SPL
shim to work correctly.
The default timer rate may be different than 25 MHz, permit overriding
the default rate in board configuration file. Ultimatelly, this should
be properly handled by a clock driver, however that is not available
on Gen5 yet.
The HF/QSPI flash layout permits up to 1 MiB large bootloader blob,
set CONFIG_BOARD_SIZE_LIMIT to enforce this limit and set the
monitor size to match accordingly.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
https://gitlab.denx.de/u-boot/custodians/u-boot-efi
Pull request for UEFI sub-system for efi-2020-04-rc4 (2)
In Linux next-20200228 patches have been merged to load an initial ramdisk
using an EFI_LOAD_FILE2_PROTOCOL provided by the firmware. See commit
ec93fc371f01 ("efi/libstub: Add support for loading the initrd from a
device path"). The idea behind it is that the firmware should be
responsible for validating the initrd in a secure boot setup.
This pull-request comprises a patch series which let's U-Boot provide an
initial implementation of the EFI_LOAD_FILE2_PROTOCOL providing the initrd.
https://gitlab.denx.de/u-boot/custodians/u-boot-uniphier
UniPhier SoC updates for v2020.04 (3rd)
- Enable ADMA and HS400 for the eMMC driver on 64-bit SoCs
- Add some convenient environment variables to handle SD card
- Sanitize the NAND controller reset sequence and its WP handling
- Sync DT with Linux
Following kernel's proposal for an arch-agnostic initrd loading
mechanism [1] let's implement the U-boot counterpart.
This new approach has a number of advantages compared to what we did up
to now. The file is loaded into memory only when requested limiting the
area of TOCTOU attacks. Users will be allowed to place the initramfs
file on any u-boot accessible partition instead of just the ESP one.
Finally this is an attempt of a generic interface across architectures
in the linux kernel so it makes sense to support that.
The file location is intentionally only supported as a config option
argument(CONFIG_EFI_INITRD_FILESPEC), in an effort to enhance security.
Although U-boot is not responsible for verifying the integrity of the
initramfs, we can enhance the offered security by only accepting a
built-in option, which will be naturally verified by UEFI Secure Boot.
This can easily change in the future if needed and configure that via ENV
or UEFI variable.
[1] https://lore.kernel.org/linux-efi/20200207202637.GA3464906@rani.riverdale.lan/T/#m4a25eb33112fab7a22faa0fd65d4d663209af32f
Signed-off-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
Very likely configs have been moved to Kconfig by scripts and this just
remains there that's why remove it.
Add handy macros:
- sdscript: source boot.scr in the file system of the SD media
- sdboot : boot the kernel using the images in the file system
of the SD media
- sdscript: update the boot firmware in the SD media
(in raw block sectors)
