With the latest mach-types values we have many instances where we no
longer need to define a value and a few cases where the name (but not
value) have changed slightly.
This reverts commit 70b26cd057f42c7126088b49d4285955c8a00eae.
This is not a strict revert as it is easier to fix
board/atmark-techno/armadillo-800eva/armadillo-800eva.c to now the
correct name (same value) than to revert that change too.
We convert CONFIG_PARTITION_UUIDS to Kconfig first. But in order to cleanly
update all of the config files we must also update CMD_PART and CMD_GPT to also
be in Kconfig in order to avoid complex logic elsewhere to update all of the
config files.
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
This is not used in U-Boot, and the only usage calls a non-existent
function. Drop it.
This is only called from one place and the function cannot be inlined.
Convert it to a normal function.
This is not defined anywhere in U-Boot. Drop this dead code.
To avoid an unnecessary arch-specific call in board_init_f(), rename this
function.
CONFIG_ARCH_MISC_INIT
CONFIG_BOARD_EARLY_INIT_F
CONFIG_ARCH_EARLY_INIT_R
This patch enables the MMC support for the SDHCI controller on the
Armada 7k db-88f7040 and the Armada 8k db-88f8040 board.
Cc: Nadav Haklai <nadavh@marvell.com>
Cc: Kostya Porotchkin <kostap@marvell.com>
Cc: Wilson Ding <dingwei@marvell.com>
Cc: Victor Gu <xigu@marvell.com>
Cc: Hua Jing <jinghua@marvell.com>
Cc: Terry Zhou <bjzhou@marvell.com>
Cc: Hanna Hawa <hannah@marvell.com>
Cc: Haim Boot <hayim@marvell.com>
Armada 3700 db-88f3720 board.
Some SDHCI drivers might need to do some special controller configuration
after the common clock set_ios() function has been called (speed / width
configuration). This patch adds a call to the newly created function
set_ios_port() when its configured in the host driver.
This will be used by the Xenon SDHCI controller driver used on the
Marvell Armada 3700 and 7k/8k ARM64 SoCs.
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
The module is continuously rebooting with the following message:
Net: data abort
pc : [<fff77f42>] lr : [<fff6e32b>]
reloc pc : [<80816f42>] lr : [<8080d32b>]
sp : fdf5ce48 ip : fdf5d79c fp : 00000017
r10: 8083cd58 r9 : fdf5cef0 r8 : fdf5d5d0
r7 : 48485000 r6 : 400000ff r5 : fdf5d6e0 r4 : fdf5d618
r3 : fdf5d5b4 r2 : fdf5d5d0 r1 : 643a3631 r0 : fdf5d6e0
Flags: nzCv IRQs off FIQs off Mode SVC_32
Resetting CPU ...
Modifications:
* Enable Ethernet configuration in the SPL.
* Update PINMUX of PHY enable GPIO.
Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
Rename CONFIG_IMX31_PHYCORE_EET to CONFIG_TARGET_IMX31_PHYCORE_EET and
make this a distinct config target.
The sdhci controller assumes that the base clock frequency is fully supported by
the peripheral and doesn't support hardware limitations. The Linux kernel
distinguishes between base clock (max_clk) of the host controller and maximum
frequency (f_max) of the card interface. Use the same differentiation and allow
the platform to constrain the peripheral interface.
Signed-off-by: Stefan Herbrechtsmeier <stefan.herbrechtsmeier@weidmueller.com>
We may want to run different firmware before running U-Boot. For
example, ARM Trusted Firmware runs before U-Boot, making U-Boot
a non-secure world boot loader. In this case, the SoC might be
initialized there, which enables us to skip SPL entirely.
This commit removes "select SPL" to make it configurable. This
also enables the Multi SoC support for the UniPhier ARMv8 SoCs.
(CONFIG_ARCH_UNIPHIER_V8_MULTI) Thanks to the driver model and
Device Tree, the U-Boot proper part is now written in a generic way.
The board/SoC parameters reside in DT. The Multi SoC support
increases the memory footprint a bit, but the U-Boot proper does
not have strict memory constraint. This will mitigate the per-SoC
(sometimes per-board) defconfig burden.
Move all of the status LED feature to drivers/led/Kconfig.
The LED status definitions were moved from the board configuration
files to the defconfig files.
TBD: Move all of the definitions in the include/status_led.h to the
relevant board's defconfig files.
Tested boards: CL-SOM-AM57x, CM-T335
Signed-off-by: Jagan Teki <jagan@openedev.com>
When falcon mode support was added, it was right around when SPL_OS_BOOT
was migrated to Kconfig. So first we must move the enablement to the
defconfig file. Next, it turned off EXT support rather than add the
information to allow for falcon mode from EXT. Add this information so
that the board compiles after 5d28b930f237.
Fixes: d96796ca23b2 ("mx6sabresd: Add Falcon mode support")
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Use the generic "distro" boot framework to enable automatic DHCP boot.
MMC and USB are not yet implemented, so this is the only boot option.
The fdt and kernel addresses are adopted from downstream; ramdisk and
scriptaddr addresses were chosen arbitrarily.
Signed-off-by: Andreas Färber <afaerber@suse.de>
Reviewed-by: Alexander Graf <agraf@suse.de>
Move it from meson-gxbb-common.h to odroid-c2.h to allow new boards not
to implement it.
Some scripts are calling the same functions, so these changes consolidate
common scripts together to reduce redundancy and shrink size a bit. This
also keeps the 'bootargs' variable from growing if manually called more
than one time. This also adds NAND booting scripts based on newly consolidated
scripts.
In 35fc84f, bootm was refactored so plain 'bootm' and
'bootm <subcommand>' shared a common implementation.
The 'bootm ramdisk' command implementation is now part of the common
implementation but not invoke by plain 'bootm' since the original
implementation never did ramdisk relocation. Instead, ramdisk
relocation happened in image_setup_linux() which is typically called
during the OS portion of 'bootm'.
On ARM, parameters to the Linux kernel can either be passed by FDT or
ATAGS. When using FDT, image_setup_linux() is called which also triggers
ramdisk relocation. When using ATAGS, image_setup_linux() is _not_
called because it mostly does FDT setup.
Instead of calling image_setup_linux() in both FDT and ATAGS cases,
include BOOTM_STATE_RAMDISK in the requested states during a plain
'bootm' if CONFIG_SYS_BOOT_RAMDISK_HIGH is set and remove the ramdisk
relocation from image_setup_linux(). This causes ramdisk relocation to
happen on any system where CONFIG_SYS_BOOT_RAMDISK_HIGH regardless of
the OS being booted. Also remove IMAGE_ENABLE_RAMDISK_HIGH as it was
only used by the now-removed code from image_setup_linux().
Signed-off-by: Rick Altherr <raltherr@google.com>
Reviewed-by: Joel Stanley <joel@jms.id.au>
commit: 65f83802b7a5b "serial: 16550: Add getfcr accessor"
breaks u-boot commandline working with long commands
sending to the board.
Since the above patch, you have to setup the fcr register.
For board/archs which enable OF_PLATDATA, the new field
fcr in struct ns16550_platdata is not filled with a
default value ...
This leads in not setting up the uarts fifo, which ends
in problems, when you send long commands to u-boots
commandline.
Detected this issue with automated tbot tests on am335x
based shc board.
The error does not popup, if you type commands. You need
to copy&paste a long command to u-boots commandshell
(or send a long command with tbot)
Possible boards/plattforms with problems:
./arch/arm/cpu/arm926ejs/lpc32xx/devices.c
./arch/arm/mach-tegra/board.c
./board/overo/overo.c
./board/quipos/cairo/cairo.c
./board/logicpd/omap3som/omap3logic.c
./board/logicpd/zoom1/zoom1.c
./board/timll/devkit8000/devkit8000.c
./board/lg/sniper/sniper.c
./board/ti/beagle/beagle.c
./drivers/serial/serial_rockchip.c
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Tested-by: Adam Ford <aford173@gmail.com>
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
[York S: clean up scripts/config_whitelist.txt]
Add the chip power supply voltage initialization on LS1046ARDB.
Add function power_init_board(), and it will initialize the
PMIC and call the chip power initialization function.
Set up chip power supply voltage according to voltage ID.
The fuse status register provides the values from on-chip
voltage ID fuses programmed at the factory. These values
define the voltage requirements for the chip.
Main operations:
1. Set up the core voltage
2. Set up the SERDES voltage and reset SERDES lanes
3. Enable/disable DDR controller support 0.9V if needed
This patch adds a simple pmic driver for the mc34vr500 pmic which
is used in conjunction with the fsl T1 and LS1 series SoC.
Add secure boot validation of MC, DPC images using
esbc_validate command.
Signed-off-by: Sumit Garg <sumit.garg@nxp.com>
Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com>
This patch binds the sys_info->freq_systembus to Platform PLL, and
implements the IPs' clock function individually.
Up to now, there are 3 kind of SoCs under Layerscape Chassis 2,
like LS1043A, LS1046A and LS1012A. But the clocks tree has a
lot of differences, for instance, the IP modules have different
dividers to derive its clock from Platform PLL. And the core
cluster PLL and platform PLL maybe have different reference
clocks, such as LS1012A. Another problem is which clock/PLL
should be described by sys_info->freq_systembus, it is confused
in Layerscape Chissis 2.
This patch is to bind the sys_info->freq_systembus to the Platform
PLL, and handle the different divider of IP modules separately
between different SoCs, and separate reference clocks of core
cluster PLL and platform PLL.
Enable UUID and GPT partition support for NXP's ARM based SoCs
i.e. LS1012A, LS1021A, LS1043A, LS1046A and LS2080A.
Also enable DOS partition for LS1012AFRDM boards.
Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
The patch enables PCIe in ls2080a defconfigs and
removes unused PCIe related macro defines.
Signed-off-by: Minghuan Lian <Minghuan.Lian@nxp.com>
The patch enables PCIe and E1000 in ls1043a defconfigs and
The patch enables PCIe and E1000 in ls1012a defconfigs and
The patch enables PCIe in ls1021a defconfigs and
Enable usb feature for ls1046ardb
Signed-off-by: Changming Huang <jerry.huang@nxp.com>
