This patch is essentially an update of u-boot MTD subsystem to
the state of Linux-3.7.1 with exclusion of some bits:
- the update is concentrated on NAND, no onenand or CFI/NOR/SPI
flashes interfaces are updated EXCEPT for API changes.
- new large NAND chips support is there, though some updates
have got in Linux-3.8.-rc1, (which will follow on top of this patch).
To produce this update I used tag v3.7.1 of linux-stable repository.
The update was made using application of relevant patches,
with changes relevant to U-Boot-only stuff sticked together
to keep bisectability. Then all changes were grouped together
to this patch.
Signed-off-by: Sergey Lapin <slapin@ossfans.org>
[scottwood@freescale.com: some eccstrength and build fixes]
Convert NAND IFC driver to support CONFIG_SYS_NAND_SELF_INIT.
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
Faraday FTSDC010 is a MMC/SD host controller.
Although there is already a driver in current u-boot release,
which is modified from eSHDC and contributed by Andes Tech.
Its performance is too terrible on Faraday A36x SoC platforms,
so I turn to implement this new version of driver which is
10+ times faster than the old one.
It's carefully designed to be compatible with Andes chips,
so it should be safe to replace it.
Signed-off-by: Kuo-Jung Su <dantesu@faraday-tech.com>
CC: Andy Fleming <afleming@gmail.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
The Freescale MPC8220 Power Architecture processors have long reached
EOL; Freescale does not even list these any more on their web site.
Remove the code to avoid wasting maitaining efforts on dead stuff.
Cc: Andy Fleming <afleming@gmail.com>
Use QSGMII card PHY address as default SGMII card PHY address, QSGMII card
PHY address is variable depends on different slot.
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
The VSC8574 is a quad-port Gigabit Ethernet transceiver with four SerDes
interfaces for quad-port dual media capability. This driver supports SGMII
and QSGMII MAC mode. For now SGMII mode is tested.
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
1, Implemented board_ft_fman_fixup_port() to fix port for kernel.
2, Implemented fdt_fixup_board_enet() to fix node status of different
slots and interfaces.
3, Adding detection of slot present for XGMII interface.
4, There is no PHY for XFI, so removed related phy address settings.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
T4160QDS shares the same platform as T4240QDS. T4160 is a low power
version of T4240, with eight e6500 cores, two DDR3 controllers, and
slightly different SerDes protocols.
Signed-off-by: York Sun <yorksun@freescale.com>
Separate CONFIG_PPC_T4240 from board config file. Prepare to add more SoC
variants supported on the same board.
T4240 has voltage ID fuse. Read the fuse and configure the voltage
correctly. Core voltage has higher tolerance on over side than below.
1. fix 10G mac offset by plus 8;
2. add second 10G port info for FM1 & FM2 when init ethernet info;
3. fix 10G lanes name to match lane protocol table;
T4240QDS uses a SST instead of SPANSION SPI flash.
This seems to be a common function for several architectures, so create
a common function rather than duplicating the code in each arch.
Also make an attempt to avoid introducing #ifdefs in the new code, partly
by removing useless #ifdefs around function declarations in the image.h
header.
This code is very large, and in SPL it isn't always useful to print
out image information (in fact there might not even be a console
active). So disable this feature unless this option is set.
There are only two left. One is unnecessary and the other can be moved
to the header file.
Much of the image code uses addresses as ulongs and pointers interchangeably,
casting between the two forms as needed.
This doesn't work with sandbox, which has a U-Boot RAM buffer which is
separate from the host machine's memory.
Adjust the cost so that translating from a U-Boot address to a pointer uses
map_sysmem(). This allows bootm to work correctly on sandbox.
Note that there are no exhaustive tests for this code on sandbox, so it is
possible that some dark corners remain.
Reviewed-by: Marek Vasut <marex@denx.de> (v1)
This function will be used to print signatures as well as hashes, so rename
it. Also make it static since it is not used outside this file.
We intend to add signatures to FITs also, so rename this function so that
it is not specific to hashing. Also rename fit_image_set_hashes() and
This function will be needed by signature checking code, so export it,
and also add docs.
The existing function is long and most of the code is indented a long
way. Before adding yet more code, split this out into its own function.
This is the main entry point to the FIT image verification code. We will
be using it to handle image verification with signatures, so rename the
function.
This function doesn't need to be exported, and with verification
we want to use it for setting the 'value' property in any node,
so rename it.
This code is never compiled into U-Boot, so move it into a separate
file in tools/ to avoid the large #ifdef.
One we split out the FIT code from image.c we will need this function.
Export it in the header.
Rather than repeat the line
#if defined(CONFIG_TIMESTAMP) || defined(CONFIG_CMD_DATE) || \
defined(USE_HOSTCC)
everywhere, put this in a header file and #define IMAGE_ENABLE_TIMESTAMP
to either 1 or 0. Then we can use a plain if() in most code and avoid
the #ifdefs.
The compiler's dead code elimination ensures that the result is the same.
Iterating through subnodes with libfdt is a little painful to write as we
need something like this:
for (depth = 0, count = 0,
offset = fdt_next_node(fdt, parent_offset, &depth);
(offset >= 0) && (depth > 0);
offset = fdt_next_node(fdt, offset, &depth)) {
if (depth == 1) {
/* code body */
Using fdt_next_subnode() we can instead write this, which is shorter and
easier to get right:
for (offset = fdt_first_subnode(fdt, parent_offset);
offset >= 0;
offset = fdt_next_subnode(fdt, offset)) {
/* code body */
Also, it doesn't require two levels of indentation for the loop body.
(Cherry-picked from dtc commit 4e76ec79)
Acked-by: Gerald Van Baren <vanbaren@cideas.com>
We don't measure boot timing on the host, or with SPL, so use both
conditions in the bootstage header. This allows us to avoid using
conditional compilation around bootstage_...() calls. (#ifdef)
Rather than needing to call one of many hashing algorithms in U-Boot,
provide a function hash_block() which handles this, and can support all
available hash algorithms.
Once we have md5 supported within hashing, we can use this function in
the FIT image code.
powerpc-eldk53-warning-fixes
We don't use zlib and gzip but do use lzo, so enable this.
Add a function which allows a (file, function, line number) to be marked
in bootstage.
Reviewed-by: Che-Liang Chiou <clchiou@chromium.org>
This is a convenient way of finding out where boottime is going. Enable
it for coreboot.
Any pointers to name strings that were passed to bootstage_mark_name()
pre-relocation should be copied post-relocation so that they don't get
trashed as the original location of U-Boot is re-used for other
purposes.
This change introduces a new API call that should be called from
board_init_r() after malloc has been initted on any board that uses
bootstage.
Signed-off-by: Doug Anderson <dianders@chromium.org>
Some functions don't have a stub for when CONFIG_BOOTSTAGE is not defined.
Add one to avoid #ifdefs in the code when this is used in U-Boot.
Reviewed-by: Tom Wai-Hong Tam <waihong@chromium.org>
While we don't want PCAT timers for timing, we want timer 2 so that we can
still make a beep. Re-purpose the PCAT driver for this, and enable it in
coreboot.
This timer runs at a rate that can be calculated, well over 100MHz. It is
ideal for accurate timing and does not need interrupt servicing.
Tidy up some old broken and unneeded implementations at the same time.
To provide a consistent view of boot time, we use the same time
base as coreboot. Use the base timestamp supplied by coreboot
as U-Boot's base time.
Signed-off-by: Simon Glass <sjg@chromium.org>base
The gpio spec for bf54x and bf60x differ a lot from the old gpio driver for bf5xx.
A lot of machine macros are used to accomodate both code in one gpio driver.
This patch split the old gpio driver and move new gpio2 support to the generic
gpio driver folder.
- To enable gpio2 driver, macro CONFIG_ADI_GPIO2 should be defined in the board's
config header file.
- The gpio2 driver supports bf54x, bf60x and future ADI processors, while the
older gpio driver supports bf50x, bf51x, bf52x, bf53x and bf561.
- All blackfin specific gpio function names are replaced by the generic gpio APIs.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
- Move blackfin serial driver to the generic driver folder.
- Move blackfin serial headers to blackfin arch head folder.
- Update the include path to blackfin serial header in start up code.
- Enable hw_watchdog_init() in watchdog.h if CONFIG_HW_WATCHDOG is defined.
- Move blackfin hw watchdog driver to the generic driver folder.
- Call hw_watchdog_init() from blackfin board init code.
- Reuse macro CONFIG_WATCHDOG_TIMEOUT_MSECS
- Update README.watchdog accordingly
Remove blackfin specific implementation of the generic serial API when
early print macro is defined.
In BFIN_BOOT_BYPASS mode, don't call generic serial_puts, because
early print in bypass mode is running before code binary is relocated
to the link address.
- Disable NAND driver on bf537-stamp.
- Make MMC_SPI optional.
- Disable LCD driver on bf527-ezkit.
- Enlarge BF609 nor flash reserved size from 256k to 512k bytes.
Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
Add softswitch_output command for bf609-ezkit to enable softswitches.
Signed-off-by: Bob Liu <lliubbo@gmail.com>
Define core 1 L1 code sram start address.
Add function to enable core 1 for BF609 and BF561.
Add config macro to allow customer to run core 1 in uboot init code on core 0.
Enable VIDEO and NAND supports only when the config options is defined.
The define should not have been put in fdt.h originally, libfdt_env.h
is the proper place for target-specific customizations.
Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
This commit adds a license header to fdt.h and libfdt_env.h
because the license was omitted.
U-Boot note: the u-boot libfdt_env.h header portion was not applied to
the u-boot libfdt_env.h because that file was created by Gerald Van Baren
(with a license header). - gvb
Ref: DTC commit 27cdc1b1
Signed-off-by: Justin Sobota <jsobota@ti.com>
Acked-by: David Gibson <david@gibson.dropbear.id.au>
Ref: DTC commit cc11e522
Signed-off-by: François Revol <revol@free.fr>
This function is useful outside libfdt, so export it.
Ref: DTC commit b7aa300e
