Copy them from Linux v3.16 tag.
My main motivation of this commit is to add compiler-clang.h.
Cc: Jeroen Hofstee <jeroen@myspectrum.nl>
update to provide usable implementation to U-Boot
Signed-off-by: Steve Rae <srae@broadcom.com>
U-Boot has imported various source files from other projects,
mostly Linux.
Something like
#ifdef __UBOOT__
[ modification for U-Boot ]
#else
[ original code ]
#endif
is an often used strategy for clarification of adjusted parts,
that is, easier re-sync in future.
Instead of defining __UBOOT__ in each source file,
passing it from the top Makefile would be easier.
Acked-by: Heiko Schocher <hs@denx.de>
Use driver model for serial ports.
Since Tegra now uses driver model for serial, adjust the definition of
V_NS16550_CLK so that it is clear that this is only used for SPL.
Some Tegra device tree files do not include information about the serial
ports. Add this and also add information about the input clock speed.
The console alias needs to be set up to indicate which port is used for
the console.
Also add a binding file since this is missing.
Series-changes; 5
- Add full serial port nodes from Linux tree (commit fc9d4dbe)
- Use /chosen/stdout-path instead of /aliases/console to specify the console
Add driver model support so that ns16550 can support operation both with
and without driver model.
The driver needs a clock frequency so cannot stand alone unfortunately. The
clock frequency must be provided by a separate driver.
Move the function that calculates the baud rate divisor into ns16550.c so
it can be used by that file.
Adjust the sandbox serial driver to use the new driver model uclass. The
driver works much as before, but within the new framework.
Serial devices support simple byte input/output and a few operations to find
out whether data is available. Add a basic uclass for serial devices to be
used by drivers that are converted to driver model.
Allow the caller to find out the device that was bound in response to this
call.
Within /chosen we may have a node which points to another node, similar
to how /aliases works. Add a helper function to do this lookup.
This is an implementation of GPIOs for Tegra that uses driver model. It has
been tested on trimslice and also using the new iotrace feature.
The implementation uses a top-level GPIO device (which has no actual GPIOS).
Under this all the banks are created as separate GPIO devices.
The GPIOs are named as per the Tegra datasheet/header files: A0..A7, B0..B7,
..., Z0..Z7, AA0..AA7, etc.
Since driver model is not yet available before relocation, or in SPL, a
special function is provided for seaboard's SPL code.
Allocate 1KB so that driver model can operate before relocation.
For some boards board_init() will change GPIOs, so we need to have driver
model available before then. Adjust the board init to arrange this, but
enable it for driver model only, just to be safe.
This does create additional #ifdef logic, but it is safer than trying to
make a pervasive change which may cause some boards to break.
The microblaze-generic board fails to build at least
with the kernel.org crosstool:
https://www.kernel.org/pub/tools/crosstool/files/bin/x86_64/4.9.0/
x86_64-gcc-4.9.0-nolibc_microblaze-linux.tar.xz
$ make CROSS_COMPILE=microblaze-linux- microblaze-generic_defconfig all
[ snip ]
CC disk/part.o
CC disk/part_dos.o
LD disk/built-in.o
CC drivers/block/systemace.o
{standard input}: Assembler messages:
{standard input}:2495: Error: operation combines symbols in different segments
{standard input}:2496: Error: operation combines symbols in different segments
{standard input}:2499: Error: operation combines symbols in different segments
{standard input}:2500: Error: operation combines symbols in different segments
{standard input}:2505: Error: operation combines symbols in different segments
{standard input}:2506: Error: operation combines symbols in different segments
{standard input}:2515: Error: operation combines symbols in different segments
{standard input}:2516: Error: operation combines symbols in different segments
{standard input}:2519: Error: operation combines symbols in different segments
{standard input}:2520: Error: operation combines symbols in different segments
{standard input}:2529: Error: operation combines symbols in different segments
{standard input}:2530: Error: operation combines symbols in different segments
{standard input}:2533: Error: operation combines symbols in different segments
{standard input}:2534: Error: operation combines symbols in different segments
{standard input}:2539: Error: operation combines symbols in different segments
{standard input}:2540: Error: operation combines symbols in different segments
{standard input}:2549: Error: operation combines symbols in different segments
{standard input}:2550: Error: operation combines symbols in different segments
make[3]: *** [drivers/block/systemace.o] Error 1
make[2]: *** [drivers/block] Error 2
make[1]: *** [drivers] Error 2
make: *** [__build_one_by_one] Error 2
It looks like the cause of this error message is the "#ident" directive.
Cc: Michal Simek <michal.simek@xilinx.com>
KBuild abuses the asm statement to write to a file and
clang chokes about these invalid asm statements. Hack it
even more by fooling this is actual valid asm code.
cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
cc: Tom Rini <trini@ti.com>
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
This patch adds the TWR_LCD_RGB card/HDMI options and the common
configuration for DCU on LS1021ATWR board.
Signed-off-by: Alison Wang <alison.wang@freescale.com>
This patch is to add DCU driver support. DCU also named
2D-ACE(Two Dimensional Animation and Compositing Engine)
is a system master that fetches graphics stored in internal
or external memory and displays them on a TFT LCD panel.
Remove the DMCTRL Tx snooping bits (TDSEN and TBDSEN) as a
workaround for LS1. It has been observed that currently
the Tx stops functioning after a fair amount of Tx traffic
with these settings on. These bits are sticky and once set
they cannot be reset from Linux, for instance.
Signed-off-by: Claudiu Manoil <claudiu.manoil@freescale.com>
LS102xA is an ARMv7 implementation. This patch is to add
basic support for LS1021ATWR board.
One DDR controller
DUART1 is used as the console
For the detail board information, please refer to README.
Signed-off-by: Chen Lu <chen.lu@freescale.com>
Signed-off-by: Yuan Yao <yao.yuan@freescale.com>
basic support for LS1021AQDS board.
One DDR controller
Signed-off-by: Jason Jin <jason.jin@freescale.com>
Signed-off-by: York Sun <yorksun@freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
JEDEC spec allows DRAM vendors to use prime DQ for write leveling. This
is not an issue unless some DQ pins are not connected. If a platform uses
regular DIMMs but with reduced DDR ECC pins, the prime DQ may end up on
those floating pins for the second rank. The workaround is to use a known
good chip select for this purpose.
For LS102xA, the processor is in little-endian mode, while esdhc IP is
in big-endian mode. CONFIG_SYS_FSL_ESDHC_LE and CONFIG_SYS_FSL_ESDHC_BE
are added. So accessing ESDHC registers can be determined by ESDHC IP's
endian mode.
This patch is to add etsec support for LS102xA. First, Little-endian
descriptor mode should be enabled. So RxBDs and TxBDs are interpreted
with little-endian byte ordering. Second, TSEC_SIZE and TSEC_MDIO_OFFSET
are different from PowerPC, redefine them for LS1021xA.
fsl_enet.h defines the mapping of the usual MII management
registers, which are included in the MDIO register block
common to Freescale ethernet controllers. So it shouldn't
depend on the CPU architecture but it should be actually
part of the arch independent fsl_mdio.h.
To remove the arch dependency, merge the content of
asm/fsl_enet.h into fsl_mdio.h.
Some files (like fm_eth.h) were simply including fsl_enet.h
only for phy.h. These were updated to include phy.h instead.
Enable drivers for FIMD, DP and parade bridge chip.
Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com>
The initialization table comes from the "Illustration of I2C command
for initialing PS8625" document supplied by Parade.
Signed-off-by: Vadim Bendebury <vbendeb@chromium.org>
On Exynos5420 and newer versions, the FIMD sysmmus are in
"on state" by default.
We have to disable them in order to make FIMD DMA work.
This patch adds the required framework to exynos_fimd driver,
and disables FIMD sysmmu on Exynos5420.
Previously, we used to statically assign values for vl_col, vl_row and
vl_bpix using #defines like LCD_XRES, LCD_YRES and LCD_COLOR16.
Introducing the function exynos_lcd_early_init() would take care of this
assignment on the fly by parsing FIMD DT properties, thereby allowing us
to remove LCD_XRES and LCD_YRES from the main config file.
Patch is the result of:
sed -i -e 's/FTDFILE/FDTFILE/g' board/sunxi/Kconfig configs/* include/configs/sunxi-common.h
sed -i -e 's/ftdfile/fdtfile/g' board/sunxi/Kconfig
Reported-by: Vagrant Cascadian <vagrant@debian.org>
Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
Acked-by: Hans de Goede <hdegoede@redhat.com>
[ ijc -- s/Spotted-by/Reported-by/ and resolve conflict vs "remove
redundant "SPL" from CONFIG_SYS_EXTRA_OPTIONS" ]
This config is valid for two devices:
- Odroid X2,
- Odroid U3.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Cc: Tom Rini <trini@ti.com>
This change adds declaration of functions:
- set_board_type() - called at board_early_init_f()
- get_board_type() - called at checkboard()
For supporting multiple board types in a one config - it is welcome
to display the current board model. This is what get_board_type()
should return.
On an Odroid U3 board, the SOC is unable to reset the eMMC card
in the DWMMC mode by the cpu software reset. Manual reset of the card
by switching proper gpio pin - fixes this issue.
Such solution needs to add a call to pre reset function.
This is done by the reset_misc() function, which is called before reset_cpu().
The function reset_misc() is a weak function.
Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Changes v4:
- arch/arm/reset: fix weak function attribute to proper style
This change introduces new common function:
- set_dfu_alt_info() - put dfu system and bootloader setting
into $dfu_alt_info.
functions declaration:
- char *get_dfu_alt_system(void)
- char *get_dfu_alt_boot(void)
- void set_dfu_alt_info(void)
and new config:
- CONFIG_SET_DFU_ALT_INFO
This function can be used for auto setting dfu configuration on boot.
Such feature is useful for multi board support by one u-boot binary.
Each board should define two functions:
- get_dfu_alt_system()
- get_dfu_alt_boot()
To reduce code duplication update am335x_igep0033.h to use ti_am335x_common.h
and convert to generic board.
Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
This patch adds boot script support to omap3 beagle board.
Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr>
This commit provides distinction between DFU device detach and reset.
The -R behavior is preserved with proper handling of the dfu-util's -e
switch, which detach the DFU device.
By running dfu-util -e; one can force device to finish the execution of
dfu command on target and execute some other scripted commands.
Moreover, some naming has been changed - the dfu_reset() method now is known
as dfu_detach(). New name better reflects the purpose of the code.
It was also necessary to increase the number of usb_gadget_handle_interrupts()
calls since we also must wait for detection of the USB reset event.
Example usage:
1. -e (detach) switch
dfu-util -a0 -D file1.bin;dfu-util -a3 -D uImage;dfu-util -e
access to u-boot prompt.
2. -R (reset) switch
dfu-util -a0 -D file1.bin;dfu-util -R -a3 -D uImage
target board reset
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
The GPIO list is very long in many cases and most of them are not used.
By default, show only the GPIOs that are in use, and provide a flag to show
all of them. This makes the 'gpio status' command much more pleasant.
In order to do this, driver model now exposes a method for obtaining the
'function' of a GPIO, which describes whether it is an input or output, for
example. Implementation of this method is optional.
Becuase the board select menu in arch/arm/Kconfig is too big,
move the Nomadik board select menu to nomadik/Kconfig.
Move also common settings (CONFIG_SYS_CPU="arm926ejs" and
CONFIG_SYS_SOC="nomadik").
move the Orion5x board select menu to orion5x/Kconfig.
CONFIG_SYS_SOC="orion5x").
move the OMAP5 board select menu to omap5/Kconfig.
Move also common settings (CONFIG_SYS_CPU="armv7" and
CONFIG_SYS_SOC="omap5").
Reviewed-by: Tom Rini <trini@ti.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
move the OMAP4 board select menu to omap4/Kconfig.
CONFIG_SYS_SOC="omap4").
move the OMAP3 board select menu to omap3/Kconfig.
CONFIG_SYS_SOC="omap3
