path: root/include
2019-08-25mtd: nand: raw: Move CONFIG_SYS_NAND_USE_FLASH_BBT to KconfigStefan Roese
Convert CONFIG_SYS_NAND_USE_FLASH_BBT to Kconfig, update defconfigs, headers and whitelist. Please note that this symbol already was used in Kconfig (imply in CONFIG_NAND_ATMEL) which did not work, since this symbol was not available in Kconfig. This changes now with this patch and all boards with CONFIG_NAND_ATMEL will have BBT enabled. Which is what I also need on my GARDENA AT91SAM based board. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Miquel Raynal <miquel.raynal@bootlin.com> Cc: Gregory CLEMENT <gregory.clement@bootlin.com> [trini: Rework such that the configs are unchanged to start with] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-25Convert CONFIG_ARCH_CPU_INIT to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ARCH_CPU_INIT Signed-off-by: Adam Ford <aford173@gmail.com> Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz> Tested-by: Felix Brack <fb@ltec.ch>
2019-08-24Merge tag 'u-boot-rockchip-20190823' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip - remove rk3288 fennec board - remove SPL raw image support for Rockchip SoCs - add common misc_init_r() for ethaddr from cpuid - enable USB HOST support for rk3328 - unify code for finding a valid gpt in part driver
2019-08-24Merge branch '2019-08-23-master-imports'Tom Rini
- Migrate CONFIG_MX_CYCLIC, CONFIG_FSL_USDHC and CONFIG_MXS_GPIO to Kconfig - Fix some SPL/TPL and ARM64 dependencies
2019-08-23Convert CONFIG_MX_CYCLIC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MX_CYCLIC Signed-off-by: Adam Ford <aford173@gmail.com> Acked-by: David Lechner <david@lechnology.com>
2019-08-23Convert CONFIG_FSL_USDHC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_FSL_USDHC Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Add IMX8M, TARGET_S32V234EVB to FSL_USDHC list] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-23kconfig: Convert CONFIG_MXS_GPIO to KconfigLukasz Majewski
This converts the following to Kconfig: CONFIG_MXS_GPIO Travis-CI: https://travis-ci.org/lmajewski/u-boot-dfu/builds/571260789 Signed-off-by: Lukasz Majewski <lukma@denx.de> Acked-by: Peng Fan <peng.fan@nxp.com> Acked-by: Jagan Teki <jagan@amarulasolutions.com>
2019-08-23Merge https://gitlab.denx.de/u-boot/custodians/u-boot-clkTom Rini
2019-08-23evb_rk3399: revert CONFIG_SYS_MMC_ENV_DEV to 0Max Kellermann
This was changed to 1 in commit 0717dde057e, but a few months later, commit 5f9411af37b swapped the order of eMMC and SD card by assigning indexed aliases to `&sdhci` and `&sdmmc`. Signed-off-by: Max Kellermann <max.kellermann@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com> (Add signature) Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-08-23disk: efi: ignore 'IGNOREME' GPT header found on cros eMMCsUrja Rannikko
Some ChromeOS devices (atleast veyron speedy) have the first 8MiB of the eMMC write protected and equipped with a dummy 'IGNOREME' GPT header - instead of spewing error messages about it, just silently try the backup GPT. Note: this does not touch the gpt cmd writing/verifying functions, those will still complain. Signed-off-by: Urja Rannikko <urjaman@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-08-23rockchip: rk3288: remove fennec board supportKever Yang
Since there is no one using this board, remove it. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-08-23rockchip: Move config SYS_MALLOC_LEN to KconfigKever Yang
Use Kconfig for option SYS_MALLOC_LEN and default to 0x2000000. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-08-22armv8: ls1088aqds: support DSPI mode by hwconfigChuanhua Han
BRDCFG4[USBOSC] and BRDCFG5[SPR] register field of Qixis device is used to control SPI and other IP signal routing. USBOSC: 0= SPI_CLK used as external USB REFCLK input driven with 24.000 MHz. SPI devices are unusable in this mode. 1= SPI_CLK used as SPI clock. SPI devices are usable in this mode. USB block is clocked from internal sources SPR[3:2]: SPI_CS / SDHC_DAT4:7 Routing (schematic net CFG_SPI_ROUTE[3:2]): 00= SDHC/eMMC 8-bit 01= SD Card Rev 2.0/3.0 10= SPI on-board memory 11= TDM Riser / SPI off-board connector. The default value is 00 if an SDCard/eMMC card is selected as the boot device. SPR[1:0]: SPI_SIN/SOUT/SCK Routing (schematic net CFG_SPI_ROUTE[1:0]): 00= SDHC Sync loop 01= TDM Riser / SPI off-board connector. 10= SPI on-board memory. 11= SPI off-board connector. By default, the SPI feature is not available, so we need to configure the above register fields to select the route to the SPI feature. Signed-off-by: Chuanhua Han <chuanhua.han@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-08-22armv8: ls1046afrwy: Define CONFIG_ENV_ADDR for QSPI BootAlison Wang
Defines CONFIG_ENV_ADDR for QSPI Boot which specifies the start address of the flash sector containing the environment. It fixes the issue that bootcmd is always set as default at bootup. Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-08-22armv8: ls1088aqds: Add support of I2C driver model.Chuanhua Han
Udate ls1088aqds board init code to support DM_I2C. Signed-off-by: Chuanhua Han <chuanhua.han@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-08-22boards: ls1088a: Add support of I2C driver modelChuanhua Han
DM_I2C_COMPAT is a compatibility layer that allows using the non-DM I2C API when DM_I2C is used.When DM_I2C_COMPAT is not enabled for compilation, a compilation error will be generated. This patch solves the problem that the i2c-related api of the ls1088a platform does not support dm. Signed-off-by: Chuanhua Han <chuanhua.han@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-08-22boards: ls2088aqds: Add support of I2C driver model.Chuanhua Han
Update ls2088aqds board init code to support DM_I2C. Signed-off-by: Chuanhua Han <chuanhua.han@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-08-22rtc: ds3232/ds3231: Add support to generate 32KHz output for driver moduleChuanhua Han
Add an implementation of the rtc_enable_32khz_output() that uses the driver model i2c APIs. Also put code related to rtc_enable_32khz_output under CONFIG_RTC_ENABLE_32KHZ_OUTPUT. Signed-off-by: Chuanhua Han <chuanhua.han@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-08-22boards: ls2088a: Add support of I2C driver model.Chuanhua Han
DM_I2C_COMPAT is a compatibility layer that allows using the non-DM I2C API when DM_I2C is used.When DM_I2C_COMPAT is not enabled for compilation, a compilation error will be generated. This patch solves the problem that the i2c-related api of the ls2088a platform does not support dm. Signed-off-by: Chuanhua Han <chuanhua.han@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-08-22armv8: ls1028aqds: Remove the definition of CONFIG_SYS_I2C_EARLY_INITChuanhua Han
Since i2c uses dm mode, i2c controller will be initialized when reading and writing devices on i2c bus. So there is no need for the original non-dm mode i2c early initialization function call, this patch removed the definition of CONFIG_SYS_I2C_EARLY_INIT. Signed-off-by: Chuanhua Han <chuanhua.han@nxp.com> Reviewed-by: Alex Marginean <alexm.osslist@gmail.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-08-22boards: ls1028a: Add support of I2C driver modelChuanhua Han
DM_I2C_COMPAT is a compatibility layer that allows using the non-DM I2C API when DM_I2C is used.When DM_I2C_COMPAT is not enabled for compilation, a compilation error will be generated. This patch solves the problem that the i2c-related api of the ls1028a platform does not support dm. Signed-off-by: Chuanhua Han <chuanhua.han@nxp.com> Reviewed-by: Alex Marginean <alexm.osslist@gmail.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-08-22configs: ls1043aqds: Move CONFIG_FSL_QSPI to defconfigAshish Kumar
Move CONFIG_FSL_QSPI from header file to defconfigs, consequently unset imply config(CONFIG_SPI_FLASH_BAR) which is not valid for LS series. Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-08-22drivers: net: mc: Report extra memory to LinuxMeenakshi Aggarwal
MC firmware need to be aligned to 512M, so minimum 512MB DDR is reserved. But MC support to work with 128MB or 256MB DDR memory also, in this case, rest of the memory is not usable. So reporting this extra memory to Linux through dtb memory fixup. Signed-off-by: Meenakshi Aggarwal <meenakshi.aggarwal@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-08-22sandbox: clk: add clk enable/disable test codePeng Fan
Since we added clk enable_count and prograte clk child enabling operation to clk parent, so add a new function sandbox_clk_enable_count to get enable_count for test usage. And add test code to get the enable_count after we enable/disable the device clk. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-08-22clk: introduce enable_countPeng Fan
As what Linux Kernel 5.3.0 provides when enable/disable clk, there is an enable_count in clk_core_disable/enable. Introduce enable_count to track the clk enable/disable count when clk_enable/disable for CCF. And Initialize enable_count to 0 when register the clk. And clk tree dump with enable_count will be supported, it will be easy for us to check the clk status with enable_count Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-08-20ARM: da850evm: Remove dead codeAdam Ford
Now that SPL supports DM_SERIAL and the direct NOR boot supports DM_SERIAL, the check to see if DM_SERIAL is defined can go away, because all da850evm variants now support DM_SERIAL. This patch simply removes some dead precompiler defines. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-08-20ARM: da850evm: Remove dead SPI CodeAdam Ford
With SPL now supporting DM_SPI, the need for compiler directives and hard-coded addresses is obsolete. This patch removes some dead legacy code defining the SPI base address Signed-off-by: Adam Ford <aford173@gmail.com>
2019-08-20ARM: omapl138_lcdk: Enable USBAdam Ford
The OMAPL138-lcdk has two USB controllers which are currently disabled. This patch enables them. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-08-20configs: Rename environment variable fit_bootfile to name_fitAndrew F. Davis
Like we did with 'fit_loadaddr' to 'addr_fit', the variable 'fit_bootfile' contains a name and so should be prefixed with name_. Make this change here. Signed-off-by: Andrew F. Davis <afd@ti.com>
2019-08-20configs: Rename environment variable fit_loadaddr to addr_fitAndrew F. Davis
This is the first part of a larger effort I would like to propose to unify and simplify the default set of environment variables. When many early environment variables were named there were fewer images being loaded, usually just a kernel. At this time names like 'loadaddr' would suffice. Now we have more images and many more commands that act on them, often re-using the same variable for several different uses. The contents of a variable are also not immediately known causing one to have to look up a chain of variables to understand what a command is actually doing. I suggest the following. To start, all variables containing names should be prefixed with name_ and addresses with addr_. This is like how K2 already does things and allows for simple universal commands like: get_fdt_nfs=nfs ${addr_fdt} /boot/${name_fdt} Which is very clear on what is intended here and would work across all board that using the this naming convention. We can do this one variable at a time, start here with addr_fit. Signed-off-by: Andrew F. Davis <afd@ti.com> Acked-by: Andreas Dannenberg <dannenberg@ti.com>
2019-08-20configs: Remove unneeded overlay_files environment variableAndrew F. Davis
The variable 'name_overlays' serves the same purpose. Remove 'overlay_files' and use 'name_overlays' everywhere. Signed-off-by: Andrew F. Davis <afd@ti.com>
2019-08-19Merge tag 'u-boot-rockchip-20190819' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip - Add ROC-RK3399-PC board support - Move CONFIG_SPI_FLASH_GIGADEVICE and CONFIG_CMD_USB_MASS_STORAGE to Kconfig - using SYSRESET_POWER_OFF for poweroff (Note that patch for rk8xx pmic is droped for it can not pass Travis build) - fix ofnode_get_name() assert
2019-08-19configs: Move CONFIG_CMD_USB_MASS_STORAGE properly into KconfigUrja Rannikko
This affects RK3036, RK322X and RK3288 - the defconfig changes done by moveconfig.py for the veyrons were left out on purpose because they dont have an OTG port, and will get their config updated in the next commit. Signed-off-by: Urja Rannikko <urjaman@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-08-19configs: Move CONFIG_SPI_FLASH_GIGADEVICE properly into KconfigUrja Rannikko
Affects rk3288 veyrons and rk3036, this was mostly done by moveconfig.py. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Urja Rannikko <urjaman@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-08-18global_data: Remove comment of reserved arch-specific GD flagsStefan Roese
With the removal of the x86 specific GD flags, there are no arch- specific GD flags any more. Let's remove the comment about reserving the upper 16 bits for arch-specific flags in the common header. This gives us more flexibility with the usage of the GD flags. As a matter of fact, we are already using more than 16 bits for common GD flags (with the addition of GD_FLG_WDT_READY). Signed-off-by: Stefan Roese <sr@denx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Cc: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-08-18cbfs: Add functions to support multiple CBFSsSimon Glass
Sometimes an image has multiple CBFS. The current CBFS API is limited to handling only one at time. Also it keeps track of the CBFS internally in BSS, which does not work before relocation, for example. Add a few new functions to overcome these limitations. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2019-08-18cbfs: Move result variable into the structSimon Glass
Move the result variable into the struct also, so that it can be used when BSS is not available. Add a function to read it. Note that all functions sill use the BSS version of the data. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2019-08-18x86: qemu: Fix build warnings with CONFIG_DISTRO_DEFAULTS=nBin Meng
Use DISTRO_BOOTENV to decouple BOOTENV from CONFIG_DISTRO_DEFAULTS. Reported-by: Heinrich Schuchardt <xypron.debian@gmx.de> Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2019-08-17Merge tag 'efi-2019-10-rc3' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-efi Pull request for UEFI sub-system for v2019.10-rc3 This pull request provides corrections for the SetVirtualAddress runtime service and avoids possible calls to NULL by consumers of the EFI_PXE_BASE_CODE_PROTOCOL.
2019-08-15efi_loader: EFI_PXE_BASE_CODE_PROTOCOL stubHeinrich Schuchardt
U-Boot implements the EFI_PXE_BASE_CODE_PROTOCOL because GRUB uses the mode information for booting via PXE. All function pointers in the protocol were NULL up to now which will cause immediate crashes when the services of the protocol are called. Create function stubs for all services of the protocol returning EFI_UNSUPPORTED. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-08-15ARM: socfpga: update CONFIG_SPL_FS_LOAD_PAYLOAD_NAME to u-boot.imgDalon Westergreen
Bring cyclone5 / arria5 / arria10 in line with convention and use u-boot.img as CONFIG_SPL_FS_LOAD_PAYLOAD_NAME. Signed-off-by: Dalon Westergreen <dalon.westergreen@intel.com>
2019-08-12Merge https://gitlab.denx.de/u-boot/custodians/u-boot-marvellTom Rini
- Various improvements to Keymile boards - mostly DT conversation (Pascal & Holger) - Removal of now unsupported Keymile boards (Pascal & Holger) - Small MVEBU PCI fix (Marek) - Turris Omnia defconfig update (Marek) - Misc Allied Telesis defconfig updates (Chris)
2019-08-12Merge tag 'u-boot-amlogic-20190812' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-amlogic - amlogic: add support for the SEI Robotic SEI510
2019-08-12Merge branch '2019-08-11-ti-imports'Tom Rini
- More DaVinci updates and fixes - PCIe support on am65x - Watchdog converted to DM - Assorted other bugfixes
2019-08-12ARM: da850-evm: Increase environment NOR partition offsetAdam Ford
The current size allocated to U-Boot is 384k, but U-Boot has grown to 436K which means that saving the environmental variables wipes out part of the U-Boot source and the board ceases to function. Due to the sector and erase size for the NOR part and a desire to not have to change partition sizes often, this patch moves the U-Boot environmental variables to an offset of 1M so saveenv does not brick the board. This patch also sets up MTDIDS and MTDPARTS to clearly show where U-Boot and U-Boot's environmental variables are located. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-08-12ARM: da850-evm: Fix Lowlevel initAdam Ford
A previous patch for enabling the NAND config set a flag called CONFIG_SKIP_LOWLEVEL_INIT when it should have been called CONFIG_SKIP_LOWLEVEL_INIT_ONLY. The affect this had was creating a delay on startup for the NOR version which is XIP and doesn't have SPL, so the lowlevel initialization functions need to operate. This delay was not really noticeable at first, but the delays have been getting longer, finally reached the point of nearly seven seconds before the board would appear to start. This patch sets the CONFIG_SKIP_LOWLEVEL_INIT_ONLY instead which means "The normal CP15 init (such as enabling the instruction cache) is still performed" per the README. It doesn't appear to have any adverse behavior on the SPI Flash or the NAND flash boards which use SPL. Fixes: 93f3362762f0 ("ARM: configs: Add da850evm_nand to boot from NAND") Signed-off-by: Adam Ford <aford173@gmail.com>
2019-08-12arm: dts: k3-am65: add support for PCIe and SERDESSekhar Nori
Add needed device-tree nodes to support PCIe 0 and SERDES on AM65x SoC. The nodes are kept disabled by default. Signed-off-by: Sekhar Nori <nsekhar@ti.com>
2019-08-12dm: core: add support for getting register address and sizeSekhar Nori
Current dev_read_*() API lacks support to get address and size of a "reg" property by name or index. Add support for the same. Livetree support has been added but not tested on real hardware. The existing unit tests testing reading address from device-tree have been updated to test address as well as size. Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com>
2019-08-12clk: add support for clk_is_match()Sekhar Nori
Add support for clk_is_match() which is required to know if two clock pointers point to the same exact physical clock. Also add a unit test for the new API. Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com>
2019-08-12board/BuR/brsmarc1: initial commitHannes Schmelzer
This commit adds support for the B&R brsmarc1 SoM. The SoM is based on TI's AM335x SoC. Mainly vxWorks 6.9.4.x is running on the board, doing some PLC stuff on various carrier boards. Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
