path: root/include
2019-06-11ARM: imx: dh-imx6: Convert SATA support to DMMarek Vasut
Enable DM SATA support on DHCOM iMX6 PDK2. Convert board code to match the DM support. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Ludwig Zenz <lzenz@dh-electronics.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-11config: Update KP's imx53 HSC config to pass key pressed informationLukasz Majewski
The information about pressed key is relevant in performing correct update and recovery scenarios via USB pendrive. This commit modifies envs to provide it. Signed-off-by: Lukasz Majewski <lukma@denx.de>
2019-06-11config: Update KP's imx53 HSC config to support SWUpdateLukasz Majewski
This commit updates envs responsible for using USB pendrive as a SWUpdate based tool for recovery and update. Signed-off-by: Lukasz Majewski <lukma@denx.de>
2019-06-11imx: hab: Increase CSF_SIZE for i.MX6 and i.MX7 devicesBreno Matheus Lima
In certain i.MX devices the encrypted boot image is failing to boot. According to AN12056 "Encrypted Boot on HABv4 and CAAM Enabled Devices" it's necessary to pad CSF to 0x2000 and append DEK blob. In this case the total image size in boot data structure must cover the entire binary otherwise the dek_blob won't be copied to memory and image won't be decrypted. Increase CSF_SIZE to 0x4000 to avoid such issue when booting encrypted boot images. Signed-off-by: Breno Lima <breno.lima@nxp.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2019-06-11regulator: bd71837: copy the bd71837 pmic driver from NXP imx u-bootMatti Vaittinen
https://source.codeaurora.org/external/imx/uboot-imx cherry picked, styled and merged commits: - MLK-18387 pmic: Add pmic driver for BD71837: e9a3bec2e95a - MLK-18590 pmic: bd71837: Change to use new fdt API: acdc5c297a96 Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Matti Vaittinen <matti.vaittinen@fi.rohmeurope.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-06-11configs: imx6-engicam: Update the recoveryboot settingJagan Teki
Since recovery boot on mmc can get the mmcpart and mmcroot dynamically, drop the static definitions and handle it properly. Tested-by: Shyam Saini <shyam.saini@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2019-06-11apalis/colibri imx6: provide proper fdtfile valueIgor Opaniuk
Provide proper fdtfile env variable value before invoking distro_bootcmd command. Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-06-11board: toradex: add colibri imx8qxp 2gb wb it v1.0b module supportMarcel Ziswiler
This commit adds initial support for the Toradex Colibri iMX8QXP 2GB WB IT V1.0B module. Unlike the V1.0A early access samples exclusively booting from SD card, they are now strapped to boot from eFuses which are factory fused to properly boot from their on-module eMMC. U-Boot supports either booting from the on-module eMMC or may be used for recovery purpose using the universal update utility (uuu) aka mfgtools 3.0. Functionality wise the following is known to be working: - eMMC and MMC/SD card - Ethernet - GPIOs - I2C Unfortunately, there is no USB functionality for the i.MX 8QXP as of yet. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-06-07lib/vsprintf: allow printing upper case GUIDsHeinrich Schuchardt
In the UEFI context GUIDs are expected to be rendered in upper case. The patch uses the formerly unused bit 1 of the parameter str_format of function uuid_bin_to_str() to indicate if we need upper or lower case output. Function uuid_string() in vsprint.c is adjusted to correctly set the bit depending on the print format code. %pUb: 01020304-0506-0708-090a-0b0c0d0e0f10 %pUB: 01020304-0506-0708-090A-0B0C0D0E0F10 %pUl: 04030201-0605-0807-090a-0b0c0d0e0f10 %pUL: 04030201-0605-0807-090A-0B0C0D0E0F10 Up to this point only a diagnostic message in mount_ubifs() using '%pUB' is concerned by the change. Further patches are needed to adjust the UEFI subsystem. A unit test is provided inside the ut_print command. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-06-05Merge tag 'efi-2019-07-rc4-2' of git://git.denx.de/u-boot-efiTom Rini
Pull request for UEFI sub-system for v2019.07-rc4-2 Support for managing the non-volatile attribute of UEFI variables is added though we do not have a backend for persistence yet. Error messages for changes of UEFI variables are provided. UEFI boottime service implementations are corrected.
2019-06-05configs/legoev3: define CONFIG_SKIP_LOWLEVEL_INITDavid Lechner
This adds a define for CONFIG_SKIP_LOWLEVEL_INIT in the legoev3 config. On the EV3, U-Boot is loaded into RAM by another bootloader, so we don't need the lowlevel init in U-Boot. Signed-off-by: David Lechner <david@lechnology.com> Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
2019-06-05riscv: Add Microchip MPFS Icicle board supportPadmarao Begari
This patch adds Microchip MPFS Icicle board support. For now, NS16550 serial driver is only enabled. The Microchip MPFS Icicle defconfig by default builds U-Boot for M-Mode with SMP support. Signed-off-by: Padmarao Begari <padmarao.begari@microchip.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de>
2019-06-05riscv: increase the environment size for the qemu-riscv platform to 128kBKarsten Merker
The existing default size of 4kB is too small as the default environment has already nearly that size and defining a single additional environment variable can exceed the available space. Signed-off-by: Karsten Merker <merker@debian.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-06-04lib: time: export usec_to_tick()Heinrich Schuchardt
In the UEFI Stall() boottime service we need access to usec_to_tick(). Export the function. Remove redundant implementation in arch/arm/mach-rockchip/rk_timer.c. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-05-31efi_loader: export efi_set_time()Heinrich Schuchardt
To let a board implement the runtime version of SetTime() we have to provide the definition of the weak function in an include. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-05-31rtc: export rtc_month_days()Heinrich Schuchardt
Export function rtc_month_days() for reuse in the UEFI subsystem. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-05-31efi_loader: correct notification of protocol installationHeinrich Schuchardt
When a protocol is installed the handle should be queued for the registration key of each registered event. LocateHandle() should return the first handle from the queue for the registration key and delete it from the queue. Implement the queueing. Correct the selftest. With the patch the UEFI SCT tests for LocateHandle() are passed without failure. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-05-31ARM: dts: sync Amlogic G12A DT with Linux 5.2-rc1Neil Armstrong
Sync from Linux commit a188339ca5a3 ("Linux 5.2-rc1") Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-05-28cmd: remove unused `display` commandHeinrich Schuchardt
Compiling the display command leads to an error undefined reference to `display_set' No implementation of display_set() exists in U-Boot. Eliminate the `display` command as well as the accompanying files. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-05-28dm: arm: bcmstb: Enable driver model MMC supportThomas Fitzsimmons
For bcm7445 and bcm7260, this patch enables CONFIG_DM_MMC and updates the bcmstb SDHCI driver to use the new driver model. This allows removal of SDHCI configuration handling from bcmstb.c, and eliminates a board removal compile warning. Signed-off-by: Thomas Fitzsimmons <fitzsim@fitzsim.org> Reviewed-by: Stefan Roese <sr@denx.de>
2019-05-28mcx: remove boardBartosz Golaszewski
This board still doesn't select CONFIG_DM and seems to be umaintained. As it makes progress on modernizing several DaVinci drivers more difficult and the maintainer has not expressed interest in updating it, this patch proposes to remove it. Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
2019-05-28twister: remove boardBartosz Golaszewski
This board still doesn't select CONFIG_DM and seems to be umaintained. As it makes progress on modernizing several DaVinci drivers more difficult and the maintainer has not expressed interest in updating it, this patch proposes to remove it. Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com> Acked-by: Stefano Babic <sbabic@denx.de>
2019-05-28mt_ventoux: remove boardBartosz Golaszewski
2019-05-28cm_t3517: remove boardBartosz Golaszewski
2019-05-28ipam390: remove boardBartosz Golaszewski
This board still doesn't select CONFIG_DM and seems to be umaintained. As it makes progress on modernizing several DaVinci drivers more difficult and the maintainer has not expressed interest in updating it, this patch proposes to remove it. Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com> Acked-by: Heiko Schocher <hs@denx.de>
2019-05-28eco5pk: remove boardBartosz Golaszewski
2019-05-28ea20: remove boardBartosz Golaszewski
2019-05-28calimain: remove boardBartosz Golaszewski
2019-05-28board/BuR: invalidate ${dtbaddr} before cfgscrHannes Schmelzer
The first memory location of ${dtbaddr} may be still valid after a warm restart of the machine and 'fdt addr ${dtbaddr}' doesn't recognize that the cfgscript didn't run properly and fallback mechanism with copying the internal fdt ${fdtcontroladdr} to ${dtbaddr} doesn't catch this. To get sure that we have proper failsafe behaviour we simply zero the first memory location of ${dtbaddr} for getting sure that the fdt is invalid if cfgscript didn't run. Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2019-05-26Merge branch 'master' of git://git.denx.de/u-boot-shTom Rini
- Gen3 PCIe driver + enablement on Salvator-X platforms. - Gen3 recovery SPL used to reload ATF/OpTee/U-Boot instead of minimon. - SDHI HS400 fixes ported from latest BSP and datasheet.
2019-05-26configs: Migrate CONFIG_FMAN_ENET and some related options to KconfigTom Rini
Move the main symbol for Freescale Fman Ethernet controller option to Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and rename the SPIFLASH one to follow the same format as all of the others. To do this fully we need to migrate CONFIG_QC, do so. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-25Merge tag 'efi-2019-07-rc3-3' of git://git.denx.de/u-boot-efiTom Rini
Pull request for UEFI sub-system for v2019.07-rc3 (3) Several bug fixes for the UEFI sub-system are provided. The SetTime() boottime service is implemented.
2019-05-24efi_loader: comments for structsHeinrich Schuchardt
Change comments for struct efi_open_protocol_info_item and struct efi_handler to Sphinx format. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-05-24Merge tag 'u-boot-stm32-20190523' of https://github.com/pchotard/u-bootTom Rini
- Add various STM32MP1 fixes for serial, env, clk, board, i2c ... - Add STM32MP1 DDR driver update: These update introduce the DDR interactive mode described in: https://wiki.st.com/stm32mpu/index.php/U-Boot_SPL:_DDR_interactive_mode This mode is used by the CubeMX: DDR tuning tool. https://wiki.st.com/stm32mpu/index.php/STM32CubeMX The DDR interactive mode is NOT activated by default because it increase the SPL size and slow down the boot time (200ms wait added).
2019-05-24configs: remove CONFIG_SYS_DSPI_XX referencesAngelo Dureghello
This patch removes CONFIG_SYS_DSPI_XX options from include/configs "m68k" .h board files, since CTAR registers are now set with default values in the cf_spi driver initialization, and configurable by devicetree. Note, these options cannot be totally removed from the whitelist, since still used from boards using fsl_dspi.c (mostly arm-based boards). Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2019-05-24drivers: spi: cf_spi: convert to driver modelAngelo Dureghello
Converting to driver model and removes non-dm code. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2019-05-23stm32mp1: migrate PREBOOT to KconfigPatrick Delaunay
Use Kconfig to activate CONFIG_PREBOOT (empty by default). Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-05-23stm32mp1: Move ENV_SIZE and ENV_OFFSET to KconfigPatrick Delaunay
Add arch stm32mp for ENV migration step and drop more items from include/configs/xxx.h. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-05-23stm32mp1: Move config SYS_MALLOC_LEN to KconfigPatrick Delaunay
This patch moves the the config SYS_MALLOC_LEN to Kconfig as it is already done for zynq arch in commit 01aa5b8f0503 ("Kconfig: Move config SYS_MALLOC_LEN to Kconfig for zynq") Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-05-22Merge tag 'dm-pull-22may19' of git://git.denx.de/u-boot-dmTom Rini
Various DM fixes Addition of ofnode_get_addr_size_index()
2019-05-22armv8: lx2160: Drop useless CONFIG_CMDLINE_EDITING from config.hAndy Shevchenko
commit 58c3e62040be ("armv8: lx2160ardb : Add support for LX2160ARDB platform") brought a new boards support with redundancy in the config.h. One of them is CONFIG_CMDLINE_EDITING which is removed by this change. Cc: Priyanka Jain <priyanka.jain@nxp.com> Cc: Peng Ma <peng.ma@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-22armv8: Secure Boot: Modify boot_a_script definitionVinitha V Pillai
esbc_validate command will not be executed if “load” command for its header fails and will further execute the source command for bootscript, without its validation and boot process continues. To halt the boot process in case secure boot header is not loaded successfully, esbc_validate command is invoked separately after “load” command. The secure boot validation of the bootscript header will fail (if header is not loaded) and halts the boot process, which prevent source command from execution. Signed-off-by: Vinitha V Pillai <vinitha.pillai@nxp.com> Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-22board: fsl: lx2160ardb: invert AQR107 pins polarityFlorin Chiculita
AQR107 PHYs interrupt pins are active-low, while the GIC expects a level-high signal. Signed-off-by: Florin Chiculita <florinlaurentiu.chiculita@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-22armv8: ls1028aqds: Add support of LS1028AQDSYuantian Tang
LS1028AQDS Development System is a high-performance computing, evaluation, and development platform that supports LS1028A QorIQ Architecture processor. Signed-off-by: Sudhanshu Gupta <sudhanshu.gupta@nxp.com> Signed-off-by: Rai Harninder <harninder.rai@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@nxp.com> Signed-off-by: Tang yuantian <andy.tang@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-22armv8: ls1028ardb: Add support for LS1028ARDBYuantian Tang
LS1028A is an ARMv8 implementation. LS1028ARDB is an evaluation platform that supports the LS1028A family SoCs. This patch add basic support of the platform. Signed-off-by: Sudhanshu Gupta <sudhanshu.gupta@nxp.com> Signed-off-by: Rai Harninder <harninder.rai@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@nxp.com> Signed-off-by: Tang Yuantian <andy.tang@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-21core: ofnode: Have ofnode_read_u32_default return a u32Trent Piepho
It was returning an int, which doesn't work if the u32 it is reading, or the default value, will overflow a signed int. While it could be made to work, when using a C standard/compiler where casting negative signed values to unsigned has a defined behavior, combined with careful casting, it seems obvious one is meant to use ofnode_read_s32_default() with signed values. Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Trent Piepho <tpiepho@impinj.com>
2019-05-21core: ofnode: Add ofnode_get_addr_size_indexKeerthy
Add ofnode_get_addr_size_index function to fetch the address and size of the reg space based on index. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-05-21fdtdec: Remove fdt_{addr,size}_unpack()Thierry Reding
U-Boot already defines the {upper,lower}_32_bits() macros that have the same purpose. Use the existing macros instead of defining new APIs. Signed-off-by: Thierry Reding <treding@nvidia.com>
2019-05-21Add an empty stdint.h fileSimon Glass
Some libraries build by U-Boot may include stdint.h. This is not used by U-Boot itself and causes conflicts with the types defined in linux/types.h. To work around this, add an empty file with this name so that it will be used in preference to the compiler version. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-05-21ARM: rmobile: Add recovery SPL for R-Car Gen3Marek Vasut
Build an SPL which can be started via SCIF download mode on R-Car Gen3 and allows loading and executing U-Boot uImage with the next stage code. This is also useful for starting e.g. ATF BL2, which inits the hardware and returns to the U-Boot SPL, which can then load e.g. U-Boot proper. The H3, M3-W, M3-N SoCs have plenty of SRAM for storing the U-Boot SPL while the payload, e.g. ATF BL2, executes, so there is no problem here. However, E3 and D3 have much less SRAM, hence the loader uses a trick where it copies itself beyond the area used by BL2 and executes from there. That area is 32kiB large and not enough to hold U-Boot SPL, BSS, stack and malloc area, so the later two are placed at +0x4000 offset from start of SRAM, another area not used by ATF BL2. To make things even more complicated, the SCIF loader cannot load to the upper 32kiB of the SRAM directly, hence the copying approach. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
