Add support for reading bootscript and bootscript header from SD. Also
renamed macros *_FLASH to *_DEVICE to represent SD alongwith NAND and
NOR flash.
Reviewed-by: Aneesh Bansal <aneesh.bansal@nxp.com>
Signed-off-by: Sumit Garg <sumit.garg@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
Remove Soc specific defines and use generic chasis specific defines
for USB controller base address mapping.
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
This downloads the same file twice for nothing.
On most platforms the print_fpga_state function is never called. Only
on dlvision-10g do we, so in that case inline it. Drop it from
everywhere else to avoid extra strings.
Acked-by: Reinhard Pfau <reinhard.pfau@gdsys.cc>
Acked-by: Dirk Eibach <dirk.eibach@gdsys.cc>
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Convert IGEP board to use UBI volumes for U-Boot, its environment and
kernel. With exception of first four sectors read by SoC boot
ROM whole (One)NAND is UBI managed.
Also merge NAND and OneNAND defconfigs as now one binary can serve
both flashes.
As code is too big now, drop CONFIG_SPL_EXT_SUPPORT to make it fit.
Allow boards to runtime detect flash type.
[trini: Adapt am33xx, duovero, omap_zoom1]
Add support for loading from UBI volumes on the top of NAND
and OneNAND.
Booting a payload out of NAND FLASH from the SPL is a crux today, as
it requires hard partioned FLASH. Not a brilliant idea with the
reliability of todays NAND FLASH chips.
The upstream UBI + UBI fastmap implementation which is about to
brought to u-boot is too heavy weight for SPLs as it provides way more
functionality than needed for a SPL and does not even fit into the
restricted SPL areas which are loaded from the SoC boot ROM.
So this provides a fast and lightweight implementation of UBI scanning
and UBI fastmap attach. The scan and logical to physical block mapping
code is developed from scratch, while the fastmap implementation is
lifted from the linux kernel source and stripped down to fit the SPL
needs.
The text foot print on the board which I used for development is:
6854 0 0 6854 1abd
drivers/mtd/ubispl/built-in.o
Attaching a NAND chip with 4096 physical eraseblocks (4 blocks are
reserved for the SPL) takes:
In full scan mode: 1172ms
In fastmap mode: 95ms
The code requires quite some storage. The largest and unknown part of
it is the number of fastmap blocks to read. Therefor the data
structure is not put into the BSS. The code requires a pointer to free
memory handed in which is initialized by the UBI attach code itself.
See doc/README.ubispl for further information on how to use it.
This shares the ubi-media.h and crc32 implementation of drivers/mtd/ubi
There is no way to share the fastmap code, as UBISPL only utilizes the
slightly modified functions ubi_attach_fastmap() and ubi_scan_fastmap()
from the original kernel ubi fastmap implementation.
Acked-by: Heiko Schocher <hs@denx.de>
To support UBI in SPL we need a simple NAND read function. Add one to
nand_spl_simple and keep it as simple as it goes.
Acked-by: Scott Wood <oss@buserror.net>
This patch implements the reading functionality for the generic I2C
EEPROM driver, which was just a non-functional stub until now.
Since the page size will be of importance for the writing support, we
add suitable members to the private data structure to keep track of it.
Compatibility strings for a range of at24c* chips are added.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Remove unnecessary board specifc config files for
zynq boards(microzed, picozed, ZC770(all), zed) and point
to zynq common config file.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Enable config CONFIG_SYS_NO_FLASH through defconfig
for all zynq boards.
Define config USB_STORAGE through defconfig for all
respective zynq boards
Add Kconfig entry config option for USB_EHCI_ZYNQ
and update the same to enable for all zynq boards
which supports USB
The EP platform also has working AHCI emulation, so I see little reason
not to implement the plumbing for it that enables us to boot from AHCI.
Code around was removed because of move to Kconfig.
Loading the fdt at 0xc00000 fails if the uncompressed kernel image is
greater than 12 MiB, which is quite common with modern kernels and
multiplatform defconfigs. Move fdtaddr to 0x1e00000 which is just under
the ramdiskaddr on most targets.
Signed-off-by: Scott Wood <oss@buserror.net>
Cc: Peter Tyser <ptyser@xes-inc.com>
Cc: Dirk Eibach <eibach@gdsys.de>
Cc: Andy Fleming <afleming@gmail.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Acked-by: Paul Gortmaker <paul.gortmaker@windriver.com>
For mpc85xx SoCs, the core begins execution from address 0xFFFFFFFC.
In non-secure boot scenario from NAND, this address will map to CPC
configured as SRAM. But in case of secure boot, this default address
always maps to IBR (Internal Boot ROM).
The IBR code requires that the bootloader(U-boot) must lie in 0 to 3.5G
address space i.e. 0x0 - 0xDFFFFFFF.
For secure boot target from NAND, the text base for SPL is kept same as
non-secure boot target i.e. 0xFFFx_xxxx but the SPL U-boot binary will
be copied to CPC configured as SRAM with address in 0-3.5G(0xBFFC_0000)
As a the virtual and physical address of CPC would be different. The
virtual address 0xFFFx_xxxx needs to be mapped to physical address
0xBFFx_xxxx.
Create a new PBI file to configure CPC as SRAM with address 0xBFFC0000
and update DCFG SCRTACH1 register with location of Header required for
secure boot.
The changes are similar to
commit 467a40dfe35f48d830f01a72617207d03ca85b4d
powerpc/mpc85xx: SECURE BOOT- NAND secure boot target for P3041
While P3041 has a 1MB CPC and does not require SPL. On T104x, CPC
is only 256K and thus SPL framework is used.
The changes are only applicable for SPL U-Boot running out of CPC SRAM
and not the next level U-Boot loaded on DDR.
Reviewed-by: Ruchika Gupta <ruchika.gupta@nxp.com>
Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com>
As part of Chain of Trust for Secure boot, the SPL U-Boot will validate
the next level U-boot image. Add a new function spl_validate_uboot to
perform the validation.
Enable hardware crypto operations in SPL using SEC block.
In case of Secure Boot, PAMU is not bypassed. For allowing SEC block
access to CPC configured as SRAM, configure PAMU.
Due to the blow up of the latest kernel size, the default gnuzip
size (8M) seems too small. The yocto kernel size I built for
mpc8315erdb board is 5294393, and it can't be boot by using the
latest u-boot. So expand gnuzip buffer for all the mpc83xx boards
to fix this issue.
Robert P. J. Day also pointed that the kernel partition on the NAND
flash is also too small, fix it at the same time.
Reported-by: Robert P. J. Day <rpjday@crashcourse.ca>
Signed-off-by: Kevin Hao <kexin.hao@windriver.com>
Robert P. J. Day has pointed that the value of SYS_MONITOR_LEN in
MPC8315ERDB.h is smaller than the u-boot.bin. This will cause the
overlap between the code of u-boot and the environment variable.
So when executing saveenv, it will corrupt the code of u-boot and
causes the board not boot. Fix this for all the mpc83xx boards by
reserving a 512K area.
Commit 555f45d8f916 ("image: Convert the IH_... values to enums")
accidentally changed some IH_ARCH_... values.
Prior to that commit, there existed a gap between IH_ARCH_M68K and
IH_ARCH_MICROBLAZE, like follows.
#define IH_ARCH_SPARC64 11 /* Sparc 64 Bit */
#define IH_ARCH_M68K 12 /* M68K */
#define IH_ARCH_MICROBLAZE 14 /* MicroBlaze */
#define IH_ARCH_NIOS2 15 /* Nios-II */
The enum conversion broke the compatibility with existing uImage
files. Reverting 555f45d8f916 will cause build error unfortunately,
so here is a more easy fix.
I dug the git history and figured out the gap was introduced by
commit 1117cbf2adac ("nios: remove nios-32 arch"). So, I revived
IH_ARCH_NIOS just for filling the gap.
I added comments to each enum block. Once we assign a value to
IH_... it is not allowed to change it.
Acked-by: Michal Simek <michal.simek@xilinx.com>
I2C offset was changed by commit 00f792e0 (added multibus support)
from 0x3100 to 0x3000. This typo leads to error when reading SPD
from DDR DIMMs.
Signed-off-by: Benjamin Kamath <bkamath@spaceflight.com>
Signed-off-by: York Sun <york.sun@nxp.com>
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
arch/arm/cpu/armv8/Makefile
arch/arm/lib/bootm-fdt.c
The PPA use PSCI to make secondary cores bootup. So when PPA was
enabled, add the CONFIG_ARMV8_PSCI to identify the SMP boot-method
between PSCI and spin-table.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
Fix a number of typos, including:
* "compatble" -> "compatible"
* "eanbeld" -> "enabled"
* "envrionment" -> "environment"
* "FTD" -> "FDT" (for "flattened device tree")
* "ommitted" -> "omitted"
* "overriden" -> "overridden"
* "partiton" -> "partition"
* "propogate" -> "propagate"
* "resourse" -> "resource"
* "rest in piece" -> "rest in peace"
* "suport" -> "support"
* "varible" -> "variable"
The code had assumed 4 CPUS before and now we have this configurable.
For now, set this to the previous default.
Cc: Chander Kashyap <k.chander@samsung.com>
Cc: Steve Rae <steve.rae@raedomain.com>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Secure_ram variable was put in generic global data. But only ARMv8
uses this variable. Move it to ARM specific data structure.
Both sun6i and sun7i have 64 KB of secure SRAM.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
The original PSCI implementation assumed CONFIG_ARMV7_PSCI_NR_CPUS=4.
Add this to platforms that have not defined it, using CONFIG_MAX_CPUS if
it is defined, or the actual number of cores for the given platform.
sun7i has 2 CPUs.
Allwinner devices support SPI flash as one of the possible
bootable media type. The SPI flash chip needs to be connected
to SPI0 pins (port C) to make this work. More information is
available at:
https://linux-sunxi.org/Bootable_SPI_flash
This patch adds the initial support for booting from SPI flash.
The existing SPI frameworks are not used in order to reduce the
SPL code size. Right now the SPL size grows by ~370 bytes when
CONFIG_SPL_SPI_SUNXI option is enabled.
While there are no popular Allwinner devices with SPI flash at
the moment, testing can be done using a SPI flash module (it
can be bought for ~2$ on ebay) and jumper wires with the boards,
which expose relevant pins on the expansion header. The SPI flash
chips themselves are very cheap (some prices are even listed as
low as 4 cents) and should not cost much if somebody decides to
design a development board with an SPI flash chip soldered on
the PCB.
Another nice feature of the SPI flash is that it can be safely
accessed in a device-independent way (since we know that the
boot ROM is already probing these pins during the boot time).
And if, for example, Olimex boards opted to use SPI flash instead
of EEPROM, then they would have been able to have U-Boot installed
in the SPI flash now and boot the rest of the system from the SATA
hard drive. Hopefully we may see new interesting Allwinner based
development boards in the future, now that the software support
for the SPI flash is in a better shape :-)
Testing can be done by enabling the CONFIG_SPL_SPI_SUNXI option
in a board defconfig, then building U-Boot and finally flashing
the resulting u-boot-sunxi-with-spl.bin binary over USB OTG with
a help of the sunxi-fel tool:
sunxi-fel spiflash-write 0 u-boot-sunxi-with-spl.bin
The device needs to be switched into FEL (USB recovery) mode first.
The most suitable boards for testing are Orange Pi PC and Pine64.
Because these boards are cheap, have no built-in NAND/eMMC and
expose SPI0 pins on the Raspberry Pi compatible expansion header.
The A13-OLinuXino-Micro board also can be used.
Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
Add an implementation of this function which mirrors the functions of the
automatic device-tree implementation. This can be used with of-platdata to
create regmaps.
Devices which use of-platdata have their own platdata. However, in many
cases the driver will have its own auto-alloced platdata, for use with the
device tree. The ofdata_to_platdata() method converts the device tree
settings to platdata.
With of-platdata we would not normally allocate the platdata since it is
provided by the U_BOOT_DEVICE() declaration. However this is inconvenient
since the of-platdata struct is closely tied to the device tree properties.
It is unlikely to exactly match the platdata needed by the driver.
In fact a useful approach is to declare platdata in the driver like this:
struct r3288_mmc_platdata {
struct dtd_rockchip_rk3288_dw_mshc of_platdata;
/* the 'normal' fields go here */
In this case we have dt_platadata available, but the normal fields are not
present, since ofdata_to_platdata() is never called. In fact driver model
doesn't allocate any space for the 'normal' fields, since it sees that there
is already platform data attached to the device.
To make this easier, adjust driver model to allocate the full size of the
struct (i.e. platdata_auto_alloc_size from the driver) and copy in the
of-platdata. This means that when the driver's bind() method is called,
the of-platdata will be present, followed by zero bytes for the empty
'normal field' portion.
A new DM_FLAG_OF_PLATDATA flag is available that indicates that the platdata
came from of-platdata. When the allocation/copy happens, the
DM_FLAG_ALLOC_PDATA flag will be set as well. The dtoc tool is updated to
output the platdata_size field, since U-Boot has no other way of knowing
the size of the of-platdata struct.
This is a flag. Adjust the name to be consistent with the other flags.
Add support for this feature in the core clock code.
This header can be included from anywhere, but will only pull in the
of-platdata struct definitions when this feature is enabled (and only in
SPL).
Provide a new function which can cope with obtaining information from
of-platdata instead of the device tree.
Add a placeholder for now so that this code will compile. It currently does
nothing.
Start up the test devices. These print out of-platdata contents, providing a
check that the of-platdata feature is working correctly.
The device-tree changes are made to sandbox.dts rather than test.dts. since
the former controls the of-platdata generation.
It is useful to be able to build SPL for sandbox. It provides additional
build coverage and allows SPL features to be tested in sandbox. However
it does not need worthwhile to always create an SPL build. It nearly
doubles the build time and the feature is (so far) seldom used.
So for now, create a separate build target for sandbox SPL. This allows
experimentation with this new feature without impacting existing workflows.
These functions are not supported in SPL, so drop them.
