This commit replaces legacy timer code with usage of arc timer
driver.
It removes arch/arc/lib/time.c file and selects CONFIG_CLK,
CONFIG_TIMER and CONFIG_ARC_TIMER options for all ARC boards by default.
Therefore we remove CONFIG_CLK option from less common axs101 and
axs103 defconfigs.
Also it removes legacy CONFIG_SYS_TIMER_RATE config symbol from
axs10x.h, tb100.h and nsim.h configs files as it is no longer required.
Signed-off-by: Vlad Zakharov <vzakhar@synopsys.com>
Enable SPL_DM on all AM43xx based platforms
Enable SPL_DM on all DRA7 based platforms.
Enable SPL_DM on all AM57xx based platforms.
Add support for the Broadcom Northstar2 SoC and SVK (bcm958712k). The
BCM5871X is a series of quad-core 64-bit 2GHz ARMv8 Cortex-A57
processors targeting a broad range of networking applications.
Signed-off-by: Jon Mason <jon.mason@broadcom.com>
In stead of defining the board EEPROM address in the board headers
let's define them in the board config files and make them
configurable by Kconfig.
Signed-off-by: Roger Quadros <rogerq@ti.com>
Scratch space can be used for features such as board detection. Define
an area within SRAM that can be used for this purpose.
[rogerq@ti.com] Rename EEPROM macro
Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com>
configs/bk4r1_defconfig
configs/colibri_vf_defconfig
configs/pcm052_defconfig
include/configs/colibri_vf.h
include/configs/pcm052.h
Move this in to Kconfig with a default of 115200.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
[trini: Run moveconfig.py, reword commit slightly]
Prepare for boards with EMMC instead of NAND flash
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
Move Freescale/NXP Vybrid to a standard arch/board approach, similar
to what has been done to i.MX 6 earlier in commit 89ebc82137be ("ARM:
mx6: move to a standard arch/board approach").
Reviewed-by: Stefano Babic <sbabic@denx.de>
Use two separate partitions for the two firmware instances. Also
resize them to be of the same size which also makes the start of
the UBI partition nicely aligned to 0x400000.
In order to detect the new MTD layout and whether we run a U-Boot
with the new BCB format or not, introduce a variable called
"updlevel" which we can use in update/upgrade scripts.
Use device-tree fixup to communicate the MTD partitions to the
kernel. Remove mtdparts from the kernel command line.
Limit memory used for relocation of FDT or initrd. This is
required to make sure that relocated artifacts are within lowmem.
If fdt_high or initrd_high are not set, U-Boot automatically
relocates artifacts to the end of memory. But this area won't
be part of lowmem and hence will not be accessible by the kernel
during early boot.
With VM split set to 2G/2G (i.MX default), only the 2GB Apalis
iMX6 is affected by that issue. With VM split set to 3G/1G (ARM
default) also modules with 1GB of memory are affected. With the
latter the amount of lowmem will be 760MiB.
The value must also not exceed available memory! Use a safe value
of 512MiB for Apalis and 256MiB for Colibri.
OPOS6UL is an i.MX6UL based SoM with 256MB RAM, 4GB eMMC and an ethernet
phy. OPOS6ULDev is carrier board for the OPOS6UL.
U-Boot SPL 2017.03-rc3-00002-g5085c26 (Mar 07 2017 - 09:48:09)
Trying to boot from MMC1
U-Boot 2017.03-rc3-00002-g5085c26 (Mar 07 2017 - 09:48:09 +0100)
CPU: Freescale i.MX6UL rev1.0 528 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 40C
Reset cause: POR
Model: Armadeus Systems OPOS6UL SoM on OPOS6ULDev board
DRAM: 256 MiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Video: 800x480x18
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Hit any key to stop autoboot: 0
Signed-off-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Today, we have cases where we wish to build all of U-Boot in Thumb2 mode for
various reasons. We also have cases where we only build SPL in Thumb2 mode due
to size constraints and wish to build the rest of the system in ARM mode. So
in this migration we introduce a new symbol as well, SPL_SYS_THUMB_BUILD to
control if we build everything or just SPL (or in theory, just U-Boot) in
Thumb2 mode.
Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
CONFIG_SPL_ABORT_ON_RAW_IMAGE causes SPL to abort and move on when it
encounters RAW images, express this same functionality as a positive
option enabling support for RAW images: CONFIG_SPL_RAW_IMAGE_SUPPORT
Also move uses of this to defconfigs.
Signed-off-by: Andrew F. Davis <afd@ti.com>
[trini: Rework Kconfig logic a little, move to common/spl/Kconfig]
This includes support for rk3188 from Heiko Stübner and and rk3328 from
Kever Yang. Also included is SPL support for rk3399 and a fix for
rk3288 to get it booting again (spl_early_init()).
Boards with an apparent need for the md5sum command had the connected
config symbol defined in their board header file.
Move this over to the respective defconfig files now that md5sum is
configured via Kconfig.
(This is a manual effort, which differs from moveconfig.py, not sure
who is right here. Boards except sandbox loose the md5sum command with
moveconfig.py, though it was explicitly mentioned in their config.h's)
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
[trini: migrate stih410-b2260]
FIT images require MD5 support to verify image checksums. So far this
was expressed by defining a CPP symbol in image.h. Since MD5 is now a
first class Kconfig citizen, express that in Kconfig instead.
This adds support for TQMa6DL using i.MX6DL and 1GiB DRAM
Since The module will use the same devicetree, we patch
the ram size in ft_board_setup.
Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
We have a Kconfig name for the module types. Let's Use it.
Some feature selections and configurations are based on the
module. Module selection selects the CPU type.
Let the runtime code can set the mmcdev and mmcroot based
on the devno using mmc_get_env_dev instead of defining
separately in build-time configs using mmc_late_init func.
Cc: Matteo Lisi <matteo.lisi@engicam.com>
Cc: Michael Trimarchi <michael@amarulasolutions.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Add runtime, modeboot env which is setting mmcboot based
on the bootdevice so-that conditional macros for MMC via
CONFIG_BOOTCOMMAND should be avoided in config files.
Boot from eMMC:
U-Boot SPL 2017.01-00318-g8e243f8 (Jan 26 2017 - 11:53:21)
Trying to boot from MMC2
U-Boot 2017.01-00318-g8e243f8 (Jan 26 2017 - 11:53:21 +0100)
CPU: Freescale i.MX6D rev1.2 at 792 MHz
Reset cause: POR
Model: Engicam i.CoreM6 Quad/Dual RQS Starter Kit
DRAM: 512 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
switch to partitions #0, OK
mmc1(part 0) is current device
Net: No ethernet found.
Booting from mmc ...
Reviewed by: Stefano Babic <sbabic@denx.de>
Add runtime, modeboot env which is setting mmcboot, or
nandboot based on the bootdevice so-that conditional
macros b/w MMC and NAND for CONFIG_BOOTCOMMAND should
Boot from eMMC:
U-Boot SPL 2017.01-00314-gd0cd9cd-dirty (Jan 25 2017 - 13:25:27)
U-Boot 2017.01-00314-gd0cd9cd-dirty (Jan 25 2017 - 13:25:27 +0100)
CPU: Freescale i.MX6UL rev1.1 528 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 36C
Reset cause: POR
Model: Engicam Is.IoT MX6UL eMMC Starterkit
DRAM: 512 MiB
In: serial
Out: serial
Err: serial
Add config options for booting Linux from NAND in UBI format.
Add NAND support for Engicam Is.IoT MX6UL board.
Add FEC support for Engicam Is.IoT MX6UL module.
Boot from MMC:
U-Boot SPL 2017.01-rc2-gba3c151-dirty (Jan 02 2017 - 16:59:33)
U-Boot 2017.01-rc2-gba3c151-dirty (Jan 02 2017 - 16:59:33 +0100)
CPU: Industrial temperature grade (-40C to 105C) at 33C
Reset cause: POR
Model: Engicam Is.IoT MX6UL Starterkit
DRAM: 512 MiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
Net: CPU Net Initialization Failed
No ethernet found.
isiotmx6ul>
USDHC base address will assigned by SPL using fsl_esdhc_initialize
and u-boot with devicetree, hence no remove base address assignment
in config files.
Enable MMC support.
The fsl sdhc driver needs regulator to enable power, so enable
regulator support.
And bootcmd and more env.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Add EVK board support.
Add the evk dts file.
LOG:
U-Boot 2017.03-rc2-00038-gab86c1d (Feb 22 2017 - 15:59:58 +0800)
CPU: Freescale i.MX7ULP rev1.0 at 500 MHz
Reset cause: POR
Boot mode: Dual boot
Model: NXP i.MX7ULP EVK
DRAM: 1 GiB
MMC: FSL_SDHC: 0
In: serial@402D0000
Out: serial@402D0000
Err: serial@402D0000
Net: Net Initialization Skipped
No ethernet found.
Add i.MX7ULP dtsi file.
Add clock and pinfun header files.
Add i.MX7ULP support.
The buadrate calculation on i.MX7ULP is different,so add a new setbrg
function for i.MX7ULP.
Add a enum lpuart_devtype for runtime check for different platforms.
Cc: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Cc: York Sun <york.sun@nxp.com>
Cc: Shaohui Xie <Shaohui.Xie@nxp.com>
Cc: Alison Wang <b18965@freescale.com>
Commit e856bdcfb492 ("flash: complete CONFIG_SYS_NO_FLASH move with renaming")
obsoleted the CONFIG_SYS_NO_FLASH option, which still is in our
rk3188_common.h header, resulting in warnings like
The following new ad-hoc CONFIG options were detected:
CONFIG_SYS_NO_FLASH
So also drop it from the rk3188 header.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Documentation says that we're returning true/false, not 1/0 so adapt
the function to return actual booleans.
evb-rk3328 is an evb from Rockchip based on rk3328 SoC:
- 2 USB2.0 Host port;
- 1 USB3.0 Host port;
- 1 HDMI port;
- 2 10/100M eth port;
- 2GB ddr;
- 16GB eMMC;
- UART to USB debug port;
Signed-off-by: William Zhang <william.zhang@rock-chips.com>
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
RK3328 is a SoC from Rockchip with quad-core Cortex-A53 CPU.
It supports two USB2.0 EHCI ports. Other interfaces are very
much like RK3288, the DRAM are 32bit width address and support
address from 0 to 4GB-16MB range.
Add empty arch/arm/mach-rockchip/rk3328/Kconfig to avoid build error:
Add dts binding header for rk3328, files origin from kernel.
Enable all the CONFIGs which need by SPL.
Added rockchip tag:
Drop CONFIG_ROCKCHIP_DWMMC for now due to build error:
Move changes to arch/arm/mach-rockchip/Kconfig to this patch:
Add SPL support for rk3399, default with of-platdata enabled.
Drop Kconfig changes to fix build error:
We are using wrong mmc instance as boot target device now. below Jaehoon Chung's
patch use mmc alias which correct it. That make tinker board can not find mmc
device. So give it correct mmc device instance.
commit 02ad33aa3a84821c8d9a6c4f167f143f6248b084
Author: Jaehoon Chung <jh80.chung@samsung.com>
Date: Thu Feb 2 13:41:14 2017 +0900
mmc: mmc-uclass: use the fixed devnum with alias node
Signed-off-by: Eddie Cai <eddie.cai.linux@gmail.com>
Add the core architecture code for the rk3188.
It doesn't support the SPL yet, as because of some
unknown error it doesn't start yet.
Tested-by: Kever Yang <kever.yang@rock-chips.com>
Drop these defines from rk3188_common.h
CONFIG_GENERIC_MMC, CONFIG_BOUNCE_BUFFER, CONFIG_DOS_PARTITION
CONFIG_PARTITION_UUIDS, CONFIG_CMD_PART:
Bring in required device clock binding files from Linux.
The clock trees for rk3066 and rk3188 are largely similar, which makes
them share the common parts in a shared header. While we focus on rk3188
for now, bring in both headers already for completeness sake.
