path: root/include
2013-08-01Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2013-07-30cfi_flash: Add prototypes of overridable functionsMasahiro Yamada
This commit adds some prototypes into include/mtd/cfi_flash.h. These functions are defined with a weak attribute in drivers/mtd/cfi_flash.c. This means they can be overrided by board-specific ones if necessary. When defining such functions under board/ directory or somewhere, cfi_flash.h should be included. This makes sure that board-specfic cfi functions are defined in a correct prototype. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Stefan Roese <sr@denx.de>
2013-07-29dfu: Implementation of target reset after communication with dfu-util's -R ↵Lukasz Majewski
switch This patch extends dfu code to support transmission with -R switch specified at dfu-util. When -R is specified, the extra USB_REQ_DFU_DETACH request is sent after successful data transmission. Then dfu resources are released and reset command is issued. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2013-07-29usb: mv_udc: Add bounce bufferMarek Vasut
The requests sent to the controller are not properly cache aligned most of the time, thus implement a simple bounce buffer to avoid problem with cache. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Lei Wen <leiwen@marvell.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2013-07-29usb: mv_udc: Improve allocation of qTD itemsMarek Vasut
Allocate the qTD items all at once instead of allocating them separately. Moreover, make sure each qTD is properly aligned to 32-bytes boundary and that cache can be safely flushed over each qTD touple. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Lei Wen <leiwen@marvell.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2013-07-29usb: mv_udc: Move QH and qTD into mv_drvMarek Vasut
Both the endpoint queue head and the endpoint item list is a controller specific thing. Move them both into controller private data. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Lei Wen <leiwen@marvell.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2013-07-29usb: mv_udc: Make use of struct ehci_ctrlMarek Vasut
The usb_lowlevel_init() call already fills and passes back struct ehci_ctrl , which readily contains correctly determined address of the port register block address computed from values from controller configuration registers. Leverage this and make use of this value as this makes the code mode universal, but also gets us rid of the CONFIG_USB_REG_BASE configuration option. Moreover, this patch cleans up the usb_gadget_register_driver() call a little by correcting the error handling. Note the usb_lowlevel_init() and mvudc_probe() are now called in reversed order, but this has no impact on the code. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Lei Wen <leiwen@marvell.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2013-07-29usb: mv_udc: Clean up the EP initializationMarek Vasut
Move the constant values that are programmed into mv_ep.ep into separate static const structure so they can be memcpy()'d when the initialization happens. Moveover, we only every init NUM_ENDPOINTS, not 2 * NUM_ENDPOINTS, so fix this bug as well. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Lei Wen <leiwen@marvell.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2013-07-29usb: mv_udc: Move endpoint array into driver dataMarek Vasut
The endpoints are operated on a per-controller basis, move the endpoint array into controller's private data. Also shuffle the struct mv_ep structure definition just above the definition of the struct mv_drv so they're well grouped together. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Lei Wen <leiwen@marvell.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2013-07-29usb: mv_udc: Clean up mv_udc.hMarek Vasut
Do a coding-style cleanup of this file and throw away useless defined values. These values were likely a result of a copy-paste job. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Lei Wen <leiwen@marvell.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2013-07-25powerpc/ppc4xx: Remove CONFIG_SYS_FLASH_PROTECTION from gdsys boardsDirk Eibach
CONFIG_SYS_FLASH_PROTECTION was active on most gdsys boards by default, while hardware flash protection was not implemented. Hardware support was added recently and we get into trouble because backward compatibility is broken (u-boot can't unprotect the protected flash after a downgrade). So we decided to disable hardware flash protection for all our boards. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2013-07-25powerpc/ppc4xx: Support gdsys multichannel iocon hardwareDirk Eibach
2013-07-25powerpc/ppc4xx: Use generic accessor functions for gdsys FPGADirk Eibach
A set of accessor functions was added to be able to access not only memory mapped FPGA in a generic way. Thanks to Wolfgang Denk for getting this sorted properly. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2013-07-25Merge branch 'master' of git://git.denx.de/u-boot-nds32Tom Rini
2013-07-25qemu-malta: Update for SPDX license identifiersTom Rini
2013-07-25Merge branch 'master' of git://git.denx.de/u-boot-mipsTom Rini
Conflict over SPDX changes means that one change was effectively dropped as it was fixing typos in a removed hunk of text. Conflicts: arch/mips/cpu/mips64/start.S Signed-off-by: Tom Rini <trini@ti.com>
2013-07-24MIPS: qemu-malta: bring up ethernetGabor Juhos
Qemu emulates a PCNET PCI card for the Malta CoreLV board. Enable the pcnet driver and add board specific ethernet initialization function to bring it up. Also enable the CONFIG_CMD_NET and CONFIG_CMD_PING options. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2013-07-24MIPS: qemu-malta: add PCI supportGabor Juhos
Qemu emulates the Galileo GT64120 System Controller which provides a CPU bus to PCI bus bridge. The patch adds driver for this bridge and enables PCI support for the emulated Malta board. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2013-07-24MIPS: qemu-malta: enable flash supportGabor Juhos
2013-07-24MIPS: qemu-malta: add support for emulated MIPS Malta boardGabor Juhos
Add minimal support for the MIPS Malta CoreLV board emulated by Qemu. The only supported peripherial is the UART. This is enough to boot U-Boot to the command prompt both in little and big endian mode. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2013-07-24MIPS: import gt64120.h header from LinuxGabor Juhos
The Linux specific register access macros, the extern function declarations and the UL suffixes has been removed. The header file will be used for the qemu-malta board. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-24Add eCos-2.0 SPDX-License-Identifier to source filesWolfgang Denk
2013-07-24Add LGPL-2.1+ SPDX-License-Identifier to source filesWolfgang Denk
2013-07-24nds32: Enable the function of passing parameters to Linuxken kuo
Add a header file, setup.h, which copy from Linux source code, this file contain structures are used to pass initialisation parameters to Linux. Enable this function on adp-ag101/adp-ag101p target Signed-off-by: Kuan-Yu Kuo <ken.kuoky@gmail.com> Cc: Macpaul Lin <macpaul@gmail.com>
2013-07-24nds32: Enable SDIO and EXT2 command support for Andes boardken kuo
2013-07-24nds32: Enable two banks of SDRAM on Andes boardken kuo
The original adp-ag101/adp-ag101p initialize only one bank(64MB) by default at boot time, but it is not enough for some application, so increasing to two banks(128M). Signed-off-by: Kuan-Yu Kuo <ken.kuoky@gmail.com> Cc: Macpaul Lin <macpaul@gmail.com>
2013-07-24pci: move pci_ftpci100.h to include/faraday/ftpci100.hGabor Juhos
Even though the header files is used only by the pci_ftpci100 driver, it contains declaration for a function which is used by external code. Move the header file to a common location which lets external code use it. Compile tested only. Cc: Macpaul Lin <macpaul@andestech.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2013-07-24block: constify sect_buf argument of ide_write_dataGabor Juhos
Add a const keyword to the sect_buf argument of ide_write_data to fix the following warning: cmd_ide.c: In function '__ide_output_data': cmd_ide.c:548: warning: passing argument 2 of 'ide_write_data' discards qualifiers from pointer target type /devel/u-boot.git/include/ide.h:76: note: expected 'ulong *' but argument is of type 'const ulong *' Also modify the driver-model documentation to match with the new prototype. Compile tested only. Cc: Macpaul Lin <macpaul@andestech.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2013-07-23fdtdec: Add compatible string for High speed i2cnaveen krishna chatradhi
Adds a new COMPAT string exynos5-hsi2c for high speed i2c controller available on exynos5 SoCs from Samsung. Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com>
2013-07-23vf610: Add I2C support for Vybrid VF610 platformAlison Wang
This patch adds I2C support for Vybrid VF610 platform and adds I2C0 support to VF610TWR board. Signed-off-by: Alison Wang <b18965@freescale.com>
2013-07-23arm/km: fix u-boot update functionalityHolger Brunck
Due to the new I2C framework we need to adapt the u-boot update function. Due to the new framework all i2c leafs behind a mux are present in the system and not only those who are defined and used. So it is bus number 5 after the rework. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com>
2013-07-23i2c, ppc4xx_i2c: switch to new multibus/multiadapter supportDirk Eibach
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Heiko Schocher <hs@denx.de> Cc: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2013-07-23tegra: i2c: Enable new CONFIG_SYS_I2C frameworkSimon Glass
This enables CONFIG_SYS_I2C on Tegra, updating existing boards and the Tegra i2c driver to support this. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Heiko Schocher <hs@denx.de>
2013-07-23i2c, multibus, keymile: get rid of EEprom_ivm envvariableHeiko Schocher
as the keymile boards use now the new i2c multibus/multiadapter framework, remove the EEprom_ivm Environmentvar, as not longer needed. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Holger Brunck <holger.brunck@keymile.com> Tested-By: Holger Brunck <holger.brunck@keymile.com>
2013-07-23i2c, multibus: get rid of CONFIG_I2C_MUXHeiko Schocher
CONFIG_I2C_MUX is replaced through the new i2c multibus/multiadapter framework, configured through CONFIG_SYS_I2C. As CONFIG_I2C_MUX is only used on the keymile boards, and they are now completely moved to the new framework, remove CONFIG_I2C_MUX. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Holger Brunck <holger.brunck@keymile.com> Tested-By: Holger Brunck <holger.brunck@keymile.com>
2013-07-23i2c, fsl_i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to fsl_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-07-23i2c: common changes for multibus/multiadapter supportHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org> Cc: Henrik Nordström <henrik@henriknordstrom.net>
2013-07-23i2c: add i2c_core and prepare for new multibus supportHeiko Schocher
This Patch introduce the new i2c_core file, which holds the I2C core functions, for the rework of the multibus/ multiadapter support. Also adds changes in i2c.h for the new I2C multibus/multiadapter support. This new support can be activated with the CONFIG_SYS_I2C define. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-07-19arm:trats:fix: Correction of loaddtb environment variable.Łukasz Majewski
Missing space for loaddtb command has been added. When missing, ext4load fails with wrong number of passed parameters. Acked-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2013-07-16mpc85xx: Add gdsys ControlCenter Digital boardDirk Eibach
The gdsys ControlCenter Digital board is based on a Freescale P1022 QorIQ SOC. It boots from SPI-Flash but can be configured to boot from SD-card for factory programming and testing. On board peripherals include: - 2x GbE - Lattice ECP3 FPGA connected via PCIe - mSATA RAID1 - USB host - DisplayPort video output - Atmel TPM Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Reinhard Pfau <reinhard.pfau@gdsys.cc> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-07-16tpm: add AUTH1 cmds for LoadKey2 and GetPubKeyReinhard Pfau
Extend the tpm library with support for single authorized (AUTH1) commands as specified in the TCG Main Specification 1.2. (The internally used helper functions are implemented in a way that they could also be used for double authorized commands if someone needs it.) Provide enums with the return codes from the TCG Main specification. For now only a single OIAP session is supported. OIAP authorized version of the commands TPM_LoadKey2 and TPM_GetPubKey are provided. Both features are available using the 'tpm' command, too. Authorized commands are enabled with CONFIG_TPM_AUTH_SESSIONS. (Note that this also requires CONFIG_SHA1 to be enabled.) Signed-off-by: Reinhard Pfau <reinhard.pfau@gdsys.cc> Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Acked-by: Che-Liang Chiou <clchiou@chromium.org> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-07-15Fix ext2/ext4 filesystem accesses beyond 2TiBFrederic Leroy
With CONFIG_SYS_64BIT_LBA, lbaint_t gets defined as a 64-bit type, which is required to represent block numbers for storage devices that exceed 2TiB (the block size usually is 512B), e.g. recent hard drives We now use lbaint_t for partition offset to reflect the lbaint_t change, and access partitions beyond or crossing the 2.1TiB limit. This required changes to signature of ext4fs_devread(), and type of all variables relatives to block sector. ext2/ext4 fs uses logical block represented by a 32 bit value. Logical block is a multiple of device block sector. To avoid overflow problem when calling ext4fs_devread(), we need to cast the sector parameter. Signed-off-by: Frédéric Leroy <fredo@starox.org>
2013-07-15Revert "MIPS: Jz4740: Add qi_lb60 board support"Tom Rini
The files board/qi/qi_lb60/qi_lb60.c and include/configs/qi_lb60.h were licensed under the GPL v3 or later, and not v2 or later. As this is incompatible with the project, revert this board support until the responsible parties are available to re-license (if so desired) under GPL v2. Signed-off-by: Tom Rini <trini@ti.com>
2013-07-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Fix a trivial conflict in arch/arm/dts/exynos5250.dtsi about gpio and serial. Conflicts: arch/arm/dts/exynos5250.dtsi Signed-off-by: Tom Rini <trini@ti.com>
2013-07-12bootm: Use selected configuration for ramdisk and fdtSimon Glass
If a specific configuraion is selected by the bootm command, e.g. with 'bootm 84000000#recoveryconf' we must honour this for not just the kernel, but also the ramdisk and FDT. In the conversion to using a common fit_image_load() function for loading images from FITs (commits a51ec63 and 53f375f) this feature was lost. Reinstate it by passing the selected configuration back from fit_image_load() to boot_get_kernel(), then use this configuration (which is stored in images->fit_uname_cfg) in both boot_get_ramdisk() and boot_get_fdt(). Signed-off-by: Simon Glass <sjg@chromium.org>
2013-07-12Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-07-12mx53ard: Change default environment to cope with OE changesOtavio Salvador
OpenEmbedded has change partitioning layout of generated image so it does not raise warnings during the boot regarding unkown partition being used for U-Boot. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
