It turns out that OpenSSL calls undefined instructions to detect
ARM capabilities at runtime (via SIGILL handler). This leads to
stack traces e.g. when logging in using SSH:
[ 877.464442] sshd (613): undefined instruction: pc=76ee2da8
Disable undefined instruction events since it is used as an
autodetecion mechanism.
Add DFU configuration which allows access to all MTD partitions.
Note that DFU is mostily suited for smaller image uploads e.g.
to update U-Boot but does not work well for large images such as
rootfs since DFU copies the whole image in a memory buffer first.
Let the kernel print some debug messages when a user program
crashes due to an exception.
Set the ver environment variable consistently in all modules.
Move the define form include/configs into the defconfig were
applicable and create a new minimal defconfig.
Add handling for the device tree for the Colibri iMX6ULL 512MB Wi-Fi / BT
Support the V1.2 hardware revision with the following pin muxing
changes:
Ddc_scl_pv4 and ddc_sda_pv5 previously used as Apalis GPIO3 and GPIO4
are now used as DDC pins.
Gen2_i2c_scl_pt5 and gen2_i2c_sda_pt6 previously used as DDC pins are
now used as USB power enable signals.
Usb_vbus_en0_pn4 and usb_vbus_en1_pn5 previously used as USB power
enable signals are now used as GPIO3 and GPIO4.
Additionally a new device tree file tegra124-apalis-v1.2-eval.dtb is
loaded on V1.2 and later modules and resp. USB power enable signals
activated.
Remove m4boot options not available on i.MX 6ULL.
Cleanup U-Boot environment settings.
This undefs CONFIG_ISO_PARTITION.
This removes NAND torture no longer needed after bringup.
Cleanup whitespace and unify order with colibri_imx7.h.
No functional change intended.
Remove/change two NAND releated configs. They are not used in the GPMI
driver and likely confuse readers.
Just like the following commit for distro boot also use the 2nd instance
for legacy sdboot:
colibri_imx7_emmc: distro boot from external SD card
93ef92091832128259ab342a314d0f3e844bb331
Finish the work started by the following commit:
apalis/colibri: fix and synchronize mount options
6ed47e0f143df1c80426edb3b705c87c443c27f7
Currently distro boot is only used for external media. Use mmc 1
which is the external SD card when booting using distro boot.
Store U-Boot environment in eMMC, before config block at the end of 1st
"boot sector".
Use proper emmc specific device tree and boot from eMMC by default
rather than from NAND aka ubi.
Clean-up config header file. Re-order boot commands.
The kernel does not know about rw,noatime. The string rw by itself
is valid, and to pass additional arguments rootflags=noatime can
be used. The kernel mounts ext3/ext4 file systems by default ro,
hence so far the kernel mounted the rootfs read-only. The init
manager systemd then remounts the rootfs after file system checking.
This makes sense and does not add measureable boot time. Let the
kernel explicitly mount ro on block device based rootfs.
The root mount flag noatime is only relevant when re-mounting
read-write, hence it needs to be present in /etc/fstab.
UBIFS used on raw NAND devices has no user space file checking,
hence there is no value to mount it in read-only first. Also mount
time for UBIFS is larger, and mounting first read-only and then
read-write has higher boot time (300ms, likely due to missing block
cache). Let the kernel explicitly mount rw on raw NAND based rootfs.
UBIFS has no atime support, hence no root mount flags needed.
This adds support for Colibri iMX7 Dual 1GB modules which come
with on-board eMMC storage (whereas the other Colibri iMX7
modules use raw NAND). A subselection (variant) for the
Colibri iMX7 target is used to maximize sharing.
The ISO partition support is mainly useful for CD drives which
are not really common in embedded space and in general anymore.
Removing ISO partition support saves 1.5kB and gets rid of the
somewhat confusing message when no partition table is present:
** First descriptor is NOT a primary desc on 0:1 **
The resulting U-Boot boots at least from serial downloader mode.
CONFIG_SYS_NAND_MX7_GPMI_62_ECC_BYTES is no longer used in code.
Remove it.
The nand torture command is a potentially destructive command used
for board bring up and qualification. Do not deploy it regularly.
PXE boot is broken with GCC 7.1 due option '-fstore-merging' enabled
by default for '-O2':
BOOTP broadcast 1
data abort
pc : [<8ff8bb30>] lr : [<00004f1f>]
reloc pc : [<17832b30>] lr : [<878abf1f>]
sp : 8f558bc0 ip : 00000000 fp : 8ffef5a4
r10: 8ffed248 r9 : 8f558ee0 r8 : 8ffef594
r7 : 0000000e r6 : 8ffed700 r5 : 00000000 r4 : 8ffed74e
r3 : 00060101 r2 : 8ffed230 r1 : 8ffed706 r0 : 00000ddd
Flags: nzcv IRQs off FIQs off Mode SVC_32
Resetting CPU ...
Core reason is usage of structures for network headers without packed
attribute.
Reviewed-by: Yauheni Kaliuta <yauheni.kaliuta@redhat.com>
Signed-off-by: Denis Pynkin <denis.pynkin@collabora.com>
(cherry picked from commit 704f3acfcf55343043bbed01c5fb0a0094a68e8a)
include/net.h
upstream changed magic numbers with define
Use ext4 file system by default.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Allow optionally bringing up the Apalis type specific 4 lane PCIe port
as well as the PCIe switch as found on the Apalis Evaluation board. In
order to avoid violating the PCIe reset timing do this by overriding the
tegra_pcie_board_port_reset() function. Note however that both the
Apalis type specific 4 lane PCIe port as well as the regular Apalis PCIe
port are also left disabled in the device tree by default.
Introduce a weak tegra_pcie_board_port_reset() function by default
calling the existing tegra_pcie_port_reset() function. Additionally add
a tegra_pcie_port_index_of_port() function to retrieve the specific PCIe
port index if required. This allows overriding the PCIe port reset
functionality from board specific code as e.g. required for Apalis T30
and Apalis TK1.
Set vidargs default to VGA resolution
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Trying to boot from an ext4 rootfs fails due to us defaulting to ext3.
While the downstream T20/T30 L4T kernel has issues with ext4 later TK1
L4T should work just fine with it. Hence enable ext4 for sdboot and
usbboot on TK1.
Use the same on-flash bad block table in U-Boot as we already
use/maintain in Linux.
Acked-by: Brandon Shibley <brandon.shibley@toradex.com>
Make sure TPS62362 set 0 defaults to 1.200V as the Linux kernel may
switch to set 0 using TPS65911 GPIO1 (EN_CORE_DVFS_N) connected to
TPS62362 VSEL1 prior to actually setting it to a sane value dependent on
the current CPU frequency.
Move Freescale/NXP Vybrid to a standard arch/board approach, similar
to what has been done to i.MX 6 earlier in commit 89ebc82137be ("ARM:
mx6: move to a standard arch/board approach").
Use device-tree fixup to communicate the MTD partitions to the
kernel. Remove mtdparts from the kernel command line.
Move the imximage.h header file to a common location so we can make
use of it from U-Boot too.
Add SDP (Serial Downloader Protocol) implementation for U-Boot. The
protocol is used in NXP SoCs boot ROM and allows to download program
images. Beside that, it can also be used to read/write registers and
download complete Device Configuration Data (DCD) sets. Currently,
this implementation only supports downloading images and reading
registers.
During porting to 2016.11 the check of a SD (mmc2) interface
was dropped, this was unintended.
U-Boot has grown to big with the enablement of FIT image. Since we
boot from a separate UBI volume, U-Boot does not need access to the
UBIFS. Also fix the maximum size, also consider the text base offset
in gfxRAM.
Rather than relying on our separate proprietary storage media dependent
boot commands use regular distro boot as a fall back.
Implement optional PCIe EvalBoard initialisation which properly reset the PLX
(now Avago) PEX 8605 PCIe switch plus PCIe devices on the Apalis Evaluation
carrier board.
Please note that you will have to enable the second PCIe port in the dts as well
e.g.:
diff --git a/arch/arm/dts/tegra30-apalis.dts b/arch/arm/dts/tegra30-apalis.dts
index be4f4d6..321c7d6 100644
--- a/arch/arm/dts/tegra30-apalis.dts
+++ b/arch/arm/dts/tegra30-apalis.dts
@@ -59,6 +59,7 @@
pci@2,0 {
+ status = "okay";
nvidia,num-lanes = <1>;
(cherry picked from commit 340f51a210df1da640a57267e6c7fa56b8a852ed)
Just release TPS65911 GPIO1 (EN_CORE_DVFS_N) connected to TPS62362
VSEL1 to switch VDD_CORE back to boot set 1 defaulting to 1.200V.
(cherry picked from commit 622d408fea7af6d2ed778b546de346e90ea1a21f)
Implement early TPS6586X PMIC rail configuration setting SM0 being
VDD_CORE_1.2V to 1.2 volts and SM1 being VDD_CPU_1.0V to 1.0 volts.
While those are PMIC power-up defaults the SoC might have been reset
separately with certain rails being left at lower DVFS states which
is e.g. the case upon watchdog reset while otherwise nearly idling.
(cherry picked from commit f7c3186985ebb244d075b04ed7c055f39f485670)
Enable the display driver on Apalis T30. Unfortunately the PWM pin
muxing wasn't any good neither which made that display stay dark.
(cherry picked from commit 2da21c1d130fa11a5bd9876c8e72fa0d57585106)
On popular request enable the display driver on Colibri T30. A few
notes about some things encountered during porting: While analogue VGA
(e.g. via the on-carrier RAMDAC) worked just fine from the beginning
the EDT display flickered like crazy which turned out to be a pin
muxing issue. Unfortunately the PWM pin muxing wasn't any good neither
which made that display stay dark. Enjoy.
(cherry picked from commit 201cc6d4e4c8213fbd103e74b0f2f2ca591edf54)
On popular request make the display driver from T20 work on T30 as
well. Turned out to be quite straight forward. However a few notes
about some things encountered during porting: Of course the T30 device
tree was completely missing host1x as well as PWM support but it turns
out this can simply be copied from T20. The only trouble compiling the
Tegra video driver for T30 had to do with some hard-coded PWM pin
muxing for T20 which is quite ugly anyway. On T30 this gets handled by
a board specific complete pin muxing table. The older Chromium U-Boot
2011.06 which to my knowledge was the only prior attempt at enabling a
display driver for T30 for whatever reason got some clocking stuff
mixed up. Turns out at least for a single display controller T20 and
T30 can be clocked quite similar. Enjoy.
(cherry picked from commit 5a472ddd7a2a017747d6c05c65eba2cd3804c02f)
Migrate Colibri T20 to U-Boot 2016.11.
(cherry picked from commit 92d747bf338ceb8d6dbdd3e5e5f7f72226ce0792)
Migrate Apalis/Colibri T30 to U-Boot 2016.11.
(cherry picked from commit 81a38df0631cfa6b3a85c97e631abf73dc0a2226)
Migrating our BSPs towards mainline U-Boot I noticed it suddenly booting
slower. With mainline Linux I noticed about a 1 to 2 second increase
while booting downstream L4T takes 10 to 15 seconds longer!
This reverts commit 858530a8c0a7ce7e573e513934804a00d6676813.
drivers/serial/Makefile
(cherry picked from commit 752aae30a791326581efafbb761c0cebaba8d3ea)
drivers/serial/serial_tegra.c
include/configs/tegra-common.h
(cherry picked from commit 4b97c4173ef96cfa4eb3ba4ea9121320efa90091)
