This patch adds skew register settings for KSZ9131. It checks first
which phy is on the board and then applies the correct skew settings.
Skew settings calculation for the KSZ9131:
The i.MX6 SoC has an output skew tolerance of -100ps to 900ps. All
PCB traces where routed exactly the same length so we can calculate
the skew settings without taking the length into consideration.
RXC skew (PHY to MAC):
- We use the 2ns DLL controlled delay on the PHY
- We do not use the skew registers
This results in the following values:
RXC
PHY fixed Delay 2000ps
PHY Added Delay 0ps
T_setup_R min 2.00ns
T_setup_R typ 2.00ns
T_setup_R max 2.00ns
T_hold_R min 1.60ns
T_hold_R typ 2.00ns
T_hold_R max 2.40ns
That means we are well within RGMII specs.
TXC skew (MAC to PHY):
- We then substract ~0.6ns with TXD[0:3] and TXC clock pad skew
register in a resulting ~1.4ns delay.
This results in the following values under consideration of the
tolerances:
TXC min TXC typ TXC max
MAC min -100ps -100ps -100ps
MAC max 900ps 900ps 900ps
PHY fixed Delay 2000ps 2000ps 2000ps
PHY added Delay -340ps -600ps -859ps
T_setup_T min 1.56ns 1.30ns 1.04ns
T_setup_T typ 2.06ns 1.80ns 1.54ns
T_setup_T max 2.56ns 2.30ns 2.04ns
T_hold_T min 1.04ns 1.30ns 1.56ns
T_hold_T typ 1.94ns 2.20ns 2.46ns
T_hold_T max 2.84ns 3.10ns 3.36ns
This shows that T_hold_T min and T_setup_T min times are out of spec
for RGMII timing. However the KSZ9131 has a minimal value for this time
of 0.8ns which is met under all circumstances.
Related-to: ELB-1299
This adds basic support for the new Micrel KSZ9131 phy.
Add support for setting linux,usable-memory property in the memory
node of device tree for the kernel [1].
This property holds a base address and size, describing a
limited region in which memory may be considered available for use by
the kernel. Memory outside of this range is not available for use.
[1] https://www.kernel.org/doc/Documentation/devicetree/bindings/chosen.txt
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
(cherry picked from commit 949b5a969d107613b61a1e5eaf9e43c75a97f42c)
When using distro boot to boot from UBI volumes the boot partition
has been hardcoded to "UBI" (capital letters). However, our default
MTD layout uses "ubi" (lower case letter). Define "ubi" as the
default UBI partition for distro boot for Toradex. This allows to
use distro boot without having to redefine the MTD partition layout
which is useful for TorizonCore.
Define addresses required for full distro boot support.
NXP downstream kernel uses legacy method to enable other cores,
which requires kernel to run in a security mode (althought upstream kernel
uses PSCI for this).
As we're using NXP kernel in our BSPs, lets enable this by default.
Remove obsolete legacy usbboot wrapper, as distroboot can handle
booting from USB drivers.
Signed-off-by: Tom Warren <twarren@nvidia.com>
(cherry picked from commit bd20266d1923f1230ed15020fbb12aa56f3f46b7)
Support the V1.2 hardware revision with the following pin muxing
changes:
Ddc_scl_pv4 and ddc_sda_pv5 previously used as Apalis GPIO3 and GPIO4
are now used as DDC pins.
Gen2_i2c_scl_pt5 and gen2_i2c_sda_pt6 previously used as DDC pins are
now used as USB power enable signals.
Usb_vbus_en0_pn4 and usb_vbus_en1_pn5 previously used as USB power
enable signals are now used as GPIO3 and GPIO4.
Additionally a new device tree file tegra124-apalis-v1.2-eval.dtb is
loaded on V1.2 and later modules and resp. USB power enable signals
activated.
(cherry picked from commit 4c63a601b90db131e92d3f6f6da6a4bc2b287df1)
Remove video=tegrafb0:640x480-16@60 aka VESA VGA mode from vidargs in
order for the panel specification in the device tree to be used. This
causes the default to be the 10.1" LVDS display which will be available
in the Toradex webshop shortly.
(cherry picked from commit d415eab4f0abb3b9dd84c50c9ded0ff976a32a2f)
Disabling ASPM fixes incompatibilities with some PCIe cards
(cherry picked from commit f7c668a4e8dce3975a7c07834c448584f768a44f)
Let the kernel print some debug messages when a user program
crashes due to an exception.
(cherry picked from commit 11d96e122a29eab51242b6502dd7ff9cce533fef)
Concept: store all console-related kernel parameters
in dedicated variable.
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Unfortunately, that missing M makes the current downstream NXP BSP
4.14.98_2.0.0_ga crash early during Linux kernel boot. Fix this.
Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Tested-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Switch to the generic compressed Kernel image type (zImage) instead of
the U-Boot specific uImage format.
1. This fixes linking issues when building with DM_VIDEO enabled mxsfb
driver.
2. Provide proper defines for both VIDEO=y and DM_VIDEO=y.
Move dcu-related code to fsl_dcu_probe_common, keep in video_hw_init()
only legacy video stack (filling GraphicPanel struct etc.).
Add wrappers for all init functions, that will let to provide
struct fb_info as an additional param (needed for further moving it from
the global scope to driver private data struct in DM converted driver).
Added default environment for hdp loading.
Added hdp loading as default for iMX8QM MEK board.
Signed-off-by: Oliver Brown <oliver.brown@nxp.com>
(cherry picked from downstream commit 432e5b4347841095c3b5a8a0d106f35deadd006e)
(cherry picked from downstream commit cb78a32fa8eb8c37932be003ebe4fa1f8c46c1d5)
Fix booting for wandboard
One of the SD-CARD slots on the Wandboard Quad B1 is MMC 2. Enable it as a
boot device.
Reviewed-by: Fabio Estevam <festevam@gmail.com>
- DWC and i.MX6 fixes
- fix complation error for CONFIG_USB
- update RPi3 DTBs to v5.1-rc6 state
- add defconfig for RPi3 B+
- Fix BCM2835_MBOX_TAG_TEST_PIXEL_ORDER define
This uclass is intended for devices that do not need any features from the
uclass, including binding children.
This will typically be used by devices that are used to bind child devices
but do not use dm_scan_fdt_dev() to do it. That is for example the case of
several USB wrappers that have 2 child devices (1 for device and 1 for
host) but bind only one at a any given time.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
The raw u-boot.bin for tinker board has been about 450KB without
debug option, and 550KB with all debug on, and the default value is 200KB,
which is not enough for run raw u-boot.bin.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
ConvertPointer() must be EFIAPI. The first parameter should be of type
efi_uint_t. Use the same parameter name as the UEFI specification.
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
Fixes for 2019.07
- menlo board
- allow SDB on Sabre
- HAB for mx6sl
- apalis board
Default value (4000ms) of PHY_ANEG_TIMEOUT for Micrel KSZ9031 contoller
isn't sufficient to finish auto-negotiation, which sometimes leads to
timeout errors:
Apalis iMX6 # dhcp
FEC Waiting for PHY auto negotiation to complete......... TIMEOUT !
Increase the auto-negotiation time-out to 15000ms.
Reviewed-by: Philippe Schenker <philippe.schenker@toradex.com>
Enable DM Video support on iMX53 M53Menlo and fix minor details
to restore previous behavior of the system.
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Since the pico-pi uses the distroboot,
this commit remove the 'script' variable (cf boot_scripts).
Signed-off-by: Pierre-Jean Texier <pjtexier@koncepto.io>
Fix set_emmcargs wrapper, which prepares proper bootargs for booting
from eMMC.
Add support for loading u-boot FIT images over the USB SDP protocol in
the SPL
Signed-off-by: Frieder Schrempf <frieder.schrempf@kontron.de>
[Various build fixes]
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Tested-by: Fabio Estevam <festevam@gmail.com>
Tested-by: Lukasz Majewski <lukma@denx.de>
Add SPL support for rk3328, default with of-platdata enabled.
[cherry picked from https://github.com/rockchip-linux/u-boot/commit/cb2b7a1bc75ebb116b1eb9b0ae0223e84d86fc4b with minor modifications]
Signed-off-by: Matwey V. Kornilov <matwey.kornilov@gmail.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-efi
Pull request for UEFI sub-system for v2019.07-rc5 (3)
This pull request provides error fixes for the graphical output protocol,
the text output protocol, and the extended text input protocol.
Setting the boot device for the bootefi command is now not only supported
by the 'load' command but also for the file system specific commands like
'fatload'.
IDE devices are no longer automatically probed by u-boot, so it should
be done by the distro boot command before attempting to boot from IDE
(just like scsi and nvme)
Signed-off-by: Joshua Watt <JPEWhacker@gmail.com>
Extra "not DM" controllers support is disabled.
u-boot BSP still good enough to upgrade and run images.
Signed-off-by: Oleksandr Zhadan <oleks@arcturusnetworks.com>
Signed-off-by: Michael Durrant <mdurrant@arcturusnetworks.com>
EFI_SIMPLE_TEXT_OUTPUT_PROTOCOL.Reset() is a function and not a void *
pointer.
- PCIe driver change to support DM model
- T2080QDS migrated to use PCIe DM model
Disable legacy PCIe driver and unused PCIe macros when DM_PCI enabled.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Use the Kconfig option to select the PCIe reset errata.
- LS1046AFRWY support
- USB errata fix and secure boot defconfig support for LS1028A
- Enabled SDHC and SATA for LX2160
- LS1046A serdes fixes
- other minor fixes
LS1046AFRWY board supports LS1046A family SoCs. This patch
add base support for this board.
Board support's 4GB ddr memory, i2c, micro-click module,microSD card,
serial console,qspi nor flash,ifc nand flash,qsgmii network interface,
usb 3.0 and serdes interface to support two x1gen3 pcie interface.
Signed-off-by: Camelia Groza <camelia.groza@nxp.com>
Signed-off-by: Madalin Bucur <madalin.bucur@nxp.com>
Signed-off-by: Pankit Garg <pankit.garg@nxp.com>
Signed-off-by: Pramod Kumar <pramod.kumar_1@nxp.com>
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Signed-off-by: Vabhav Sharma <vabhav.sharma@nxp.com>
During SD boot, MC firmware and DPC are copied from SD card to DDR.
Size reserved between MC and DPC firmware on DDR is 1MB.
If the size of MC firmware(load address 0x80000000) is more than 1 MB
then part of MC firmware will be overwritten by DPC firmware (load
address 0x80100000).
Fix: Update the MC/DPL/DPC firmware's DDR address as per their
respective addresses in SD card.
Signed-off-by: Wasim Khan <wasim.khan@nxp.com>
Add bootcmd for IFC NOR boot and SD boot.
Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com>
Add secure boot defconfig for ls1028aqds and ls1028ardb boards.
Signed-off-by: Yuantian Tang <andy.tang@nxp.com>
Default environment variable is more complete. Also scans for efi
binaries for example.
Signed-off-by: Mian Yousaf Kaukab <ykaukab@suse.de>
- Drop zipitz2 board (Tom)
- Add DEPRECATED option (Tom)
- Mark legacy or non-dm drivers as DEPRECATED (Jagan)
