path: root/include
2013-10-07am335x_evm: Switch to zImage as default rather than uImageTom Rini
2013-10-04Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-10-03ARM: VExpress: enable ARMv7 virt support for VExpress A15Andre Przywara
To enable hypervisors utilizing the ARMv7 virtualization extension on the Versatile Express board with the A15 core tile, we add the required configuration variable. Also we define the board specific smp_set_cpu_boot_addr() function to set the start address for secondary cores in the VExpress specific manner. There is no need to provide a custom smp_waitloop() function here. This also serves as an example for what to do when adding support for new boards. Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
2013-10-03ARM: add SMP support for non-secure switchAndre Przywara
Currently the non-secure switch is only done for the boot processor. To enable full SMP support, we have to switch all secondary cores into non-secure state also. So we add an entry point for secondary CPUs coming out of low-power state and make sure we put them into WFI again after having switched to non-secure state. For this we acknowledge and EOI the wake-up IPI, then go into WFI. Once being kicked out of it later, we sanity check that the start address has actually been changed (since another attempt to switch to non-secure would block the core) and jump to the new address. The actual CPU kick is done by sending an inter-processor interrupt via the GIC to all CPU interfaces except the requesting processor. The secondary cores will then setup their respective GIC CPU interface. While this approach is pretty universal across several ARMv7 boards, we make this function weak in case someone needs to tweak this for a specific board. The way of setting the secondary's start address is board specific, but mostly different only in the actual SMP pen address, so we also provide a weak default implementation and just depend on the proper address to be set in the config file. Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
2013-10-03ARM: add assembly routine to switch to non-secure stateAndre Przywara
While actually switching to non-secure state is one thing, another part of this process is to make sure that we still have full access to the interrupt controller (GIC). The GIC is fully aware of secure vs. non-secure state, some registers are banked, others may be configured to be accessible from secure state only. To be as generic as possible, we get the GIC memory mapped address based on the PERIPHBASE value in the CBAR register. Since this register is not architecturally defined, we check the MIDR before to be from an A15 or A7. For CPUs not having the CBAR or boards with wrong information herein we allow providing the base address as a configuration variable. Now that we know the GIC address, we: a) allow private interrupts to be delivered to the core (GICD_IGROUPR0 = 0xFFFFFFFF) b) enable the CPU interface (GICC_CTLR[0] = 1) c) set the priority filter to allow non-secure interrupts (GICC_PMR = 0xFF) Also we allow access to all coprocessor interfaces from non-secure state by writing the appropriate bits in the NSACR register. The generic timer base frequency register is only accessible from secure state, so we have to program it now. Actually this should be done from primary firmware before, but some boards seems to omit this, so if needed we do this here with a board specific value. The Versatile Express board does not need this, so we remove the frequency from the configuration file here. After having switched to non-secure state, we also enable the non-secure GIC CPU interface, since this register is banked. Since we need to call this routine also directly from the smp_pen later (where we don't have any stack), we can only use caller saved registers r0-r3 and r12 to not mess with the compiler. Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
2013-10-02Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-10-02Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-10-02Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-09-25samsung: trats2: add support for new board Trats2Piotr Wilczek
This patch add support for a new Samsung board Trats2. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-09-25drivers:power:max77693: add support for new multi function pmic max77693Piotr Wilczek
This patch add support for new multi function pmic max77693. The driver is split into three modules: pmic, muic and fuelgage. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-09-24usb:g_dnl:dfu: Download gadget and DFU function code clean upLukasz Majewski
The download gadget code and DFU function lacks of proper declarations for the case when a target board wants to use only one of available usb functions. Moreover the relevant declarations have been moved to consistent localization (like <dfu.h>). Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de>
2013-09-24usb:gadget:Remove redundant #includes for USB composite gadget and its functionsLukasz Majewski
Only the <linux/usb/gadget.h> requires error.h include. Hence, several includes of error.h at USB gadget functions are not needed. Moreover unnecessary malloc.h includes were also removed. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de>
2013-09-24usb:g_dnl:ums: Conditional compilation for mass storage function ↵Lukasz Majewski
(f_mass_storage) The mass storage composite function is now compiled in only when CONFIG_USB_GADGET_MASS_STORAGE is defined. Such change provides binary size reduction for boards which use USB download gadget (like am335x_evm) with DFU, but don't use UMS. For example at am335x_evm board reduction is more than 2KiB for text and around 120B for data. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de>
2013-09-24am335x_evm: enable DFU RAMAfzal Mohammed
Enable DFU for RAM, provide example dfu_alt_info Signed-off-by: Afzal Mohammed <afzal.mohd.ma@gmail.com> Cc: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2013-09-24dfu: ram supportAfzal Mohammed
DFU spec mentions it as a method to upgrade firmware (software stored in writable non-volatile memory). It also says other potential uses of DFU is beyond scope of the spec. Here such a beyond the scope use is being attempted - directly pumping binary images from host via USB to RAM. This facility is a developer centric one in that it gives advantage over upgrading non-volatile memory for testing new images every time during development and/or testing. Directly putting image onto RAM would speed up upgrade process. This and convenience was the initial thoughts that led to doing this, speed improvement over MMC was only 1 second though - 6 sec on RAM as opposed to 7 sec on MMC in beagle bone, perhaps enabling cache and/or optimizing DFU framework to avoid multiple copy for ram (if worth) may help, and on other platforms and other boot media like NAND maybe improvement would be higher. And for a platform that doesn't yet have proper DFU suppport for non-volatile media's, DFU to RAM can be used. Another minor advantage would be to increase life of mmc/nand as it would be less used during development/testing. usage: <image name> ram <start address> <size> eg. kernel ram 0x81000000 0x1000000 Downloading images to RAM using DFU is not something new, this is acheived in openmoko also. DFU on RAM can be used for extracting RAM contents to host using dfu upload. Perhaps this can be extended to io for squeezing out register dump through usb, if it is worth. Signed-off-by: Afzal Mohammed <afzal.mohd.ma@gmail.com> Cc: Heiko Schocher <hs@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Gerhard Sittig <gsi@denx.de> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Acked-by: Heiko Schocher <hs@denx.de>
2013-09-24dfu: unify mmc/nand read/write ops enumAfzal Mohammed
MMC and NAND independently defines same enumerators for read/write. Unify them by defining enum in dfu header. RAM support that is being added newly also can make use of it. Signed-off-by: Afzal Mohammed <afzal.mohd.ma@gmail.com> Cc: Heiko Schocher <hs@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2013-09-24dfu: Extract common DFU code to handle "dfu_alt_info" environment variableLukasz Majewski
New dfu_init_env_entities() function has been extracted from cmd_dfu.c and stored at dfu core. This is a dfu centric code, so it shall be processed in the core. Change-Id: I756c5de922fa31399d8804eaadc004ee98844ec2 Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Heiko Schocher <hs@denx.de>
2013-09-24ARM: atmel: add RNDIS gadget supportBo Shen
Add RNDIS gadget support to test atmel usba udc driver Signed-off-by: Bo Shen <voice.shen@atmel.com>
2013-09-24USB: gadget: add atmel usba udc driverBo Shen
Add atmel usba udc driver support, porting from Linux kernel The original code in Linux Kernel information is as following commit e01ee9f509a927158f670408b41127d4166db1c7 Author: Jingoo Han <jg1.han@samsung.com> Date: Tue Jul 30 17:00:51 2013 +0900 usb: gadget: use dev_get_platdata() Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. Signed-off-by: Bo Shen <voice.shen@atmel.com>
2013-09-24dfu: Make maximum DFU file size equal to default DFU data bufferLukasz Majewski
Up till now the DFU maximum file size (to be written to e.g. eMMC) was different from the DFU data buffer size. It caused errors when one buffer was smaller than data to be written. Now, the maximum DFU file size is equal to default DFU buffer size. In spite of this, user is still able to manually adjust those default values. Change-Id: Ied75d0f7b59588ebd79dae9a22af801d36622216 Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2013-09-24Sound: WM8994: Support I2S0 channelDani Krishna Mohan
This patch modifies the WM8994 codec to support I2S0 channel in codec slave mode Signed-off-by: Dani Krishna Mohan <krishna.md@samsung.com>
2013-09-20am335x_evm.h: If mmcdev and bootpart switch to mmcdev 1, so should mmcroot.Robert P. J. Day
If, in CONFIG_BOOTCOMMAND, the environment switches both the mmcdev and bootpart variables to refer to MMC device 1, it would make sense that the mmcroot env variable should switch to that device as well. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2013-09-20ARM: DRA7: Enable saveenv commandLokesh Vutla
dra7xx_evm has eMMC and the default environment can be stored in it. So enabling saveenv command and the configs to store environment in eMMC. Tested on DRA752 ES1.0 Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-09-20am335x:Handle worst case scenario for Errata 1.0.24Steve Kipisz
In Errata 1.0.24, if the board is running at OPP50 and has a warm reset, the boot ROM sets the frequencies for OPP100. This patch attempts to drop the frequencies back to OPP50 as soon as possible in the SPL. Then later the voltages and frequencies up set higher. Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com> Cc: Lars Poeschel <poeschel@lemonage.de> Signed-off-by: Steve Kipisz <s-kipisz2@ti.com> [trini: Adapt to current framework] Signed-off-by: Tom Rini <trini@ti.com>
2013-09-20am335x_evm: am33xx_spl_board_init function and scale core frequencyTom Rini
Add a am33xx_spl_board_init (and enable the PMICs) that we may see, depending on the board we are running on. In all cases, we see if we can rely on the efuse_sma register to tell us the maximum speed. In the case of Beaglebone White, we need to make sure we are on AC power, and are on later than rev A1, and then we can ramp up to the PG1.0 maximum of 720Mhz. In the case of Beaglebone Black, we are either on PG2.0 that supports 1GHz or PG2.1. As PG2.0 may or may not have efuse_sma set, we cannot rely on this probe. In the case of the GP EVM, EVM SK and IDK we need to rely on the efuse_sma if we are on PG2.1, and the defaults for PG1.0/2.0. Signed-off-by: Tom Rini <trini@ti.com>
2013-09-20Merge branch 'master' of git://git.denx.de/u-boot-mmcTom Rini
2013-09-20Add parentheses to ALLOC_ALIGN_BUFFER macro'sMischa Jonker
Without those it's very easy to make mistakes when for instance the 'size' field is more than just a constant. Signed-off-by: Mischa Jonker <mjonker@synopsys.com> Cc: Alexey Brodkin <abrodkin@synopsys.com> Cc: Marek Vasut <marex@denx.de> Cc: Anton Staaf <robotboy@chromium.org> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de>
2013-09-20mx6sabresd: Fix the fdt file for the mx6dl versionFabio Estevam
We need to load 'imx6dl-sabresd.dtb' in the mx6dl version. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2013-09-20mx6slevk: Add Ethernet supportFabio Estevam
mx6slevk has a SMSC8720 connected in RMII mode. Add support for it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-09-20mx35pdk: Remove CONFIG_SYS_CACHELINE_SIZEFabio Estevam
In arch/arm/cpu/arm1136/cpu.c we have: #ifndef CONFIG_SYS_CACHELINE_SIZE #define CONFIG_SYS_CACHELINE_SIZE 32 #endif ,so there is no need to define 'CONFIG_SYS_CACHELINE_SIZE' with the default size in the board config file. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-09-20wandboard: Use imx6dl-wandboard.dtb for the solo versionFabio Estevam
The wandboard solo version should boot the 'imx6dl-wandboard.dtb' file, since dual-lite and solo variants are the same SoC with only the number of cores being different. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-09-20drivers/power/pmic: Add tps65910 driverPhilip, Avinash
Add a driver for the TPS65910 PMIC that is found in the AM335x GP EVM, AM335x EVM SK and others. Signed-off-by: Philip, Avinash <avinashphilip@ti.com> [trini: Split and rework Avinash's changes into new drivers/power framework] Signed-off-by: Tom Rini <trini@ti.com>
2013-09-20drivers/power/pmic: Add tps65217 driverGreg Guyotte
Add a driver for the TPS65217 PMIC that is found in the Beaglebone family of boards. Signed-off-by: Greg Guyotte <gguyotte@ti.com> [trini: Split and rework Greg's changes into new drivers/power framework] Signed-off-by: Tom Rini <trini@ti.com>
2013-09-20SPDX: fix IBM-pibs license identifierWolfgang Denk
The SPDX License List version 1.19 now contains an official entry for the IBM-pibs license. However, instead of our suggestion "ibm-pibs", the SPDX License List uses "IBM-pibs", with the following rationale: "The reason being that all other SPDX License List short identifiers tend towards using capital letters unless spelling a word. I'd prefer to be consistent to this end". Change the license IDs to use the official name. Signed-off-by: Wolfgang Denk <wd@denx.de>
2013-09-20Cosmetic: Fix a number of typos, no functional changes.Robert P. J. Day
Fix various misspellings of things like "environment", "kernel", "default" and "volatile", and throw in a couple grammar fixes. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2013-09-20Fix some obvious typos across multiple subsystems.Robert P. J. Day
Typoes fixed: "partion" -> "partition" "retrive", "retreive" -> "retrieve" "th" -> "to" Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2013-09-19arm: atmel: cpux9k2: increase malloc space to fix crash on start u-bootJens Scharsig (BuS Elektronik)
Since UBIFS is enabled for cpux9k2, more malloc space is needed. For the current uboot 2013.10-rcX the size is to small, this will fix the startup problems by increasing the malloc space to 4MiB. Signed-off-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-09-17mmc: size optimization when !CONFIG_MMC_SPIPaul Burton
When CONFIG_MMC_SPI is not enabled, the MMC_MODE_SPI capability can never be set. However there is code in mmc.c which uses the mmc_host_is_spi macro to check that capability & act accordingly. If we expand that macro to 0 when CONFIG_MMC_SPI is not set (since it will always be 0 at runtime anyway) then the compiler can optimize away the SPI-specific code paths in mmc.c. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-09-17mmc: sdhci: use the SDHCI_QUIRK_USE_WIDE8 for samsung SoCJaehoon Chung
Samsung SoC is supported the WIDE8, even if Controller version is v2.0. So add the SDHCI_QUIRK_USE_WIDE8 for Samsung-SoC. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-09-13Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2013-09-13Merge branch 'master' of git://git.denx.de/u-boot-armStefano Babic
Conflicts: MAINTAINERS boards.cfg Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-09-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-09-11Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: tools/Makefile
2013-09-11apf27: add FPGA support for the apf27 boardtrem
Signed-off-by: Philippe Reynes <tremyfr@yahoo.fr> Signed-off-by: Eric Jarrige <eric.jarrige@armadeus.org> Acked-by: Stefano Babic <sbabic@denx.de>
2013-09-11apf27: add support for the armadeus APF27 boardtrem
Signed-off-by: Philippe Reynes <tremyfr@yahoo.fr> Signed-off-by: Eric Jarrige <eric.jarrige@armadeus.org> Signed-off-by: Nicolas Colombain <nicolas.colombain@armadeus.com>
2013-09-10powerpc/p2041: fix I2C controller's offsetShaohui Xie
Without this patch, SPD access will fail which leads to DDR init fail. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Tested-by: Chris Packham <judge.packham@gmail.com> Acked-by: York Sun <yorksun@freescale.com>
2013-09-10ARM: mxs: Add SanDisk Sansa Fuze+ boardMarek Vasut
Add STMP3780-based Sansa Fuze+ board. This board is a small PMP device sporting a CPU which was later rebranded to i.MX233 . Currently supported is USB gadget mode and MMC . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2013-09-10ARM: mxs: Add Creative ZEN XFi3 boardMarek Vasut
Add STMP3780-based XFi3 board. This board is a small PMP device sporting a CPU which was later rebranded to i.MX233 . Currently supported is USB gadget mode and both external SD and internal Phison SD-NAND bridge . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2013-09-09Merge branch 'master' of git://www.denx.de/git/u-boot-ppc4xxTom Rini
2013-09-07ppc4xx: Fix GPIO handling in lwmon5 and lcd4_lwmon5 BSPStefan Roese
LCD4 needs a slightly different GPIO configuration than the original LWMON5 variant. GPIO49 needs to be configured to a default output value of 0 (permanent voltage supply). Additionally lcd4 also needs to enable the LSB transmitter. Signed-off-by: Stefan Roese <sr@denx.de>
