This is not used in U-Boot. Drop it.
CONFIG_CMD_DISPLAY
CONFIG_CMD_DIAG
[trini: imply CMD_DIAG on some keymile configs]
This option is not used in U-Boot. Drop it.
CONFIG_CMD_DEKBLOB
Note: This option does not seem to actually be enabled by any board.
[trini: imply under SECURE_BOOT for mx5/6/7]
This option does not exist in U-Boot. Drop it.
CONFIG_CMD_CRAMFS
[trini: imply CMD_CRAMFS for keymile]
CONFIG_CMD_CLK
[trini: imply CMD_CLK on ARCH_ZYNQ]
CONFIG_CMD_CHIP_CONFIG
CONFIG_CMD_CBFS
[trini: imply CMD_CBFS on SYS_COREBOOT]
CONFIG_SYS_WHITE_ON_BLACK
[trini: Make this default y on various SoCs]
CONFIG_CMD_BSP
CONFIG_CMD_BMP
[trini: Add depends on LCD || DM_VIDEO || VIDEO]
CONFIG_CMD_BMODE
[trini: Make this default y and depend on mx5/6/7]
CONFIG_CMD_BEDBUG
CONFIG_CMD_BAT
This looks like a typo. Fix it.
CONFIG_CMD_AES
CONFIG_AES
[trini: Add select AES to CMD_AES]
This is only used by one board and should not be a CONFIG option. Instead
it should use the driver model pmic framework. For now, just move the
setting into the only board that uses it.
CONFIG_PMIC_AS3722
Before converting this to Kconfig, rename it to match the other PMICs.
A few boards had not been fully re-synced with CONFIG_ARCH_MX5 / CONFIG_MX51 /
CONFIG_MX53 being in Kconfig. Do so now.
In Linux, CONFIG_ARCH_OMAP2PLUS is used for OMAP2 or later SoCs.
Rename CONFIG_ARCH_OMAP2 to CONFIG_ARCH_OMAP2PLUS to follow this
naming.
Move the OMAP2+ board/SoC choice down to mach-omap2/Kconfig to slim
down the arch/arm/Kconfig level.
These were reminders that somehow slipped through the cracks
or were erroneously introduced after previous clean-ups.
Getting rid of then once again. Hopefully for good now :)
Where missing and appropriate replace with CONFIG_CMDLINE_EDITING
which really enables shell history as of now.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Peter Griffin <peter.griffin@linaro.org>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Steve Rae <steve.rae@raedomain.com>
Cc: Jon Mason <jon.mason@broadcom.com>
Cc: Stefan Roese <sr@denx.de>
Add support for the Terasic DE10-Nano board. The board
is based on the DE0-Nano-Soc board but adds a larger FPGA
and an HDMI output.
Signed-off-by: Dalon Westergreen <dwesterg@gmail.com>
Reviewed-by: Dinh Nguyen <dinguyen@kernel.org>
Currently $fdtfile is constructed from CONFIG_DEFAULT_TREE, containing
the filename. However on arm64 that file is located in an allwinner
subdirectory.
To avoid the need for users/distros symlinking the .dtb files, prepend
the vendor directory for ARM64.
This aligns Pine64 with other boards such as Raspberry Pi 3.
Signed-off-by: Andreas Färber <afaerber@suse.de>
Reviewed-by: Alexander Graf <agraf@suse.de>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Before this patch, CONFIG_SYS_BOOTPARAMS_LEN was the same size as
CONFIG_SYS_MALLOC_LEN. So, if malloc() had previously been called, and
initr_malloc_bootparams() was called, it would fail with an out-of-
memory error. This patch fixes this issue by expanding the malloc pool
to 256KB.
Signed-off-by: Kyle Edwards <kyleedwardsny@gmail.com>
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
This fixes an issue with the saveenv command causing U-Boot to no
longer work on the QEMU Mips pseudoboard. Because the offset of the
environment was being determined by CONFIG_SYS_MONITOR_LEN, and this
value was less than the actual size of U-Boot, saveenv was overwriting
parts of the U-Boot code. Because CONFIG_SYS_MONITOR_LEN is no longer
used on MIPS, this patch removes it and places the environment at the
end of the pseudoboard's 4MB flash.
As we have now V3s support in board code, the V3s DTSI file should also
be added.
Add also some CCU include headers to satisfy the DTSI file.
Signed-off-by: Icenowy Zheng <icenowy@aosc.xyz>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Basic U-Boot support is now present for V3s.
Some memory addresses are changed specially for V3s, as the original
address map cannot fit into a so small DRAM.
As the DRAM controller code needs a big refactor, the SPL support is
disabled in this version.
Signed-off-by: Icenowy Zheng <icenowy@aosc.io>
Convert the CONS_INDEX configuration to Kconfig.
Update sunxi's defconfigs to remove SYS_EXTRA_OPTIONS variable not
needed anymore.
Default value is 1 except for sun5i (equals 2) and sun8i (equals 5).
Signed-off-by: Mylène Josserand <mylene.josserand@free-electrons.com>
[Maxime: Added a depends on ARCH_SUNXI to avoid build breakages]
If the system is running PSCI firmware, the System Reset function
(func ID: 0x80000009) is supposed to be handled by PSCI, that is,
the SoC/board specific reset implementation should be moved to PSCI.
U-Boot should call the PSCI service according to the arm-smccc
manner.
The arm-smccc is supported on ARMv7 or later. Especially, ARMv8
generation SoCs are likely to run ARM Trusted Firmware BL31. In
this case, U-Boot is a non-secure world boot loader, so it should
not be able to reset the system directly.
Adjust ARM SMC Calling Convention code for U-Boot:
- Replace the license block with SPDX
- Change path to asm-offsets.h
- Define UNWIND() as no-op
- Add Kconfig entry
- Add asm-offsets
Imports ARM SMC Calling Convention code from Linux 4.11-rc6.
The files have been copied as follows:
[Linux] [U-Boot]
arch/arm/kernel/smccc-call.S -> arch/arm/cpu/armv7/smccc-call.S
arch/arm64/kernel/smccc-call.S -> arch/arm/cpu/armv8/smccc-call.S
arch/arm/include/asm/opcodes* -> arch/arm/include/asm/opcodes*
include/linux/arm-smccc.h -> include/linux/arm-smccc.h
Use CONFIG_ARCH_LS1021A instead.
Signed-off-by: York Sun <york.sun@nxp.com>
Use CONFIG_ARCH_LS1043A instead.
Use CONFIG_ARCH_LS2080A instead.
- Add SD secure boot target for ls1046ardb.
- Change the u-boot size defined by a macro for copying the main
U-Boot by SPL to also include the u-boot Secure Boot header size
as header is appended to u-boot image. So header will also be
copied from SD to DDR.
- CONFIG_MAX_SPL_SIZE is limited to 90KB. SPL is copied to OCRAM
(128K) where 32K are reserved for use by boot ROM and 6K for the
header.
- Reduce the size of CAAM driver for SPL Blobification functions
and descriptors, that are not required at the time of SPL are
disabled. Further error code conversion to strings is disabled
for SPL build.
Signed-off-by: Vinitha Pillai <vinitha.pillai@nxp.com>
Signed-off-by: Sumit Garg <sumit.garg@nxp.com>
Signed-off-by: Ruchika Gupta <ruchika.gupta@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
Add NAND secure boot target for ls1043ardb.
U-Boot by SPL to also include the u-boot Secure Boot header size as
header is appended to u-boot image. So header will also be copied
from SD to DDR.
- MACRO for CONFIG_BOOTSCRIPT_COPY_RAM is enabled to copy Bootscript
from NAND to DDR. Offsets for Bootscript on NAND and DDR have been
also defined.
- Add SD secure boot target for ls1043ardb.
- Implement FSL_LSCH2 specific spl_board_init() to setup CAAM stream
ID and corresponding stream ID in SMMU.
from SD to DDR.
(128K) where 32K are reserved for use by boot ROM and 6K for secure
boto header.
- Error messages during SPL boot are limited to error code numbers
instead of strings to reduce the size of SPL image.
Signed-off-by: Vinitha Pillai-B57223 <vinitha.pillai@nxp.com>
Add QSPI Secure Boot target to enable chain of trust
Reviewed-by: Ruchika Gupta <ruchika.gupta@nxp.com>
Add QSPI Secure Boot target. Also enable sec init.
Using changes in this patch we were able to reduce approx 4k
size of u-boot-spl.bin image. Following is breif description of
changes to reduce SPL size:
1. Changes in board/freescale/ls1046ardb/Makefile to remove
compilation of eth.c and cpld.c in case of SPL build.
2. Changes in board/freescale/ls1046ardb/ls1046ardb.c to keep
only ddr_init and board_early_init_f funcations in case of SPL
build.
3. Changes in ls1046a_common.h & ls1046ardb.h to remove driver
specific macros due to which static data was being compiled in
case of SPL build.
4. Disable MMC driver from bieng compiled in case of SPL NAND
build and NAND driver from bieng compiled in case of SPL MMC build.
Using changes in this patch we were able to reduce approx 10k
1. Changes in board/freescale/ls1043ardb/Makefile to remove
2. Changes in board/freescale/ls1043ardb/ls1043ardb.c to keep
build.
3. Changes in ls1043a_common.h & ls1043ardb.h to remove driver
case of SPL build.
5. Remove I2C driver support from SPL in case of LS1043ARDB.
