Adjust the sandbox serial driver to use the new driver model uclass. The
driver works much as before, but within the new framework.
Serial devices support simple byte input/output and a few operations to find
out whether data is available. Add a basic uclass for serial devices to be
used by drivers that are converted to driver model.
Allow the caller to find out the device that was bound in response to this
call.
Within /chosen we may have a node which points to another node, similar
to how /aliases works. Add a helper function to do this lookup.
This is an implementation of GPIOs for Tegra that uses driver model. It has
been tested on trimslice and also using the new iotrace feature.
The implementation uses a top-level GPIO device (which has no actual GPIOS).
Under this all the banks are created as separate GPIO devices.
The GPIOs are named as per the Tegra datasheet/header files: A0..A7, B0..B7,
..., Z0..Z7, AA0..AA7, etc.
Since driver model is not yet available before relocation, or in SPL, a
special function is provided for seaboard's SPL code.
Allocate 1KB so that driver model can operate before relocation.
For some boards board_init() will change GPIOs, so we need to have driver
model available before then. Adjust the board init to arrange this, but
enable it for driver model only, just to be safe.
This does create additional #ifdef logic, but it is safer than trying to
make a pervasive change which may cause some boards to break.
The microblaze-generic board fails to build at least
with the kernel.org crosstool:
https://www.kernel.org/pub/tools/crosstool/files/bin/x86_64/4.9.0/
x86_64-gcc-4.9.0-nolibc_microblaze-linux.tar.xz
$ make CROSS_COMPILE=microblaze-linux- microblaze-generic_defconfig all
[ snip ]
CC disk/part.o
CC disk/part_dos.o
LD disk/built-in.o
CC drivers/block/systemace.o
{standard input}: Assembler messages:
{standard input}:2495: Error: operation combines symbols in different segments
{standard input}:2496: Error: operation combines symbols in different segments
{standard input}:2499: Error: operation combines symbols in different segments
{standard input}:2500: Error: operation combines symbols in different segments
{standard input}:2505: Error: operation combines symbols in different segments
{standard input}:2506: Error: operation combines symbols in different segments
{standard input}:2515: Error: operation combines symbols in different segments
{standard input}:2516: Error: operation combines symbols in different segments
{standard input}:2519: Error: operation combines symbols in different segments
{standard input}:2520: Error: operation combines symbols in different segments
{standard input}:2529: Error: operation combines symbols in different segments
{standard input}:2530: Error: operation combines symbols in different segments
{standard input}:2533: Error: operation combines symbols in different segments
{standard input}:2534: Error: operation combines symbols in different segments
{standard input}:2539: Error: operation combines symbols in different segments
{standard input}:2540: Error: operation combines symbols in different segments
{standard input}:2549: Error: operation combines symbols in different segments
{standard input}:2550: Error: operation combines symbols in different segments
make[3]: *** [drivers/block/systemace.o] Error 1
make[2]: *** [drivers/block] Error 2
make[1]: *** [drivers] Error 2
make: *** [__build_one_by_one] Error 2
It looks like the cause of this error message is the "#ident" directive.
Cc: Michal Simek <michal.simek@xilinx.com>
This patch adds the TWR_LCD_RGB card/HDMI options and the common
configuration for DCU on LS1021ATWR board.
Signed-off-by: Alison Wang <alison.wang@freescale.com>
This patch is to add DCU driver support. DCU also named
2D-ACE(Two Dimensional Animation and Compositing Engine)
is a system master that fetches graphics stored in internal
or external memory and displays them on a TFT LCD panel.
Remove the DMCTRL Tx snooping bits (TDSEN and TBDSEN) as a
workaround for LS1. It has been observed that currently
the Tx stops functioning after a fair amount of Tx traffic
with these settings on. These bits are sticky and once set
they cannot be reset from Linux, for instance.
Signed-off-by: Claudiu Manoil <claudiu.manoil@freescale.com>
LS102xA is an ARMv7 implementation. This patch is to add
basic support for LS1021ATWR board.
One DDR controller
DUART1 is used as the console
For the detail board information, please refer to README.
Signed-off-by: Chen Lu <chen.lu@freescale.com>
Signed-off-by: Yuan Yao <yao.yuan@freescale.com>
basic support for LS1021AQDS board.
One DDR controller
Signed-off-by: Jason Jin <jason.jin@freescale.com>
Signed-off-by: York Sun <yorksun@freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
JEDEC spec allows DRAM vendors to use prime DQ for write leveling. This
is not an issue unless some DQ pins are not connected. If a platform uses
regular DIMMs but with reduced DDR ECC pins, the prime DQ may end up on
those floating pins for the second rank. The workaround is to use a known
good chip select for this purpose.
For LS102xA, the processor is in little-endian mode, while esdhc IP is
in big-endian mode. CONFIG_SYS_FSL_ESDHC_LE and CONFIG_SYS_FSL_ESDHC_BE
are added. So accessing ESDHC registers can be determined by ESDHC IP's
endian mode.
This patch is to add etsec support for LS102xA. First, Little-endian
descriptor mode should be enabled. So RxBDs and TxBDs are interpreted
with little-endian byte ordering. Second, TSEC_SIZE and TSEC_MDIO_OFFSET
are different from PowerPC, redefine them for LS1021xA.
fsl_enet.h defines the mapping of the usual MII management
registers, which are included in the MDIO register block
common to Freescale ethernet controllers. So it shouldn't
depend on the CPU architecture but it should be actually
part of the arch independent fsl_mdio.h.
To remove the arch dependency, merge the content of
asm/fsl_enet.h into fsl_mdio.h.
Some files (like fm_eth.h) were simply including fsl_enet.h
only for phy.h. These were updated to include phy.h instead.
This commit provides distinction between DFU device detach and reset.
The -R behavior is preserved with proper handling of the dfu-util's -e
switch, which detach the DFU device.
By running dfu-util -e; one can force device to finish the execution of
dfu command on target and execute some other scripted commands.
Moreover, some naming has been changed - the dfu_reset() method now is known
as dfu_detach(). New name better reflects the purpose of the code.
It was also necessary to increase the number of usb_gadget_handle_interrupts()
calls since we also must wait for detection of the USB reset event.
Example usage:
1. -e (detach) switch
dfu-util -a0 -D file1.bin;dfu-util -a3 -D uImage;dfu-util -e
access to u-boot prompt.
2. -R (reset) switch
dfu-util -a0 -D file1.bin;dfu-util -R -a3 -D uImage
target board reset
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
The GPIO list is very long in many cases and most of them are not used.
By default, show only the GPIOs that are in use, and provide a flag to show
all of them. This makes the 'gpio status' command much more pleasant.
In order to do this, driver model now exposes a method for obtaining the
'function' of a GPIO, which describes whether it is an input or output, for
example. Implementation of this method is optional.
Becuase the board select menu in arch/arm/Kconfig is too big,
move the Nomadik board select menu to nomadik/Kconfig.
Move also common settings (CONFIG_SYS_CPU="arm926ejs" and
CONFIG_SYS_SOC="nomadik").
move the Orion5x board select menu to orion5x/Kconfig.
CONFIG_SYS_SOC="orion5x").
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
move the OMAP5 board select menu to omap5/Kconfig.
Move also common settings (CONFIG_SYS_CPU="armv7" and
CONFIG_SYS_SOC="omap5").
Reviewed-by: Tom Rini <trini@ti.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
move the OMAP4 board select menu to omap4/Kconfig.
CONFIG_SYS_SOC="omap4").
move the OMAP3 board select menu to omap3/Kconfig.
CONFIG_SYS_SOC="omap3
move the KirkWood board select menu to kirkwood/Kconfig.
Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and
CONFIG_SYS_SOC="kirkwood").
Acked-by: Prafulla Wadasdkar <prafulla@marvell.com>
Cc: Luka Perkov <luka@openwrt.org>
move the Rmobile board select menu to rmobile/Kconfig.
Consolidate also common settings (CONFIG_SYS_CPU="armv7" and
CONFIG_SYS_SOC="rmobile").
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
move the Tegra board select menu to tegra/Kconfig.
Insert the Tegra SoC select menu between the arch select and the
board select.
Architecture select
|-- Tegra Platform (Tegra)
|- Tegra SoC select (Tegra20 / 30 / 114 / 124)
|- Board select
CONFIG_SYS_SOC="tegra*") and always "select" CONFIG_SPL as follows:
config TEGRA
bool
select SPL
Cc: Tom Warren <twarren@nvidia.com>
move the Zynq board select menu to zynq/Kconfig.
CONFIG_SYS_SOC="zynq").
Refactor board/xilinx/zynq/MAINTAINERS too.
Tested-by: Michal Simek <michal.simek@xilinx.com>
Newer FLASH types used on these boards don't allow writing of subpages.
So disable subpage write in the NAND driver. Additionally we need to
tell the UBI layer in the kernel that he also should only write 2048
bytes. This is done with an additional command line parameter for the
kernel commandline.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Prafulla Wadaskar <prafulla@marvell.com>
Add support for booting Images and for unzipping Image.gz files.
- Drop DEBUG
- Drop defines we can use the default of.
- Provide a larger malloc pool.
- Correct default locations for kernel / initrd / device tree
The default format for arm64 Linux kernels is the "Image" format,
described in Documentation/arm64/booting.txt. This, along with an
optional gzip compression on top is all that is generated by default.
The Image format has a magic number within the header for verification,
a text_offset where the Image must be run from, an image_size that
includes the BSS and reserved fields.
This does not support automatic detection of a gzip compressed image.
The bcm_ep board configuration is used by a number of boards
including Cygnus and NSP.
Add builds for the bcm958300k and the bcm958622hr boards.
Signed-off-by: Scott Branden <sbranden@broadcom.com>
Signed-off-by: Steve Rae <srae@broadcom.com>
The Broadcom StarFighter2 Ethernet driver is used in multiple Broadcom
SoC(s) and:
- supports multiple MAC blocks,
- provides support for the Broadcom GMAC.
This driver requires MII and PHYLIB.
Signed-off-by: Jiandong Zheng <jdzheng@broadcom.com>
To enable hypervisors utilizing the ARMv7 virtualization extension
on the Arndale board, add the simple SMP pen address writer function
and add the required configuration variables to switch all cores to
HYP mode before launching the OS.
This allows booting KVM and Xen directly from u-boot.
Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org>
Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Enable initialization fo designware ethernet controller. With this
patch, ethernet works in my configuration, provided I set ethernet
address in the environment.
Signed-off-by: Pavel Machek <pavel@denx.de>
Though nios2-generic board meant to be a template, it is helpful
to be able to test on a real hardware. As the nios2 linux is
developed and tested on a 3c120 FPGA based Golden Hardware Reference
Design, it makes sense to rebase nios2-generic on this FPGA design.
The nios2-yanu.h contains hardware registers and bits of
opencores yanu. As there is no other user of this header
, it should be moved into the driver.
CC: Renato Andreola <renato.andreola@imagos.it>
The nios2.h is nios2 cpu specific, and should go arch asm
directory.
The nios2-io.h defines hardware registers and bits of several FPGA
IP cores. It could be divided in to the specific drivers, including
altera timer, altera sysid, altera uart and altera jtag uart. The
altera pio and altera spi drivers use their own hardware definitions.
The removal of nios2-io.h will help modularity and maintenance.
To fix the build error when build for Altera dev kit, not
virtual target. At same time, set the build for Altera dev
kit as default instead virtual target. With that, U-Boot
is booting well and SPL still lack of few drivers.
Signed-off-by: Chin Liang See <clsee@altera.com>
Cc: Pavel Machek <pavel@denx.de>
Cc: Tom Rini <trini@ti.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Commit e3a5bbce broke the FIT image tests by not loading a ramdisk even if
a load address is provided in the FIT. The rationale was that a load address
of 0 should be considered to mean 'do not load'.
Add a new load operation which supports this feature, so that the ramdisk
will be loaded if a non-zero load address is provided.
The commit (SHA1: 8fc171318e352) reintroduced correct values for vendor and
product IDs required for UMS gadget to work properly either at Windows or
Linux.
This data was missing for GONI target, so this commit corrects this mistake.
Acked-by: Robert Baldyga <r.baldyga@samsung.com>
Acked-by: Minkyu Kang <mk7.kang@samsung.com>
