This patch defines CFG_64BIT_VSPRINTF and CFG_64BIT_STRTOUL for all
440/460 platforms. This may be needed since those platforms support
36bit physical address space.
The MVBC_P is a MPC5200B based camera system with Intel Gigabit ethernet
controller (using e1000) and custom Altera Cyclone-II FPGA on PCI.
Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
Update the sys_eeprom.c file to handle both NXID and CCID EEPROM formats. The
NXID format replaces the older CCID format, but it's important to support both
since most boards out there still use the CCID format. This change is in
preparation for using one file to handle both formats. This will also unify
EEPROM support for all Freescale 85xx and 86xx boards.
Also update the 86xx board header files to use the standard CFG_I2C_EEPROM_ADDR
instead of ID_EEPROM_ADDR.
The L2_INIT_RAM option was unused, and recent changes to the TLB code
meant that the INIT_RAM TLBs weren't being cleared out. In order to reduce
the amount of mapped space attached to nothing, we change things so the TLBs
get cleared.
Signed-off-by: Andy Fleming <afleming@freescale.com>
The fake flash bank was generating errors for anyone who didn't have a
PromJET hooked up to the board. As that constitutes the vast majority of
users, we remove it.
Add support for using a PCIe ATI Video card on PCIe2.
Add new L1/L2 SPRs related to e500mc cache config and control.
Make the default build for the sbc8560 board be powerpc
capable with libfdt support.
This was proposed by Paul Gortmaker in response to Wolfgang's comments on
similar #defines in sbc8560.h.
Add in the default fdt settings and the typical EXTRA_ENV
settings as borrowed from the mpc8560ads. Fix a couple
of stale references to the mpc8560ads dating back to the
original clone/fork.
The existing config doesn't define CONFIG_HAS_ETH0, and so the
fdt support doesn't update the zeros in the dtb local-mac with
real data from the u-boot env. Since the existing config is
tailored to just two interfaces, get rid of the ETH2 definitions
at the same time.
Also don't include any end user specific data into the environment
by default -- things like MAC address, network parameters etc. need
to come from the end user.
The definitions for the TSEC have become out of date. There is no
longer any such options like "CONFIG_MPC85xx_TSEC1" or similar.
Update to match those of other boards, like the MPC8560ADS.
Acked-by: Ben Warren <biggerbadderben@gmail.com>
Delete the crypto node if not on an E-processor. If on 8360 or 834x family,
check rev and up-rev crypto node (to SEC rev. 2.4 property values)
if on an 'EA' processor, e.g. MPC8349EA.
The 8544 DS doesn't have any cacheable Local Bus memories set up. By mapping
space for some anyway, we were allowing speculative loads into unmapped space,
which would cause an exception (annoying, even if ultimately harmless).
Removing LBC_CACHE_BASE, and using LBC_NONCACHE_BASE for the LBC LAW solves the
problem.
Clean Makefile
Move device specific values to driver for better reading
Redesign uartlite driver to in_be32 and out_be32 macros
Fix missing header in io.h
caused by missing dcache status/enable/disable functions.
Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
Add #define CONFIG_MCFTMR in EB+MCF-EV123.h configuration file
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
The timer was assigned to wrong timer memory mapped which
caused udelay() and timer() not working properly.
Signed-off-by: Kurt Mahan <kmahan@freescale.com>
Some boards based on AT91SAM926X-EK use smaller DF chips to keep
bootstrap, u-boot and its environment, using NAND or other external
storage for kernel and rootfs. This patch adds support for
small 1024x263 chip.
Signed-off-by: Sergey Lapin <slapin@ossfans.org>
ADS5121 Rev 3 board is now the default config
config targets are now
ads5121_config
Rev 3 board with
PCI
M41T62 on board RTC
512MB DRAM
ads5121_rev2_config
Rev 2 board with
No PCI
256MB DRAM
Signed-off-by: Martha Marx <mmarx@silicontkx.com>
Acked-by: John Rigby <jrigby@freescale.com>
Consolidate ADS5121 IO Pin configuration to one file
board/ads5121/iopin.c.
Remove pin config from cpu/mpc512x/fec.c
Newer PPC's like 440SPe, 460EX/GT can be equipped with more than 2GB of SDRAM.
To support such configurations, we "only" map the first 2GB via the TLB's. We
need some free virtual address space for the remaining peripherals like, SoC
devices, FLASH etc.
Note that ECC is currently not supported on configurations with more than 2GB
SDRAM. This is because we only map the first 2GB on such systems, and therefore
the ECC parity byte of the remaining area can't be written.
Signed-off-by: Larry Johnson <lrj@acm.org>
This PCI-X e1000 variant works by just adding in the correct
PCI IDs in the appropriate places.
(introduced by commit 391fd93ab23e15ab3dd58a54f5b609024009c378)
This patch makes SPARC targets build again. It is caused by
phys_addr_t and phys_size_t being defined in the wrong header
file. include/lmb.h need those typedefs to build.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
Some macros such as NAND_CTL_SETALE conflict between current and legacy
NAND, being defined by the subsystem in the former case and the board
config file in the latter.
ARM: Fix for incorrect version of patch applied when
adding support for the Lyrtech SFF-SDR board.
Signed-off-by: Philip Balister, OpenSDR <philip@opensdr.com>
The LMB code now uses phys_addr_t and phys_size_t. Also, there were a couple
of casting problems in the bootm code that called the LMB functions.
common/env_common.c (default_env): new function that resets the environment to
the default value
common/env_common.c (env_relocate): use default_env instead of own copy
common/env_nand.c (env_relocate_spec): use default_env instead of own copy
include/environment.h: added default_env prototype
Signed-off-by: Werner Almesberger <werner@openmoko.org>
Signed-off-by: Harald Welte <laforge@openmoko.org>
This is particularly problematic now that non-NAND-specific code is
including <nand.h>, and thus all debugging code is being compiled
regardless of whether it was requested, as reported by Scott McNutt
<smcnutt@psyent.com>.
After we move the atmel_mci driver into drivers/mmc, we can't select
it with CONFIG_MMC anymore. Introduce a new symbol specifically for
this driver so that there's no ambiguity.
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Acked-by: Jean-Chritophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
This avoids an early global data reference.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
Signed-off-by: Matvejchikov Ilya <matvejchikov@gmail.com>
The compiler will help find mismatches between printf formats and
arguments if you let it. This patch adds the necessary attributes to
declarations in include/common.h, then begins to correct the resulting
compiler warnings. Some of these were bugs, e.g., "$d" instead of
"%d" and incorrect arguments. Others were just annoying, like
int-long mismatches on a system where both are 32 bits. It's worth
fixing the annoying errors to catch the real ones.
Signed-off-by: Andrew Klossner <andrew@cesa.opbu.xerox.com>
Disable SH ether driver.
