The board is now manufactured by Aries Embedded GmbH , rename it.
At present there are only 8-bit and 32-bit read/write routines in
the rtc uclass driver. This adds the 16-bit support.
There is option which is not used:
CONFIG_ZBOOT_32
Remove it from default x86 config and from whitelist.
The function 'board_fit_image_post_process' is defined only when the
config option CONFIG_FIT_IMAGE_POST_PROCESS is enabled. For secure
systems that do not use SPL but do use FIT kernel images, only
CONFIG_FIT_IMAGE_POST_PROCESS will be defined, which will result in an
implicit declaration of function 'board_fit_image_post_process' warning
while building u-boot. Fix this warning.
Signed-off-by: Madan Srinivas <madans@ti.com>
Signed-off-by: Andrew F. Davis <afd@ti.com>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
The most common name for a FIT image containing a bootable kernel is
"fitImage", as our builds now use this name also, change this to the
default in our U-Boot environment.
Now that we have common MMC/SD boot environment
variables that can be used across TI platforms,
switch OMAP-L138 LCDK to use them.
As a nice side-effect, we get support for using
uEnv.txt on this platform.
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Introduce include/environment/ti/mmc.h that
consolidates environment variable definitions
for various TI boards that support MMC/SD.
This allows reuse of same environment variables
on non-ARMv7 TI platforms like OMAP-L138 for
example.
While at it, move DFU-related environment variable
includes to only non-SPL builds for AM335x and
AM437x since they are not really used for SPL
today.
Use environment variables for various memory addresses
used on OMAP-L138 LCDK board. This makes it easy to
customize the boot process.
OMAP-L138 LCDK board does not have a SPI flash.
Remove spiboot related environment variable
definitions.
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
BeagleBone Blue is next grenation of boards from BeagleBoard.org, focusing
on robotics with a TI wl1835 wireless module for connectivity.
This board can be indentified by the BLAx value after A335BNLT (BBB)
in the at24 eeprom:
BLAx: [aa 55 33 ee 41 33 33 35 42 4e 4c 54 42 4c 41 30 |.U3.A335BNLTBLA2|]
http://beagleboard.org/blue
https://github.com/beagleboard/beaglebone-blue
firmware: https://github.com/beagleboard/beaglebone-black-wireless/tree/master/firmware
wl18xx mac address: /proc/device-tree/ocp/ethernet@4a100000/slave@4a100200/mac-address
Signed-off-by: Robert Nelson <robertcnelson@gmail.com>
CC: Tom Rini <trini@konsulko.com>
CC: Jason Kridner <jkridner@beagleboard.org>
CC: Will Newton <willn@resin.io>
SeeedStudio BeagleBone Green Wireless (BBGW) is an expansion of the
SeeedStudio Green (BBG) with the Ethernet replaced by a TI wl1835
wireless module.
This board can be indentified by the GW1x value after A335BNLT (BBB)
in the at24 eeprom:
GW1x [aa 55 33 ee 41 33 33 35 42 4e 4c 54 47 57 31 41 |.U3.A335BNLTGW1A|]
http://beagleboard.org/green-wireless
http://wiki.seeed.cc/BeagleBone_Green_Wireless/
wl18xx mac address: Stored in at24 eeprom at address 5-16:
hexdump -e '8/1 "%c"' /sys/bus/i2c/devices/0-0050/eeprom | cut -b 5-16
BeagleBone Black Wireless is clone of the BeagleBone Black (BBB) with
the Ethernet replaced by a TI wl1835 wireless module.
This board can be indentified by the BWAx value after A335BNLT (BBB)
in the at24 eeprom:
BWAx [aa 55 33 ee 41 33 33 35 42 4e 4c 54 42 57 41 35 |.U3.A335BNLTBWA5|]
http://beagleboard.org/black-wireless
It also enables commands for cache enable/disable/status.
Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
cc: Christophe KERELLO <christophe.kerello@st.com>
The env command 'args_fit' does not define a root path, this forces us to
embed the rootfs into the FIT image. FIT images do not need to contain a
rootfs, when they do not the kernel will fall-back to the kernel argument
'root', if this is not defined the kernel will not boot. It is safe to
add this as when we do have the rootfs in FIT this argument is ignored.
As 'loadfit' is only called from the MMC boot path, use 'args_mmc' to
correctly populate 'bootargs'.
SPI U-Boot image for K2 boards have now exceeded 512K partition
allocated to it and no longer fit the partitions defined in kernel DTS
file. Therefore, pass an updated MTD partition table from U-Boot as
kernel command line arguments to avoid kernel from accidentally
modifying boot loader image that has overflowed to next user partition.
To do is, introduce a common environment file for declaring SPI
partition so that each individual boards need not repeat the same.
Choose appropriate SPI bus from board config file and pass it as command
line argument to kernel.
Signed-off-by: Vignesh R <vigneshr@ti.com>
On boards that defines ENV_IS_NOWHERE, such as the NES classic, commit
19dbe7d1a3f7 ("common: Move environment choice to Kconfig") broke the build
because of a missing environment size.
Reintroduce a default environment size consistent with what we had before.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
In order for the user to be able to see and modify them, add those
variables to the default environment.
Reviewed-by: Jagan Teki <jagan@openedev.com>
Enable the NAND and UBI support in the configuration header so that we can
(finally) use it.
Acked-by: Jagan Teki <jagan@openedev.com>
The environment location is something that might change per board
(depending on what storage options are availaible there) or depending on
the user choice (when we have several options).
Instead of hardcoding it in our configuration header, create a Kconfig
choice with the options we use for now, and the symbols that depend on it.
Once done, also remove the irrelevant sunxi defines.
With d53ecad92f06 some unused interrupt related code was removed.
However all of these options are currently unused. Rather than migrate
some of these options to Kconfig we just remove the code in question.
The only related code changes here are that in some cases we use
CONFIG_STACKSIZE in non-IRQ related context. In these cases we rename
and move the value local to the code in question.
Fixes: d53ecad92f06 ("Merge branch 'master' of git://git.denx.de/u-boot-sunxi")
trini: Disable CONFIG_SPL_USE_ARCH_MEMSET on orangepi_2
This header file is used by three archs. It could be used by all of them
since relocation is a common function. Move it into a generic file.
This header file is used by two archs. It could be used by all of them
since it allows the cache to be on during relocation. Move it into a
generic file.
We don't need this PPC-specific function in generic code. Move it to
the powerpc directory.
This is an weak function present on all archs so we should have it in the
common header file. Remove it from arch-specific headers and add a
function comment.
At present we cannot use this function as an init sequence call without a
wrapper, since it returns the RAM size. Adjust it to set the RAM size in
global_data instead, and return 0 on success.
It looks like only cm5200 and tqm8xx use this feature, so we don't really
need it in generic code. Drop it and have the users access gd->board_type
directly.
This is not used by any board. Drop it.
Clean up board_f sequence a little
This series tries to remove #ifdefs from the board_f init sequence. It
gets as far as I2C and then we need to discuss whether we can start to
remove the old I2C framework.
I think that ideally each entry in the init sequence should be enabled by
at most one CONFIG, which is in Kconfig and is not arch-specific.
END
Acked-by: Lukasz Majewski <lukma@denx.de>
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
These are not used in U-Boot. Manual relocation fixup is used by blackfin
but that is being removed.
Move these two function calls into checkcpu(), which is called on this
arch immediately after these two.
We don't need a special hook for sandbox as one of the later ones will do
just as well. We can print error messages about bad options after we
print the banner. In fact, it seems better.
This function is called just before checkcpu() on MPX83xx. Move it to the
code for that arch.
There is no good reason to use a different name on PowerPC. Change it to
timer_init() like the others.
Reviewed-by: York Sun <york.sun@nxp.com>
We can just call this from the only place that needs it.
We can just call this from the only function that needs it.
We really don't need to have a name like this in the generic init
sequence. Use the generic get_clocks() name so that we can merge these
two at some point.
While x86 is the only user and this could in principle be moved to
arch_cpu_init() there is some justification for this being a separate
call. It provides a way to handle init which is not CPU-specific, but
must happen before the CPU can be set up.
Rename the function to be more generic.
This file is missing the usual header guard. Add it.
The OpenRISC architecture is currently unmaintained, remove.
Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
The SPARC architecture is currently unmaintained, remove.
Cc: Francois Retief <fgretief@spaceteq.co.za>
The architecture is currently unmaintained, remove.
Cc: Benjamin Matthews <mben12@gmail.com>
Cc: Chong Huang <chuang@ucrobotics.com>
Cc: Dimitar Penev <dpn@switchfin.org>
Cc: Haitao Zhang <hzhang@ucrobotics.com>
Cc: I-SYST Micromodule <support@i-syst.com>
Cc: M.Hasewinkel (MHA) <info@ssv-embedded.de>
Cc: Martin Strubel <strubel@section5.ch>
Cc: Peter Meerwald <devel@bct-electronic.com>
Cc: Sonic Zhang <sonic.adi@gmail.com>
Cc: Valentin Yakovenkov <yakovenkov@niistt.ru>
Cc: Wojtek Skulski <info@skutek.com>
Cc: Wojtek Skulski <skulski@pas.rochester.edu>
When this board was switched to using more DM drivers we didn't disable
the legacy PCA953X driver. This in turn learn to a build time warning
about implicit functions as i2c.h would not say anything about
'i2c_read' nor 'i2c_write'. But this was not a fatal error as none of
the legacy driver would be linked in either.
Fixes: e389033f72b5 ("imx: mx6sxsabreauto: enable more dm drivers")
Reviewed-by: Stefano Babic <sbabic@denx.de>
Traditionally Allwinner SoCs have their boot ROM mapped just below 4GB,
while the first SRAM region is mapped at address 0.
With the extended physical memory support of the A80 this was changed,
so the BROM is now at address 0 and the SRAM region starts right behind
this at 64KB. This configuration seems to be called "high SRAM".
Instead of enumerating the SoCs which have copied this configuration,
let's call a spade a spade and introduce a Kconfig option for this setup.
SoCs implementing this (A80, A64 and H5, so far), can then select this
configuration.
Simplify the config header definition on the way.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
For some reason we were pretty conservative when defining the maximum
SPL size for the Allwinner A80(sun9i) SoC.
According to the manual the SRAM A1 is even 40KB, but the BROM
probably still has the 32 KiB load limit. For the sake of simplicity,
merge the SPL memory definitions for the A64 and A80 SoCs, since both
SoC share the BROM/SRAM A1 memory layout.
This helps to further simplify this is in the next patch.
Some Freescale boards used an extra version of the constant to hold the
Generic Timer frequency. This can easily be covered by the now unified
COUNTER_FREQUENCY constant, so remove this extra variable from those
boards.
Many ARMv8 boards define a constant COUNTER_FREQUENCY to specify the
frequency of the ARM Generic Timer (aka. arch timer).
ARMv7 boards traditionally used CONFIG_TIMER_CLK_FREQ for the same
purpose. It seems useful to unify them.
Since there are less occurences of the latter version, lets convert all
users over to COUNTER_FREQUENCY.
