CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present
in most ARM board config files.
IRQs are only enabled for 1 config, so remove the unused config options
for IRQ and FIQ stack size as well.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Add SPL options to tegra20 config files and enable SPL build for
tegra20 boards. Also remove redundant code from u-boot that is not
contained in SPL.
Signed-off-by: Allen Martin <amartin@nvidia.com>
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Tested-by: Thierry Reding <thierry.reding@avionic-design.de>
Signed-off-by: Tom Warren <twarren@nvidia.com>
Add tegra20-common-post.h to be consistent with other tegra20 boards.
Acked-by: Thierry Reding <thierry.reding@avionic-design.de>
Rename CONFIG_MACH_TEGRA_GENERIC to the less confusing CONFIG_TEGRA.
The meaning of the config options is now:
CONFIG_TEGRA - Any tegra chip
CONFIG_TEGRA20 - A tegra20 family chip
CONFIG_TEGRA30 - A tegra30 family chip (not added yet)
This is make naming consistent with the kernel and devicetree and in
preparation of pulling out the common tegra20 code.
The Raspberry Pi model B uses the BCM2835 SoC, has 256MB of RAM,
contains an SMSC 9512 USB LAN/Hub chip, and various IO connectors.
For more details, see http://www.raspberrypi.org/.
Various portions (cache enable, MACH_TYPE setup, RAM size limit, stack
relocation to top of RAM) extracted from work by:
Oleksandr Tymoshenko <gonzo@bluezbox.com>.
GPIO driver enablement by Vikram Narayanan <vikram186@gmail.com>.
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
Acked-by: Tom Rini <trini@ti.com>
Configuration in vexpress and u8500.v1 is different from what
is needed in u8500.v2. As such, card configuration specifics need
to reside in the board file rather than the driver.
Signed-off-by: John Rigby <john.rigby@linaro.org>
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
LAN and GBF need to be powered explicitely, doing so with
interface to AB8500 companion chip.
Enabling timers and clocks in PRCMU and cleaning up mailbox.
drivers/gpio/Makefile
Also enable the ohci port on hawkboard. These additions result in an
increased u-boot size -- adjust the same accordingly in the board's
config.
Move the usb header for da8xx platforms under arch-davinci.
Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com>
Make the lowlevel_init function that these platforms have which just
sets up the stack and calls a C function available to all armv7
platforms. As part of this we change some of the macros that are used
to be more clear. Previously (except for am335x evm) we had been
setting CONFIG_SYS_INIT_SP_ADDR to a series of new defines that are
equivalent to simply referencing NON_SECURE_SRAM_END. On am335x evm we
should have been doing this initially and do now.
Cc: Sricharan R <r.sricharan@ti.com>
Tested-by: Allen Martin <amartin@nvidia.com>
Fix build failure due the move of mx28 code to 'mxs' SoC.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
This i.MX28 platform supports the following:
* 2x FEC ethernet
* USB on USBH0
* I2C EEPROM
* SPI NVRAM
* LEDs
On this board, the console is always set to the serial line.
Do not allow to overwrite it when video is enabled.
CC: Fabio Estevam <fabio.estevam@freescale.com>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
Most code can be shared between i.MX23 and i.MX28 as both are from
i.MXS family; this source directory structure makes easy to share code
among them.
Turn on data and instruction caches.
This adds support for Bluegiga APX4 Development Kit. It is built around
Freescale i.MX28. Currently supported features are: ethernet, I2C, MMC,
RTC and USB. APX4 has only one ethernet port.
Signed-off-by: Veli-Pekka Peltola <veli-pekka.peltola@bluegiga.com>
Signed-off-by: Lauri Hintsala <lauri.hintsala@bluegiga.com>
This adds support for the AT91SAM9G20 boards by taskit GmbH.
Both boards, Stamp9G20 and PortuxG20, are integrated in one
file. PortuxG20 is basically a SBC built around the Stamp9G20.
Signed-off-by: Markus Hubig <mhubig@imko.de>
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Signed-off-by: Andreas Bießmann <andreas.deve@googlemail.com>
Add at91sam9x5ek board support, this board support the following SoCs
AT91SAM9G15, AT91SAM9G25, AT91SAM9G35, AT91SAM9X25, AT91SAM9X35
Using at91sam9x5ek_nandflash to configure for the board
Now only supports NAND with software ECC boot up
Signed-off-by: Bo Shen <voice.shen@atmel.com>
[move MAINTAINERS entry to right place]
Beaglebone uses SMSC PHY which works incorrectly with generic PHY
driver so enable SMSC PHY driver to fix networking problems on
Beaglebone.
Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: U-Boot DM <u-boot-dm@lists.denx.de>
Cc: Tom Rini <trini@ti.com>
This fixes the breakage with SPL on most OMAP boards after the GPIO
driver was moved.
am33xx boards have at least one eeprom and in the case of beaglebones
with capes, more.
- Add default commands
- Add HUSH parser
- Make environment, malloc areas larger
- Add ATAGS and OF_LIBFDT
- Add defaults to boot ramdisk and MMC, use uEnv.txt
This patch adds SPL support for IGEP-based boards.
Tested on an IGEPv2 Rev.C board with Micron NAND Flash memory.
Signed-off-by: Javier Martinez Canillas <javier@dowhile0.org>
IGEP-based boards can have two different flash memories, a OneNAND or a
NAND device. Add a configuration option for to choose which memory to use.
Acked-by: Enric Balletbo i Serra <eballetbo@gmail.com>
This patch adds board-specific initialization for CPSW on
TI AM335X based boards. Tested on BeagleBone.
Signed-off-by: Chandan Nath <chandan.nath@ti.com>
[Ilya: split board-specific part into separate patch]
CPSW is an on-chip ethernet switch that is found on various SoCs from Texas
Instruments. This patch adds a simple driver (based on the Linux driver) for
this hardware module.
This patch also adds support to clean and flush dcache during packet send
and receive.
Changes by Sandhya: Added support to clean and flush dcache during packet
send/receive and added timeouts.
Signed-off-by: Cyril Chemparathy <cyril@ti.com>
Signed-off-by: Satyanarayana, Sandhya <sandhya.satyanarayana@ti.com>
[Ilya: Cleaned cache handling, some style cleanup, some small
fixes, use of internal RAM for descriptors]
also fix NS16550_init() as we need 16x divider
Signed-off-by: Mikhail Kshevetskiy <mikhail.kshevetskiy@gmail.com>
Acked-by: Christian Riesch <christian.riesch@omicron.at>
Tested-by: Christian Riesch <christian.riesch@omicron.at>
Acked-by: Sughosh Ganu <urwithsughosh@gmail.com>
Tested-by: Sughosh Ganu <urwithsughosh@gmail.com>
This patch sets up pinmux, enables fclk, and
defines CONFIG_I2C_MULTI_BUS
Signed-off-by: Steve Sakoman <steve@sakoman.com>
Signed-off-by: Peter Meerwald <p.meerwald@bct-electronic.com>
omap2plus_defconfig now has built-in compile support for EXT4 enabled
by default now. So, we can use EXT4 as the default root file system
type for MMC.
An OMAP specific serial driver was merged on the Linux kenel a long
time ago. So, it makes sense to default the console name to OMAP
ttyO instead of the generic ttyS naming.
This patch adds support for direct NOR boot mode on
da850/omap-l138. Added da850evm_direct_nor entry in
boards.cfg to allow to build targets.
Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com>
Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com>
Signed-off-by: Hadli, Manjunath <manjunath.hadli@ti.com>
This patch adds configuration required for NAND SP
on DA850/OMAP-L138.
DA850/OMAP-L138 does not support strict MMC/SD boot mode. SPL will
be in SPI flash and U-Boot image will be in MMC/SD card. SPL will
do the low level initialization and then loads the u-boot image
from MMC/SD card.
Define CONFIG_SPL_MMC_LOAD macro in the DA850/OMAP-L138
configuration file to enable this feature.
define SPI specific configs for SPL only when CONFIG_USE_SPIFLASH
config is defined
On Logic PD Rev.3 DA850/OMAP-L138 EVM, NOR and MMC/SD cannot
work together. This patch enables the MMC/SD support only
when NOR support is disabled. NOR Flash identification works
even without this patch, but erase and write will have issues.
This patch adds support for MMC/SD on DA850/OMAP-L138.
UART_RESET, UART_CLK_RUNNING_MASK, and UART_SMART_IDLE_EN
are defined inn evm.c but not used. Also removes unnecessary
include of serial.h
PHYS_DRAM_1_SIZE is defined in am335x_evm.h but never used.
Detect hot-water-button to start a differnt image.
CC: Tom Rini <trini@ti.com>
Patch drops also not used CFI setup in the
configuration file.
Parameters used for configuring certain SoC peripherals are parsed
from the cfg file and appended as part of the ais image's header. The
u-boot-spl.ais generated is flashed separately to the nand, so do not
delete the file after generation of u-boot.ais.
This patch moves all bootcount implementations into a common
directory: drivers/bootcount. The generic bootcount driver
is now usable not only by powerpc platforms, but others as well.
Cc: Valentin Longchamp <valentin.longchamp@keymile.com>
Cc: Christian Riesch <christian.riesch@omicron.at>
Cc: Manfred Rudigier <manfred.rudigier@omicron.at>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Reinhard Meyer <reinhard.meyer@emk-elektronik.de>
Tested-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Acked-by: Rob Herring <rob.herring@calxeda.com>
Remove old o2dnt board without OF support. New support for this board
is added by the previous patch, O2I configuration.
