path: root/include
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-25configs: Re-sync CONFIG_USB_MUSB_HOSTTom Rini
Now that CONFIG_USB_MUSB_HOST is part of Kconfig, migrate that over to the defconfig files. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-25Merge branch 'master' of git://www.denx.de/git/u-boot-uniphierTom Rini
2016-04-25Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2016-04-25dm: core: Add dev_get_addr_ptr() to return a pointer to the reg addressStefan Roese
On some platforms (e.g. x86), the return value of dev_get_addr() can't be assigned to a pointer type variable directly. As there might be a difference between the size of fdt_addr_t and the pointer type. On x86 for example, "fdt_addr_t" is 64bit but "void *" only 32bit. So assigning the register base directly in dev_get_addr() results in this compilation warning: warning: cast to pointer from integer of different size This patch introduces the new function dev_get_addr_ptr() that returns a pointer to the 'reg' address that can be used by drivers in this case. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-04-24ARM: uniphier: speed up loading kernel image from NOR deviceMasahiro Yamada
Copy the kernel image double-word-wise rather than byte-wise. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-04-24ARM: uniphier: reserve the last 64 byte of SDRAMMasahiro Yamada
The last 64 byte of each DDR channel of PH1-LD20 is periodically used as a scratch area for the DDR PHY training. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-04-24ARM: uniphier: add PH1-LD20 SoC supportMasahiro Yamada
This is the first ARMv8 SoC from Socionext Inc. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-04-20Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
Conflicts: configs/bcm28155_ap_defconfig configs/dra72_evm_defconfig configs/dra74_evm_defconfig configs/ma5d4evk_defconfig Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: dwc3: Move CONFIG_USB_DWC3_PHY_* to KconfigSam Protsenko
2016-04-20usb: dwc3: Move CONFIG_USB_DWC3_OMAP to KconfigSam Protsenko
2016-04-20usb: dwc3: Move CONFIG_USB_DWC3_GADGET/HOST to KconfigSam Protsenko
Description was borrowed from kernel dwc3 Kconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_VBUS_DRAW to KconfigSam Protsenko
The description was borrowed from kernel. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Boards using 0 mA as CONFIG_USB_GADGET_VBUS_DRAW value were moved to use 2 mA (as minimal allowed by Kconfig). Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-19Add initial support for Technexion's PICO-IMX6UL-EMMC boardFabio Estevam
Add support for Technexion's PICO-IMX6UL-EMMC board. For information about this board, please visit: http://www.technexion.com/products/pico/pico-som/pico-imx6-emmc Signed-off-by: Richard Hu <richard.hu@technexion.com> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-04-19board: ge: bx50v3: Use pwm for display backlightAkshay Bhat
Setup the LCD backlight brightness control pin to use PWM Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com> Cc: Stefano Babic <sbabic@denx.de>
2016-04-18bx50v3: Enable CONFIG_OF_LIBFDT in defconfigAkshay Bhat
As of commit 69e173eb57d1f4848f070c83456096ba5d2ba1b4, CONFIG_OF_LIBFDT needs to be selected in defconfig instead of board specific header file. Hence enable CONFIG_OF_LIBFDT in defconfig. Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com>
2016-04-18efi_loader: Fall back to fdtfile naming conventionAlexander Graf
When there is no $fdtfile variable set, we still have a good chance that on 32bit arm the fdtfile really is just called $soc-$board.dtb. Enable the exports for $soc and $board in our distr defaults and make use of them in the efi boot script. Reported-by: Andreas Faerber <afaerber@suse.de> Reported-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Andreas Färber <afaerber@suse.de>
2016-04-18efi_loader: Pass fdt address directly to bootefi cmdAlexander Graf
The bootefi cmd today fetches its device tree pointer from either the location appointed by "fdt addr" with a fallback to the U-Boot control fdt. This integration is unusual for U-Boot and diverges from the way we usually handle parameters to boot commands. So let's pass the fdt directly into the bootefi command instead and move the control fdt logic into the distro boot script. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Andreas Färber <afaerber@suse.de>
2016-04-18Remove references to CONFIG_CMD_EXT3, no such commandRobert P. J. Day
2016-04-18dragonboard410c: Fix environment variablesAndreas Färber
Some variables for the distro boot commands were missing, using some custom name instead. Rename them. Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Signed-off-by: Andreas Färber <afaerber@suse.de>
2016-04-18configs: ks2: move CMD_NAND to defconfigsLokesh Vutla
NAND is not yet enabled on all Keystone2 platforms. So enabled CMD_NAND in the respective defconfigs only if available. Reported-by: Nishanth Menon <nm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-18memory: Move TI_AEMIF config to KCONFIGLokesh Vutla
Not all Keystone2 devices has AEMIF NAND controller. So adding Kconfig entry for CONFIG_TI_AEMIF and enabling it in respective defconfigs on platforms with AEMIF controller. Reported-by: Nishanth Menon <nm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-18dragonboard410c: Add CONFIG_SYS_CACHELINE_SIZEMateusz Kulikowski
Add missing define to board header file. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Andreas Färber <afaerber@suse.de>
2016-04-18distro: Enable iso partition codeAlexander Graf
Now that we can properly boot EFI payloads from iso el torito images, let's enable support for isos by default in the distro header. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-04-18efi_loader: Increase path string to 32 charactersAlexander Graf
Whenever we want to tell our payload about a path, we limit ourselves to a reasonable amount of characters. So far we only passed in device names - exceeding 16 chars was unlikely there. However by now we also pass real file path information, so let's increase the limit to 32 characters. That way common paths like "boot/efi/bootaa64.efi" fit just fine. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-04-18efi_loader: Pass file path to payloadAlexander Graf
The payload gets information on where it got loaded from. This includes the device as well as file path. So far we've treated both as the same thing and always gave it the device name. However, in some situations grub2 actually wants to find its loading path to find its configuration file. So let's split the two semantically separte bits into separate structs and pass the loaded file name into our payload when we load it using "load". Signed-off-by: Alexander Graf <agraf@suse.de>
2016-04-18cmd: fdt: Use separate CMD_FDT Kconfig entry instead of OF_LIBFDTMichal Simek
Create CMD_FDT Kconfig entry to have an option to disable fdt command which is not required for small configuration which requires libfdt only. Enable it by default for all targets which enables OF_LIBFDT. Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fixup flea3/sandbox/id8313/siemens-am33xx/smartweb] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-18kconfig: Move CONFIG_OF_LIBFDT to KconfigMichal Simek
This patch follows work done by: "Move CONFIG_OF_LIBFDT to Kconfig" (sha1: 69e173eb57d1f4848f070c83456096ba5d2ba1b4) Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Add xpress* to the patch] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-18bcm281xx: save ENV to MMCSteve Rae
Enable saving ENV to MMC for the bcm281xx boards. Signed-off-by: Steve Rae <srae@broadcom.com>
2016-04-16ARM: rpi: fix 64-bit CONFIG_SYS_TEXT_BASEStephen Warren
The Pi firmware has changed the default "kernel" load address for 64-bit mode. The authors have confirmed that this is a deliberate and long-term change. Adapt U-Boot to the new value. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2016-04-15fdt: implement dev_get_addr_name()Stephen Warren
This function parses the reg property based on an index found in the reg-names property. This is required for bindings that are written using reg-names rather than hard-coding indices in reg. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-04-13Merge branch 'master' of git://www.denx.de/git/u-boot-microblazeTom Rini
2016-04-13ARM64: zynqmp: Use i2c cadence DM driverMichal Simek
Use i2c cadence DM driver for all zynqmp targets except ZCU102 because I2C muxes and PCA953x are not supported in the tree yet. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2016-04-13ARM64: zynqmp: Enable pca953x driver for zcu102Michal Simek
zcu102 has two pca953x on i2c bus 0. Chips 0x20 and 0x21. Enable option to work with these two chips. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-13gpio: Kconfig: Enable Zynq GPIO driver using kconfigSiva Durga Prasad Paladugu
Enable DM GPIO and ZYNQ GPIO using kconfig instead of the board config file. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-13ARM64: zynqmp: Clean header after moving stuff to KconfigMichal Simek
Moving stuff to Kconfig by script is keep some empty lines or comment in the file. Remove them. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-13ARM64: zynqmp: Add support for zc1751 with DC cardsMichal Simek
Support ZynqMP zc1751 with DC cards. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-13ARM64: zynqmp: Add support for ZCU102 platformMichal Simek
Add new board support. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-13ARM64: zynqmp: Move kernel and fdt offsets and sizes to board config fileSiva Durga Prasad Paladugu
Move kernel and fdt offsets and sizes to board config file as the flash size varies across boards Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-13ARM: zynq: Do not perform reset at the end of thorMichal Simek
Setup reset off for lthor. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-13ARM: zynq: Support systems with more memory banksMichal Simek
This is example how to change u-boot to support more memory banks read from DT. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-13ARM: zynq: Use memory initialization based on DTS fileMichal Simek
Remove hardcoded memory sizes. Use information from DT memory node. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-13ARM: zynq: Extend microzed board supportMichal Simek
Add missing DT nodes and enable USB. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Nathan Rossi <nathan@nathanrossi.com>
2016-04-13Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
