path: root/include
2012-09-01video: add dp_enabled variable in vidinfo structureDonghwa Lee
To support display port in exynos fb driver, added dp_enabled variable in vidinfo structure that set in board file. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-09-01arm:trats: loaduimage environment variable defied for TRATS targetŁukasz Majewski
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-09-01SMDK5250: Enable UART and MMC for Exynos5250 Rev 1.0Rajeshwari Shinde
This patch sets UART3 and MMC channle 0 for Exynos5250 Rev 1.0 Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-09-01SMDK5250: Add smdk5250-uboot-spl.ldsRajeshwari Shinde
Default spl/u-boot-spl.lds created by spl/Makefile resolves the spl text load addr to 0x0. As 0x0 belongs to iROM addr so Global variables can not be used. Adding specific smdk5250-uboot-spl.lds makes possible to use Global Variables in spl. Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-09-01tegra20: enable SPL for tegra20 boardsAllen Martin
Add SPL options to tegra20 config files and enable SPL build for tegra20 boards. Also remove redundant code from u-boot that is not contained in SPL. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-01tegra20: tec: add tegra20-common-post.hAllen Martin
Add tegra20-common-post.h to be consistent with other tegra20 boards. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-01tegra20: rename CONFIG_MACH_TEGRA_GENERICAllen Martin
Rename CONFIG_MACH_TEGRA_GENERIC to the less confusing CONFIG_TEGRA. The meaning of the config options is now: CONFIG_TEGRA - Any tegra chip CONFIG_TEGRA20 - A tegra20 family chip CONFIG_TEGRA30 - A tegra30 family chip (not added yet) Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-01tegra20: rename tegra2 -> tegra20Allen Martin
This is make naming consistent with the kernel and devicetree and in preparation of pulling out the common tegra20 code. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-01ARM: add Raspberry Pi model B board, using BCM2835 SoCStephen Warren
The Raspberry Pi model B uses the BCM2835 SoC, has 256MB of RAM, contains an SMSC 9512 USB LAN/Hub chip, and various IO connectors. For more details, see http://www.raspberrypi.org/. Various portions (cache enable, MACH_TYPE setup, RAM size limit, stack relocation to top of RAM) extracted from work by: Oleksandr Tymoshenko <gonzo@bluezbox.com>. GPIO driver enablement by Vikram Narayanan <vikram186@gmail.com>. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Tom Rini <trini@ti.com>
2012-09-01u8500: Separating mmc config parameters from driverJohn Rigby
Configuration in vexpress and u8500.v1 is different from what is needed in u8500.v2. As such, card configuration specifics need to reside in the board file rather than the driver. Signed-off-by: John Rigby <john.rigby@linaro.org> Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01snowball: applying power to LAN and GBF controllersMathieu J. Poirier
LAN and GBF need to be powered explicitely, doing so with interface to AB8500 companion chip. Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: John Rigby <john.rigby@linaro.org>
2012-09-01snowball: Adding architecture dependent initialisationMathieu J. Poirier
Enabling timers and clocks in PRCMU and cleaning up mailbox. Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: John Rigby <john.rigby@linaro.org>
2012-09-01snowball: Add support for ux500 based snowball boardMathieu J. Poirier
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: John Rigby <john.rigby@linaro.org> Acked-by: Tom Rini <trini@ti.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Conflicts: drivers/gpio/Makefile
2012-09-01da8xx/hawkboard: Add support for ohci host controllerSughosh Ganu
Also enable the ohci port on hawkboard. These additions result in an increased u-boot size -- adjust the same accordingly in the board's config. Move the usb header for da8xx platforms under arch-davinci. Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com>
2012-09-01omap4/5/am33xx: Make lowlevel_init available to all armv7 platformsTom Rini
Make the lowlevel_init function that these platforms have which just sets up the stack and calls a C function available to all armv7 platforms. As part of this we change some of the macros that are used to be more clear. Previously (except for am335x evm) we had been setting CONFIG_SYS_INIT_SP_ADDR to a series of new defines that are equivalent to simply referencing NON_SECURE_SRAM_END. On am335x evm we should have been doing this initially and do now. Cc: Sricharan R <r.sricharan@ti.com> Tested-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01am335x evm: Enable support for spi0Tom Rini
2012-09-01sc_sps_1: Adjust board config to use 'mxs' SoC codeOtavio Salvador
Fix build failure due the move of mx28 code to 'mxs' SoC. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de>
2012-09-01MX28: Add SchulerControl SC_SPS_1 platformMarek Vasut
This i.MX28 platform supports the following: * 2x FEC ethernet * USB on USBH0 * I2C EEPROM * SPI NVRAM * LEDs Signed-off-by: Marek Vasut <marex@denx.de>
2012-09-01vision2: do not overwrite the consoleFabio Estevam
On this board, the console is always set to the serial line. Do not allow to overwrite it when video is enabled. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-09-01mx51evk: do not overwrite the consoleFabio Estevam
2012-09-01MX5: mx53loco: do not overwrite the consoleStefano Babic
On this board, the console is always set to the serial line. Do not allow to overwrite it when video is enabled. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-09-01mxs: reorganize source directory for easy sharing of code in i.MXS SoCsOtavio Salvador
Most code can be shared between i.MX23 and i.MX28 as both are from i.MXS family; this source directory structure makes easy to share code among them. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de>
2012-09-01mx28evk: Turn on cachesFabio Estevam
Turn on data and instruction caches. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-09-01Add support for Bluegiga APX4 Development KitVeli-Pekka Peltola
This adds support for Bluegiga APX4 Development Kit. It is built around Freescale i.MX28. Currently supported features are: ethernet, I2C, MMC, RTC and USB. APX4 has only one ethernet port. Signed-off-by: Veli-Pekka Peltola <veli-pekka.peltola@bluegiga.com> Signed-off-by: Lauri Hintsala <lauri.hintsala@bluegiga.com> Cc: Stefano Babic <sbabic@denx.de>
2012-09-01at91: Add support for taskit AT91SAM9G20 boards.Markus Hubig
This adds support for the AT91SAM9G20 boards by taskit GmbH. Both boards, Stamp9G20 and PortuxG20, are integrated in one file. PortuxG20 is basically a SBC built around the Stamp9G20. Signed-off-by: Markus Hubig <mhubig@imko.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Andreas Bießmann <andreas.deve@googlemail.com>
2012-09-01arm : Atmel : add at91sam9x5ek board supportBo Shen
Add at91sam9x5ek board support, this board support the following SoCs AT91SAM9G15, AT91SAM9G25, AT91SAM9G35, AT91SAM9X25, AT91SAM9X35 Using at91sam9x5ek_nandflash to configure for the board Now only supports NAND with software ECC boot up Signed-off-by: Bo Shen <voice.shen@atmel.com> [move MAINTAINERS entry to right place] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01am335x_evm: enable SMSC PHY driverIlya Yanok
Beaglebone uses SMSC PHY which works incorrectly with generic PHY driver so enable SMSC PHY driver to fix networking problems on Beaglebone. Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
2012-09-01dm: Move OMAP GPIO driver to drivers/gpio/Marek Vasut
Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: U-Boot DM <u-boot-dm@lists.denx.de> Cc: Tom Rini <trini@ti.com> Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01dm: Select CONFIG_SPL_GPIO_SUPPORT on OMAPMarek Vasut
This fixes the breakage with SPL on most OMAP boards after the GPIO driver was moved. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: U-Boot DM <u-boot-dm@lists.denx.de> Cc: Tom Rini <trini@ti.com> Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01am33xx evm: Add CONFIG_CMD_EEPROM and relatedTom Rini
am33xx boards have at least one eeprom and in the case of beaglebones with capes, more. Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01am335x_evm: Update config for common usageTom Rini
- Add default commands - Add HUSH parser - Make environment, malloc areas larger - Add ATAGS and OF_LIBFDT - Add defaults to boot ramdisk and MMC, use uEnv.txt Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01OMAP3: igep00x0: add SPL support for IGEP-based boardsJavier Martinez Canillas
This patch adds SPL support for IGEP-based boards. Tested on an IGEPv2 Rev.C board with Micron NAND Flash memory. Signed-off-by: Javier Martinez Canillas <javier@dowhile0.org>
2012-09-01OMAP3: igep00x0: Add config option to choose flash storage memoryJavier Martinez Canillas
IGEP-based boards can have two different flash memories, a OneNAND or a NAND device. Add a configuration option for to choose which memory to use. Signed-off-by: Javier Martinez Canillas <javier@dowhile0.org> Acked-by: Enric Balletbo i Serra <eballetbo@gmail.com>
2012-09-01am335x_evm: CPSW supportChandan Nath
This patch adds board-specific initialization for CPSW on TI AM335X based boards. Tested on BeagleBone. Signed-off-by: Chandan Nath <chandan.nath@ti.com> [Ilya: split board-specific part into separate patch] Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
2012-09-01cpsw: add driver for cpsw ethernet deviceCyril Chemparathy
CPSW is an on-chip ethernet switch that is found on various SoCs from Texas Instruments. This patch adds a simple driver (based on the Linux driver) for this hardware module. This patch also adds support to clean and flush dcache during packet send and receive. Changes by Sandhya: Added support to clean and flush dcache during packet send/receive and added timeouts. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Signed-off-by: Chandan Nath <chandan.nath@ti.com> Signed-off-by: Satyanarayana, Sandhya <sandhya.satyanarayana@ti.com> [Ilya: Cleaned cache handling, some style cleanup, some small fixes, use of internal RAM for descriptors] Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
2012-09-01serial/ns16550: ns16550 has a different register layout on SOC_DA8XXMikhail Kshevetskiy
also fix NS16550_init() as we need 16x divider Signed-off-by: Mikhail Kshevetskiy <mikhail.kshevetskiy@gmail.com> Acked-by: Christian Riesch <christian.riesch@omicron.at> Tested-by: Christian Riesch <christian.riesch@omicron.at> Acked-by: Sughosh Ganu <urwithsughosh@gmail.com> Tested-by: Sughosh Ganu <urwithsughosh@gmail.com>
2012-09-01omap: am335x_evm: enable i2c1 channelSteve Sakoman
This patch sets up pinmux, enables fclk, and defines CONFIG_I2C_MULTI_BUS Signed-off-by: Steve Sakoman <steve@sakoman.com>
2012-09-01beagle: fix termination of buddy env settingPeter Meerwald
Signed-off-by: Peter Meerwald <p.meerwald@bct-electronic.com>
2012-09-01igep00x0: default mmcrootfstype to EXT4Javier Martinez Canillas
omap2plus_defconfig now has built-in compile support for EXT4 enabled by default now. So, we can use EXT4 as the default root file system type for MMC. Signed-off-by: Javier Martinez Canillas <javier@dowhile0.org> Acked-by: Enric Balletbo i Serra <eballetbo@gmail.com>
2012-09-01igep00x0: default to OMAP-specific serial driverJavier Martinez Canillas
An OMAP specific serial driver was merged on the Linux kenel a long time ago. So, it makes sense to default the console name to OMAP ttyO instead of the generic ttyS naming. Signed-off-by: Javier Martinez Canillas <javier@dowhile0.org> Acked-by: Enric Balletbo i Serra <eballetbo@gmail.com>
2012-09-01da850/omap-l138: add support for direct NOR boot modeLad, Prabhakar
This patch adds support for direct NOR boot mode on da850/omap-l138. Added da850evm_direct_nor entry in boards.cfg to allow to build targets. Tested-by: Christian Riesch <christian.riesch@omicron.at> Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com> Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com> Signed-off-by: Hadli, Manjunath <manjunath.hadli@ti.com>
2012-09-01da850/omap-l138: Add support for NAND SPLLad, Prabhakar
This patch adds configuration required for NAND SP on DA850/OMAP-L138. Tested-by: Christian Riesch <christian.riesch@omicron.at> Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com> Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com> Signed-off-by: Hadli, Manjunath <manjunath.hadli@ti.com>
2012-09-01da850/omap-l138: Add support to read u-boot image from MMC/SDLad, Prabhakar
DA850/OMAP-L138 does not support strict MMC/SD boot mode. SPL will be in SPI flash and U-Boot image will be in MMC/SD card. SPL will do the low level initialization and then loads the u-boot image from MMC/SD card. Define CONFIG_SPL_MMC_LOAD macro in the DA850/OMAP-L138 configuration file to enable this feature. Tested-by: Christian Riesch <christian.riesch@omicron.at> Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com> Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com> Signed-off-by: Hadli, Manjunath <manjunath.hadli@ti.com>
2012-09-01da850/omap-l138: Define SPI specific configs for SPL only when SPI is usedLad, Prabhakar
define SPI specific configs for SPL only when CONFIG_USE_SPIFLASH config is defined Tested-by: Christian Riesch <christian.riesch@omicron.at> Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com> Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com> Signed-off-by: Hadli, Manjunath <manjunath.hadli@ti.com>
2012-09-01da850/omap-l138: Make MMC and NOR support mutually exclusiveRajashekhara, Sudhakar
On Logic PD Rev.3 DA850/OMAP-L138 EVM, NOR and MMC/SD cannot work together. This patch enables the MMC/SD support only when NOR support is disabled. NOR Flash identification works even without this patch, but erase and write will have issues. Tested-by: Christian Riesch <christian.riesch@omicron.at> Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com> Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com> Signed-off-by: Hadli, Manjunath <manjunath.hadli@ti.com>
2012-09-01da850/omap-l138: Add MMC support for DA850/OMAP-L138Lad, Prabhakar
This patch adds support for MMC/SD on DA850/OMAP-L138. Tested-by: Christian Riesch <christian.riesch@omicron.at> Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com> Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com> Signed-off-by: Hadli, Manjunath <manjunath.hadli@ti.com>
2012-09-01omap: am335x_evm: remove unused definitionsSteve Sakoman
UART_RESET, UART_CLK_RUNNING_MASK, and UART_SMART_IDLE_EN are defined inn evm.c but not used. Also removes unnecessary include of serial.h PHYS_DRAM_1_SIZE is defined in am335x_evm.h but never used. Signed-off-by: Steve Sakoman <steve@sakoman.com>
2012-09-01OMAP3: mcx: read hot-water-button after resetStefano Babic
Detect hot-water-button to start a differnt image. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tom Rini <trini@ti.com>
2012-09-01OMAP3: mcx: updated default environmentStefano Babic
Patch drops also not used CFI setup in the configuration file. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tom Rini <trini@ti.com>
