path: root/include
2008-10-13Merge branch 'master' of /home/stefan/git/u-boot/u-bootStefan Roese
2008-10-12Merge branch 'master' of ssh://10.10.0.7/home/wd/git/u-boot/masterWolfgang Denk
2008-10-12Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2008-10-12Merge branch 'master' of git://git.denx.de/u-boot-fdtWolfgang Denk
2008-10-12Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2008-10-10ppc4xx: Update DU440 configMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-08MPC8572DS: Fix compile warningsKumar Gala
Commit 445a7b38308eb05b41de74165b20855db58c7ee5 introduced the following compile warnings: cmd_i2c.c:112: warning: missing braces around initializer cmd_i2c.c:112: warning: (near initialization for 'i2c_no_probes[0]') Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-10-08i.MX31: switch to CFG_HZ=1000Guennadi Liakhovetski
Switch to the standard CFG_HZ=1000 value, while at it, minor white-space cleanup, remove CFG_CLKS_IN_HZ from config-headers. Tested on mx31ads, provides 2% or 0.4% precision depending on the CONFIG_MX31_TIMER_HIGH_PRECISION flag. Measured with stop-watch on 100s boot-delay. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-10-07Remove redundant #define for MPC8536DSHaiying Wang
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2008-10-07Add ID EEPROM support for MPC8572DSHaiying Wang
The ID EEPROM on MPC8572DS board locates on I2C bus 1. Its the storage for system information like mac addresses etc. This patch enables it. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2008-10-07Minor fixes for I2C address on MPC8572DSHaiying Wang
MPC8572DS has two i2c buses. This patch moves the DDR SPD_EEPROM to i2c bus 1 according to the board spec, and adds the 2nd i2c bus offset. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2008-10-07Fix the incorrect DDR clk freq reporting on 8536DSJason Jin
On 8536DS board, When the DDR clk is set async mode(SW3[6:8] != 111), The display is still sync mode DDR freq. This patch try to fix this. The display DDR freq is now the actual freq in both sync and async mode. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2008-10-04libfdt: Fix error in documentation for fdt_get_alias_namelen()Gerald Van Baren
Oops, screwed up the function name in the documenting comment for this function. Trivial correction in this patch. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Acked-by: Gerald Van Baren <vanbaren@cideas.com>
2008-10-02libfdt: Add function to explicitly expand aliasesDavid Gibson
Kumar has already added alias expansion to fdt_path_offset(). However, in some circumstances it may be convenient for the user of libfdt to explicitly get the string expansion of an alias. This patch adds a function to do this, fdt_get_alias(), and uses it to implement fdt_path_offset(). Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
2008-10-01Fix an overflow case in fdt_offset_ptr() detected by GCC 4.3.Jon Loeliger
Using Gcc 4.3 detected this problem: ../dtc/libfdt/fdt.c: In function 'fdt_next_tag': ../dtc/libfdt/fdt.c:82: error: assuming signed overflow does not occur when assuming that (X + c) < X is always false To fix the problem, treat the offset as an unsigned int. The problem report and proposed fix were provided by Steve Papacharalambous <stevep@freescale.com>. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-10-01TQM5200: enable support for ATAPI devicesWolfgang Denk
2008-09-24mpc83xx: don't disable autobootKim Phillips
bootdelay set to -1 'permanently' disables autobooting, even if bootcmd is specified. Change to a positive value to allow autobooting when a bootcmd is set. Reported-by: Coray Tate <Coray.Tate@freescale.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-09-24mpc83xx: Fix typo in include/mpc83xx.hNobuhiro Iwamatsu
Fixed typo from CONIFG_MPC837X to CONFIG_MPC837X Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-09-24mpc83xx: add h/w flash protection to board configsKim Phillips
the operating system may leave flash in a h/w locked state after writing. This allows u-boot to continue to write flash by enabling h/w unlocking by default. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-09-22Fix Spartan-3 definitions.Laurent Pinchart
A few Spartan-3 definitions erroneously use Spartan-3E size constants. This patch fixes them. Signed-off-by: Laurent Pinchart <laurentp@cse-semaphore.com>
2008-09-22Remove duplicate Spartan-3E definition.Laurent Pinchart
Signed-off-by: Laurent Pinchart <laurentp@cse-semaphore.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-09-22socrates: change default mtest address rangeAnatolij Gustschin
Running mtest command on socrates without specifying an address range crashes the board. This patch changes default mtest address range to prevent this behavior. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-09-22socrates: fix SPD EEPROM addressAnatolij Gustschin
Commit be0bd8234b9777ecd63c4c686f72af070d886517 changed SPD EEPROM address to 0x51 and DDR SDRAM detection stopped working. Change this address back to 0x50. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-09-19sh: Fix compile warningNobuhiro Iwamatsu
2008-09-18ADS5121: fix typo in "rootpath" default settingWolfgang Denk
2008-09-16TQM8xx: Fix CFI flash driver support for all TQM8xx based boardsWolfgang Denk
After switching to using the CFI flash driver, the correct remapping of the flash banks was forgotten. Also, some boards were not adapted, and the old legacy flash driver was not removed yet. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-09-13Coding style cleanup, update CHANGELOGWolfgang Denk
2008-09-1385xx: socrates: Add support for new image format.u-boot@bugs.denx.de
Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-09-13powerpc: Fix bootm to boot up again with a RamdiskHeiko Schocher
Commit 2a1a2cb6 didnt remove the dummy mem reservation in fdt_chosen, and this stopped Linux from booting with a Ramdisk. This patch fixes this, by deleting the useless dummy mem reservation. When booting with a Ramdisk, a fix offset FDT_RAMDISK_OVERHEAD is now added to of_size, so we dont need anymore a dummy mem reservation. I measured the value of FDT_RAMDISK_OVERHEAD on a MPC8270 based system (=0x44 bytes) and rounded it up to 0x80). Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kumar Gala <galak@kernel.crashing.org>
2008-09-13Add support for LZMA uncompression algorithm.Luigi 'Comio' Mantellini
Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-12Merge branch 'Makefile-next' of git://git.denx.de/u-boot-armWolfgang Denk
2008-09-12Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2008-09-12ppc4xx: Enable device tree (FDT) support in zeus board portStefan Roese
2008-09-12ppc4xx: Fix SDRAM inititialization of multiple 405 based board portsStefan Roese
This patch fixes a problem introdiced with patch bbeff30c [ppc4xx: Remove superfluous dram_init() call or replace it by initdram()]. The boards affected are: - PCI405 - PPChameleonEVB - quad100hd - taihu - zeus Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-12ARM: synchronize mach-types.h with linux 2.6.27-rc6Jean-Christophe PLAGNIOL-VILLARD
2008-09-12ARM OMAP : Correct Invalid Timer Register Field Declaration in omap1510.h & ↵Gururaja Hebbar K R
omap730.h - Correct Invalid #define of MPUTIM_PTV_MASK for omap1510 & omap730 register definition MPUTIM_PTV_MASK is defined as #define MPUTIM_PTV_MASK (0x7<<PTV_BIT) while it should have been #define MPUTIM_PTV_MASK (0x7<<MPUTIM_PTV_BIT) - Below Patch corrects the same Signed-off-by: Gururaja Hebbar <gururajakr@sanyo.co.in>
2008-09-12i.MX31: Make the SPI bus and chip select configurable for MC13783Magnus Lilja
The i.MX31 has three SPI buses and each bus has several chip selects and the MC13783 chip can be connected to any of these. The current RTC driver for MC13783 is hardcoded for CSPI2/SS2. This patch makes make MC13783 SPI bus and chip select configurable via CONFIG_MC13783_SPI_BUS and CONFIG_MC13783_SPI_CS. Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
2008-09-10ap325rxa: remove duplicate CONFIG_FLASH_CFI_DRIVERJean-Christophe PLAGNIOL-VILLARD
2008-09-10move cmd_get_data_size to command.cJean-Christophe PLAGNIOL-VILLARD
add CMD_DATA_SIZE macro to enable it Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-10cleanup use of CFG_ENV_IS_IN_FLASHJean-Christophe PLAGNIOL-VILLARD
- #if CFG_ENV_IS_IN_FLASH - #if (CFG_ENV_IS_IN_FLASH == 1) - #define CFG_ENV_IS_IN_FLASH 0 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-10rename CFG_ENV_IS_NOWHERE in CONFIG_ENV_IS_NOWHEREJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_IN_SPI_FLASH in CONFIG_ENV_IS_IN_SPI_FLASHJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_IN_ONENAND in CONFIG_ENV_IS_IN_ONENANDJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_IN_NVRAM in CONFIG_ENV_IS_IN_NVRAMJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_IN_NAND in CONFIG_ENV_IS_IN_NANDJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_IN_DATAFLASH in CONFIG_ENV_IS_IN_DATAFLASHJean-Christophe PLAGNIOL-VILLARD
