CONFIG_LCD_INFO_BELOW_LOGO is really only meaningful if
CONFIG_LCD_LOGO is set. We should always check to see if
CONFIG_LCD_LOGO is set whenever we do anything based on it.
Otherwise, we will run into compilation problems.
Signed-off-by: Justin Waters <justin.waters@timesys.com>
The AT91SAM9G20-EK board is an updated revision of the AT91SAM9260
board. It is essentially the same, with a few minor differences.
This adds support for it.
Since there are very few differences between the EK and DK boards,
you simply select the board that you wish to use via the config
line. This simplifies the forward porting effort, while still
maintaining the old build steps.
This patch adds esd's loadpci BSP command to CPCI4052 and
CPCI405AB board. This requires CONFIG_CMD_BSP and CONFIG_PRAM.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
- Move the TLB entry of PIXIS_BASE from TLB0 to TLB1[8], because in CAMP mode,
all the TLB0 entries will be invalidated after cpu1 brings up kernel, thus cpu0
can not access PIXIS_BASE anymore (any access will cause DataTLBError exception)
- Set CONFIG_SYS_DDR_TLB_START to 9 for MPC8572DS board.
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
Rename _BASE to _BUS, as it's actually a PCI bus address,
separate virtual and physical addresses into _VIRT and _PHYS,
and use each appopriately. This makes the code easier to read
and understand, and facilitates mapping changes going forward.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Signed-off-by: Remy Böhmer <linux@bohmer.net>
Currently MPC85xx and MPC86xx boards just calculate the localbus frequency
and print it out, but don't save it.
This changes where its calculated and stored to be more consistent with the
CPU, CCB, TB, and DDR frequencies and the MPC83xx localbus clock.
The localbus frequency is added to sysinfo and calculated when sysinfo is
set up, in cpu/mpc8[56]xx/speed.c, the same as the other frequencies are.
get_clocks() copies the frequency into the global data, as the other
frequencies are, into a new field that is only enabled for MPC85xx and
MPC86xx.
checkcpu() in cpu/mpc8[56]xx/cpu.c will print out the local bus frequency
from sysinfo, like the other frequencies, instead of calculating it on the
spot.
Signed-off-by: Trent Piepho <tpiepho@freescale.com>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Acked-by: Jon Loeliger <jdl@freescale.com>
The values given for the PHY address were wrong, so the code
read no valid PHY ID, and fell through to the generic PHY
support, which would work on 1000M but would not auto negotiate
down to 100M or 10M.
Lets make things a bit more user friendly. It isn't 1985 anymore.
These interfaces don't have usable connectors on the board, so don't
bother enumerating or configuring them.
On newer CPUs, 8536, 8572, and 8610, the CLKDIV field of LCRR is five bits
instead of four.
In order to avoid an ifdef, LCRR_CLKDIV is set to 0x1f on all systems. It
should be safe as the fifth bit was defined as reserved and set to 0.
Code that was using a hard coded 0x0f is changed to use LCRR_CLKDIV.
If we have addr map support enabled use the mapping functions to
implement virt_to_phys() and map_physmem().
Initial support for Extreme Engineering Solutions XPedite5370 -
a MPC8572-based 3U VPX single board computer with a PMC/XMC
site.
Initial support for NXP's 4 and 8 bit I2C gpio expanders
(eg pca9537, pca9557, etc). The CONFIG_PCA953X define
enables support for the devices while the CONFIG_CMD_PCA953X
define enables the pca953x command. The CONFIG_CMD_PCA953X_INFO
define enables an 'info' sub-command which provides summary
information for the given pca953x device.
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
Casting a pointer to a phys_addr_t when it's an unsigned long long
on a 32-bit system without first casting to a non-pointer type
generates a compiler warning. Fix this.
All implementations of the functions i2c_reg_read() and
i2c_reg_write() are identical. We can save space and simplify the
code by converting these functions into inlines and putting them in
i2c.h.
Acked-By: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Add a library that helps in translating between virtual and physical
addresses. This library can be useful as a simple means to implement
map_physmem() and virt_to_phys() for platforms that need functionality
beyond the simple 1:1 mapping.
virt_to_phys() returns the physical address given a virtual. In most
cases this will be just the input value as the vast majority of
systems run in a 1:1 mode.
However in systems that are not running this way it should report the
physical address or ~0 if no mapping exists for the given virtual
address.
Also fix some minor typos.
FDT support is used for both FIT style images and for architectures
that can pass a fdt blob to an OS (ppc, m68k, sparc).
For other architectures and boards which do not pass a fdt blob to an
OS but want to use the new uImage format, we just need FIT support.
Now we can have the 4 following configurations :
1) FIT only CONFIG_FIT
2) fdt blob only CONFIG_OF_LIBFDT
3) both CONFIG_OF_LIBFDT & CONFIG_FIT
4) none none
SH4 is different a value of CACHE_OC_NUM_ENTRIES and
CACHE_OC_WAY_SHIFT every CPU.
This patch corrects these values.
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
This patch fixes building U-Boot for CPCI405 boards.
Microblaze platforms use generic settings and to have
many platforms is confusing that's why I decided to remove this
platform from U-BOOT. ml401 tree is sufficient for covering
all Microblaze platforms.
This change will go through microblaze custodian tree.
Compiling U-Boot in an old OS environment (RedHat-7.3 :-) gives the
following warnings from FDT:
include/libfdt_env.h:50: warning: redefinition of 'uintptr_t'
/usr/include/stdint.h:129: warning: 'uintptr_t' previously declared here
Fix: Protect the definition of uintptr_t when compiling on the host
system.
Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
Signed Off By: Graeme Russ <graeme.russ@gmail.com>
This patch adds support for reading fs information from summary
node instead of scanning full eraseblock.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
