This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
Another shell scripting command that has not been moved.
Moved using tools/moveconfig.py using these settings:
CMD_SETEXPR bool n y
Commit 92ac52082140 (net: Remove all references to CONFIG_ETHADDR
and friends) accidentally dropped #endif. Since then, gr_ep2s60
could not build.
scripts/kconfig/conf --silentoldconfig Kconfig
CHK include/config.h
GEN include/autoconf.mk
In file included from include/config.h:5:0,
from ./include/common.h:18:
include/configs/gr_ep2s60.h:15:0: error: unterminated #ifndef
#ifndef __CONFIG_H__
make[1]: *** [include/autoconf.mk] Error 1
Add ARMv7M STM32F1 support including clocks, timer, gpio, and flash.
Signed-off-by: Matt Porter <mporter@konsulko.com>
Switch to generic timer implementation from lib/time.c .
This also fixes a signed overflow which was in __udelay()
implementation.
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Tyler Baker <tyler.baker@linaro.org>
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
The foundation model (FVP) emulator nominally boots using
a clean, uncompressed kernel and the "booti" command. Augment
the default U-Boot script to do this.
gd->ram_size is stored as phys_size_t type which can be bigger than an
unsigned long on some architectures. When using unsigned long type,
SDRAM of 4GiB or larger will not print the correct size, but using
phys_size_t will.
Signed-off-by: Andrew Bradford <andrew.bradford@kodakalaris.com>
bootm_find_ramdisk_fdt() renamed to bootm_find_images() for readability.
The function bootm_find_ramdisk_fdt() appears to be a simple wrapper for
bootm_find_ramdisk(), bootm_find_fdt(), and now bootm_find_loadables().
I didn't see any other callers entering a bootm_find<thing>, so removing
the wrapper, and condensing these together hopefully makes the code a
little simpler.
Signed-off-by: Karl Apsite <Karl.Apsite@dornerworks.com>
Added a trimmed down instance of boot_get_<thing>() to satisfy the
minimum requierments of the added feature. The function follows the
normal patterns set by other boot_get<thing>'s, which should make it a
bit easier to combine them all together into one boot_get_image()
function in a later refactor.
Documentation for the new function can be found in source:
include/image.h
Added FIT_LOADABLE_PROP, so the user can identify an optional entry
named "loadables" in their .its configuration. "loadables" is a comma
separated list in the .its
Documentation can be found in doc/uImage.FIT/source_file_format.txt and
doc/uImage.Fit/multi-with-loadables.its
In the latest Linux coding style, <linux/io.h> should be included
rather than <asm/io.h>. To follow this standard also in U-Boot,
add include/linux/io.h. Currently, it just includes <asm/io.h>.
The Juno reference design typically plugs the root FS
on a USB stick. We need to wait a bit for the root to
appear so tell this on the default command line.
Generic board support seems to work just fine. Tested on ml507 with
bitstream generated on the latest ISE software.
Tested-by: Georg Schardt <schardt@team-ctech.de>
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
The ARM Trusted Firmware or other security solutions are
eating memory from the top of the physical SDRAM1 space,
moving backward from 0xffffffff, currently occupying e.g.
0xfe000000-0xffffffff with Trusted Firmware.
This solution to reserving memory for secure world is not
optimal, so we need to think of how the secure world and
earlier boot stages should communicate to U-Boot what
memory they are eating up. For now let's just put 16MB
aside.
Also enable the memory test command and define start and
end of the test range so we can check that we actually have
all that memory available and working.
Suggested-by: Axel Haslam <ahaslam@baylibre.com>
Define U_BOOT_TZ alongside U_BOOT_TIME and U_BOOT_DATE and use it to
include the timezone in the version output.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
Testing on the ARM Versatile Express Juno board showed intermittent CFI
flash detection problems.
Debug output in exception cases showed that the NOR flash was returning
incorrect values to a query command:
fwc addr 0000000008000000 cmd f0 f0f0f0f0 32bit x 8 bit
fwc addr 0000000008000000 cmd ff ffffffff 32bit x 8 bit
fwc addr 0000000008000154 cmd 98 98989898 32bit x 8 bit
is= cmd 51(Q) addr 0000000008000040 is= 00800051 51515151
fwc addr 0000000008001554 cmd 98 98989898 32bit x 8 bit
fwc addr 0000000008000000 cmd f0 00f000f0 32bit x 16 bit
fwc addr 0000000008000000 cmd ff 00ff00ff 32bit x 16 bit
fwc addr 0000000008000154 cmd 98 00980098 32bit x 16 bit
is= cmd 51(Q) addr 0000000008000040 is= 00800051 00510051
fwc addr 0000000008001554 cmd 98 00980098 32bit x 16 bit
Debugging showed that the problem could be solved by preventing u-boot
from scanning different flash widths by specifying
CONFIG_SYS_FLASH_CFI_WIDTH so that only using the 'correct' width was
used.
Signed-off-by: Ryan Harkin <ryan.harkin@linaro.org>
Move CONFIG_CMD_CACHE to mx6_common and standardise the way it's defined.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Reviewed-by: Tom Rini <trini at konsulko.com>
Move all standard mx6 MMC configs to mx6_common.
Move all standard filesystem, partition and fdt options to mx6_common.
Move generic miscellaneous options that are standard across most, if not all,
mx6 boards to central mx6_common define to ensure consistent features.
Define common LOADADDR and BOOTDELAY to ensure a consistent experience
across mx6 boards
Define CONFIG_MXC_GPIO and CONFIG_CMD_GPIO by default in mx6_common
Define the standard ATAG consfigs in mx6_common.
All boards define CONFIG_MX6, CONFIG_DISPLAY_BOARDINFO, CONFIG_DISPLAY_CPUINFO
and CONFIG_SYS_GENERIC_BOARD so define them in mx6_common
The linux/sizes.h, asm/arch/imx-regs.h, asm/imx-common/gpio.h,
config_cmd_default.h includes are used fairly universally across imx6 boards
so include them in mx6_common.h by default.
We define CONFIG_SYS_NO_FLASH before config_cmd_default.h so that we
don't have to undef CONFIG_CMD_FLASH / CONFIG_CMD_IMLS everywhere.
Standardise mx6_common.h to the same as other mx6 boards
We will use the same env size and redundancy used for NAND env for MMC.
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
add support for imx6dl based aristainetos2 board
U-Boot 2015.04-rc5-00066-g60f6ed4 (Apr 10 2015 - 08:46:27)
CPU: Freescale i.MX6DL rev1.1 at 792 MHz
Reset cause: WDOG
Board: aristaitenos2
Watchdog enabled
I2C: ready
DRAM: 1 GiB
NAND: 1024 MiB
MMC: FSL_SDHC: 0
SF: Detected N25Q128A with page size 256 Bytes, erase size 64 KiB, total 16 MiB
Display: lg4573 (480x800)
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Hit any key to stop autoboot: 0
Don't use error-prone arch timer code and instead use system
timer implementation to simplify our code.
This changes enable ONFI detection. The Read ID command now allows
one address byte which is needed for ONFI detection. To read the
ONFI parameter page, the NAND_CMD_PARAM need to be supported. The
CMD code enables one command and one address byte along with reading
data from flash using R/B#, as specified by ONFI.
Signed-off-by: Stefan Agner <stefan@agner.ch>
This commit allows users to enable/disable the Freescale NFC
controller found in systems like Vybrid (VF610), MPC5125, MCF54418
or Kinetis K70 via Kconfig with more detailed help docs.
[scottwood: updated vf610twr_nand_defconfig]
Falcon mode entails the SPL booting the OS directly instead of U-Boot.
Currently we need to build one U-boot image for each of the wandboard
variants: quad, dual-lite and solo.
By switching to SPL we can support all these variants with a single binary,
which is very convenient.
Based on the work from Richard Hu.
Tested kernel booting on the three boards.
Signed-off-by: Richard Hu <hakahu@gmail.com>
Tested-by: Vagrant Cascadian <vagrant@aikidev.net>
Reviewed-by: Stefano Babic <sbabic@denx.de>
Add a new "env" subcommand to the ut command.
This will run unit tests on the env code. This should be targetable to
any device that supports the env features needed for the tests.
The asserts are sometimes called from the context of the test command
itself so make sure that a return that happens as a result of a failure
is compatible with that command return. When called within a test, the
return value is ignored.
Unify the command for running unit tests further by moving the "ut_time"
command over to "ut time".
Unify the command for running unit tests further by moving the "dm test"
command over to "ut dm".
Add a command that all other unit tests should be a sub-command of.
Also include a command that will run all tests.
Separate the ability to define tests and assert status of test functions
from the dm tests so they can be used more consistently throughout all
tests.
When the ethaddr is changed in the env, update the device pdata at the
same time (only if it is probed for the DM case; only if registered for
the non-DM case). Again this gets us closer to completely non-polled
env needed to simplify the net_loop.
This requires that the NET feature select the REGEX feature.
Check that the common network stack's env vars conform to the proper
format for IP addresses.
Instead of checking for changes to the env each time we enter the
net_loop, use the env callbacks to update the values of the variables.
Don't update the variables when the source was programmatic, since the
variables were the source of the new value.
Use a regular expression to apply the default formatting flags for all
ethaddr env vars.
We already could tell the difference in the callback between an import
and "other" which we called interactive. Now add further distinction
between interactive (i.e. running env set / env edit / env ask / etc.
from the U-Boot command line) and programmatic (i.e. when u-boot source
calls any variant of setenv() ).
Allow the features that use env_attrs to specify regexs for the name
In some cases it can be helpful to have context in the callback about
the calling situation. This is needed for following patches.
