a single #define.
March 13, 2005); new configuration options CONFIG_JFFS2_LZO and
CONFIG_JFFS2_LZARI are added. Both are undefined by default.
Added missing variable declaration in cmd_nand.c
Modified CFG_PCI_PTM1MS in configs/PLU405.h to map 128MB ram
Update for P3G4
Fix problems in cmd_universe.c
PM520 boards.
Fix PHY address for canmb board.
Cleanup.
Make PCI target address spaces on PMC405 and CPCI405 boards
configurable via environment variables
Add i2c_reg_write() and i2c_reg_write() for at91rm9200 I2C
* Patch by Steven Scholz, 07 Apr 2005:
Fix compiler warning in altera.c
* Patch by Ladislav Michl, 06 Apr 2005:
Fix voiceblue configuration.
Updates for OCOTEA board:
- Changed U-Boot size from 512kByte to 256kByte
- Fixed flash driver to support boot from soldered user flash
- Added README for switch from PIBS firmware to U-Boot
- creating SoC subdir for Atmel AT91RM9200 cpu/arm920t/at91rm9200
- moving code out of cpu/at91rm9200 into cpu/arm920t/at91rm9200
- update the pxa-regs.h file for PXA27x chips
- add PXA27x based ADSVIX board
- add support for MMC on PXA27x processors
* Patch by Andrew E. Mileski, 28 Nov 2004:
Fix PPC4xx SPD SDRAM detection bug
* Patch by Hiroshi Ito, 26 Nov 2004:
Fix logic of "test -z" and "test -n" commands
Add support for VoiceBlue board.
* Patch by Ladislav Michl, 05 Apr 2005:
Fix netboot_common() prototypes.
* Cleanup.
- Use i.MX watchdog timer for reset_cpu()
- Move reset_cpu() out of cpu/arm920t/start.S into the SoC specific
subdirectories cpu/arm920t/imx/ and cpu/arm920t/s3c24x0/
(now in interupts.c)
Interfaces are named as follows: "ENET1" - TSEC2, "ENET2" - FEC
* Patch by Martin Krause, 04 Apr 2005:
Update default configuration for CMC_PU2 board.
- remove all references to CONFIG_INIT_CRITICAL for ARM based boards
- introduce two new configuration options instead:
CONFIG_SKIP_LOWLEVEL_INIT and CONFIG_SKIP_RELOCATE_UBOOT
reset timers so it's save to use udelay() in timeout code.
- Add low-boot option for MPC8260ADS board (if lowboot is selected,
the jumper for the HRCW source should select flash. If lowboot is
not selected, the jumper for the HRCW source should select the
BCSR.
- change default load base address to 0x00400000
Add support for Analogue & Micro Rattler boards.
Tested on Rattler8248.
* Patch by Andre Renaud, 08 Nov 2004:
Fix watchdog support in common/lcd.c
* Patch by Marc Leeman, 05 Nov 2003:
Enable all 4 PCMBRW buffers for the MPC8245 processor since the CPU
bug only affects the XPC8245 processors
- Add support for MicroSys CPU87 board
- Add support for MicroSys PM854 board
Add missing 440GX SDRAM Controller reset
Declare reset_cpu() in include/common.h instead locally
- Add support for HIDDEN_DRAGON board
- fix endianess problem in driver/rtl1839.c
* Patch by Allen Curtis, 21 Oct 2004:
support multiple serial ports
- create SoC specific directories include/asm-arm/arch-imx and
include/asm-arm/arch-s3c24x0
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL
- rename memsetup into lowlevel_init (function name and source files)
enable SNTP support in some boards.
Add automatic HW detection for CMC_PU2 and CMC_BASIC
Fix flash erase timeout on CMC_PU2
add SNTP support and expand time server and time offset fields of
DHCP support. See doc/README.SNTP
* Patch by Steven Scholz, 13 Dec 2004:
Fix bug in at91rm920 ethernet driver
Remove duplicated code by merging memsetup.S files for
at91rm9200 boards into one cpu/at91rm9200/lowlevel.S
Cleanup duplicate definition of overwrite_console()
* Update TQM5200 configuration;
prepare for Rev. 200 starter kit boards
Add support for Nios-II EPCS Controller core.
* Patch by Scott McNutt, 20 Oct 2004:
Nios-II cleanups:
- Add sysid command (Nios-II only).
- Locate default exception trampoline at proper offset.
- Implement I/O routines (readb, writeb, etc)
- Implement do_bootm_linux
- use TQM5200_auto as MAKEALL target for TQM5200 systems
- add support for SM501 graphics controller
- add support for graphic console on TQM5200
- add support for TQM5200 Rev 200
- cleanup, fix typo in include/configs/TQM5200.h
* Cleanup, fix typo in include/configs/TQM5200.h
- Change the name of the Ethernet driver: MOTO ENET -> ENET
- Reformat boot messages
- Enable redundant environment
- Replace the -O2 optimization flag with -mno-string
Restore copyright statements in OHCI drivers.
* Add support for TQM8540 board
NC650: changed NAND flash addressing to using UPMB
"brightness" environment variable.
(common/cmd_ide.c, common/cmd_reiser.c, common/cmd_scsi.c).
* Enable USB and IDE support for INKA4x0 board
* Patch by Andrew Dyer, 28 February 2005:
fix ext2load passing an incorrect pointer to get_partition_info()
resulting in load failure for devices other than 0
