The IDE_BUS(dev) macro was previously doing dev >> 1. This however is a
mis-match of the usage in common/cmd_ide.c and would cause boards with
multiple ports / devices to not correctly detect all devices. For more
details please see:
http://lists.denx.de/pipermail/u-boot/2012-April/122525.html
[Tom Rini: Reword commit message only]
Tested-by: Luka Perkov <uboot@lukaperkov.net>
Signed-off-by: Simon Baatz <gmbnomis@gmail.com>
The default configuration for ml507 will generate a hang() in the
Xilinx uartlite driver.
userial_ports[] in drivers/serial/serial_xuartlite.c does not get
initialized properly. CONFIG_SERIAL_BASE is unused.
XILINX_UARTLITE_BASEADDR is used instead.
Signed-off-by: Rommel Custodio <sessyargc+uboot@gmail.com>
Due to grown code sizes the TQM85xx boards don't build any more with
some older tool chains (like ELDK 4.2). As these boards have long
reached EOL it seems a waste of effort trying to fix them. The vendor
has agreed to drop support for them, too. So let's get rid of them.
Cc: Stefan Roese <sr@denx.de>
cc: Kim Phillips <kim.phillips@freescale.com>
Add minimal support for Altera's SOCFPGA Cyclone 5 hardware.
Signed-off-by: Dinh Nguyen <dinguyen@altera.com>
Signed-off-by: Chin Liang See <clsee@altera.com>
Signed-off-by: Pavel Machek <pavel@denx.de>
Acked-by: Tom Trini <trini@ti.com>
Cc: Wolfgang Denx <wd@denx.de>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
v8: Remove no_return attribute for reset_cpu
Based on v2012.10-rc2
Add support for Xilinx Zynq board.
CC: Joe Hershberger <joe.hershberger@gmail.com>
The driver is used on Xilinx Zynq platform.
CC: Marek Vasut <marex@denx.de>
This patch adds support for the X600 SPEAr600 based board. Its also
the first SPEAr600 board that uses the newly introduced SPEAr600
SPL support. Xloader is not necessary any more. By using the new
"u-boot.spr" make target, one image will generated containing both,
U-Boot SPL (with mkimage header as needed by the SPEAr BootROM, and
the main U-Boot with mkimage header.
Cc: Amit Virdi <amit.virdi@st.com>
Cc: Vipin Kumar <vipin.kumar@st.com>
On x86 machines gd is unfortunately a #define, so we should avoid using
gd for anything. This patch changes uses of gd to bgd so that ext4fs
can be used on x86.
A better fix would be to remove the #define in x86, but I'm not sure
how to do that.
This is required to configure the external 88e6352 switch on nusa.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Holger Brunck <holger.brunck@keymile.com>
cc: Prafulla Wadaskar <prafulla@marvell.com>
Acked-by: Prafulla Wadaskar <Prafulla@marvell.com>
Malloc len of 128K caused a warning from
ehci_hcd asking for more.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
Add support for new board iConnect from Iomega.
More information about the device can be found here:
http://go.iomega.com/en/products/network-storage-desktop/wireless-data-station/network-hard-drive-iconnect/?partner=4735
Signed-off-by: Luka Perkov <uboot@lukaperkov.net>
Tested-by: Wojciech Dubowik <wojciech.dubowik@neratec.com>
Tested-by: Tim Fletcher <tim@night-shade.org.uk>
This patch adds support for the LaCie board d2 Network v2 which share
a lot of hardware caracteristics with the 2Big Network v2.
- CPU: Marvell 88F6281 1200Mhz
- SDRAM memory: 256MB DDR2 400Mhz
- 2 SATA ports: internal and eSATA
- Gigabit ethernet: PHY Marvell 88E1116R
- Flash memory: SPI NOR 512KB (Macronix MX25L4005A)
- i2c EEPROM: 512 bytes (24C04 type)
- 2 USB2 ports: host and host/device
- 1 push button
- 1 power switch
- 1 SATA LED (bi-color, blue and red)
Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
This patch adds support for the LaCie boards Network Space v2 (Lite and
Mini). This two boards are derived from the Network Space v2 and a lot
of hardware caracteristics are shared.
- CPU: Marvell 88F6192 800Mhz
- SDRAM memory: 128MB DDR2 200Mhz
- 1 SATA port: internal
- Gigabit ethernet: PHY Marvell 88E1318
- 2 USB2 ports (Lite only): host and host/device
- 1 push button
Defines CONFIG_EFI_PARTITION for LaCie boards.
Additionally this patch defines CONFIG_DOS_PARTITION. Note that this
definition is implicit in mv_common.h when CONFIG_CMD_USB is enabled.
Support of the MINI2440 board from FriendlyARM from
an old version of u-boot :
http://repo.or.cz/r/u-boot-openmoko/mini2440.git
Currently, supporting only boot from NOR.
Signed-off-by: Gabriel Huau <contact@huau-gabriel.fr>
armadillo-800eva needs this config.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
The Armadillo-800EVA board has Renesas R-Mobile R8A7740, 512MB DDR3-SDRAM,
Ethernet, and more.
This patch supports the following functions:
- 512MB DDR3-SDRAM
- Serial console (SCIF)
- Ethernet MAC(MII) & PHY(SMSC)
Signed-off-by: Hideyuki Sano <hideyuki.sano.dn@renesas.com>
kzm9g board use global timer. But by commit 813ffda31, timer function of
rmobile was changed that global timer might be used, when CONFIG_GLOBAL_TIMER
was defined.
This add CONFIG_GLOBAL_TIMER to board config file.
Some rmobile SoC has TMU base timer function. This supports TMU.
Remove CONFIG_ARM_CORTEXA9.
Remove CONFIG_INTEGRATOR and CONFIG_ARCH_CINTEGRATOR. These are not for kzm9g.
Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
Set NFS_TIMEOUT to 10,000 msec.
The value of CONFIG_BAUDRATE is treated as string and put as initial value of
environment variable. If it begin with '(', it is wrongly parsed to 0 in number.
So I removed '(' and ')'.
Change U-Boot prompt to board specific one.
Reserve first 16MB for RT-CPU (as same as kernel config).
The KZM-A9-GT board has Renesas R-Mobile SH73A0, 512MB DDR2-SDRAM,
USB, Ethernet, and more.
- 512MB DDR2-SDRAM
- 16MB NOR Flash memory
- Ethernet (SMSC)
- I2C
Since a while, the size of the u-boot.bin image is larger than
256kB. This requires moving the environment sectors by one. As
we are at it, we also update a few other custom settings.
Signed-off-by: Wolfgang Grandegger <wg@denx.de>
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net>
A fast boot is important to the beaglebone, so save 2 seconds here by
decreasing bootdelay. This is still plenty time to break into the prompt,
I do that at least once a day.
Mount the rootfs RO by default, this is needed to make fsck succeed
without resorting to an initramfs.
Signed-off-by: Koen Kooi <koen@dominion.thruhere.net>
This patch adds support for networking in SPL. Some devices are
capable of loading SPL via network so it makes sense to load the
main U-Boot binary via network too. This patch tries to use
existing network code as much as possible. Unfortunately, it depends
on environment which in turn depends on other code so SPL size
is increased significantly. No effort was done to decouple network
code and environment so far.
Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
This patch adds support for networking in SPL on TI AM335x based
boards. Vendor Class Identifier used by SPL during BOOTP is
"AM335x U-Boot SPL".
Signed-off-by: Bastian Ruppert <Bastian.Ruppert@Sewerin.de>
CC: Tom Rini <trini@ti.com>
Do not allow to overwrite it when video is enabled.
Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
cc: Thomas Weber <weber@corscience.de>
Signed-off-by: Lei Wen <leiwen@marvell.com>
Add a new config CONFIG_GZIP_ENABLED, if enabled, the uboot bin would
include zlib's deflate method which could be used for compressing.
On some system (e.g. powerpc), the load-address and entry-point is
located at address 0. So the current approach to load the image
(payload) including the header to the address "load-address - 64"
can't work here.
This patch adds an flag to skip this copying including header to
the SPL framework. By setting SPL_COPY_PAYLOAD_ONLY, only the
playload will be copied. This will be used by the SPL NOR flash
driver on powerpc.
SPL NOR flash booting support is quite simple. Only copying of the
images is needed.
On MPC5xxx we need to make sure to only use the standard memcpy()
implementation and not the MPC5xxx specific one. As the MPC5xxx
version has some complexity which is not needed for this SPL
booting.
The common spl framework expects the u-boot payload size through
CONFIG_SYS_MONITOR_LEN. Define the macro with the u-boot's size. With
this change, CONFIG_SYS_NAND_U_BOOT_SIZE is no longer required. Delete
the same.
Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com>
- Convert the non-relocation part of board_init_f to spl_board_init, turn on CONFIG_SPL_BOARD_INIT in the configs.
- Remove duplicated code.
- Add spl_boot_device() that returns the statically chosen boot device.
