https://gitlab.denx.de/u-boot/custodians/u-boot-imx
Fixes for 2019.07
- menlo board
- allow SDB on Sabre
- HAB for mx6sl
- apalis board
Default value (4000ms) of PHY_ANEG_TIMEOUT for Micrel KSZ9031 contoller
isn't sufficient to finish auto-negotiation, which sometimes leads to
timeout errors:
Apalis iMX6 # dhcp
FEC Waiting for PHY auto negotiation to complete......... TIMEOUT !
Increase the auto-negotiation time-out to 15000ms.
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Reviewed-by: Philippe Schenker <philippe.schenker@toradex.com>
Enable DM Video support on iMX53 M53Menlo and fix minor details
to restore previous behavior of the system.
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Since the pico-pi uses the distroboot,
this commit remove the 'script' variable (cf boot_scripts).
Signed-off-by: Pierre-Jean Texier <pjtexier@koncepto.io>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
Fix set_emmcargs wrapper, which prepares proper bootargs for booting
from eMMC.
Add support for loading u-boot FIT images over the USB SDP protocol in
the SPL
Signed-off-by: Frieder Schrempf <frieder.schrempf@kontron.de>
[Various build fixes]
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Tested-by: Fabio Estevam <festevam@gmail.com>
Tested-by: Lukasz Majewski <lukma@denx.de>
Add SPL support for rk3328, default with of-platdata enabled.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
[cherry picked from https://github.com/rockchip-linux/u-boot/commit/cb2b7a1bc75ebb116b1eb9b0ae0223e84d86fc4b with minor modifications]
Signed-off-by: Matwey V. Kornilov <matwey.kornilov@gmail.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-efi
Pull request for UEFI sub-system for v2019.07-rc5 (3)
This pull request provides error fixes for the graphical output protocol,
the text output protocol, and the extended text input protocol.
Setting the boot device for the bootefi command is now not only supported
by the 'load' command but also for the file system specific commands like
'fatload'.
IDE devices are no longer automatically probed by u-boot, so it should
be done by the distro boot command before attempting to boot from IDE
(just like scsi and nvme)
Signed-off-by: Joshua Watt <JPEWhacker@gmail.com>
Extra "not DM" controllers support is disabled.
u-boot BSP still good enough to upgrade and run images.
Signed-off-by: Oleksandr Zhadan <oleks@arcturusnetworks.com>
Signed-off-by: Michael Durrant <mdurrant@arcturusnetworks.com>
EFI_SIMPLE_TEXT_OUTPUT_PROTOCOL.Reset() is a function and not a void *
pointer.
- PCIe driver change to support DM model
- T2080QDS migrated to use PCIe DM model
Disable legacy PCIe driver and unused PCIe macros when DM_PCI enabled.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Use the Kconfig option to select the PCIe reset errata.
- LS1046AFRWY support
- USB errata fix and secure boot defconfig support for LS1028A
- Enabled SDHC and SATA for LX2160
- LS1046A serdes fixes
- other minor fixes
LS1046AFRWY board supports LS1046A family SoCs. This patch
add base support for this board.
Board support's 4GB ddr memory, i2c, micro-click module,microSD card,
serial console,qspi nor flash,ifc nand flash,qsgmii network interface,
usb 3.0 and serdes interface to support two x1gen3 pcie interface.
Signed-off-by: Camelia Groza <camelia.groza@nxp.com>
Signed-off-by: Madalin Bucur <madalin.bucur@nxp.com>
Signed-off-by: Pankit Garg <pankit.garg@nxp.com>
Signed-off-by: Pramod Kumar <pramod.kumar_1@nxp.com>
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Signed-off-by: Vabhav Sharma <vabhav.sharma@nxp.com>
During SD boot, MC firmware and DPC are copied from SD card to DDR.
Size reserved between MC and DPC firmware on DDR is 1MB.
If the size of MC firmware(load address 0x80000000) is more than 1 MB
then part of MC firmware will be overwritten by DPC firmware (load
address 0x80100000).
Fix: Update the MC/DPL/DPC firmware's DDR address as per their
respective addresses in SD card.
Signed-off-by: Wasim Khan <wasim.khan@nxp.com>
Add bootcmd for IFC NOR boot and SD boot.
Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com>
Add secure boot defconfig for ls1028aqds and ls1028ardb boards.
Signed-off-by: Yuantian Tang <andy.tang@nxp.com>
Default environment variable is more complete. Also scans for efi
binaries for example.
Signed-off-by: Mian Yousaf Kaukab <ykaukab@suse.de>
- Drop zipitz2 board (Tom)
- Add DEPRECATED option (Tom)
- Mark legacy or non-dm drivers as DEPRECATED (Jagan)
- Assorted gadget fixes
Pull request for UEFI sub-system for v2019.07-rc5 (2)
This pull request provides bug fixes for the UEFI sub-system. The most
relevant one concerns the allocation of memory at address 0. It is
needed for booting Linux on several boards via bootefi, e.g. the Asus
TinkerBoard.
An undefined reference bug in disk/part.c related to a division is
resolved.
- More board removal
The setexpr shell command calls cmd_get_data_size() which is only built
when CMD_DATA_SIZE is defined. We need to define CMD_DATA_SIZE if
CONFIG_CMD_SETEXPR is selected or the build will fail if no other
command selecting this option is enabled.
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
In order to migrate this symbol to Kconfig introduce a new symbol to
guard it, CONFIG_SYS_CUSTOM_LDSCRIPT. When that is set we can then
provide the exact final location o the script.
A number of boards set CONFIG_SYS_LDSCRIPT and then end up using one of
the default searched LDSCRIPT paths. Remove these customizations.
The non-CONFIG_SPL_FRAMEWORK SPL used on some PowerPC platforms have a
choice between CONFIG_SPL_NAND_BOOT, CONFIG_SPL_MMC_BOOT and
CONFIG_SPL_SPI_BOOT. Migrate this to Kconfig
Convert CONFIG_TFTP_BLOCKSIZE to Kconfig, update defconfigs,
headers and whitelist.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Christian Gmeiner <christian.gmeiner@gmail.com>
Convert CONFIG_IP_DEFRAG to Kconfig, update defconfigs, headers
and whitelist. This patch is a follow-up on a patch by Christian
Gmeiner with the added config/header/whitelist updates.
Reported-by: Christian Gmeiner <christian.gmeiner@gmail.com>
This variable is defined in UEFI specification 2.8, section 8.1.
Its value should be updated whenever we add any usable runtime services
function.
Currently we only support SetVirtualAddress() for all systems and
ResetSystem() for some.
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Last change to this board was done in 2016, has no prospects of
ever being converted to DM, drop it.
Cc: Chris Brandt <chris.brandt@renesas.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Cc: Vladimir Zapolskiy <vz@mleia.com>
Cc: Yoshihiro Shimoda <shimoda.yoshihiro.uh@renesas.com>
In fastboot_*_get_part_info() functions we can use stronger typing by
expecting const strings.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Now that various SPI related options depend on CONFIG_DEPRECATED, in
order for platforms to build out of the box they need to disable various
other options.
Cc: Albert ARIBAUD <albert.aribaud@3adev.fr>
Reviewed-by: Marek Vasut <marek.vasut@gmail.com>
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Per discussion on the list, drop this board again.
Cc: Vasily Khoruzhick <anarsoul@gmail.com>
Acked-by: Vasily Khoruzhick <anarsoul@gmail.com>
- pinctrl: meson-gx: fix GPIO_TEST_N and GPIOCLK_ groups
- pinctrl: meson-gxbb: add hdmi related pins to fix HDMI on GXBB
- pinctrl: meson: add support for getting pinmux status
- pinctrl: meson-g12a: add support for drive-strength-microamp property
This pull request provides fixes for event services.
Add drive-strength-microamp property support to allow drive strength in uA
Signed-off-by: Guillaume La Roque <glaroque@baylibre.com>
Tested-by: Neil Armstrong <narmstrong@baylibre.com>
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
- Add Ethernet support for STM32MP1
- Add saveenv support for STM32MP1
- Add STM32MP1 Avenger96 board support
- Add SPI driver suport for STM32MP1
- Add watchdog support for STM32MP1
- Update power supply check via USB TYPE-C for STM32MP1 discovery board
u-boot-imx-20190612
- Board fixes:
- imx6logic
- wandboard
- mx6sabre boots again
- imx8qm_mek
- pico-* boards
- Toradex apalis / colibri
- engicam imx6 (environment)
- KP MX53
- opos6ul
- Switch to DM:
- vining2000
- dh MX6
- Toradex colibri i.MX7
- Novena
- Security : fix CSF size for HAB
- Other:
- imx: fix building for i.mx8 without spl
- pcie and switch to DM
mx6sabreauto: Enable SPL SDP support
Enable DM Serial support on iMX6SX VINING|2000.
Cc: Silvio Fricke <silvio.fricke@softing.com>
Remove such unneeded custom config options because the
provided default values are good enough.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Acked-by: Peng Fan <peng.fan@nxp.com>
