path: root/include
2010-11-04omap3evm: Fix mechanism to identify board revisionSanjeev Premi
Function omap3_evm_get_revision() - to identify the board revision was called at end of setup_net_chip(). Board revision can be ascertained only by identifying the Ethernet chipset - but combining setup operations with revision detection isn't a good idea. So, moved the function after call to setup_net_chip(). Function setup_net_chip() should be ideally be called only when CONFIG_CMD_NET is defined. But this leaves the board revision "undetected". This patch allows static definition of revision or default fallback to the latest revision. Signed-off-by: Sanjeev Premi <premi@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04omap3evm: Support relocationSanjeev Premi
This patch adds relocation support for omap3evm. Content of the patch is based on changes for Beagleboard. Signed-off-by: Sanjeev Premi <premi@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04ARMV7: OMAP3: Use generic mmc driver on OMAP3 IGEP moduleEnric Balletbo i Serra
This patch switches from the legacy mmc driver to the new generic mmc driver Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04ARMV7: OMAP3: Use generic mmc driver on IGEP v2Enric Balletbo i Serra
2010-11-04ARMV7: OMAP: Fix build after introduction of GENERATED_GBL_DATA_SIZESteve Sakoman
This patch fixes the issue by defining and using CONFIG_SYS_INIT_RAM_SIZE and CONFIG_SYS_INIT_RAM_ADDR. Based on an email discussion with Wolfgang Denk and Heiko Schocher. Signed-off-by: Steve Sakoman <steve.sakoman@linaro.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04ARMV7: OMAP3: Add expansion board detection for BeagleKoen Kooi
Beagle expansion boards contain an i2c eeprom to identify themselves. This patch adds code to read and parse the eeprom contents. It prints the expansion board name and revision and modifies environment variables as appropriate. This patch is based on the Overo expansion board code. Signed-off-by: Koen Kooi <k-kooi@ti.com> Signed-off-by: Steve Sakoman <steve.sakoman@linaro.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04ARMV7: OMAP3: Add expansion board detection for OveroSteve Sakoman
Overo expansion boards contain an i2c eeprom to identify themselves. This patch adds code to read and parse the eeprom contents. It prints the expansion board name and revision and modifies environment variables as appropriate. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-29Merge branch 'master' of git://git.denx.de/u-boot-marvellWolfgang Denk
Conflicts: include/configs/km_arm.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-29Merge branch 'master' of git://git.denx.de/u-boot-imxWolfgang Denk
2010-10-29Drop support for CONFIG_SKIP_RELOCATE_UBOOTWolfgang Denk
For ARM systems, before ELF relocation was introduced, CONFIG_SKIP_RELOCATE_UBOOT coul be used to prevent *COPYING* the U-Boot image from whereever it was loaded to it's link address (CONFIG_SYS_TEXT_BASE). The name was badly chosen, as no relocation was performed at all, it was just a memcpy(). With ELF relocation, this does not work like that any more, and related boards need to be fixed anyway. So don't keep this relict any longer. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-29Drop support for CONFIG_SYS_ARM_WITHOUT_RELOCWolfgang Denk
When this define was introduced, the idea was to provide a soft migration path for ARM boards to get adapted to the new relocation support. However, other recent changes led to a different implementation (ELF relocation), where this no longer works. By now CONFIG_SYS_ARM_WITHOUT_RELOC does not only not help any more, but it actually hurts because it obfuscates the actual code by sprinkling it with lots of dead and non-working debris. So let's make a clean cut and drop CONFIG_SYS_ARM_WITHOUT_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-29Replace CONFIG_RELOC_FIXUP_WORKS by CONFIG_NEEDS_MANUAL_RELOCWolfgang Denk
By now, the majority of architectures have working relocation support, so the few remaining architectures have become exceptions. To make this more obvious, we make working relocation now the default case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-28kirkwood: get rid of config.mk filesPrafulla Wadaskar
After moving the definition of CONFIG_SYS_TEXT_BASE to the respective board config files, all Marvell kirkwood board have just a single and common entry in their config.mk files: KWD_CONFIG = $(SRCTREE)/board/$(BOARDDIR)/kwbimage.cfg Replace the only reference to KWD_CONFIG in the top level Makefile by an equivalent setting, and remove all kirkwood config.mk files. Signed-off-by: Wolfgang Denk <wd at denx.de> Cc: Prafulla Wadaskar <prafulla at marvell.com> Cc: Siddarth Gore <gores at marvell.com> Cc: Simon Kagstrom <simon.kagstrom at netinsight.net> Cc: Heiko Schocher <hs at denx.de> Cc: Eric Cooper <ecc at cmu.edu> Acked-by: Wolfgang Denk <wd at denx.de> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2010-10-28kirkwood: guruplug: Relocate NAND environment areaGray Remlin
Current default options increase u-boot size to overlap the location of the environment in NAND, move environment higher up Signed-off-by: Gray Remlin <g_remlin@rocketmail.com>
2010-10-28mx51evk: support new relocation schemeShawn Guo
This patch is to fix build breakage and support new relocation scheme for mx51evk. - Correct IRAM base address and add size definition The IRAM starts from 0x1FFE0000 on final revsion i.mx51 than 0x1FFE8000 which is for older revision. - Include imx-regs.h in mx51evk.h Definitions like CSD0_BASE_ADDR and IRAM_BASE_ADDR can be referred to. - Define CONFIG_SYS_INIT_RAM_ADDR and CONFIG_SYS_INIT_RAM_SIZE They are used to define init RAM layout. - Remove comment for CONFIG_SYS_GBL_DATA_SIZE which has been buried by Wolfgang's commit below 25ddd1fb: Replace CONFIG_SYS_GBL_DATA_SIZE by auto-generated value Signed-off-by: Shawn Guo <shawn.gsc@gmail.com>
2010-10-28mx51evk: consolidate env for mmcboot and netbootShawn Guo
This patch is to consolidate default mx51evk env for two primary boot modes, mmcboot and netboot. It also cleans some unused env like netdev, uboot and redundant env like loadaddr since CONFIG_LOADADDR already defines it. Signed-off-by: Shawn Guo <shawn.gsc@gmail.com>
2010-10-28mx51evk: Fix 2 hours reset issueShawn Guo
The mx51evk u-boot has an issue that system will get reset every 2 hours. MC13892 has an inside charge timer which expires in 120 minutes. If ICHRG and CHGAUTOB are not set properly, this timer expiration will get system power recycled. Since mx51evk has no Li-Ion battery on board, the patch sets ICHRG in externally powered mode and sets CHGAUTOB bit to avoid automatic charging, so that system will not get reset by this timer expiration. The patch also corrects the bit field definition of register 48 (Charger 0) per latest MC13892 Reference Manual. Signed-off-by: Shawn Guo <shawn.gsc@gmail.com>
2010-10-27Coding Style cleanupWolfgang Denk
2010-10-26Remove config.mk for da8xxevm based boards.Sughosh Ganu
Move CONFIG_SYS_TEXT_BASE to the board's config file, and remove the now unnecessary config.mk file. Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com> Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
2010-10-26include/asm-offsets.h: automatically generate assembler constantsWolfgang Denk
A recurrent issue is that certain C level constructs like sizeof() or offsetof() cannot be used in assembler files, which is inconvenient when such constructs are used in the definition of macro names etc. To avoid duplication of such definitions (and thus another cause of problems), we adapt the Linux way to automatically generate the respective definitions from the respective C header files. In Linux, this is implemented in include/linux/kbuild.h, Kbuild, and arch/*/kernel/asm-offsets.c; we adapt the code from the Linux v2.6.36 kernel tree. We also copy the concept of the include/generated/ directory which can be used to hold other automatically generated files as well. We start with an architecture-independent lib/asm-offsets.c which generates include/generated/generic-asm-offsets.h (included by include/asm-offsets.h, which is what will be referred to in the actual source code). Later this may be extended by architecture-specific arch/*/lib/asm-offsets.c files that will generate a include/generated/asm-offsets.h. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-26Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
2010-10-25Blackfin: adi boards: set compiled size limitsMike Frysinger
2010-10-25ppc4xx: Add Io and IoCon 405EP board supportDirk Eibach
Board support for the Guntermann & Drunck CATCenter Io. Board support for the Guntermann & Drunck IoCon. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2010-10-23MVBLM7: make TSEC2 work again.Andre Schwarz
SICRH has been misconfigured, i.e. TSEC2 clock + D[0:3] are GPIOs. Fix this to be RGMII signals again. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
2010-10-23Merge branch 'for-wd-master' of git://git.denx.de/u-boot-pxaWolfgang Denk
2010-10-23Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2010-10-23Merge branch 'master' of git://git.denx.de/u-boot-videoWolfgang Denk
2010-10-23Merge branch 'master' of git://git.denx.de/u-boot-shWolfgang Denk
2010-10-23a4m072: add CONFIG_SYS_FLASH_BANKS_SIZES defineIlya Yanok
This patch adds CONFIG_SYS_FLASH_BANKS_SIZES define to make use of new cfi_flash driver ability to detect flash chips that are bigger than a corresponding address window (we have such situation on some revs of a4m072). Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2010-10-22XPedite5500 board supportJohn Schmoller
Initial support for Extreme Engineering Solutions XPedite5500 - a P2020-based PMC/XMC single board computer. Signed-off-by: John Schmoller <jschmoller@xes-inc.com> Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22xes: Add POST support for 8xxx boardsPeter Tyser
Add memory and I2C posts to the XPedite517x/520x/537x board families. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22mpc86xx: Add generic POST word read/write supportPeter Tyser
The PIC's TFRR register doesn't affect hardware and is generally unused, so use as storage for the POST word. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22post/i2c: Rename I2C_ADDR_LIST to CONFIG_SYS_POST_I2C_ADDRSPeter Tyser
Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22xes: Make X-ES board names more genericPeter Tyser
Some U-Boot images for X-ES boards support multiple products in the same family. For example, the XPedite5370, XPedite5371, and XPedite5372 are similar enough that one U-Boot image can work on all 3 cards. To make it clear that a U-Boot image can work on boards of the same family, rename the boards with the least significant digit of 'x'. While we're at it, change the board config file and make targets to be lowercase. Also change the default uImage and fdt filenames to "board.uImage" and "board.dtb" to be more generic. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22xes: Add board_flash_wp_on()John Schmoller
Add board_flash_wp_on() to check a pca9557 gpio pin to see if non-volatile memory write protection is enabled. Previously, write protected NOR flashes would fail initialization which resulted in a bootup error such as: ... DTT: 53 C local / 64 C remote (adt7461@4c) DTT: 54 C local (ds1621@48) FLASH: Executed from FLASH1 POST memory PASSED FLASH: ## Unknown FLASH on Bank 1 - Size = 0x00000000 = 0 MB ## Unknown FLASH on Bank 2 - Size = 0x00000000 = 0 MB *** failed *** ### ERROR ### Please RESET the board ### With this patch, NOR flash initialization is skipped: ... DTT: 53 C local / 64 C remote (adt7461@4c) DTT: 54 C local (ds1621@48) FLASH: Executed from FLASH1 POST memory PASSED FLASH: Uninitialized - Write Protect On L2: 1024 KB enabled NAND: 1024 MiB ... Note that flash related commands such as flinfo and saveenv will error out when flash write protection is enabled. Signed-off-by: John Schmoller <jschmoller@xes-inc.com> Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22xes: Consolidate checkboard()John Schmoller
Create a common checkboard() function to support all X-ES's Freescale boards. Also, add a get_board_derivative() function which reads hardware strapping resistors to determine what model a board is. This allows one U-Boot image to support multiple boards. Signed-off-by: John Schmoller <jschmoller@xes-inc.com> Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22pci: Add ability to re-enumerate PCI busesJohn Schmoller
Add a new 'pci enum' command which re-enumerates the PCI buses. This command is enabled via the CONFIG_CMD_PCI_ENUM define and can be useful in boards with FPGAs connected via PCI/PCIe, boards that support PCI hot-plugging, or during PCI debug. Also enable the 'pci enum' command for X-ES's Freescale-based boards. Signed-off-by: John Schmoller <jschmoller@xes-inc.com> Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Wolfgang Denk <wd@denx.de>
2010-10-22xes: Use common PCI initialization codePeter Tyser
Common Freescale code for PCI initialization now exists, so migrate X-ES boards to use it. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22corenet_ds: Update CONFIG_SYS_GBL_DATA_SIZE to deal with growth in gd_tKumar Gala
The recent change the env code added an additional 32 bytes into gd_t and that causes to grow pass the previous CONFIG_SYS_GBL_DATA_SIZE size. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22PXA: Remove "xsengine" boardMarek Vasut
This board is broken and it's not possible to repair it. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-10-22PXA: Remove "wepep250" boardMarek Vasut
This board is broken and impossible to repair without deep knowledge or availability of the hardware. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-10-22PXA: Remove "delta" boardMarek Vasut
2010-10-22PXA: zipitz2: Add missing CONFIG_SYS_TEXT_BASEMarek Vasut
2010-10-22PXA: vpac270: Add missing CONFIG_SYS_TEXT_BASEMarek Vasut
2010-10-22PXA: xm250: Fix for relocMarek Vasut
2010-10-22PXA: xaeniax: Fix for relocMarek Vasut
2010-10-22PXA: trizepsiv: Fix for relocMarek Vasut
2010-10-22PXA: pxa255_idp: Fix for relocMarek Vasut
