Signed-off-by: Justin Waters <justin.waters@timesys.com>
include/configs/at91sam9261ek.h
This patch came from Atmel. It fixes a number of NAND issues, as well as the
9263 rev B SPI bug.
This patch adds support for the AT91SAM9G20-EK board. It comes from the patch
u-boot-1.1.5_atmel_1.6.diff, courtesy of linux4sam.org.
The timings for the dataflash chip on the SAM9RL-EK board are incorrect. This patch fixes them.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Justin Waters <justin.waters@timesys.com>
The CMD API has changed significantly since the patches were originally written. This fixes these problems and cleans up the code a little.
MAKEALL
board/at91rm9200dk/at45.c
common/cmd_flash.c
drivers/Makefile
drivers/at45.c
drivers/dataflash.c
drivers/dm9000x.c
drivers/nand/nand.c
drivers/nand/nand_base.c
drivers/nand/nand_ids.c
drivers/nand/nand_util.c
examples/Makefile
include/asm-arm/mach-types.h
This patch adds support for the following boards:
AT91RM9200-EK
AT91SAM9260-EK
AT91SAM9261-EK
AT91SAM9263-EK
AT91SAM9RL-EK
It was downloaded from http://www.linux4sam.org/twiki/pub/Linux4SAM/U-Boot/u-boot-1.1.5_atmel_1.5.diff.bz2
CONFIG_QE shouldn't be in the wrap of CONFIG_PCI, fix it.
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
rsdproto board support has wrong I2C frequency and wrong return value
handling.
Signed-off-by: Luotao Fu <l.fu@pengutronix.de>
Ugh. I *hate* to back this change out, but these compiler flags don't
work for relocation on all versions of GCC. I've not been able to
reproduce the environment in my setup (and hence, not been able to
find a combination that *does* work), so I've got no choice but to go
back to the old gcc flags and linker script.
This patch has been sent on:
- 29 Sep 2007
Although mips_io_port_base is currently a part of IDE command, it is quite
fundamental for MIPS I/O port access such as in[bwl] and out[bwl]. So move
it to MIPS general part, and introduce `set_io_port_base()' from Linux.
This patch is triggered by multiple definition of `mips_io_port_base' build
error on gth2 (and tb0229 also needs this fix.)
board/gth2/libgth2.a(gth2.o): In function `log_serial_char':
/home/skuribay/devel/u-boot.git/board/gth2/gth2.c:47: multiple definition of `mips_io_port_base'
common/libcommon.a(cmd_ide.o):/home/skuribay/devel/u-boot.git/common/cmd_ide.c:712: first defined here
make: *** [u-boot] Error 1
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
Basically, refactor the CFG_PIXIS_VBOOT_MASK values
into the separate board config files.
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
This patch adds support for 1000BASE-X to functions "miiphy_speed ()" and
"miiphy_duplex()". It also adds function "miiphy_is_1000base_x ()", which
returns non-zero iff the PHY registers are configured for 1000BASE-X. The
"mii info" command is modified to distinguish between 1000BASE-T and -X.
Signed-off-by: Larry Johnson <lrj@acm.org>
Signed-off-by: Ben Warren <bwarren@qstreams.com>
The configuration file has already enabled USB, but it
missed definition of CFG_OHCI_SWAP_REG_ACCESS, the USB
on MPC8641HPCN can not work because of the wrong USB
register endian.
And add the USB command to U-Boot commands list.
Signed-off-by: Zhang Wei <wei.zhang@freescale.com>
To get the IDS8247 board working following are done:
- FCC2 is deactivated
- FCC1 is activated
- I2C is activated
- CFI driver is activated
- Adapted for use with LIBFDT
Signed-off-by: Sergej Stepanov <Sergej.Stepanov@ids.de>
Wolfgang is right: It's not a good idea to set up default initial
ethernet addresses for a board, even though they belong to the local
range.
This will change the failure mode from "IT manager screams at you for
using duplicate ethernet addresses" to a nice error message explaining
that the ethernet address hasn't been set properly.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
With this patch PSC3 is configured as UART. This is done, because if
the pins of PSC3 are not configured at all (-> all pins are GPI),
due to crosstalk, spurious characters may be send over the RX232_2_TXD
signal line.
Signed-off-by: Martin Krause <martin.krause@tqs.de>
signal line.
