This board has been orphan for a while.
(Emails to its maintainer have been bouncing.)
Because MPC82xx family is old enough, nobody would pick up
the maintainership on it.
Cc: Wolfgang Denx <wd@denx.de>
Because MPC8xx family is old enough, nobody would pick up
The quad100hd has been unmaintained and dead ever since it's been
added some 6 years ago. Remove it.
Also update README.scrapyard and insert some commit IDs for removed
boards.
Cc: Stefan Roese <sr@denx.de>
Cc: Gary Jennejohn <gljennjohn@googlemail.com>
bootdelay_process() never returns in some circumstances, whichs makes the
control flow confusing. Change it so that the decision about how to execute
the boot command is made in the main_loop() code, so it is easier to follow.
Move CLI stuff to cli.c.
Move these details from main (which doesn't care which parser is used) to
cli.c where they belong.
This code seems unnecessarily complex. We really just need to check the
global_data. Now that is it all in one place, and not arch-specific, this
is pretty easy.
Add a bootretry_ prefix to these two functions, and remove the need for
the #ifdef around everything (it moves to the Makefile).
This code is only used by one board, so it seems a shame to clutter up
the readline code with it. Move it into its own file.
The autoboot code is complex and long. It deserves its own file with
a simple interface from main.c.
This makes it clear where the code resides.
It doesn't make sense to have the simple parser and the readline code
all in main. Split them out into separate files.
Move the CLI prototypes from common.h to cli.h as part of an effort to
reduce the size of common.h.
Hush is a command-line interpreter, so rename it to make that clearer.
Add CONFIG_SYS_GENERIC_BOARD for all Exynos4 boards.
Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com>
Cc: Przemyslaw Marczak <p.marczak@samsung.com>
Cc: Lukasz Majewski <l.majewski@samsung.com>
Add the ability to display the code offset of an initcall even after it
is relocated. This makes it much easier to relate initcalls back to the
U-Boot System.map file.
The backlight uses FETs on the TPS65090. Enable this so that the display
is visible.
Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
The TPS65090 pmic chip can be on exynos5250 boards. Therefore,
select the appropriate config option for TPS65090 devices.
This commit should really use exynos5-dt.c, when it is available.
This adds driver support for the TPS65090 PMU. Support includes
hooking into the pmic infrastructure so that the pmic commands
can be used on the console. The TPS65090 supports the following
functionality:
- fet enable/disable/querying
- getting and setting of charge state
Even though it is connected to the pmic infrastructure it does
not hook into the pmic charging charging infrastructure.
The device tree binding is from Linux, but only a small subset of
functionality is supported.
Signed-off-by: Tom Wai-Hong Tam <waihong@chromium.org>
Signed-off-by: Hatim Ali <hatim.rv@samsung.com>
Signed-off-by: Katie Roberts-Hoffman <katierh@chromium.org>
Signed-off-by: Rong Chang <rongchang@chromium.org>
Signed-off-by: Sean Paul <seanpaul@chromium.org>
Signed-off-by: Vincent Palatin <vpalatin@chromium.org>
Signed-off-by: Aaron Durbin <adurbin@chromium.org>
This enum should be common across all PMICs rather than having it
independently defined with the same name in multiple places.
Commit be3b51aa did this mostly, but several have been added since. Do the
job again.
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
Development board for headless gateway platform from Abilis Systems.
Initial commit with working UART and DW GMAC.
For now with generic Ethernet PHY due to problems in Realtek PHY driver.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Christian Ruppert <christian.ruppert@abilis.com>
Cc: Pierrick Hascoet <pierrick.hascoet@abilis.com>
using UBI and DM together leads in compiler error, as
both define a "struct device", so rename "struct device"
in include/dm/device.h to "struct udevice", as we use
linux code (MTD/UBI/UBIFS some USB code,...) and cannot
change the linux "struct device"
In this configuration the environment will save in file: uboot.env of
mmc card.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Also we enable the mmc command in configuration file.
As both CONFIG_CMD_MMC and CONFIG_CMD_USB use the CONFIG_DOS_PARTITION,
so remove the redundant CONFIG_DOS_PARTITION definition.
As at91 board config file will include the SoC header, so we can remove
the ARM926EJS definition in board config files.
Now the AT91FAMILY is already defined in the at91 SoC header. The at91
board config file will include the SoC header file.
So we can remove the redundant AT91FAMILY definition in at91 board
config files.
[rebase patch]
Cc: Bo Shen <voice.shen@atmel.com>
Tested-by: Bo Shen <voice.shen@atmel.com>
The new atmelimage converts a machine code BLOB to bootable ROM image. Atmel
ROM has no sophisticated image format, it only checks the first 7 ARM vectors.
The vectors can contain valid B or LDR opcodes, the 6'th vector contains the
image size to load.
Additionally the PMECC header can be written by the atmelimage target. The
parameters must be given via the -n switch as a coma separated list. For
example:
mkimage -T atmelimage \
-n usePmecc=1,sectorPerPage=4,sectorSize=512,spareSize=64,eccBits=4,eccOffset=36 \
-d spl/u-boot-spl.bin boot.bin
A provided image can be checked for correct header setup. It prints out the
PMECC header parameters if it has one and the 6'th interrupt vector content.
---8<---
Image Type: ATMEL ROM-Boot Image with PMECC Header
PMECC header
eccOffset: 36
sectorSize: 512
eccBitReq: 4
spareSize: 64
nbSectorPerPage: 4
usePmecc: 1
6'th vector has 17044 set
--->8---
A SPL binary modified with the atmelimage mkimage target was succesfully
booted on a sama5d34ek via MMC and NAND.
Enable CONFIG_SYS_GENERIC_BOARD, so that we get rid of the following
warning on boot:
"Warning: Your board does not use generic board. Please read
doc/README.generic-board and take action. Boards not
upgraded by the late 2014 may break or be removed."
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Tested-by: Josh Wu <josh.wu@atmel.com>
warning on boot:
warning on boot:
warning on boot:
It supports boot from NAND and SD/MMC card.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Add support for booting from an MMC card.
Signed-off-by: Henrik Nordström <henrik@henriknordstrom.net>
Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
Cc: Tom Cubie <Mr.hipboi@gmail.com>
Reviewed-by: Tom Rini <trini@ti.com>
On Mon, 2014-05-05 at 14:18 +0200, Stefan Roese wrote:
> > + case 1:
> > +#if CONFIG_MMC1_PG
> Are you sure that this is correct and shouldn't be:
> +#ifdef CONFIG_MMC1_PG
It's "correct" in so far as it works (the boards.cfg config stuff
#defines things to 1), but I think you are right that it isn't the
preferred style. But...
> A quick scan through this patch series shows that this define
> is not set at all. Perhaps its outdated? Or is it used to support
> some other sunxi SoC? Not sure, perhaps it should be removed for
> now.
...I had thought that it was to support some other board which wasn't
being upstreamed right now, so eventually useful and harmless for now,
but I've just checked and it isn't actually used by any of the boards in
u-boot-sunxi.git. So rather than fix it to use #ifdef lets drop it.
Rather than resend the entire series, here is v5.1 of this patch.
> Other than this please add my:
> Reviewed-by: Stefan Roese <sr@denx.de>
Thanks!
8<---------------------------------
>From 20704e35a41664de5f516ed0e02981ac06085102 Mon Sep 17 00:00:00 2001
Date: Fri, 7 Mar 2014 04:29:39 +0000
Subject: [PATCH v5.1 7/8] sunxi: mmc support
This adds support for the MMC controller on the Allwinner A20 (sun7i)
processor.
Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net>
Signed-off-by: Luke Leighton <lkcl@lkcl.net>
Signed-off-by: Oliver Schinagl <oliver@schinagl.nl>
Signed-off-by: Wills Wang <wills.wang.open@gmail.com>
Cc: Aaron Maoye <leafy.myeh@allwinnertech.com>
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
Add support for the GMAC Ethernet controller on Allwinner A20 (sun7i)
processors. Enable for the Cubietruck.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Signed-off-by: Jens Kuske <jenskuske@gmail.com>
This patch adds generic board, start of day and basic build system support for
the Allwinner A20 (sun7i) processor. This code will not been compiled until the
build is hooked up in a later patch. It has been split out to keep the patches
manageable.
Signed-off-by: Adam Sampson <ats@offog.org>
Signed-off-by: Aleksei Mamlin <mamlinav@gmail.com>
Signed-off-by: Alexandru Gagniuc <mr.nuke.me@gmail.com>
Signed-off-by: Emilio López <emilio@elopez.com.ar>
Signed-off-by: Luc Verhaegen <libv@skynet.be>
Signed-off-by: Patrick Wood <patrickhwood@gmail.com>
Enable CONFIG_SYS_GENERIC_BOARD on highbank.
Signed-off-by: Rob Herring <robh@kernel.org>
Move addresses for kernel, ramdisk and fdt blob to own variables. Add dtb
blob loading to all existing boot scripts, dtb filenames were taken from
vanilla kernel. Introduce new boot script bootcmd_legacy, which only loads
a kernel and a ramdisk. Make this the default boot script. This should also
restore the behaviour of the original bootloader.
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Tom Rini <trini@ti.com>
Signed-off-by: Michael Walle <michael@walle.cc>
Add environment partition runtime detection callback.
Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il>
