2002-11-18 | * Patch by Daniel Engström, 13 Nov 2002:LABEL_2002_11_18_0115 | wdenk | |
Add support for i386 architecture and AMD SC520 board * Patch by Pierre Aubert, 12 Nov 2002: Add support for DOS filesystem and booting from DOS floppy disk | |||
2002-11-11 | * Patch by Jim Sandoz, 07 Nov 2002:LABEL_2002_11_11_2211 | wdenk | |
Increase number of network RX buffers (PKTBUFSRX in "include/net.h") for EEPRO100 based boards (especially SP8240) which showed "Receiver is not ready" errors when U-Boot was processing the receive buffers slower than the network controller was filling them. * Get rid of obsolete include/mpc74xx.h | |||
2002-11-10 | * Vince Husovsky, 7 Nov 2002:LABEL_2002_11_10_2310 | wdenk | |
Add "-n" to linker options to get rid of "Not enough room for program headers" problem * Patch by David Müller, 05 Nov 2002 Rename CONFIG_PLL_INPUT_FREQ to CONFIG_SYS_CLK_FREQ so we can use an already existing name * Patch by Pierre Aubert, 05 Nov 2002 Hardware related improvements in FDC boot code * Patch by Holger Schurig, 5 Nov 2002: Make the PXA really change it's frequency * Patch by Pierre Aubert, 05 Nov 2002 Add support for slave serial Spartan 2 FPGAs * Fix uninitialized memory (MAC address) in 8xx SCC/FEC ethernet drivers | |||
2002-11-05 | Quick & Dirty fix for log buffer problem when environment is not set | wdenk | |
Trigger watchdog when reading the env - this might take a while. Set debugging baud rate for KUP4K board | |||
2002-11-05 | * Add support for log buffer which can be passed to Linux kernel'sLABEL_2002_11_05_1735 | wdenk | |
syslog mechanism; used especially for POST results. * Patch by Klaus Heydeck, 31 Oct 2002: Add initial support for kup4k board | |||
2002-11-05 | * Patch by Robert Schwebel, 04 Nov 2002:LABEL_2002_11_05_0120 | wdenk | |
- use watchdog to reset PXA250 systems - added progress callbacks to (some of the) ARM code - update for Cogent CSB226 board * Add support for FPS860 board | |||
2002-11-04 | Patch by Guillaume Alexandre,, 04 Nov 2002: | wdenk | |
Improve PCI access on 32-bits Compact PCI bus Adjust VFD initialization on TRAB Cleanup RRvision video code | |||
2002-11-03 | * Fix mdelay() on TRAB - this was still the debugging version with | wdenk | |
seconds instead of ms. * Patch by Robert Schwebel, 1 Nov 2002: XScale related cleanup (affects all ARM boards) * Cleanup of names, warnings and README. | |||
2002-11-03 | Initial revision | wdenk | |
2002-11-02 | Initial revision | wdenk | |
2002-10-31 | Initial revision | wdenk | |
2002-10-26 | Initial revision | wdenk | |
2002-10-25 | Initial revision | wdenk | |
2002-10-24 | Initial revision | wdenk | |
2002-10-21 | Initial revision | wdenk | |
2002-10-19 | Initial revision | wdenk | |
2002-10-17 | Initial revision | wdenk | |
2002-10-11 | Initial revision | wdenk | |
2002-10-07 | Initial revision | wdenk | |
2002-10-02 | Initial revision | wdenk | |
2002-09-30 | Initial revision | wdenk | |
2002-09-28 | Initial revision | wdenk | |
2002-09-27 | Initial revision | wdenk | |
2002-09-26 | Initial revision | wdenk | |
2002-09-20 | Initial revision | wdenk | |
2002-09-18 | Initial revision | wdenk | |
2002-09-17 | Initial revision | wdenk | |
2002-09-15 | Initial revision | wdenk | |
2002-09-12 | Initial revision | wdenk | |
2002-09-10 | Initial revision | wdenk | |
2002-09-07 | Initial revision | wdenk | |
