Upon further review, not all code authors are in favour of this change.
This reverts commit ee3556bcafbb05e59aabdc31368984e76acaabc4.
>From DFU_ALT_INFO_EMMC (include/environment/ti/dfu.h) we can see that
rootfs will be flashed to second partition on eMMC. But at the moment we
have only one partition in $partitions environment variable. Let's add
"bootloader" partition prior to "rootfs", so that DFU works correctly.
This also fixes eMMC boot, which looks for rootfs on second partition.
"bootloader" partition start corresponds to "u-boot.img.raw" in DFU
eMMC info, which is 0x300 sector (384 KiB offset from eMMC start).
rootfs start address can be also found from DFU eMMC info.
bootloader-related area is finished at 0x1500 sector (2688 KiB offset
from eMMC start). This should be the start address for rootfs in
While at it, fix U-Boot environment address to be the same as for
AM57x EVM, so that it doesn't clash with other partitions.
So now eMMC layout looks like this:
0 +------------------------+
| MBR/GPT header | 128 -
128 +------------------------+
| MLO | 256 -
384 +------------------------+
| u-boot.img | 1792 bootloader
2176 +------------------------+
| //////// hole //////// | 256 -
2432 +------------------------+
| U-Boot environment | 128 -
2560 +------------------------+
| (redundant) |
2688 +------------------------+
| rootfs | remaining rootfs
end +------------------------+
"hole" area can be used further for storing U-Boot environment (like
it's done in AM57x EVM config file) or for increasing u-boot.img area
(in case u-boot.img size increased, e.g. if new dtbs were added).
This commit conforms with Linux partition table from f6d245b8c56c
("arm: am57xx: Fix Linux boot from eMMC") commit, making things in
uniform way.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Migrate the option CONFIG_SPL_FRAMEWORK and make this gate most of the
current set of options we have in Kconfig. We will need to have some
options available for SPL and !SPL_FRAMEWORK so this is important. In a
few cases we re-order existing options so that we have less escapes from
the SPL_FRAMEWORK guard.
The option CONFIG_SPL_MMC_MINIMAL is unused in code, drop it.
Provide description for struct efi_driver_ops.
%s/Indentiies/Identifies/g
This driver is no longer used on any supported platform in U-Boot and
there is no interest in maintaining it further from people that have
used it historically.
Cc: Michal Simek <michal.simek@xilinx.com>
c: Alexey Brodkin <alexey.brodkin@gmail.com>
Acked-by: Michal Simek <michal.simek@xilinx.com>
Remove CONFIG_BOOT_RETRY_TIME as it doesn't do much good and enable
CONFIG_HUSH_PARSER in xtfpga_defconfig.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
efi_disk_register should return as status code (efi_status_t).
Disks with zero blocks should be reported as 'not ready' without throwing
an error.
This patch solves a problem running OpenBSD on system configured with
CONFIG_BLK=n (e.g. i.MX6).
Reported-by: Jonathan Gray <jsg@jsg.id.au>
Tested-by: Jonathan Gray <jsg@jsg.id.au>
Add stubs for UpdateCapsule, QueryCapsuleCapabilities, and
QueryVariableInfo.
Change the return type of efi_driver_init() to efi_status_t.
efi_driver_init() calls efi_add_driver() which returns an efi_status_t
value. efi_driver_init() should not subject this value to a conversion to
int losing high bits on 64bit systems.
Currently we set the function pointer for the CreateEventEx boot service
to NULL. When called this would lead to an immediate failure.
A function stub is provided which handles the case that the boot service
is called without an event group and returns EFI_UNSUPPORTED otherwise.
Before the patch an undefined constant EFI_SUBSYSTEM was used in the
crt0 code. The current version of binutils does not swallow the error.
https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=888403
The necessary constant IMAGE_SUBSYSTEM_EFI_APPLICATION is already
defined in pe.h. So let's factor out asm-generic/pe.h for the
image subsystem constants and use it in our assembler code.
IMAGE_SUBSYSTEM_SAL_RUNTIME_DRIVER does not exist in the specification
let's use IMAGE_SUBSYSTEM_EFI_ROM instead.
The include pe.h is only used in code maintained by Alex so let him be the
maintainer here too.
Reported-by: Andre Przywara <andre.przywara@arm.com>
Tested-by: Vagrant Cascadian <vagrant@debian.org>
To make this driver easier to be reused, dual-license DDR driver.
Signed-off-by: York Sun <york.sun@nxp.com>
CC: Simon Glass <sjg@chromium.org>
CC: Tom Rini <trini@konsulko.com>
CC: Heinrich Schuchardt <xypron.glpk@gmx.de>
CC: Thomas Schaefer <thomas.schaefer@kontron.com>
CC: Masahiro Yamada <yamada.masahiro@socionext.com>
CC: Robert P. J. Day <rpjday@crashcourse.ca>
CC: Alexander Merkle <alexander.merkle@lauterbach.com>
CC: Joakim Tjernlund <joakim.tjernlund@transmode.se>
CC: Curt Brune <curt@cumulusnetworks.com>
CC: Valentin Longchamp <valentin.longchamp@keymile.com>
CC: Wolfgang Denk <wd@denx.de>
CC: Anatolij Gustschin <agust@denx.de>
CC: Ira W. Snyder <iws@ovro.caltech.edu>
CC: Marek Vasut <marek.vasut@gmail.com>
CC: Kyle Moffett <Kyle.D.Moffett@boeing.com>
CC: Sebastien Carlier <sebastien.carlier@gmail.com>
CC: Stefan Roese <sr@denx.de>
CC: Peter Tyser <ptyser@xes-inc.com>
CC: Paul Gortmaker <paul.gortmaker@windriver.com>
CC: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Extend the instantiate_rng() function and the corresponding CAAM job
descriptor to instantiate all RNG state handles. This moves the RNG
instantiation code in line with the CAAM kernel driver.
Previously, only the first state handle was instantiated. The second
one was instantiated by the CAAM kernel driver. This works if the
kernel runs in secure mode, but fails in non-secure mode since the
kernel driver uses DEC0 directly instead of over the job ring
interface. Instantiating all RNG state handles in u-boot removes the
need for using DEC0 in the kernel driver, making it possible to use
the CAAM in non-secure mode.
Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de>
Tested-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org>
Reviewed-by: York Sun <york.sun@nxp.com>
Enable validation of boot.scr script prior to its execution dependent
on "secureboot" flag in environment. Enable fall back option to
qspi boot in case of secure boot.
Signed-off-by: Sumit Garg <sumit.garg@nxp.com>
Signed-off-by: Vinitha Pillai <vinitha.pillai@nxp.com>
config_fallbacks.h has some logic that sets HAVE_BLOCK_DEVICE
based on a list of enabled options. Moving HAVE_BLOCK_DEVICE to
Kconfig allows us to drastically shrink the logic in
config_fallbacks.h
[trini: Rename HAVE_BLOCK_DEVICE to CONFIG_BLOCK_DEVICE]
Migrate the base and sub-options to Kconfig. Note that we only enable
this in the base sandbox config now.
Cc: Alexey Brodkin <alexey.brodkin@gmail.com>
Is this driver still used anywhere? It's fishy that it's only enabled
in sandbox anymore.
config_fallback.h has some logic that checks a variety of options
and selects LIB_UUID if it hasn't already been selected. This
will all LIB_UUID in Kconfig and select this option for the list
of options to allow us to remove the logic from fallbacks
config_fallbacks.h had some logic to automatically select
LIB_RAND if RANDOM_UUID or CMD_UUID were set if LIB_HW_RAND wasn't
already selected. By migrating LIB_HW_RAND to Kconfig, we can
remove this check from config_fallbacks.h and put it into Kconfig
Reviewed-by: Lukasz Majewski <lukma@denx.de>
[trini: Turn into a choice, add NET_RANDOM_ETHADDR]
CONFIG_APBH_DMA
CONFIG_APBH_DMA_BURST
CONFIG_APBH_DMA_BURST8
Reviewed-by: Stefan Agner <stefan.agner@toradex.com>
[trini: Add in MMC as well]
Enable CONFIG_ENV_VARS_UBOOT_CONFIG for all STM32 boards
It allows to retrieve the SoC name into the "soc" environment
variable.
Signed-off-by: Christophe Priouzeau <christophe.priouzeau@st.com>
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
Reviewed-by: Vikas Manocha <vikas.manocha@st.com>
This converts CONFIG_NAND_MXS to Kconfig.
The motivation for moving MX28 selection to Kconfig is to be able
to better handle NAND MXS selection through Kconfig.
This selection method also aligns with the way other i.MX SoCs are
selected in U-Boot.
The motivation for moving MX23 selection to Kconfig is to be able
selected in U-Boot.
CONFIG_MXC_GPIO
Since CONFIG_PHY_SMSC was already in Kconfig, move this from
header file to defconfig
Since CONFIG_MXC_UART is already in Kconfig, move this from
the header to imx6q_logic_defconfig
Reviewed-by: Stefano Babic <sbabic@denx.de>
This commit removes an attempt to workaround a previous compilation
warning that is is now fixed in "include/configs/ti_omap3_common.h".
Signed-off-by: Derald D. Woods <woods.technical@gmail.com>
This commit fixes the following compiler warnings when DM_SERIAL is
enabled.
---8<-------------------------------------------------------------------
CC spl/board/ti/evm/evm.o
In file included from /solution/scm/u-boot-master/board/ti/evm/evm.c:16:0:
/solution/scm/u-boot-master/include/ns16550.h:31:0: warning: "CONFIG_SYS_NS16550_REG_SIZE" redefined
#define CONFIG_SYS_NS16550_REG_SIZE (-1)
In file included from /solution/scm/u-boot-master/include/configs/omap3_evm.h:22:0,
from include/config.h:5,
from /solution/scm/u-boot-master/include/common.h:21,
from /solution/scm/u-boot-master/board/ti/evm/evm.c:14:
/solution/scm/u-boot-master/include/configs/ti_omap3_common.h:33:0: note: this is the location of the previous definition
# define CONFIG_SYS_NS16550_REG_SIZE (-4)
LD spl/board/ti/evm/built-in.o
CC spl/drivers/serial/ns16550.o
In file included from /solution/scm/u-boot-master/drivers/serial/ns16550.c:11:0:
from /solution/scm/u-boot-master/drivers/serial/ns16550.c:7:
LD spl/drivers/serial/built-in.o
Follow bootz's pattern by moving the booti_setup to arch/arm/lib.
This allows to use booti_setup in other paths, e.g booting
an Android image containing Image format.
Note that kernel relocation is move out of booti_setup and it is the
caller's responsibility to do it and allows them do it differently. say,
cmd/booti.c just do a manually, while in the bootm path, we can use
bootm_load_os(with some changes).
Signed-off-by: Bin Chen <bin.chen@linaro.org>
The second area of android image was intended to put a 2nd stage
bootloader but in practice were rarely used (in my knowledge).
An proposal was made to the AOSP to (re)use the second area as the dtb[1],
This patch itself doesn't depend on that proposal being accepted but it won't
be that helpful as well if that proposal won't be accepted. But don't do
any harm as well.
[1] https://android-review.googlesource.com/#/c/417447/
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
FreeBSD, like OpenBSD, uses BIG_ENDIAN, LITTLE_ENDIAN, and BYTE_ORDER,
whereas Linux and compatibles use __-prefixed names. Define the names
the same as the OpenBSD block below it.
These are declared in Kconfig, but some #defines have crept in.
CONFIG_FPGA
CONFIG_FPGA_ALTERA
CONFIG_FPGA_CYCLON2
CONFIG_FPGA_SOCFPGA
CONFIG_FPGA_XILINX
CONFIG_FPGA_ZYNQMPPL
Select CONFIG_CMD_USB_MASS_STORAGE so that the 'ums' can be used.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Selecting CONFIG_USB_FUNCTION_MASS_STORAGE=y in the defconfig leads to
the following error:
cmd/built-in.o: In function `do_usb_mass_storage':
cmd/usb_mass_storage.c:217: undefined reference to `fsg_main_thread'
cmd/usb_mass_storage.c:170: undefined reference to `fsg_init'
CONFIG_USB_FUNCTION_MASS_STORAGE option is built only for
the non-SPL case as per the logic in drivers/usb/gadget/Makefile,
so remove the incorrect CONFIG_SPL ifdefery to fix the build
failure.
Tested-by: Shawn Guo <shawn.guo@linaro.org>
Introduce SDR104 and HS200 support
The implementation takes linux kernel sdhci.c and sdhci-esdhc-imx.c
as reference.
- Implement esdhc_change_pinstate to dynamically change pad settings
- Implement esdhc_set_timing
- Implement esdhc_set_voltage to switch voltage
- Implement fsl_esdhc_execute_tuning to execute time process
- Enlarge the cfg->f_max to 200MHz.
- Parse fsl,tuning-step, fsl,tuning-start-tap and
fsl,strobe-dll-delay-target from device tree.
- Parse no-1-8-v property
- Introduce esdhc_soc_data to indicate the flags and caps
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
The board header file included a reference to the starting point
from nitrogen6x.h, but since so much changed, the file bears
little resemblance to that file.
Signed-off-by: Eric Nelson <eric@nelint.com>
The initial implementation of mx6memcal reset the CPU after
running the memory calibration procedure because the generic
board has no information about which boot devices are available.
Now that we have SDP support in SPL, use it to allow a full
U-Boot to be uploaded (i.e. to use "mtest").
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
