path: root/include
2006-07-21Code cleanupWolfgang Denk
2006-07-21Enable initrd ATAG for xm250 board.Wolfgang Denk
Patch by Josef Wagner, 05 Sep 2005
2006-07-21Add support for friendly-arm SBC-2410X boardWolfgang Denk
Patch by JinHua Luo, 01 Sep 2005
2006-07-21Add support for KVME080 boardWolfgang Denk
Patch by Sangmoon Kim, 18 Aug 2005
2006-07-21* Cleanup TQM5200 board configurations:Wolfgang Denk
- make highboot configurations use environment at high end, too, to avoid flash fragmentation - always use redundand environment - don't enable video code for modules without graphics controller - provide useful (though different) mtdparts settings - get rid of CONFIG_CS_AUTOCONF which was always set anyway * Extend mkconfig tool to print more useful target name
2006-07-19Add support for high-boot on TQM5200 and TQM5200S boards.Wolfgang Denk
Hint: the CPLD on the TQM5200 must be programmed with a software version supporting the high boot option! The new TQM5200S is already supporting this option. On the TQM5200 this option will be supported in configurations with MPC5200 rev B processors. To actually "high boot", set jumper X30 on the STK52xx. Patch by Martin Krause, 12 Jul 2006
2006-07-19Add support for new TQM5200 revisionsWolfgang Denk
- Support for TQM5200S (short version without graphic controller) - Support for modules with 'N' type S29GL128N Spansion flashes (requires changes to flash layout) - Support for MPC5200B cpu (mostly support for second SDRAM bank)
2006-07-19Fix support for PS/2 keyboard on TQM85xx boardsWolfgang Denk
The PS/2 keyobard driver for the TQM85xx modules only supports the internal DUART of the MPC85xx CPU. Since the MPC8560 doesn't include a DUART, the TQM8560 modules can't be used with the PS/2 keyboard controller on the STK85xx board. The PS/2 keyboard driver should work with the modules TQM8540, TQM8541 and TQM8555, but it only has been tested on a TQM8540, yet. Make sure the PS/2 controller on the STK85xx is programmed. Jumper settings: X66 1-2, 9-10; X61 2-3 Patch by Martin Krause, 21 Jun 2006
2006-07-19Adjust RTC century handling on STK52xx board to match Linux driver.Wolfgang Denk
Patch by Martin Krause, 12 Jun 2006
2006-07-19Enable buffered flash writes for TB5200 board.Wolfgang Denk
2006-07-19Fix some bugs in TRAB board flash driver.Wolfgang Denk
- increase CFG_FLASH_ERASE_TOUT from 2 to 15 seconds - use CFG_FLASH_WRITE_TOUT for programming instead of CFG_FLASH_ERASE_TOUT - remove "Unlock Bypass" mode, because macronix flashes do not support this mode officially - fix flash reset command from 0x00FF to 0x00F0. 0x00FF is only specified for Intel compatible flashes, not for AMD compatible. Patch by Martin Krause, 15 Feb 2006
2006-07-19Add support for TB5200 boardWolfgang Denk
The TB5200 ("Tinybox") is a small baseboard for the TQM5200 module integrated in a little aluminium case. Patch by Martin Krause, 8 Jun 2006 Some code cleanup
2006-07-18Enable buffered flash writes for TQM5200 board.Wolfgang Denk
2006-07-13Merge with /home/mk/11-cmb1920/u-bootWolfgang Denk
2006-07-13Cleanup duplicate definitions in MCC200 config file.Wolfgang Denk
2006-07-12Add support for TQM885D board.Markus Klotzbuecher
Patch by Martin Krause, 20 Mar 2006 Signed-off-by: Martin Krause <martin.krause@tqs.de>
2006-07-12Support for spc1920 board.Markus Klotzbuecher
Patch by Markus Klotzbuecher, 12 Jul 2006
2006-07-11MCC200 board: support console on any one of the Quad UART ports.Wolfgang Denk
2006-07-10Major PCMCIA Cleanup to make code better readable and maintainable.Wolfgang Denk
Notes: - Board-dependend code for RPXLITE and RPXCLASSIC-based boards placed to the drivers/rpx_pmcia.c file to avoid duplication. Same for TQM8xx-based boards (drivers/tqm8xx_pmcia.c). - drivers/i82365.c has been split into two parts located at board/atc/ti113x.c and board/cpc45/pd67290.c (ATC and CPC45 are the only boards using CONFIG_82365). - Changes were tested for clean build and *very* *few* boards.
2006-07-06MCC200: map the 2nd Quad UART into the processor's address space.Wolfgang Denk
2006-07-06Fix timer problems on AMCC yucca board.Marian Balakowicz
Set Timer Clock Select to use CPU clock as a timer input source.
2006-07-05Bring yucca config more in line with other AMCC boards.Wolfgang Denk
2006-07-05Merge with /home/m8/git/u-bootWolfgang Denk
2006-07-04Add system memory to the PCI region list for AMCC PPC44x CPUs.Marian Balakowicz
Enabled it for Yucca board.
2006-07-03Cleanup config file and bootup output for Yucca board.Marian Balakowicz
2006-06-30Merge with /home/m8/git/u-bootWolfgang Denk
2006-06-30Fix CONFIG_440_GX define usage.Marian Balakowicz
2006-06-30Remove autogenerated bmp_logo.h file.Marian Balakowicz
2006-06-30Merge: Add support for AMCC 440SPe CPU based eval board (Yucca).Marian Balakowicz
2006-06-30Add support for AMCC 440SPe CPU based eval board (Yucca).Marian Balakowicz
2006-06-26Cleanup trab board for GCC-4.xWolfgang Denk
2006-06-20Merge with /home/hs/U-Boot/u-boot-devWolfgang Denk
2006-06-19Add support for wrPPMC7xx/74xx boardsHeiko Schocher
Patch from Richard Danter, 12 Aug 2005
2006-06-19Merge with ssh://fifi/home/wd/git/u-boot/masterWolfgang Denk
2006-06-16Add support for gth2 boardWolfgang Denk
Patch by Thomas Lange, Aug 11 2005
2006-06-16Add support for CONFIG_SERIAL_MULTI on MPC5xxxWolfgang Denk
Patch by Martin Krause, 8 Jun 2006 This patch supports two serial consoles on boards with a MPC5xxx CPU. The console can be switched at runtime by setting stdin, stdout and stderr to the desired serial interface (serial0 or serial1). The PSCs to be used as console port are definded by CONFIG_PSC_CONSOLE and CONFIG_PSC_CONSOLE2. See README.serial_multi for details.
2006-06-16Update configuration for CMC-PU2 boardWolfgang Denk
Patch by Martin Krause, 17 Nov 2005
2006-06-16Add support for PS/2 keyboard on TQM85xx boardWolfgang Denk
Patch by Martin Krause, 07 Nov 2005 Tested on a STK85XX baseboard. Make sure the PS/2 controller has been programmed. Jumper Settings: X66 1-2, 9-10; X61 2-3
2006-06-16Adjust TQM5200 make targetsWolfgang Denk
Make the automatic CS configuration the default. The dedicated configurations CONFIG_TQM5200_AA, CONFIG_TQM5200_AB and CONFIG_TQM5200_AC are removed. "TQM5200_config" is now the default for STK52XX.200 base boards. On a STK52XX.100 base board "TQM5200_STK100_config" must be used. Patch by Martin Krause, 07 Nov 2005
2006-06-16Disable JFFS2 support for trab boardWolfgang Denk
Patch by Martin Krause, 27 Oct 2005
2006-06-16Change mtdparts definition on trab board to match current flash mapWolfgang Denk
2006-06-13Minor cleanup for PCS440EP boardStefan Roese
Patch by Stefan Roese, 13 Jun 2006
2006-06-10Minor code cleanup.Wolfgang Denk
2006-06-10Merge with /home/hs/U-Boot/u-boot-devWolfgang Denk
2006-06-08Nios II - Add Altera EP1C20, EP1S10 and EP1S40 boardsScott McNutt
Patch by Scott McNutt, 08 Jun 2006
2006-06-08Nios II - Add EPCS Controller bootrom work-aroundScott McNutt
-When booting from an epcs controller, the epcs bootrom may leave the slave select in an asserted state causing soft reset hang. This patch ensures slave select is negated at reset. Patch by Scott McNutt, 08 Jun 2006
2006-06-08Update PK1C20 boardScott McNutt
-Update base addresses for standard configuration -Eliminate use of CACHE_BYPASS in board code Patch by Scott McNutt, 08 Jun 2006
2006-06-08Nios II - Fix I/O Macros and mini-app stubsScott McNutt
-Fix asm/io.h macros -Eliminate use of CACHE_BYPASS in cpu code -Eliminate assembler warnings -Fix mini-app stubs and force no small data Patch by Scott McNutt, 08 Jun 2006
2006-06-07Minor cleanup for PCS440EP boardWolfgang Denk
2006-06-06Update PCS440EP port to fit into one flash device (incl. environment)Stefan Roese
Patch by Stefan Roese, 06 Jun 2006
