Exactly one board has defined CONFIG_SYS_PROMPT_HUSH_PS2 to a value
different than "> " which is vision2. I have Cc'd the maintainer here
as I strongly suspect this is a bug rather than intentional behavior.
We provide a default table of { 9600, 19200, 38400, 57600, 115200 }
in <config_fallbacks.h> which mkconfig places after <configs/...h> in
the generated config file. This is used when a board has not set its
own table.
If the testpin is asserted, first check if a test_bank
variable is defined before trying to boot this
test_bank.
Signed-off-by: Thomas Herzmann <thomas.herzmann@keymile.com>
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
kmcoge5ne starts the post tests if the testpin on
the board was enabled. Currently it does simply a memory
test.
Increase bootlimit to 3 to be more tolerant during the
boot process before switching to the backup application.
This board is a MPC8360 board. Two flashes are present
a NOR flash were u-boot and the u-boot environment is stored
and a NAND flash for the application code. This board has 512MB
SDRAM.
Additionaly we introduce a common km8360.h file and convert kmeter1 to
use this.
Signed-off-by: Christian Herzig <christian.herzig@keymile.com>
cc: Kim Phillips <kim.phillips@freescale.com>
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Gerlando Falauto <gerlando.falauto@keymile.com>
cc: Heiko Schocher <hs@denx.de>
Add support for a second flash.
By default, a single flash chip is set up:
- called 'boot'
- mtd name for ubi 'ubi0'
MTDIDS and MTDPARTS may be overwritten to add a second flash.
The 'ubiattach' command is featured in two versions:
- if CONFIG_KM_UBI_PARTITION_NAME_APP is not defined:
this is the version as up to now
- if CONFIG_KM_UBI_PARTITION_NAME_APP is defined:
a check on 'actual_bank' will be done to determine the flash to boot
from.
Use CONFIG_KM_UBI_PARTITION_NAME_BOOT and
CONFIG_KM_UBI_PARTITION_NAME_APP to define where to put the bootloader
and the applications.
Example:
In the board config do:
... snip ...
"boot:" \
"768k(u-boot)," \
"128k(env)," \
"128k(envred)," \
"-(" CONFIG_KM_UBI_PARTITION_NAME_BOOT ");" \
"app:" \
"-(" CONFIG_KM_UBI_PARTITION_NAME_APP ");"
... snap ...
You may also need to enable the second flash:
... snip ...
/* additional featured for COGE5 */
... snap ...
Signed-off-by: Andreas Huber <andreas.huber@keymile.com>
We don't use PCI on kmeter1 and never will be, so remove some
unneeded code.
This additional header is unneeded, we can use the tuxx1.h for this
target.
The malloc buffer is not large enough to hold a flash sector (0x20000 bytes)
in addition to whatever else it normally holds, so double its size. This
fixes a failure trying to save the environment:
=> save
Saving Environment to Flash...
Unable to save the rest of sector (122880)
. done
Protected 1 sectors
This problem probably surfaced from some other change that significantly
increased the normal memory usage, thereby not leaving enough room for
the saveenv command.
* 'master' of git://git.denx.de/u-boot-video:
video: atmel/lcd: add LCD driver for new Atmel SoC
video: cfb_console: flush dcache for frame buffer in DRAM
cfb_console: Ignore bell character
cfb_console: Add console_clear_line function
cfb_console: Fix function console_back
omap3_dss: cosmetic changes
omap3_dss: add optional framebuffer
mx53loco: Add LCD support
mx5: Rename mx51_fb_init()
mx53: Allow IPUv3 driver to also work on mx53
mx51evk: Add LCD support
EXYNOS: display 32bpp bitmap TIZEN logo
create lib/tizen directory
LCD: display 32bpp decompressed bitmap image
common/lcd.c: reduce one CONFIG_LCD_LOGO ifdef
common/lcd.c: reduce some CONFIG_LCD_*_LOGO ifdefs
common/lcd.c: use ARRAY_SIZE
cmd_bmp.c: make bmp_display() usable by drivers or board code
LCD: support another s6e8ax0 panel type
LCD: change s6e8ax0 panel gamma value
include/video.h: drop unused video_printf()
* 'master' of git://git.denx.de/u-boot-mips:
MIPS: board.c: move extern declarations to u-boot-mips.h
MIPS: bootm_qemu_mips.c: make checkpatch.pl clean
MIPS: bootm.c: make checkpatch.pl clean
The new Atmel SoC (at91sam9x5 series and at91sam9n12) add a totally
different LCD controller. Add this new driver to support it.
Using CONFIG_ATMEL_HLCD (distinguish with CONFIG_ATMEL_LCD) to enable
this in board configuration file.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
This fixes some remaining checkpatch.pl warnings.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
This is an sh2a device (max 266MHz) with FPU, video display
controller (VDC), 8 serial ports, 4 I2C channels, 3 CAN ports,
SD and on-chip USB.
The RSK2+SH7269 board uses the SH7269 processor. It is often
referred to as just rsk7269.
Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com>
with sh_eth
The board with sh_eth needs to set CONFIG_SH_ETHER_PHY_MODE.
And SH7734 needs to set value of CONFIG_SH_ETHER_SH7734_MII.
The AP-SH4A-4A board has SH7734, 64MB DDR2-SDRAM, USB,
Ethernet, and more.
This patch supports the following functions:
- 64MB DDR2-SDRAM
- 16MB NOR Flash memory
- Serial console (SCIF)
- Ethernet (SH-Ether with Gigabit)
- I2C
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
This read MAC address from Serial EEPROM and set.
The r0p7734 board has SH7734, 128MB DDR2-SDRAM, USB,
Ethernet, and more.
- 128MB DDR2-SDRAM
- 32MB NOR Flash memory
- Ethernet (SH-Ether/SMSC)
Add support for CLAA07LC0ACW LCD that connects to the mx53loco board.
Configure the board to show the Linux logo on the LCD.
Also increase the size of CONFIG_SYS_MALLOC_LEN variable to take into account
the framebuffer usage.
Acked-by: Jason Liu <r64343@freescale.com>
The ipuv3 driver is currently only used on mx51, but it can be extended to work
on mx53 and mx6 as well.
Rename mx51_fb_init(), so that it can be used by other SoCs.
Add support for CLAA07LC0ACW LCD that connects to the mx51evk board.
This patch supports drawing 32bpp bitmap TIZEN logo in exynos fb.
"tizen_hd_logo.h" data is compressed from trats_logo.bmp to
trats_logo.bmp.gz by gzip and converted to tizen_hd_logo.h header file
format by some application. The logo data is decompressed in the exynos
fb driver by bmp_display().
Signed-off-by: Donghwa Lee <dh09.lee@samsung.com>
Acked-by: Minkyu Kang <mk7.kang@samsung.com>
This directory includes tizen logo data, common tizen library and so on.
[ agust: change to conditionally build lib/tizen directory ]
Currently bmp_display() is static and can not be used directly
in the driver or board code. Export it for other users.
There is no such function in the code, so remove this prorotype.
Add several levels of DEBUG prints so that you can limit the noise to
the severety of your problem.
DEBUG_LL_STATE = Link local state machine changes
DEBUG_DEV_PKT = Packets or info directed to the device
DEBUG_NET_PKT = Packets on info on the network at large
DEBUG_INT_STATE = Internal network state changes
Code based on networking/zcip.c in busybox
commit 8531d76a15890c2c535908ce888b2e2aed35b172
Use the NetArpTxPacket for the ARP packet, not to hold what used to
be in NetTxPacket.
This saves a copy and makes the code easier to understand.
A new non-static function net_init() will initialize buffers and
read from the environment. Only update from the env on each entry
to NetLoop().
When the network is VLAN or SNAP, net_update_ether() will preserve
the original Ethernet packet header and simply replace the src and
dest MACs and the protocol
Call a built-in dummy if none is registered... don't require
protocols to register a handler (eliminating dummies)
NetConsole now uses the ARP handler when waiting on arp
(instead of needing a #define hack in arp.c)
Clear handlers at the end of net loop
Changes to NetState now go through an accessor function called
net_set_state()
Use this entry-point consistently across the net/ code
Use a static inline function to preserve code size
ICMP (ping) was reimplementing IP header code... it now shares code.
Use field names and sizes when accessing ARP packets
Make the comment more accurate about the header including SNAP
This name more explicitly claims that it does not include the
header size
Remove typedef and lower-case name
Remove typedef and lower-case letters
Eliminate the typedef and remove capital letters
Separate the Ethernet header from the 802 header.
Base the size constants on the structs.
Add a structure that only contains IP header fields to be used by
functions that don't need UDP
Rename IP_HDR_SIZE_NO_UDP to IP_HDR_SIZE
Rename IP header related things to IP_UDP. The existing definition
of IP_t includes UDP header, so name it to accurately describe the
structure.
Separate this functionality out of the net.c behemoth
Checking for CDP packets should be encapsulated, not copied code.
Some boards claim to need ping, but don't support net.
That makes no sense, and causes problems now that ping
is in a separate file.
Indent at the same level as other struct members.
